Wi-Fi na notebooku ASUS X552
WiFi, drátové sítě atd.
Re: Wi-Fi na notebooku ASUS X552
#21 Příspěvek od juhele2014 »
:arrow: Zadej do terminálu inxi -F a postni to sem. Dej to mezi závorky při volbě Code.
příklad:
guma@pc-lojza ~ $ inxi -F
System:    Host: pc-lojza Kernel: 4.4.4-040404-generic i686 (32 bit) Desktop: Xfce 4.11.8 Distro: Linux Mint 17.1 Rebecca
Machine:   System: Hewlett-Packard product: HP ProBook 650 G1 version:
           Mobo: Hewlett-Packard model: 1993 version: KBC Version 16.36
           Bios: Hewlett-Packard version: L77 Ver. 01.02 date: 12/05/2013
CPU:       Dual core Intel Core i5-4200M CPU (-HT-MCP-) cache: 3072 KB flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx)
           Clock Speeds: 1: 2817.382 MHz 2: 2656.347 MHz 3: 2685.058 MHz 4: 2517.480 MHz
Graphics:  C
:mrgreen:
Ricmond
#22 Příspěvek od Ricmond »
OK tak tady to je
ricmond@ricmond-X550VB:~$ inxi -F
System:    Host: ricmond-X550VB Kernel: 3.19.0-51-generic x86_64 (64 bit) Desktop: Gnome Distro: Ubuntu 14.04 trusty
Machine:   Mobo: ASUSTeK model: X550VB version: 1.0 Bios: American Megatrends version: X550VB.217 date: 01/22/2014
CPU:       Dual core Intel Core i5-3230M CPU (-HT-MCP-) cache: 3072 KB flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx)
           Clock Speeds: 1: 2156.171 MHz 2: 1262.320 MHz 3: 2025.359 MHz 4: 1263.539 MHz
Graphics:  Card: Intel 3rd Gen Core processor Graphics Controller
           X.Org: 1.17.1 drivers: intel (unloaded: fbdev,vesa) FAILED: nouveau Resolution: 1366x768@60.0hz
           GLX Renderer: Mesa DRI Intel Ivybridge Mobile GLX Version: 3.0 Mesa 10.5.9
Audio:     Card: Intel 7 Series/C210 Series Family High Definition Audio Controller driver: snd_hda_intel
           Sound: Advanced Linux Sound Architecture ver: k3.19.0-51-generic
Network:   Card-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller driver: r8169
           IF: eth0 state: up speed: 100 Mbps duplex: full mac: 10:c3:7b:1f:4c:98
           Card-2: Broadcom BCM43142 802.11b/g/n driver: bcma-pci-bridge
           IF: N/A state: N/A mac: N/A
Drives:    HDD Total Size: 1000.2GB (0.5% used) 1: id: /dev/sda model: ST1000LM024_HN size: 1000.2GB
Partition: ID: / size: 80G used: 4.9G (7%) fs: ext4 ID: swap-1 size: 8.47GB used: 0.00GB (0%) fs: swap
RAID:      No RAID devices detected - /proc/mdstat and md_mod kernel raid module present
Sensors:   System Temperatures: cpu: 41.0C mobo: N/A gpu: 40.0
           Fan Speeds (in rpm): cpu: N/A
Info:      Processes: 203 Uptime: 5 min Memory: 614.8/7870.4MB Client: Shell (bash) inxi: 1.9.17
#23 Příspěvek od juhele2014 »
:arrow: Hmmm, tak běž sem http://www.linux-mint-czech.cz/jak-nain ... nux-mintu/ , mrkni na odstavec Instalace jádra 4.4.4 v 64-bitové verzi Linux Mintu , pusť terminál a zkopíruj tam všechno, co je v tom šedém poli (začíná to cd a končí deb). Pak restartuj, a když zadáš do terminálu příkaz uname -a , tak hned zkraje vidíš, že máš nový kernel. Tlačítko wifiny se rozsvítí. Akorát mě zaráží v tvém výpisu Desktop: Gnome Distro: Ubuntu 14.04 trusty, ale ono to nějak dopadne ... ;)
Ricmond
#24 Příspěvek od Ricmond »
Tak jsem to udělal ale wifi pořád nic :(
ricmond@ricmond-X550VB:~$ uname -a
Linux ricmond-X550VB 4.4.4-040404-generic #201603031931 SMP Fri Mar 4 00:34:16 UTC 2016 x86_64 x86_64 x86_64 GNU/Linux
#25 Příspěvek od juhele2014 »
Co máš vlastně za linux? ( inxi -F )
Co ukáže výpis sudo lshw -c network ?
Ricmond
#26 Příspěvek od Ricmond »
System:    Host: ricmond-X550VB Kernel: 4.4.4-040404-generic x86_64 (64 bit) Desktop: Gnome Distro: Ubuntu 14.04 trusty
           Clock Speeds: 1: 1212.757 MHz 2: 1299.796 MHz 3: 1204.835 MHz 4: 1435.078 MHz
           Sound: Advanced Linux Sound Architecture ver: k4.4.4-040404-generic
Drives:    HDD Total Size: 1000.2GB (0.6% used) 1: id: /dev/sda model: ST1000LM024_HN size: 1000.2GB
Partition: ID: / size: 80G used: 5.4G (8%) fs: ext4 ID: swap-1 size: 8.47GB used: 0.00GB (0%) fs: swap
Sensors:   System Temperatures: cpu: 40.0C mobo: N/A gpu: 38.0
           Fan Speeds (in rpm): cpu: 2000
Info:      Processes: 231 Uptime: 1 min Memory: 608.2/7869.7MB Client: Shell (bash) inxi: 1.9.17
ricmond@ricmond-X550VB:~$ sudo lshw -c network ?
[sudo] password for ricmond:
Hardware Lister (lshw) - B.02.16
usage: lshw [-format] [-options ...]
       lshw -version
	-version        print program version (B.02.16)
format can be
	-html           output hardware tree as HTML
	-xml            output hardware tree as XML
	-short          output hardware paths
	-businfo        output bus information
options can be
	-class CLASS    only show a certain class of hardware
	-C CLASS        same as '-class CLASS'
	-c CLASS        same as '-class CLASS'
	-disable TEST   disable a test (like pci, isapnp, cpuid, etc. )
	-enable TEST    enable a test (like pci, isapnp, cpuid, etc. )
	-quiet          don't display status
	-sanitize       sanitize output (remove sensitive information like serial numbers, etc.)
	-numeric        output numeric IDs (for PCI, USB, etc.)
#27 Příspěvek od juhele2014 »
:arrow: Pouze sudo lshw -c network
#28 Příspěvek od menom »
Mohol by si pridat vypis z terminalu, aby sme zistili pci.id wifi karty:
lspci -nn -d 14e4:
Ricmond
#29 Příspěvek od Ricmond »
omlouvám se že to tak trvalo jsem v práci a musel jsem přijít nato jak se připojit přes telefon tak a tady to je
  *-network
       description: Network controller
       product: BCM43142 802.11b/g/n
       vendor: Broadcom Corporation
       physical id: 0
       bus info: pci@0000:03:00.0
       version: 01
       width: 64 bitsricmond@ricmond-X550VB:~$ lspci -nn -d 14e4:
03:00.0 Network controller [0280]: Broadcom Corporation BCM43142 802.11b/g/n [14e4:4365] (rev 01)
       clock: 33MHz
       capabilities: pm msi pciexpress bus_master cap_list
       configuration: driver=bcma-pci-bridge latency=0
       resources: irq:17 memory:f7900000-f7907fff
  *-network
       physical id: 0.2
       bus info: pci@0000:04:00.2
       logical name: eth0
       version: 0a
       serial: 10:c3:7b:1f:4c:98
       capacity: 1Gbit/s
       width: 64 bits
       clock: 33MHz
       capabilities: pm msi pciexpress msix vpd bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd 1000bt 1000bt-fd autonegotiation
       configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=2.3LK-NAPI duplex=half firmware=rtl8411-1_0.0.3 06/18/12 latency=0 link=no multicast=yes port=MII speed=10Mbit/s
       resources: irq:29 ioport:d000(size=256) memory:f2104000-f2104fff memory:f2100000-f2103fff
  *-network
       physical id: 1
       logical name: usb0
       serial: 02:5c:51:50:35:64
       capabilities: ethernet physical
       configuration: broadcast=yes driver=rndis_host driverversion=22-Aug-2005 firmware=RNDIS device ip=192.168.42.246 link=yes multicast=yes
#30 Příspěvek od menom »
Este ze mame mobily, to je v takejto situacii na nezaplatenie.
Takze pci.id tvojej karty je 14e4:4365
Malo by pomoct:
sudo apt-get install bcmwl-kernel-source
sudo reboot
