Po instalacii problém [vyřešeno]
Prešiel som z Ubuntu 15.10 na Mint a som veľmi spokojný len mám jeden problém. Prostredie, okná pri presúvaní mi ako keby kockujú na rohoch nejaký tearing alebo čo. V ubuntu to vyriešila inštalácia grafického ovládača na intel hd 5500 graphic cez intel graphic installer. Tu mi to nejde lebo mi program vyhodí chybu, že graphic chipset bol nenájdený.
Re: Po instalacii problém
A co máš za pc? Postni sem výpis z terminálu inxi -F
mint@mint ~ $ inxi -F
System: Host: mint Kernel: 3.19.0-32-generic x86_64 (64 bit)
Desktop: Cinnamon 2.8.6 Distro: Linux Mint 17.3 Rosa
Machine: System: Hewlett-Packard product: HP ProBook 450 G2 v: A3008DD10B03
Mobo: Hewlett-Packard model: 2248 v: KBC Version 59.19
Bios: Hewlett-Packard v: M73 Ver. 01.00 date: 11/27/2014
CPU: Dual core Intel Core i3-5010U (-HT-MCP-) cache: 3072 KB
clock speeds: max: 2100 MHz 1: 2100 MHz 2: 2099 MHz 3: 2100 MHz
4: 2100 MHz
Graphics: Card: Intel Broadwell-U Integrated Graphics
Resolution: 1366x768@60.0hz
GLX Renderer: Mesa DRI Intel HD Graphics 5500 (Broadwell GT2)
GLX Version: 3.0 Mesa 10.5.9
Audio: Card-1 Intel Wildcat Point-LP High Definition Audio Controller
driver: snd_hda_intel
Card-2 Intel Broadwell-U Audio Controller driver: snd_hda_intel
Network: Card-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
driver: r8169
IF: eth0 state: down mac: d0:bf:9c:f8:e6:1e
Card-2: Intel Wireless 3160 driver: iwlwifi
IF: wlan0 state: up mac: d0:7e:35:bf:ec:da
Drives: HDD Total Size: 507.9GB (1.1% used)
ID-1: /dev/sda model: ST500LT012 size: 500.1GB
ID-2: USB /dev/sdb model: DataTraveler_2.0 size: 7.8GB
Partition: ID-1: / size: 1.9G used: 123M (7%) fs: overlay dev: N/A
ID-2: swap-1 size: 4.18GB used: 0.00GB (0%) fs: swap dev: /dev/sda5
Sensors: System Temperatures: cpu: 40.0C mobo: 0.0C
Fan Speeds (in rpm): cpu: N/A
Info: Processes: 183 Uptime: 4 min Memory: 624.9/3841.4MB
Nechapem ako keby som mal vypnutu vsync.
4: 2100 MHz
driver: r8169
mrkni sem: http://www.linux-mint-czech.cz/instalac ... nux-mintu/ akorát před instalací je potřeba změnit název distra v /etc/lsb-release viz. diskuze pod článkem:
pak:
stáhnout nainstalovat a změnit zpět distro na:
DISTRIB_ID=Ubuntu
DISTRIB_RELEASE=14.10
DISTRIB_CODENAME=utopic
DISTRIB_DESCRIPTION=“Ubuntu Utopic Unicorn (development branch)“
wget --no-check-certificate https://download.01.org/gfx/RPM-GPG-KEY-ilg -O - | \
sudo apt-key add -
wget --no-check-certificate https://download.01.org/gfx/RPM-GPG-KEY-ilg-2 -O - | \
sudo apt-key add -
DISTRIB_ID=LinuxMint
DISTRIB_RELEASE=17.3
DISTRIB_CODENAME=rosa
DISTRIB_DESCRIPTION="Linux Mint 17.3 Rosa"
Instalace ovladačů se nepovedla.
Stále to píše, že distribuce není podporovaná .
Grafiku mám
Intel Corporation Mobile 4 Series Chipset Integrated Graphics Controller
Grafiku mám
A stáhl sis ten instalátor 1.1 ? ten je pro 14.10, ta 1.2 je pro 15.04
https://01.org/linuxgraphics/downloads/ ... inux-1.1.0
Snažil jsem si to hlídal, ale nejsem si jist. Doma prověřím a případně vyzkouším znovu. Díky moc.
Tak jsem celý postup zopakoval a dával si pozor. Bohužel stále to píše, že distribuce není podporována.
Někde (teď si to nemohu vybavit) jsem zahlédl, že podpora je už jen pro verze ubuntu 15.04 a výše.
jj je to možný, furt tam něco mění, takže co bylo včera není dnes Mám intel na netbooku tak to doma zkusím
V Cinnamon mi obrazovka čas od času nesnesitelně problikávala.
Přešel jsem na MATE a tam to nedělá. Proč tomu tak je se mi nepodařilo zjistit.
