cairo dock
cairo dock
Zdravim,
cairo dock verze 3.3.2 je fajn. Ale po vypnuti a znovuzapnuti pocitace se nezobrazi, pres to ze je nastaven jako program po spusteni.
Diky za radu.
Diky za radu.
Lenovo T520
7.7GB RAM
7.7GB RAM
Re: cairo dock
Ahoj, a jaký příkaz máš nastavený v programech po spuštění? jen "cairo-dock" nebo i nějaký parametr? A když otevřeš terminál a zadáš "cairo-dock" co se vypíše? Mám také cairo-dock ale jen ve virtualu LM17MATE RC a spouští se mi OK. Ještě záleží zda se ti to pouští s podporou openGL záleží pak na ovladači GK zda to podporuje
Re: cairo dock
~ $ cairo-dock
warning : (/build/buildd/cairo-dock-3.3.2/src/implementations/cairo-dock-glx.c:_initialize_opengl_backend:179)
couldn't find an appropriate visual, trying to get one without Stencil buffer
(it may cause some little deterioration in the rendering) ...
Cairo-Dock version : 3.3.2
Compiled date : Jan 21 2014 23:39:59
Built with GTK : 3.8
Running with OpenGL: 1
warning : (/build/buildd/cairo-dock-3.3.2/src/implementations/cairo-dock-glx.c:_is_blacklisted:54)
This card is blacklisted due to a bug with your video drivers: Intel 4000 HD Ivybridge Mobile.
Please have a look there: https://bugs.freedesktop.org/show_bug.cgi?id=55036
warning : (/build/buildd/cairo-dock-3.3.2/src/implementations/cairo-dock-glx.c:_post_initialize_opengl_backend:374)
The OpenGL backend will be deactivated. Note that you can force this OpenGL backend by launching the dock with this command: 'cairo-dock -o'
OpenGL Version: 3.0 Mesa 9.2.1
OpenGL Vendor: Intel Open Source Technology Center
OpenGL Renderer: Mesa DRI Intel(R) Ivybridge Mobile
Launcher-API-Daemon: registered as Unity: <dbus.service.BusName com.canonical.Unity on <dbus._dbus.SessionBus (session) at 0x1140290> at 0x11266d0>
connect...
-> connected to cairo-dock
Launcher-API-Daemon: Update application://thunderbird.desktop with dbus.Dictionary({dbus.String(u'count'): dbus.Int64(4L, variant_level=1), dbus.String(u'urgent'): dbus.Boolean(False, variant_level=1), dbus.String(u'progress-visible'): dbus.Boolean(False, variant_level=1), dbus.String(u'count-visible'): dbus.Boolean(True, variant_level=1), dbus.String(u'progress'): dbus.Double(0.0, variant_level=1)}, signature=dbus.Signature('sv'))
Launcher-API-Daemon: set_count (4)
Launcher-API-Daemon: set_progress (0.00)
Launcher-API-Daemon: set_urgent (0)
Launcher-API-Daemon: set_count_visible (1)
Traceback (most recent call last):
File "./Twitter", line 34, in <module>
from twitter import Twitter
File "/home/krab/.config/cairo-dock/third-party/Twitter/twitter.py", line 18, in <module>
from oauth import oauth
ImportError: No module named oauth
Launcher-API-Daemon: set_progress_visible (0)
('new owner:', dbus.UTF8String(':1.71'))
Launcher-API-Daemon: launcher bus name changed: :1.58
connect...
Lenovo T520
7.7GB RAM
7.7GB RAM
Re: cairo dock
Víš, jak moc tomu rozumím? ... Vůbec... jen chápu, že moje grafická karta není podporovaná. Ale jak udělat, aby byla? :/ Lze ji nějak vyřadit z black listu? Vždyť to stejně funguje, když to zapnu manuálně.
Lenovo T520
7.7GB RAM
7.7GB RAM
Re: cairo dock
ovladač nepodporuje to opengl, zkus to cairo zavřít, pak pustit terminál a zadat "cairo-dock -A" měla by se objevit hláška zda chceš zapnout opengl tak dej ne, případně uprav ten příkaz v programech po spuštění na "cairo-dock -c"
Re: cairo dock
Díky moc, ale nepomohlo. Při spuštění z terminálu to teď napsalo toto:
~ $ cairo-dock
Running with OpenGL: 0
Launcher-API-Daemon: registered as Unity: <dbus.service.BusName com.canonical.Unity on <dbus._dbus.SessionBus (session) at 0x205e1d0> at 0x20446d0>
connect...
Launcher-API-Daemon: Update application://thunderbird.desktop with dbus.Dictionary({dbus.String(u'count'): dbus.Int64(0L, variant_level=1), dbus.String(u'urgent'): dbus.Boolean(False, variant_level=1), dbus.String(u'progress-visible'): dbus.Boolean(False, variant_level=1), dbus.String(u'count-visible'): dbus.Boolean(False, variant_level=1), dbus.String(u'progress'): dbus.Double(0.0, variant_level=1)}, signature=dbus.Signature('sv'))
Launcher-API-Daemon: set_count (0)
Launcher-API-Daemon: set_count_visible (0)
('new owner:', dbus.UTF8String(':1.69'))
Launcher-API-Daemon: launcher bus name changed: :1.35
~ $ cairo-dock
connect...
Lenovo T520
7.7GB RAM
7.7GB RAM
Re: cairo dock
A když to spustíš s tím parametrem "cairo-dock -c" tak to vypíše co?
Re: cairo dock
~ $ cairo-dock -c
Launcher-API-Daemon: registered as Unity: <dbus.service.BusName com.canonical.Unity on <dbus._dbus.SessionBus (session) at 0x23e21d0> at 0x23c86d0>
connect...
('new owner:', dbus.UTF8String(':1.75'))
connect...
Lenovo T520
7.7GB RAM
7.7GB RAM
Re: cairo dock
ale mám to nastavené jako spouštěcí příkaz v programech po spuštění jako cairo-dock -c a stejně to nenaběhne samo. Tak nevím.
Lenovo T520
7.7GB RAM
7.7GB RAM
Re: cairo dock
tak ještě zkus upgrade jádra http://www.linux-mint-czech.cz/jak-nain ... nux-mintu/ jestli se něco změní
