[phpBB Debug] PHP Warning: in file [ROOT]/ext/alfredoramos/seometadata/event/listener.php on line 114: Undefined array key 12828 [phpBB Debug] PHP Warning: in file [ROOT]/ext/alfredoramos/seometadata/event/listener.php on line 114: Trying to access array offset on value of type null Tipy a triky pro Linux-Oprava (pridanie) default. rozlíšenia - Fórum Linux Mint CZ&SK
[ michal: ~ ]$ xrandr
Screen 0: minimum 8 x 8, current 1440 x 900, maximum 16384 x 16384
VGA-0 disconnected (normal left inverted right x axis y axis)
DVI-D-0 connected primary 1440x900+0+0 (normal left inverted right x axis y axis) 510mm x 290mm
1920x1080 60.0 +
1680x1050 60.0
1600x1200 60.0
1440x900 59.9*
1280x1024 75.0 60.0
1280x960 60.0
1280x720 60.0
1024x768 75.0 60.0
1024x576 60.0
800x600 75.0 60.3
640x480 75.0 59.9
HDMI-0 disconnected (normal left inverted right x axis y axis)
takže jedu na DVI. Monitor mám ale v poměru 16:9 (viz. 510mm x 290mm), ovladač mi ale nabízí vesměs rozlišení 16:10. Používám teď to 1140x900. Dá se tam nějak dostat třeba 1440x810 ?
