Nefunkcna WiFi USB karta ieee802.11N 300Mb v PC [vyřešeno]
michaelf1
Re: Nefunkcna wifi usb karta v pc
#31 Příspěvek od michaelf1 »
Dakujem, ja to prezijem. Uz nebudem to komentovat, nebol by som otvaral toto vlakno ale na fore tato karta nebola.
Tu mas tie chyby su na strane 2: Pri preinstalovani balicka vypise:
(Číta sa databáza ... momentálne je nainštalovaných 163505 súborov alebo adresárov.
Preparing to unpack .../dkms_rtl8192eu_4.3.1.1.11320.20140505-2_all.deb ...
Removing all DKMS Modules
Done.
Unpacking rtl8192eu-kernel-source (4.3.1.1.11320.20140505) over (4.3.1.1.11320.20140505) ...
Nastavuje sa balík rtl8192eu-kernel-source (4.3.1.1.11320.20140505) ...
Loading new rtl8192eu-4.3.1.1.11320.20140505 DKMS files...
Building only for 4.0.2-040002-generic
Building for architecture i686
Building initial module for 4.0.2-040002-generic
Error! Bad return status for module build on kernel: 4.0.2-040002-generic (i686)
Consult /var/lib/dkms/rtl8192eu/4.3.1.1.11320.20140505/build/make.log for more information.
update-initramfs: deferring update (trigger activated)
Processing triggers for initramfs-tools (0.103ubuntu4.4) ...
update-initramfs: Generating /boot/initrd.img-4.0.2-040002-generic
W: Possible missing firmware /lib/firmware/rtl_nic/rtl8107e-2.fw for module r8169
W: Possible missing firmware /lib/firmware/rtl_nic/rtl8107e-1.fw for module r8169
W: Possible missing firmware /lib/firmware/rtl_nic/rtl8168h-2.fw for module r8169
W: Possible missing firmware /lib/firmware/rtl_nic/rtl8168h-1.fw for module r8169
Warning: No support for locale: sk_SK.utf8
^Cdpkg: error processing package initramfs-tools (--install):
podproces nainštalovaný skript post-installation bol prerušený
Vyskytli sa chyby počas spracovania:
Strana 3 : DKMS make.log for rtl8192eu-4.3.1.1.11320.20140505 for kernel 4.4.0-45-generic (i686)
Pi okt 21 15:51:42 CEST 2016
make ARCH=i386 CROSS_COMPILE= -C /lib/modules/4.4.0-45-generic/build M=/var/lib/dkms/rtl8192eu/4.3.1.1.11320.20140505/build modules
make[1]: Entering directory `/usr/src/linux-headers-4.4.0-45-generic'
CC [M] /var/lib/dkms/rtl8192eu/4.3.1.1.11320.20140505/build/core/rtw_cmd.o
cc1: error: -Werror=date-time: no option -Wdate-time
make[2]: *** [/var/lib/dkms/rtl8192eu/4.3.1.1.11320.20140505/build/core/rtw_cmd.o] Chyba 1
make[1]: *** [_module_/var/lib/dkms/rtl8192eu/4.3.1.1.11320.20140505/build] Chyba 2
make[1]: Leaving directory `/usr/src/linux-headers-4.4.0-45-generic'
make: *** [modules] Chyba 2
teraz mam nainstalovane jadro 4.4. a hlasi tu istu chybu vid input cervene. (To iste bolo na jadre 3.13./ 3.16/3.19).
Naposledy upravil(a) michaelf1 dne 22 říj 2016, 13:20, celkem upraveno 2 x.
michaelf1
#32 Příspěvek od michaelf1 »
libc-dev-bin a libc6-dev tieto subory boli nainstalovane - manualne
michaelf1
#33 Příspěvek od michaelf1 »
menom píše:Ten dmesg | tail nevypise vzdy vsetko, napriek tomu je velka sanca ze vo vypise dmesg bude
daco o blizsie o tej karte.
Mohol by si zadat prikaz dmesg a kopirovat to na http://www.pastebin.com
a sem dat odkaz, leboje to dlhe.
Alebo ako zvykne juhele2014 radit skusit novsie jadro (kernel).
Tuje cast vypisu z prikazu dmesg :
dmesg
2015 FUJITSU LIMITED
[    1.683403] usb 1-2: New USB device found, idVendor=0bda, idProduct=818b
[    1.683413] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    1.683420] usb 1-2: Product: 802.11n NIC
[    1.683426] usb 1-2: Manufacturer: Realtek
[    1.683431] usb 1-2: SerialNumber: 00e04c000001
[    1.684952] r8169 Gigabit Ethernet driver 2.3LK-NAPI loaded
[    1.685225] r8169 0000:02:07.0 (unnamed net_device) (uninitialized): not PCI Express
[    1.685878] r8169 0000:02:07.0 eth0: RTL8110s at 0xf8418000, 00:01:80:5e:57:58, XID 04000000 IRQ 22
[    1.685887] r8169 0000:02:07.0 eth0: jumbo features [frames: 7152 bytes, tx checksumming: ok]
michaelf1
#34 Příspěvek od michaelf1 »
idem znova od strany jedna,prepac prehliadol som na tvojom prispevku ten samotny prikaz dmesg.Teraz som to dal na ten web.
Ak by si nahodou mal este zaujem tu je link :http://pastebin.com/44qyyFy2 neviem ci je to spravne ak nie tak ma nasmeruj.
Dakujem
#35 Příspěvek od menom »
Mohol si vyskusat postup co napisal redhawk na aplikovanie tych fixov .
michaelf1
#36 Příspěvek od michaelf1 »
porad ako tu prilepim tie scrreny.Vsetko som spravil podla redhawka, ale network manager kartu nezapol
petertomasy
#37 Příspěvek od petertomasy »
Myslím, že problém sa dá vyriešiť s nadhľadom, len to chce isť na to pragmaticky , dodržať určitý postup, zásady ... Ak chceš vyriešime to tu spolu, pomôže to aj iným .
Ja razím spôsob pre mňa najjednoduchší , a to si skompilovať zdrojový kód modulu (ovládač) priamo na tvoje železo. Pretože aj tie ostatné príklady v podstate boli zdrojáky.
Zásada (základ ) je , že musíš mať softvér na kompiláciu a nejaké znalosti, čo to vlastne robíš ... a aj mať aktuálne jadro a systém ( u mňa )
peter@peter:~$ uname -r
4.4.0-45-generic
Nikto múdry z neba nespadol .
Všeobecný postup:
1. stiahnuť si zdrojový kód
2. rozbaliť
3. premiestniť sa do rozbaleného súboru
4. spustiť kompiláciu príkazom "make"
5. premiestniť "modul.ko" na správne miesto, zvyčajne "make install"
to je všetko.
Ale niekedy sa vyskytne error, a to už nastáva menší, ale isto riešiteľný problém, to už potom treba tu vložiť presné znenie chyby, inak ti nikto nepomôže . Väčšinou stačí upraviť jeden až dva súbory v zdrojáku , a pokračuješ ďaľej, tieto chyby sú dobre zdokumentovatelné na sieti, takže no problém.
ja so si teda stiahol tento zdroják a za 30 sek si urobil binárku ovládača... ale aj ja som si musel ešte predtým tiež upraviť kód , lebo som mal errory... Ale iné ako ty.
Potom som na sieti už našiel opraveny zdroják pre jadra 4.3 a vyššie ,takže už žiadny error
cd driver
git clone https://github.com/donahue95/rtl8192eu-linux-driver
cd rtl8192eu-linux-driver
make
peter@peter:~$cd Plocha
Cloning into 'rtl8192eu-linux-driver'...
remote: Counting objects: 377, done.
remote: Total 377 (delta 0), reused 0 (delta 0), pack-reused 377
Receiving objects: 100% (377/377), 1.62 MiB | 344.00 KiB/s, done.
Resolving deltas: 100% (129/129), done.
Checking connectivity... done.
peter@peter:~$ cd rtl8192eu-linux-driver/
peter@peter:~/Plocha/rtl8192eu-linux-driver$ make
make ARCH=x86_64 CROSS_COMPILE= -C /lib/modules/4.4.0-45-generic/build M=/home/peter/Plocha/rtl8192eu-linux-driver modules
make[1]: Entering directory '/usr/src/linux-headers-4.4.0-45-generic'
LD [M] /home/peter/Plocha/rtl8192eu-linux-driver/8192eu.o
Building modules, stage 2.
MODPOST 1 modules
CC /home/peter/Plocha/rtl8192eu-linux-driver/8192eu.mod.o
LD [M] /home/peter/Plocha/rtl8192eu-linux-driver/8192eu.ko
make[1]: Leaving directory '/usr/src/linux-headers-4.4.0-45-generic'
ako vidíš modul 8192eu.ko sa uspešne skompiloval a už ho len premiestniť na správne miesto
sudo make install
tak a teraz ti už internet funguje... ;)
michaelf1
#38 Příspěvek od michaelf1 »
chlape,kde si bol si super :D , mas pravdu internet ide aj na jadre 3.19
Dakujem tebe, ale aj ostatnym.
michaelf1
#39 Příspěvek od michaelf1 »
michaelf1 píše:chlape,kde si bol si super :D , mas pravdi internet ide aj na jadre 3.19
desktop ~ $ ifconfig -a
eth0      Link encap:Ethernet  HWaddr 00:01:80:5e:57:58
          UP BROADCAST MULTICAST  MTU:1500  Metric:1
          RX packets:0 errors:0 dropped:0 overruns:0 frame:0
          TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B)
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          inet6 addr: ::1/128 Scope:Host
          UP LOOPBACK RUNNING  MTU:65536  Metric:1
          RX packets:2726 errors:0 dropped:0 overruns:0 frame:0
          TX packets:2726 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:0
          RX bytes:255529 (255.5 KB)  TX bytes:255529 (255.5 KB)
wlan0     Link encap:Ethernet  HWaddr 68:ca:00:01:28:22
          inet addr:192.168.0.105  Bcast:192.168.0.255  Mask:255.255.255.0
          inet6 addr: fe80::6aca:ff:fe01:2822/64 Scope:Link
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:41874 errors:0 dropped:1003 overruns:0 frame:0
          TX packets:31884 errors:0 dropped:1 overruns:0 carrier:0
          RX bytes:48389935 (48.3 MB)  TX bytes:5044953 (5.0 MB)
