1.mam stazeny wine-1.6-rc1.tar.bz2
2.ten jsem rozbalil (adresar: wine-1.6-rc1)
dale nevim jak nainstalovat.
nasel jsem, ze bych mel pouzit v terminalu ./configure ten vypise:
checking build system type... x86_64-unknown-linux-gnu
checking host system type... x86_64-unknown-linux-gnu
checking whether make sets $(MAKE)... yes
checking for gcc... gcc
checking whether the C compiler works... yes
checking for C compiler default output file name... a.out
checking for suffix of executables...
checking whether we are cross compiling... no
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ISO C89... none needed
checking for g++... no
checking for c++... no
checking for gpp... no
checking for aCC... no
checking for CC... no
checking for cxx... no
checking for cc++... no
checking for cl.exe... no
checking for FCC... no
checking for KCC... no
checking for RCC... no
checking for xlC_r... no
checking for xlC... no
checking whether we are using the GNU C++ compiler... no
checking whether g++ accepts -g... no
checking for cpp... cpp
checking whether gcc -m32 works... no
configure: error: Cannot build a 32-bit program, you need to install 32-bit development libraries.
mam Mint 15, Cinnamon 64bit, 3.8.0-19
