Rrdtool graf
Rrdtool graf
Dobry den,
chcem sa opýtať akoby som vykreslil graf pomocou Rrdtool ak mám už namerané hodnoty zo senzora z mobilneho telefonu v txt. Ďakujem za pomoc.
Re: Rrdtool graf
To nebude těžké - je ten texťák k dispozici?
Re: Rrdtool graf
jasné je...len ten textak sa mi tu neda uploudnuť tak ho tu skopírujem len a poprosil by som aj vysvetlenie ak sa to dá urobiť
2017/10/17 23:26:34-magn:3.25,4.75,-28.0,|
2017/10/17 23:26:34-magn:5.75,8.75,-52.25,|
2017/10/17 23:26:34-magn:7.0,9.75,-57.5,|
2017/10/17 23:26:34-magn:6.75,9.25,-58.0,|
2017/10/17 23:26:35-magn:6.25,9.75,-58.0,|
2017/10/17 23:26:35-magn:7.25,9.75,-58.5,|
2017/10/17 23:26:35-magn:6.75,9.75,-58.75,|
2017/10/17 23:26:35-magn:6.25,9.25,-58.75,|
2017/10/17 23:26:35-magn:6.5,10.25,-58.25,|
2017/10/17 23:26:36-magn:6.75,10.5,-58.25,|
2017/10/17 23:26:36-magn:6.0,10.0,-58.0,|
2017/10/17 23:26:36-magn:6.0,10.0,-57.5,|
2017/10/17 23:26:37-magn:5.25,10.25,-58.25,|
2017/10/17 23:26:37-magn:6.5,9.5,-58.5,|
2017/10/17 23:26:37-magn:6.75,10.0,-58.0,|
2017/10/17 23:26:37-magn:7.0,10.25,-58.5,|
2017/10/17 23:26:38-magn:6.5,10.25,-58.5,|
2017/10/17 23:26:39-magn:6.5,10.25,-58.5,|
2017/10/17 23:26:40-magn:6.5,10.25,-58.5,|
2017/10/17 23:26:40-magn:5.75,11.0,-58.5,|
2017/10/17 23:26:40-magn:5.75,9.75,-57.75,|
2017/10/17 23:26:41-magn:6.0,10.0,-58.0,|
2017/10/17 23:26:41-magn:6.75,10.75,-58.0,|
2017/10/17 23:26:41-magn:6.0,11.25,-58.25,|
2017/10/17 23:26:41-magn:6.25,11.0,-58.5,|
2017/10/17 23:26:41-magn:6.5,10.0,-58.0,|
2017/10/17 23:26:42-magn:6.25,10.25,-58.25,|
2017/10/17 23:26:42-magn:6.0,10.25,-58.25,|
2017/10/17 23:26:42-magn:6.5,10.25,-58.25,|
2017/10/17 23:26:42-magn:6.25,10.5,-58.0,|
2017/10/17 23:26:43-magn:6.25,10.5,-58.0,|
2017/10/17 23:26:44-magn:6.25,10.5,-58.0,|
2017/10/17 23:26:44-magn:7.0,10.25,-57.25,|
2017/10/17 23:26:44-magn:6.5,10.5,-57.0,|
2017/10/17 23:26:44-magn:6.75,9.5,-57.0,|
2017/10/17 23:26:45-magn:5.75,10.25,-58.0,|
2017/10/17 23:26:45-magn:6.25,10.5,-58.0,|
2017/10/17 23:26:45-magn:5.75,10.5,-58.0,|
2017/10/17 23:26:45-magn:6.25,10.5,-58.5,|
2017/10/17 23:26:46-magn:6.5,10.5,-58.25,|
2017/10/17 23:26:47-magn:6.5,10.5,-58.25,|
2017/10/17 23:26:47-magn:7.25,10.25,-58.5,|
2017/10/17 23:26:47-magn:6.25,9.75,-59.0,|
2017/10/17 23:26:48-magn:6.5,10.25,-58.5,|
2017/10/17 23:26:48-magn:6.25,10.25,-57.5,|
2017/10/17 23:26:48-magn:6.25,10.25,-57.75,|
2017/10/17 23:26:48-magn:7.25,10.25,-57.5,|
2017/10/17 23:26:49-magn:7.25,10.25,-57.0,|
2017/10/17 23:26:49-magn:6.5,11.25,-57.0,|
2017/10/17 23:26:49-magn:6.25,11.5,-57.75,|
2017/10/17 23:26:49-magn:6.25,11.25,-58.0,|
2017/10/17 23:26:49-magn:6.25,11.0,-57.75,|
2017/10/17 23:26:50-magn:5.75,11.0,-58.0,|
2017/10/17 23:26:50-magn:6.0,12.0,-57.75,|
2017/10/17 23:26:50-magn:6.25,11.5,-58.5,|
2017/10/17 23:26:50-magn:6.5,11.75,-58.0,|
2017/10/17 23:26:50-magn:5.25,11.5,-57.75,|
2017/10/17 23:26:51-magn:5.75,12.0,-58.5,|
2017/10/17 23:26:51-magn:6.5,11.75,-58.25,|
2017/10/17 23:26:51-magn:5.75,11.0,-57.75,|
2017/10/17 23:26:51-magn:6.25,11.5,-58.0,|
2017/10/17 23:26:52-magn:6.25,11.5,-58.0,|
2017/10/17 23:26:52-magn:5.75,11.5,-57.5,|
2017/10/17 23:26:52-magn:6.25,11.5,-57.75,|
2017/10/17 23:26:52-magn:5.75,11.5,-58.5,|
2017/10/17 23:26:52-magn:5.5,11.5,-58.75,|
2017/10/17 23:26:53-magn:5.75,11.5,-58.0,|
2017/10/17 23:26:53-magn:6.25,11.0,-58.0,|
2017/10/17 23:26:53-magn:6.25,11.25,-58.0,|
2017/10/17 23:26:54-magn:6.25,11.25,-58.0,|
2017/10/17 23:26:54-magn:6.25,12.25,-58.25,|
malo by byť 100 hodnôt z mgnetického senzora mobilu
Re: Rrdtool graf
RRDtool jsem instaloval, ale jede to přes terminál. Asi tomu musíš předhodit tu tvojí databázi, ovšem se správnou koncovkou. Mě to napsalo (po zadání rrdtoool info) :
Stahnul sem to odsud https://pkgs.org/download/rrdtool-tcl
knobloch@knobloch-pc ~ $ rrdtool info
RRDtool 1.4.7 Copyright 1997-2012 by Tobias Oetiker <tobi@oetiker.ch>
Compiled Jan 2 2014 19:40:30
Usage: rrdtool [options] command command_options
* info - returns the configuration and status of the RRD
rrdtool info filename.rrd
Re: Rrdtool graf
Rrdtool som aj ja nainštaloval ale neviem ako vykreslím z toho txt ten graf
Re: Rrdtool graf
s v tom Cacti to pôjde nejak vykresliť...viem že to v txt nepôjde...len neviem ako to txt dám to toho rrd exportovať...ale skusim pozrieť to Cacti či tam nemá nejakú taku funckiu bo čo
Re: Rrdtool graf
takže ak by som tieto hodnoty napr. skopíroval do Excelu a v Exceli dal uložiť súbor ako .csv..tak by to v Cacti mohlo ísť...skúsim to večer vyskúšať ked budem doma
Re: Rrdtool graf
tak nainštaloval som si Cacti...ale ked dám Import Templates tak chce po mne xml a nie css...a nikde inde som nenašiel žeby po mne Cacti pýtalo css...to nebude také lahké
