kamera Vyřešeno
Re: kamera
#11 Příspěvek od Ventero1 »
menom píše: 08 lis 2022, 18:26 Bud neni pripojena, alebo je to hardver, ktory nema podporu v linuxe.
Nieco sa o tom pise aj na oficialnom fore LM:
https://forums.linuxmint.com/viewtopic. ... a#p1803059
I tak by se tam prece melo vypsat ID zarizeni - nebo ne? Minimalne se na urovni portu detekuje, ze k nemu neco aktivniho je pripojene. Pokud ne, tak soudruzi vyvojari v novejsich verzich zase vyrobili neomluvitelnou minelu a nedotah ..
Re: kamera
#12 Příspěvek od menom »
Bob M pise:
bob@bob-HP-ProBook-6550b ~ $ dmesg | grep uvcvideo
[   14.623605] uvcvideo: Found UVC 1.00 device USB2.0 PC CAMERA (18ec:3299)
[   14.624219] uvcvideo: UVC non compliance - GET_DEF(PROBE) not supported. Enabling workaround.
[   14.624539] uvcvideo 2-1.3:1.0: Entity type for entity Processing 2 was not initialized!
[   14.624541] uvcvideo 2-1.3:1.0: Entity type for entity Camera 1 was not initialized!
[   14.625632] uvcvideo: Found UVC 1.00 device USB2.0-Camera (0bda:5801)
[   14.631646] uvcvideo 1-1.5:1.0: Entity type for entity Processing 2 was not initialized!
[   14.631649] uvcvideo 1-1.5:1.0: Entity type for entity Camera 1 was not initialized!
[   14.631650] uvcvideo 1-1.5:1.0: Entity type for entity Extension 4 was not initialized!
[   14.631781] usbcore: registered new interface driver uvcvideo
[  891.945501] uvcvideo: Found UVC 1.00 device iCM10 (060b:8003)
[  891.947688] uvcvideo 2-1.3:1.0: Entity type for entity Processing 2 was not initialized!
[  891.947692] uvcvideo 2-1.3:1.0: Entity type for entity Camera 1 was not initialized!
[  891.947695] uvcvideo 2-1.3:1.0: Entity type for entity Extension 4 was not initialized!
[  893.245501] uvcvideo: Found UVC 1.00 device iCM10 (060b:8003)
[  893.247688] uvcvideo 2-1.3:1.0: Entity type for entity Processing 2 was not initialized!
[  893.247693] uvcvideo 2-1.3:1.0: Entity type for entity Camera 1 was not initialized!
[  893.247696] uvcvideo 2-1.3:1.0: Entity type for entity Extension 4 was not initialized!
[  896.829629] uvcvideo: Found UVC 1.00 device iCM10 (060b:8003)
[  896.831892] uvcvideo 2-1.3:1.0: Entity type for entity Processing 2 was not initialized!
[  896.831897] uvcvideo 2-1.3:1.0: Entity type for entity Camera 1 was not initialized!
[  896.831900] uvcvideo 2-1.3:1.0: Entity type for entity Extension 4 was not initialized!
[ 1322.025002] uvcvideo: Found UVC 1.00 device iCM10 (060b:8003)
[ 1322.027027] uvcvideo 2-1.3:1.0: Entity type for entity Processing 2 was not initialized!
[ 1322.027033] uvcvideo 2-1.3:1.0: Entity type for entity Camera 1 was not initialized!
[ 1322.027037] uvcvideo 2-1.3:1.0: Entity type for entity Extension 4 was not initialized!
[ 1327.656615] uvcvideo: Found UVC 1.00 device iCM10 (060b:8003)
[ 1327.658668] uvcvideo 2-1.3:1.0: Entity type for entity Processing 2 was not initialized!
[ 1327.658674] uvcvideo 2-1.3:1.0: Entity type for entity Camera 1 was not initialized!
[ 1327.658678] uvcvideo 2-1.3:1.0: Entity type for entity Extension 4 was not initialized!
[ 1335.593129] uvcvideo: Found UVC 1.00 device iCM10 (060b:8003)
[ 1335.595517] uvcvideo 2-1.3:1.0: Entity type for entity Processing 2 was not initialized!
[ 1335.595522] uvcvideo 2-1.3:1.0: Entity type for entity Camera 1 was not initialized!
[ 1335.595525] uvcvideo 2-1.3:1.0: Entity type for entity Extension 4 was not initialized!
To bolo asi na LM 18 jadro detekovalo zariadenie, no aj tak kamera nefungovala.
Vypis dmesg su hlasky jadra, to jadro vtedy zariadenie videlo, ine jadro nevidi, tak to je.
Re: kamera
#13 Příspěvek od Ventero1 »
Tohle ale nemá mít na starosti jádro, ale udev a pod. - tedy bude něco špatně v komunikaci jádra a sw řídícím správu usb portů - předpokládám, že to jde za systemd. Na tyhle ProBook 6440b (to je prakticky totéž) jsem instalovával kdysi Xubu 14.04. a ta kamera fachala.
Vyzkoušel bych stáhnout Xubu 14.04.1 a pak Xubu 18.04.1 a pak v Live. Ještě bych zkusil MX - ten je stále byz systemd a má širokou podporu starého HW.
Ještě je tu varianta, že u tohodle ntb není kamera na USB portu, ale na I2C, jako mívaly některé ntb zvukovky - a s tím měl Linux vždy problémy.
Prostě pokud něco připojím na usb, tak by měl příslušný sw detekovat a předat jádru. Jediné, co mě napadá, pokud je to USB, že má interní port kamery svůj netradiční řadič a tedy chybí ovladač - pak už by bylo logické, že kamera není detekována vůbec.
Tady mě pořád štve u Linuxu, že nejsou vyčleněny a katalogizovány samotné moduly všech driverů, které by se pak pomocí nástroje (a ten v podobě DKMS existuje) zakompilovali do jádra dle potřeby.
Re: kamera
#14 Příspěvek od menom »
HP 6550b je znamych pre linux asi 40 variant a u niektorych neni vobec detekovane zariadenie kamera.
Ked jadro nepozna to zariadenie, tak zbytocne hladat chybu v udev ci system demon.
Re: kamera
#15 Příspěvek od Ventero1 »
Tady se nebavime, ze neni rozpoznane zarizeni, ale ze nefunguje basalni detekce, ze se neco pripojilo - tohle podle me neni vec jadra.
peco99
Re: kamera
#16 Příspěvek od peco99 »
Ventero1 píše: 09 lis 2022, 08:04 Tohle ale nemá mít na starosti jádro, ale udev a pod. - tedy bude něco špatně v komunikaci jádra a sw řídícím správu usb portů - předpokládám, že to jde za systemd. Na tyhle ProBook 6440b (to je prakticky totéž) jsem instalovával kdysi Xubu 14.04. a ta kamera fachala.
Ak to dobre chápem tak mám inštalovat Xubuntu ako operačný systém? Priznám sa to mi za to nestojí,zaobídem sa bez kamery.Ďakujem pekne za odbornú odpoveď.
Re: kamera
#17 Příspěvek od Ventero1 »
Ne instalovat, ale zkusit jako live session - mohlo by to napovědět víc. Nebo třeba Mint 17.1 - ten je ještě adekvátní stáří NTB - a také navrhuji jiné prostředí - Xfce. Nelze jednak, i při nízké pravděpodobnosti, takto od stolu vyloučit chybu v Mate verzi a také myslím, že Mate v takto nové verzi na tenhle stroj není svojí náročností zcela adekvátní.
Jinak to je rezolutní odmítnutí - Mint má sice některé přednosti, hlavně pro začátečníky, ale není tak bezkonkurenční a dokonalý aby byl nenahraditelný něčím, kde by mohlo fungovat vše ...
Re: kamera
#18 Příspěvek od Ventero1 »
menom píše: 09 lis 2022, 12:56 HP 6550b je znamych pre linux asi 40 variant a u niektorych neni vobec detekovane zariadenie kamera
Nevím zda to číslo znamená 40 variant, nýbrž jen, že tento stroj se dostal 40 x dostal do záznamů ..
Re: kamera
#19 Příspěvek od menom »
Vyskusat spustit operacny system z usb kluca - flashky je dobry tip, akurat nie stare nepodporovane OS ako Mint 17.1.
Ale nieco novsie co ma podporu a dostava aktualizacie - z hladiska bezpecnosti aj vylepsenia OS.
Dobre je skusit MX Linux v xfce verzii alebo hocijaku z popularnych distribucii a urobit vypisy v terminali po zadani tych 2 prikazov.
Ci nejaky OS tu kameru ukaze.
Na tom obrazku 40 znamena 40 zaznamov s inou zostavou. Staci ze namiesto 1 RAM modulu su 2, alebo iny harddisk ci SSD
a je to brane ako nove HWid.
Re: kamera
#20 Příspěvek od Ventero1 »
Zkusil bych ty stare verze ponejprv, aby byla jistota, ze to vubec muze fungovat. U novych verzi je trochu problem s modulem ovladace grafiky i915 pro starsi cipy - konkretne z roslisenim.
I kdyby to melo jet plne na stare verzi Linuxu, tak je pri normalnim chovani na netu riziko marginalni - nemam rad tohle straseni à-la Microsoft ...
Jj 40 variant - takhle nejak jsem si to predstavoval ..
