Čierna obrazovka po prihlásení [vyřešeno] Vyřešeno
Neck
#1 Příspěvek od Neck »
Zdravím, odhodlal som sa nainštalovať Linux mint Cinnamon na môj stolný počítač. Inštalácia v pohode, len po vypnutí a opätovnom zapnutí PC mi po zadaní hesla pre môj účet ostane len čierna obrazovka a nič sa nedeje. Pomáha jedine tvrdý reštart PC a potom to už ide.
Okrem toho mi pri zadávaní hesla z ničoho nič zhasne numlock kontrolka, hoci je numlock zapnutý.
neviem, či vám toto pomôže:
milo@PC ~ $ inxi -F
System:    Host: PC Kernel: 4.4.0-21-generic x86_64 (64 bit)
           Desktop: Cinnamon 3.0.7  Distro: Linux Mint 18 Sarah
Machine:   System: Gigabyte product: N/A
           Mobo: Gigabyte model: B150M-HD3 DDR3-CF v: x.x
           Bios: American Megatrends v: F1 date: 08/10/2015
CPU:       Dual core Intel Core i3-6100 (-HT-MCP-) cache: 3072 KB
           clock speeds: max: 3700 MHz 1: 799 MHz 2: 799 MHz 3: 799 MHz
           4: 799 MHz
Graphics:  Card: Advanced Micro Devices [AMD/ATI] Oland PRO [Radeon R7 240/340]
           Display Server: X.Org 1.18.3 drivers: ati,radeon (unloaded: fbdev,vesa)
           Resolution: 1920x1080@60.00hz
           GLX Renderer: Gallium 0.4 on AMD OLAND (DRM 2.43.0, LLVM 3.8.0)
           GLX Version: 3.0 Mesa 11.2.0
Audio:     Card-1 Intel Sunrise Point-H HD Audio driver: snd_hda_intel
           Card-2 Advanced Micro Devices [AMD/ATI] Cape Verde/Pitcairn HDMI Audio [Radeon HD 7700/7800 Series]
           Sound: Advanced Linux Sound Architecture v: k4.4.0-21-generic
Network:   Card: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
           driver: r8169
           IF: enp2s0 state: up speed: 100 Mbps duplex: full
           mac: 40:8d:5c:4f:c8:23
Drives:    HDD Total Size: 760.2GB (1.9% used)
           ID-1: /dev/sda model: KINGSTON_SHFS37A size: 120.0GB
           ID-2: /dev/sdb model: WDC_WD6400BEVT size: 640.1GB
Partition: ID-1: / size: 102G used: 6.1G (7%) fs: ext4 dev: /dev/dm-0
           ID-2: /boot size: 472M used: 59M (14%) fs: ext2 dev: /dev/sda1
           ID-3: swap-1 size: 8.54GB used: 0.00GB (0%) fs: swap dev: /dev/dm-1
Sensors:   System Temperatures: cpu: 29.8C mobo: 27.8C gpu: 34.0
           Fan Speeds (in rpm): cpu: N/A
Info:      Processes: 186 Uptime: 31 min Memory: 1214.6/7936.7MB
Allconius
Re: 4ierna obrazovka po prihlásení
#2 Příspěvek od Allconius »
Ahoj, to je divné, že to po tom restartu jede, zatím jsem se setkal jen s případy, že to buď jelo nebo nejelo. Když spustíš správce ovladačů, co ti to nabízí za možnosti ? S tím numlockem zkus nainstalovat numlockx:
sudo apt-get install numlockx
a pak dej Přihlašovací okno - Možnosti - Zapnout numlock, mám sice MATE, ale v Cinnamonu by to mělo jít podobně.
Neck
#3 Příspěvek od Neck »
Numlockx som nainštaloval a stále to blbne, svieti si ako sa mu chce. Ten správca ovládačov mi vypísal: Neznáme, toto zariadenie nefunguje. pod tým je uvedené: Intel-microcode, číslo verzie a pýta sa ma to, či to chcem nainštalovať, alebo vôbec nepoužívať. Čital som dnes, že GIgabyte má s týmto nejaký problém a je k tomu vydaná nová verzia biosu. Idem spraviť flash a uvidím, či problém zmizne. Ale vďaka za radu. Osobne si myslím, že aj ten numlock bude mať na svedomí bios.
#4 Příspěvek od juhele2014 »
:arrow: Máš na monitoru nastavené rozměry 1920x1080 natvrdo, nebo máš zaplou automatiku? Jinak - desky Gigabyte jsou jedny z nejlepších, ale grafárna ATIna mě do baráku nesmí ... :D
#5 Příspěvek od juhele2014 »
:o
Kde si koupil ten bord Gigabyte? V Alze doufám nee ... :?
Neck
#6 Příspěvek od Neck »
Problém vyriešený. Flash biosu na najnovšiu verziu napravil všetko...
#7 Příspěvek od juhele2014 »
:arrow: To ten Gigabyte šel pěkně do kytek, když rok starej bios je nevhodnej ... :(
