Nefunkční tlačítka trackpointu u Dell E6520
caine
Re: Nefunkční tlačítka trackpointu u Dell E6520
#21 Příspěvek od caine »
Nejprve jsem provedl sudo apt remove --purge xserver-xorg-input-libinput-hwe-18.04
Pak restlartoval a stále nic.
Výpis xinput list se nezměnil.
Podrobný výpis je teď díky jinému ovladači podstatně jiný, ale že bych z toho byl moudrý...
xinput list
⎡ Virtual core pointer                    	id=2	[master pointer  (3)]
⎜   ↳ Virtual core XTEST pointer              	id=4	[slave  pointer  (2)]
⎜   ↳ AlpsPS/2 ALPS GlidePoint                	id=13	[slave  pointer  (2)]
xinput --list-props 13
Device 'AlpsPS/2 ALPS GlidePoint':
	Device Enabled (165):	1
	Coordinate Transformation Matrix (167):	1.000000, 0.000000, 0.000000, 0.000000, 1.000000, 0.000000, 0.000000, 0.000000, 1.000000
	Device Accel Profile (293):	1
	Device Accel Constant Deceleration (294):	2.500000
	Device Accel Adaptive Deceleration (295):	1.000000
	Device Accel Velocity Scaling (296):	12.500000
	Synaptics Edges (297):	300, 1700, 210, 1190
	Synaptics Finger (298):	12, 15, 0
	Synaptics Tap Time (299):	180
	Synaptics Tap Move (300):	107
	Synaptics Tap Durations (301):	180, 180, 100
	Synaptics ClickPad (302):	0
	Synaptics Middle Button Timeout (303):	75
	Synaptics Two-Finger Pressure (304):	141
	Synaptics Two-Finger Width (305):	7
	Synaptics Scrolling Distance (306):	48, 48
	Synaptics Edge Scrolling (307):	1, 0, 0
	Synaptics Two-Finger Scrolling (308):	1, 0
	Synaptics Move Speed (309):	1.000000, 1.750000, 0.081934, 0.000000
	Synaptics Off (310):	0
	Synaptics Locked Drags (311):	0
	Synaptics Locked Drags Timeout (312):	5000
	Synaptics Tap Action (313):	2, 3, 0, 0, 1, 3, 0
	Synaptics Click Action (314):	1, 1, 0
	Synaptics Circular Scrolling (315):	0
	Synaptics Circular Scrolling Distance (316):	0.100000
	Synaptics Circular Scrolling Trigger (317):	0
	Synaptics Circular Pad (318):	0
	Synaptics Palm Detection (319):	0
	Synaptics Palm Dimensions (320):	10, 100
	Synaptics Coasting Speed (321):	20.000000, 50.000000
	Synaptics Pressure Motion (322):	15, 80
	Synaptics Pressure Motion Factor (323):	1.000000, 1.000000
	Synaptics Resolution Detect (324):	1
	Synaptics Grab Event Device (325):	0
	Synaptics Gestures (326):	1
	Synaptics Capabilities (327):	1, 1, 1, 1, 1, 1, 0
	Synaptics Pad Resolution (328):	1, 1
	Synaptics Area (329):	0, 0, 0, 0
	Synaptics Noise Cancellation (330):	12, 12
	Device Product ID (288):	2, 8
	Device Node (289):	"/dev/input/event6"
#22 Příspěvek od menom »
Ano neni to presne jako v tom 17.3 mate,
Tak matne si spominam, ze som pomahal davno riesit trackpoint na dell a bol to rovnaky HW
co je v thinkpadoch.
Na tvojom mieste by som skusil este instalovat toto:
tp-smapi-dkms
a este
tpb
caine
#23 Příspěvek od caine »
Nainstalováno, restartováno... zklamáno. Nic. Mrzí mě, že vám zbytečně beru čas. Ale stejně děkuju!
#24 Příspěvek od menom »
Vpohode, este posledny vystrel od boku zadat do terminalu prikaz na
load modulu evdev:
sudo modprobe evdev
Vyskusat tlacitka ci sa nieco zmeni ....
caine
#25 Příspěvek od caine »
:cry:
Nezměnilo.
Myslíte, že má smysl zkoušet i nějaká jiná linux distra? Když to nerozchodil ani MX linux, u kterého je jako jedna z předností uvedeno, že podporuje ovladače i pro starší stroje?
#26 Příspěvek od Ventero1 »
Takze vedle na foru uzivatel Dell Lat. E5xxx - podobny ntb - Ubu 18.04 ve vypisu xinput to druhe zarizeni ma stejne jako ve vypisu LM 17.3. O trackpointu nic nepise - cekam na odpoved, ale zas mu blbne dotykova plocha - zatim navrh na reseni zmena citlivosti.
Takze zkus nabootovat live Ubu 18.04, jestli pujde tam ...
caine
#27 Příspěvek od caine »
Ubu 18.04 live vyzkoušeno a ani ťuk.
Co se přecitlivělosti touchpadu týče... u livka LM 17.3 jsem nic takového nepozoroval. Teď při návratu do LM 19.3 je to horší. Při rolování (dvěma prsty), hlavně při najetí na spodní okraj plošky touchpadu mi stránka často hupne zpátky třeba o celou půlku, ale... to asi až někdy jindy :roll: )
Naposledy upravil(a) caine dne 11 úno 2020, 13:14, celkem upraveno 1 x.
#28 Příspěvek od menom »
caine píše: 07 úno 2020, 09:44 :cry:
Nezměnilo.
MX ma viacej verzii a tak pripada do uvahy vyskusat aj starsie ale stale podporovane rady MX 18.x , MX 17.x
To ze nedetekuje ten dual stick, moze suviset s jadrom.
Mozno este skusit instalovat ubuntacke jadro s oznacenim hwe , ked aj ovladace su nejak modifikovane hwe.
#29 Příspěvek od Ventero1 »
Tak tomu uzivateli ten trackpoint funguje v 18.04.
Muzes zkusit jine jadro,,,
#30 Příspěvek od Ventero1 »
A nebo me jeste napada - bylo pri instalaci zarizeni online a zatrzeno ziskat behem instalace SW tretich stran? Paklize to LM ma taky takto ...
