LM 19.2 nejde zvuk Audigy 2
Re: LM 19.2 nejde zvuk Audigy 2
#21 Příspěvek od menom »
Ak to preinstalujes na system kde to funguje, tak by si mohol za rovnakych podmienok
urobit este teraz v nefunkcnom ten podrobny vypis:
pacmd list cards
Odlozit jako textak.
Potom po instalaci systemu to iste a porovnat v com su ine
#22 Příspěvek od labeent »
menom píše: 10 srp 2019, 04:20 .
pacmd list cards
Terminal:~$ pacmd list cards
Memory blocks currently allocated: 1, size: 63,9 KiB.
Memory blocks allocated during the whole lifetime: 124275, size: 324,6 MiB.
Memory blocks imported from other processes: 0, size: 0 B.
Memory blocks exported to other processes: 0, size: 0 B.
Total sample cache size: 0 B.
Default sample spec: s16le 2ch 44100Hz
Default channel map: front-left,front-right
Default sink name: alsa_output.pci-0000_05_01.0.iec958-stereo
Default source name: alsa_input.pci-0000_05_01.0.analog-mono
Memory blocks of type POOL: 1 allocated/60967 accumulated.
Memory blocks of type POOL_EXTERNAL: 0 allocated/0 accumulated.
Memory blocks of type APPENDED: 0 allocated/0 accumulated.
Memory blocks of type USER: 0 allocated/0 accumulated.
Memory blocks of type FIXED: 0 allocated/48319 accumulated.
Memory blocks of type IMPORTED: 0 allocated/14989 accumulated.
26 module(s) loaded.
    index: 0
	argument: <>
	used: -1
	load once: yes
	properties:
		module.author = "Lennart Poettering"
		module.description = "Automatically restore the volume/mute state of devices"
		module.version = "11.1"
    index: 1
	argument: <>
	used: -1
	load once: yes
	properties:
		module.description = "Automatically restore the volume/mute/device state of streams"
    index: 2
	argument: <>
	used: -1
	load once: yes
	properties:
		module.description = "Automatically restore profile of cards"
    index: 3
	argument: <>
	used: -1
	load once: yes
	properties:
		module.description = "Augment the property sets of streams with additional static information"
    index: 4
	argument: <>
	used: -1
	load once: no
	properties:
    index: 5
	argument: <>
	used: -1
	load once: yes
	properties:
		module.author = "Michael Terry"
		module.description = "When a sink/source is added, switch to it or conditionally switch to it"
    index: 6
	argument: <>
	used: -1
	load once: yes
	properties:
		module.description = "Detect available audio hardware and load matching drivers"
    index: 7
	argument: <device_id="0" name="pci-0000_01_00.1" card_name="alsa_card.pci-0000_01_00.1" namereg_fail=false tsched=yes fixed_latency_range=no ignore_dB=no deferred_volume=yes use_ucm=yes card_properties="module-udev-detect.discovered=1">
	used: 0
	load once: no
	properties:
		module.description = "ALSA Card"
    index: 8
	argument: <device_id="1" name="pci-0000_05_01.0" card_name="alsa_card.pci-0000_05_01.0" namereg_fail=false tsched=yes fixed_latency_range=no ignore_dB=no deferred_volume=yes use_ucm=yes card_properties="module-udev-detect.discovered=1">
	used: 0
	load once: no
	properties:
    index: 9
	argument: <>
	used: -1
	load once: yes
	properties:
		module.author = "Frédéric Dalleau, Pali Rohár"
		module.description = "Policy module to make using bluetooth devices out-of-the-box easier"
    index: 10
	argument: <>
	used: -1
	load once: yes
	properties:
		module.author = "João Paulo Rechi Vita"
		module.description = "Detect available Bluetooth daemon and load the corresponding discovery module"
    index: 11
	argument: <>
	used: -1
	load once: yes
	properties:
		module.description = "Detect available BlueZ 5 Bluetooth audio devices and load BlueZ 5 Bluetooth audio drivers"
    index: 12
	argument: <>
	used: -1
	load once: no
	properties:
		module.description = "Native protocol (UNIX sockets)"
    index: 13
	argument: <>
	used: -1
	load once: yes
	properties:
		module.description = "GConf Adapter"
    index: 14
	argument: <>
	used: -1
	load once: yes
	properties:
		module.description = "Automatically restore the default sink and source"
    index: 15
	argument: <>
	used: -1
	load once: yes
	properties:
		module.description = "When a sink/source is removed, try to move its streams to the default sink/source"
    index: 16
	argument: <>
	used: -1
	load once: yes
	properties:
		module.author = "Colin Guthrie"
		module.description = "Udržuje nahraný vždy alespoň jeden cíl, i když se jedná o \"null\""
    index: 17
	argument: <>
	used: -1
	load once: yes
	properties:
		module.description = "Automatically set device of streams based on intended roles of devices"
    index: 18
	argument: <>
	used: -1
	load once: yes
	properties:
		module.description = "When a sink/source is idle for too long, suspend it"
    index: 19
	argument: <>
	used: -1
	load once: yes
	properties:
		module.description = "Create a client for each ConsoleKit session of this user"
    index: 20
	argument: <>
	used: -1
	load once: yes
	properties:
		module.description = "Create a client for each login session of this user"
    index: 21
	argument: <>
	used: -1
	load once: yes
	properties:
		module.description = "Position event sounds between L and R depending on the position on screen of the widget triggering them."
    index: 22
	argument: <>
	used: -1
	load once: yes
	properties:
		module.description = "Mute & cork streams with certain roles while others exist"
    index: 23
	argument: <>
	used: -1
	load once: yes
	properties:
		module.description = "Detect when various filters are desirable"
    index: 24
	argument: <>
	used: -1
	load once: yes
	properties:
		module.description = "Load filter sinks automatically when needed"
    index: 25
	argument: <>
	used: -1
	load once: no
	properties:
		module.description = "Command line interface protocol (UNIX sockets)"
2 sink(s) available.
    index: 0
	driver: <module-alsa-card.c>
	flags: HARDWARE DECIBEL_VOLUME LATENCY DYNAMIC_LATENCY
	state: SUSPENDED
	suspend cause: IDLE
	priority: 9030
	volume: front-left: 65536 / 100% / 0,00 dB,   front-right: 65536 / 100% / 0,00 dB
	        balance 0,00
	base volume: 65536 / 100% / 0,00 dB
	volume steps: 65537
	muted: yes
	current latency: 0,00 ms
	max request: 0 KiB
	max rewind: 0 KiB
	monitor source: 0
	             Stereo
	used by: 0
	linked by: 0
	configured latency: 0,00 ms; range is 0,50 .. 371,52 ms
	card: 0 <alsa_card.pci-0000_01_00.1>
	module: 7
	properties:
		alsa.resolution_bits = "16"
		device.api = "alsa"
		device.class = "sound"
		alsa.class = "generic"
		alsa.subclass = "generic-mix"
		alsa.name = "HDMI 0"
		alsa.id = "HDMI 0"
		alsa.subdevice = "0"
		alsa.subdevice_name = "subdevice #0"
		alsa.device = "3"
		alsa.card = "0"
		alsa.card_name = "HDA ATI HDMI"
		alsa.long_card_name = "HDA ATI HDMI at 0xfe8fc000 irq 26"
		alsa.driver_name = "snd_hda_intel"
		device.bus_path = "pci-0000:01:00.1"
		sysfs.path = "/devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card0"
		device.bus = "pci"
		device.vendor.id = "1002"
		device.vendor.name = "Advanced Micro Devices, Inc. [AMD/ATI]"
		device.product.id = "aa58"
		device.product.name = "Juniper HDMI Audio [Radeon HD 5700 Series]"
		device.string = "hdmi:0"
		device.buffering.buffer_size = "65536"
		device.buffering.fragment_size = "32768"
		device.access_mode = "mmap+timer"
		device.profile.name = "hdmi-stereo"
		device.profile.description = "Digital Stereo (HDMI)"
		device.description = "Juniper HDMI Audio [Radeon HD 5700 Series] Digital Stereo (HDMI)"
		alsa.mixer_name = "ATI R6xx HDMI"
		alsa.components = "HDA:1002aa01,00aa0100,00100200"
		module-udev-detect.discovered = "1"
		device.icon_name = "audio-card-pci"
	ports:
		hdmi-output-0: HDMI / DisplayPort (priority 5900, latency offset 0 usec, available: no)
			properties:
				device.icon_name = "video-display"
	active port: <hdmi-output-0>
  * index: 1
	state: SUSPENDED
	suspend cause: IDLE
	priority: 9038
	        balance 0,00
	volume steps: 65537
	muted: no
	max request: 0 KiB
	max rewind: 0 KiB
	monitor source: 1
	sample spec: s16le 2ch 48000Hz
	             Stereo
	used by: 0
	linked by: 0
	configured latency: 0,00 ms; range is 0,50 .. 341,33 ms
	card: 1 <alsa_card.pci-0000_05_01.0>
	module: 8
	properties:
		device.api = "alsa"
		alsa.name = "ADC Capture/Standard PCM Playback"
		alsa.id = "emu10k1"
		alsa.device = "0"
		alsa.card = "1"
		alsa.card_name = "SB Audigy 2 ZS [SB0350]"
		alsa.long_card_name = "SB Audigy 2 ZS [SB0350] (rev.4, serial:0x20021102) at 0xe880, irq 17"
		alsa.driver_name = "snd_emu10k1"
		device.bus_path = "pci-0000:05:01.0"
		sysfs.path = "/devices/pci0000:00/0000:00:1e.0/0000:05:01.0/sound/card1"
		device.bus = "pci"
		device.vendor.id = "1102"
		device.vendor.name = "Creative Labs"
		device.product.id = "0004"
		device.product.name = "EMU10k2/CA0100/CA0102/CA10200 [Sound Blaster Audigy Series] (SB0350 Audigy 2 ZS)"
		device.string = "iec958:1"
		device.buffering.fragment_size = "65536"
		device.profile.name = "iec958-stereo"
		device.profile.description = "Digitální stereo (IEC958)"
		device.description = "EMU10k2/CA0100/CA0102/CA10200 [Sound Blaster Audigy Series] (SB0350 Audigy 2 ZS) Digitální stereo (IEC958)"
		alsa.mixer_name = "SigmaTel STAC9750,51"
		alsa.components = "AC97a:83847650"
	ports:
		iec958-stereo-output: Digitální výstup (S/PDIF) (priority 0, latency offset 0 usec, available: unknown)
			properties:
	active port: <iec958-stereo-output>
3 source(s) available.
    index: 0
	flags: DECIBEL_VOLUME LATENCY DYNAMIC_LATENCY
	state: SUSPENDED
	suspend cause: IDLE
	priority: 1030
	        balance 0,00
	volume steps: 65537
	muted: no
	max rewind: 0 KiB
	             Stereo
	used by: 0
	linked by: 0
	monitor_of: 0
	module: 7
	properties:
		device.description = "Monitor of Juniper HDMI Audio [Radeon HD 5700 Series] Digital Stereo (HDMI)"
		device.class = "monitor"
		alsa.card = "0"
		device.bus = "pci"
		device.string = "0"
    index: 1
	state: SUSPENDED
	suspend cause: IDLE
	priority: 1030
	        balance 0,00
	volume steps: 65537
	muted: no
	max rewind: 0 KiB
	             Stereo
	used by: 0
	linked by: 0
	monitor_of: 1
	module: 8
	properties:
		device.description = "Monitor of EMU10k2/CA0100/CA0102/CA10200 [Sound Blaster Audigy Series] (SB0350 Audigy 2 ZS) Digitální stereo (IEC958)"
		alsa.card = "1"
		device.bus = "pci"
		device.string = "1"
  * index: 2
	flags: HARDWARE HW_VOLUME_CTRL DECIBEL_VOLUME LATENCY DYNAMIC_LATENCY
	state: SUSPENDED
	suspend cause: IDLE
	priority: 9039
	volume: mono: 47185 /  72% / -8,56 dB
	        balance 0,00
	volume steps: 65537
	muted: no
	max rewind: 0 KiB
	sample spec: s16le 1ch 44100Hz
	channel map: mono
	             Mono
	used by: 0
	linked by: 0
	configured latency: 0,00 ms; range is 0,50 .. 743,04 ms
	module: 8
	properties:
		device.api = "alsa"
		alsa.id = "emu10k1"
		alsa.device = "0"
		alsa.card = "1"
		device.bus = "pci"
		device.string = "hw:1"
		device.profile.name = "analog-mono"
		device.profile.description = "Analogové mono"
		device.description = "EMU10k2/CA0100/CA0102/CA10200 [Sound Blaster Audigy Series] (SB0350 Audigy 2 ZS) Analogové mono"
	ports:
		analog-input-mic: Mikrofon (priority 8700, latency offset 0 usec, available: unknown)
			properties:
				device.icon_name = "audio-input-microphone"
	active port: <analog-input-mic>
6 client(s) logged in.
    index: 0
	driver: <module-systemd-login.c>
	owner module: 20
	properties:
		application.name = "Login Session c2"
		systemd-login.session = "c2"
    index: 1
	driver: <protocol-native.c>
	owner module: 12
	properties:
		application.name = "libcanberra"
		native-protocol.peer = "UNIX socket client"
		native-protocol.version = "32"
		application.version = "0.30"
		application.id = "org.freedesktop.libcanberra"
		application.process.id = "1498"
		application.process.user = "labe"
		application.process.host = "labe-Asus-desktop"
		application.process.binary = "csd-sound"
		application.language = "cs_CZ.UTF-8"
		window.x11.display = ":0"
		application.process.machine_id = "f3d85c83fd6e458aba76dbf56f683032"
		application.process.session_id = "c2"
    index: 2
	owner module: 12
	properties:
		application.name = "Cinnamon Volume Control"
		application.id = "org.gnome.VolumeControl"
		application.icon_name = "multimedia-volume-control"
		application.version = "4.2.0"
		application.process.id = "1652"
		application.process.binary = "cinnamon"
    index: 3
	owner module: 12
	properties:
		application.name = "Cinnamon Volume Control Media Keys"
		application.process.id = "1497"
		application.process.binary = "csd-media-keys"
    index: 8
	owner module: 12
	properties:
		application.name = "Pale Moon"
		application.process.id = "20528"
		application.process.binary = "palemoon"
		application.icon_name = "palemoon"
    index: 14
	driver: <cli.c>
	owner module: 25
	properties:
		application.name = "UNIX socket client"
2 card(s) available.
    index: 0
	owner module: 7
	properties:
		alsa.card = "0"
		device.bus = "pci"
		device.string = "0"
		device.description = "Juniper HDMI Audio [Radeon HD 5700 Series]"
	profiles:
		output:hdmi-stereo: Digital Stereo (HDMI) výstup (priority 5400, available: no)
		off: Vypnuto (priority 0, available: unknown)
	active profile: <output:hdmi-stereo>
	sinks:
		alsa_output.pci-0000_01_00.1.hdmi-stereo/#0: Juniper HDMI Audio [Radeon HD 5700 Series] Digital Stereo (HDMI)
	sources:
		alsa_output.pci-0000_01_00.1.hdmi-stereo.monitor/#0: Monitor of Juniper HDMI Audio [Radeon HD 5700 Series] Digital Stereo (HDMI)
	ports:
			properties:
    index: 1
	owner module: 8
	properties:
		alsa.card = "1"
		device.bus = "pci"
		device.string = "1"
		device.description = "EMU10k2/CA0100/CA0102/CA10200 [Sound Blaster Audigy Series] (SB0350 Audigy 2 ZS)"
	profiles:
		input:analog-mono: Analogové mono vstup (priority 2, available: unknown)
		input:analog-stereo: Analogové stereo vstup (priority 60, available: unknown)
		input:iec958-stereo: Digitální stereo (IEC958) vstup (priority 55, available: unknown)
		output:analog-mono: Analogové mono výstup (priority 200, available: unknown)
		output:analog-mono+input:analog-mono: Analogové duplexní mono (priority 202, available: unknown)
		output:analog-mono+input:analog-stereo: Analogové mono výstup + Analogové stereo vstup (priority 260, available: unknown)
		output:analog-mono+input:iec958-stereo: Analogové mono výstup + Digitální stereo (IEC958) vstup (priority 255, available: unknown)
		output:analog-stereo: Analogové stereo výstup (priority 6000, available: unknown)
		output:analog-stereo+input:analog-mono: Analogové stereo výstup + Analogové mono vstup (priority 6002, available: unknown)
		output:analog-surround-21: Analogový Surround 2.1 výstup (priority 800, available: unknown)
		output:analog-surround-21+input:analog-mono: Analogový Surround 2.1 výstup + Analogové mono vstup (priority 802, available: unknown)
		output:analog-surround-40: Analogový Surround 4.0 výstup (priority 700, available: unknown)
		output:analog-surround-40+input:analog-mono: Analogový Surround 4.0 výstup + Analogové mono vstup (priority 702, available: unknown)
		output:analog-surround-41: Analogový Surround 4.1 výstup (priority 800, available: unknown)
		output:analog-surround-41+input:analog-mono: Analogový Surround 4.1 výstup + Analogové mono vstup (priority 802, available: unknown)
		output:analog-surround-50: Analogový Surround 5.0 výstup (priority 700, available: unknown)
		output:analog-surround-50+input:analog-mono: Analogový Surround 5.0 výstup + Analogové mono vstup (priority 702, available: unknown)
		output:analog-surround-51: Analogový Surround 5.1 výstup (priority 800, available: unknown)
		output:analog-surround-51+input:analog-mono: Analogový Surround 5.1 výstup + Analogové mono vstup (priority 802, available: unknown)
		output:analog-surround-71: Analog Surround 7.1 výstup (priority 700, available: unknown)
		output:analog-surround-71+input:analog-mono: Analog Surround 7.1 výstup + Analogové mono vstup (priority 702, available: unknown)
		output:iec958-stereo: Digitální stereo (IEC958) výstup (priority 5500, available: unknown)
		output:iec958-stereo+input:analog-mono: Digitální stereo (IEC958) výstup + Analogové mono vstup (priority 5502, available: unknown)
	active profile: <output:iec958-stereo+input:analog-mono>
	sinks:
		alsa_output.pci-0000_05_01.0.iec958-stereo/#1: EMU10k2/CA0100/CA0102/CA10200 [Sound Blaster Audigy Series] (SB0350 Audigy 2 ZS) Digitální stereo (IEC958)
	sources:
		alsa_output.pci-0000_05_01.0.iec958-stereo.monitor/#1: Monitor of EMU10k2/CA0100/CA0102/CA10200 [Sound Blaster Audigy Series] (SB0350 Audigy 2 ZS) Digitální stereo (IEC958)
		alsa_input.pci-0000_05_01.0.analog-mono/#2: EMU10k2/CA0100/CA0102/CA10200 [Sound Blaster Audigy Series] (SB0350 Audigy 2 ZS) Analogové mono
	ports:
			properties:
		iec958-stereo-input: Digitální vstup (S/PDIF) (priority 0, latency offset 0 usec, available: unknown)
			properties:
		analog-output: Analogový výstup (priority 9900, latency offset 0 usec, available: unknown)
			properties:
			properties:
0 sink input(s) available.
0 source output(s) available.
0 cache entrie(s) available.
#23 Příspěvek od labeent »
Já dělám vždycky novou instalaci. To jsem myslel updaty ze "Správy aktualizací" ...
