Chtel jsem povisit stavajici verzi Calibre na verzi ktera byla uvedena v clanku http://www.linux-mint-czech.cz/. Bohuzel to dopadlo tak ze po poviseni my uz nejde prevadet knizky z pdf do mobi.
Tady je vypis:
calibre, version 0.9.6 (linux2, isfrozen: False)
Chyba převodu: Selhalo: Convert book 1 of 1 (Hvězdné moře)
Resolved conversion options
calibre version: 0.9.6
{'asciiize': False,
'author_sort': None,
'authors': None,
'base_font_size': 16.0,
'book_producer': None,
'change_justification': u'original',
'chapter': u"//*[((name()='h1' or name()='h2') and re:test(., '\\s*((chapter|book|section|part)\\s+)|((prolog|prologue|epilogue)(\\s+|$))', 'i')) or @class = 'chapter']",
'chapter_mark': u'pagebreak',
'comments': None,
'cover': u'/tmp/calibre_0.9.6_tmp_gLOvnZ/s4khKd.jpeg',
'debug_pipeline': None,
'dehyphenate': True,
'delete_blank_paragraphs': True,
'disable_font_rescaling': False,
'dont_compress': False,
'duplicate_links_in_toc': False,
'embed_font_family': None,
'enable_heuristics': False,
'extra_css': None,
'extract_to': None,
'filter_css': u'',
'fix_indents': True,
'font_size_mapping': u'12.0, 12.0, 14.0, 16.0, 18.0, 20.0, 22.0, 24.0',
'format_scene_breaks': True,
'html_unwrap_factor': 0.4,
'input_encoding': None,
'input_profile': <calibre.customize.profiles.InputProfile object at 0x8f76f6c>,
'insert_blank_line': False,
'insert_blank_line_size': 0.5,
'insert_metadata': False,
'isbn': None,
'italicize_common_cases': True,
'keep_ligatures': False,
'language': None,
'level1_toc': None,
'level2_toc': None,
'level3_toc': None,
'line_height': 0.0,
'linearize_tables': False,
'margin_bottom': 1.0,
'margin_left': 1.0,
'margin_right': 1.0,
'margin_top': 1.0,
'markup_chapter_headings': True,
'max_toc_links': 50,
'minimum_line_height': 120.0,
'mobi_file_type': u'both',
'mobi_ignore_margins': False,
'mobi_keep_original_images': False,
'mobi_toc_at_start': False,
'new_pdf_engine': False,
'no_chapters_in_toc': False,
'no_images': False,
'no_inline_navbars': True,
'no_inline_toc': False,
'output_profile': <calibre.customize.profiles.KindleOutput object at 0x8f7e94c>,
'page_breaks_before': u"//*[name()='h1' or name()='h2']",
'personal_doc': u'[PDOC]',
'prefer_author_sort': False,
'prefer_metadata_cover': False,
'pretty_print': False,
'pubdate': None,
'publisher': None,
'rating': None,
'read_metadata_from_opf': u'/tmp/calibre_0.9.6_tmp_gLOvnZ/qtzkSG.opf',
'remove_fake_margins': True,
'remove_first_image': True,
'remove_paragraph_spacing': True,
'remove_paragraph_spacing_indent_size': 1.5,
'renumber_headings': True,
'replace_scene_breaks': u'',
'search_replace': '[]',
'series': None,
'series_index': None,
'share_not_sync': False,
'smarten_punctuation': False,
'sr1_replace': None,
'sr1_search': None,
'sr2_replace': None,
'sr2_search': None,
'sr3_replace': None,
'sr3_search': None,
'start_reading_at': None,
'subset_embedded_fonts': False,
'tags': None,
'timestamp': None,
'title': None,
'title_sort': None,
'toc_filter': None,
'toc_threshold': 6,
'toc_title': None,
'unsmarten_punctuation': False,
'unwrap_factor': 0.45,
'unwrap_lines': True,
'use_auto_toc': False,
'verbose': 2}
InputFormatPlugin: PDF Input running
on /tmp/calibre_0.9.6_tmp_gLOvnZ/4OwL56.pdf
Converting file to html...
Retrieving document metadata...
Generating manifest...
Rendering manifest...
Parsing all content...
Parsing index.html ...
Initial parse failed, using more forgiving parsers
Parsing index.html as HTML
Generating default TOC from spine...
Merging user specified metadata...
Detecting structure...
Auto generated TOC with 0 entries.
Traceback (most recent call last):
File "/usr/bin/calibre-parallel", line 20, in <module>
sys.exit(main())
File "/usr/lib/calibre/calibre/utils/ipc/worker.py", line 186, in main
result = func(*args, **kwargs)
File "/usr/lib/calibre/calibre/gui2/convert/gui_conversion.py", line 31, in gui_convert_override
override_input_metadata=True)
File "/usr/lib/calibre/calibre/gui2/convert/gui_conversion.py", line 25, in gui_convert
plumber.run()
File "/usr/lib/calibre/calibre/ebooks/conversion/plumber.py", line 1060, in run
from calibre.ebooks.oeb.transforms.flatcss import CSSFlattener
File "/usr/lib/calibre/calibre/ebooks/oeb/transforms/flatcss.py", line 20, in <module>
from calibre.ebooks.oeb.stylizer import Stylizer
File "/usr/lib/calibre/calibre/ebooks/oeb/stylizer.py", line 23, in <module>
from cssselect import HTMLTranslator
ImportError: No module named cssselect
