Instalace Linux Mint 20.3 CE Vyřešeno
Re: Instalace Linux Mint 20.3 CE
Často je třeba vymazat záznamy z SB a také TPM ..
System:
Host: keyzio-laptop Kernel: 5.15.0-22-generic x86_64 bits: 64
Desktop: GNOME 41.3 Distro: Ubuntu 22.04 (Jammy Jellyfish)
Machine:
Type: Laptop System: ASUSTeK product: ROG Flow X13 GV301QH_GV301QH v: 1.0
serial: <superuser required>
Mobo: ASUSTeK model: GV301QH v: 1.0 serial: <superuser required>
UEFI: American Megatrends LLC. v: GV301QH.409 date: 01/27/2022
Battery:
ID-1: BAT0 charge: 37.2 Wh (66.2%) condition: 56.2/62.0 Wh (90.7%)
volts: 15.9 min: 15.9
CPU:
Info: 8-core model: AMD Ryzen 7 5800HS with Radeon Graphics bits: 64
type: MT MCP cache: L2: 4 MiB
Speed (MHz): avg: 1255 min/max: 1200/3200 cores: 1: 1372 2: 1395 3: 1195
4: 1197 5: 1196 6: 1196 7: 1198 8: 1191 9: 1340 10: 1224 11: 1396 12: 1395
13: 1197 14: 1196 15: 1196 16: 1197
Graphics:
Device-1: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q] driver: nvidia
v: 470.103.01
Device-2: AMD Cezanne driver: amdgpu v: kernel
Device-3: IMC Networks USB2.0 HD UVC WebCam type: USB driver: uvcvideo
Display: x11 server: X.Org v: 1.20.14 driver: X:
loaded: amdgpu,ati,nvidia unloaded: fbdev,modesetting,nouveau,vesa
gpu: amdgpu resolution: 3840x2400~60Hz
OpenGL: renderer: AMD RENOIR (DRM 3.42.0 5.15.0-22-generic LLVM 12.0.1)
v: 4.6 Mesa 21.3.5
Audio:
Device-1: AMD Renoir Radeon High Definition Audio driver: snd_hda_intel
Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor driver: N/A
Device-3: AMD Family 17h HD Audio driver: snd_hda_intel
Sound Server-1: ALSA v: k5.15.0-22-generic running: yes
Sound Server-2: PulseAudio v: 15.99.1 running: yes
Sound Server-3: PipeWire v: 0.3.48 running: yes
Network:
Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi
IF: wlp6s0 state: up mac: 70:9c:d1:5e:06:cd
Bluetooth:
Device-1: Intel AX200 Bluetooth type: USB driver: btusb
Report: hciconfig ID: hci0 state: up address: 70:9C:D1:5E:06:D1 bt-v: 3.0
Drives:
Local Storage: total: 476.94 GiB used: 10.48 GiB (2.2%)
ID-1: /dev/nvme0n1 vendor: Western Digital
model: PC SN530 SDBPTPZ-512G-1002 size: 476.94 GiB
Partition:
ID-1: / size: 467.89 GiB used: 10.47 GiB (2.2%) fs: ext4
dev: /dev/nvme0n1p2
ID-2: /boot/efi size: 511 MiB used: 5.2 MiB (1.0%) fs: vfat
dev: /dev/nvme0n1p1
Swap:
ID-1: swap-1 type: file size: 2 GiB used: 0 KiB (0.0%) file: /swapfile
Sensors:
System Temperatures: cpu: 30.0 C mobo: N/A gpu: amdgpu temp: 29.0 C
Fan Speeds (RPM): cpu: 0
Info:
Processes: 376 Uptime: 1m Memory: 15.04 GiB used: 1.25 GiB (8.3%)
Shell: Bash inxi: 3.3.13
Takze jo - takhle to ma byt. Instaloval jsi tedy i do Ubu proprietal na nVidii.
Mint by fungoval tez, kdyby jsi tam povysil na jadro 5.15 nebo 5.16, ale on to tak velky rozdil neni a bud rad ze jsi se zbavil Cinnamonu. Jinak dalsi informace, ze Ubuntu a tedy i Mint a dalsi odvozena distra to proste s dvema grafikami moc neumi. Zde lepe funguji veci bez systemd - jako prave napr. MX
Kdyby jsi zkusil ten AHS Mint, tak by to pravdepodobne slo take.
Ne, nic s nVidia jsem neinstaloval..alespon ne explicitne...dal jsem instalaci a pak
a take jsem mozna zaskrtaval pri instalaci Ubuntu, ze chci stahnout software 3tich stran
A co se tyce povyseni LM tak jsem zkousel nejaky navod ale skoncil jsem hned na prvnim prikazu
neco takoveho bylo vysledkem
Jake je tedy doporucene distro pro zacatecniky uz s vyssim jadrem a podporou dvou grafik ?
Proc je dobre ze jsem se zbavil Cinnammonu (na jejich strankach byli 3 verze a Cinnamon byla nejnovejsi) ?
sudo apt update && sudo apt upgrade -y
ppa:canonical-kernel-team/proposed
unable to init server
...este aktivuj cannonical livepatch...
Cinnamon neni nejnovejsi verze - je to typ graficke nadstavby a bohuzel dosti problematicky. A to je fakt i presto, ze ma sve priznivce az fanousky.
Ted jedes nejspise na Gnome.
Ano suhlasim, je to velmi pravdepodobne.
Ubuntu nesledujem, ale LM ma nvidia-prime-applet.
Ked su dostupne ovladace, tak vie prepinat medzi grafickymi kartami jednotlivo aj spolu aby fungovali.
Takze to moze vyskusat tazatel, alebo ak niekto ma taky hardver.
Nvidia-prime-applet nema ani debian ani MX Linux, tie maju zase ine vyhody (ako pre koho).
V tom ubuntu ma sice ovladace amd s 5.15 + nividia 470 ale graficky vykon podla toho vypisu taha ta slabsia grafika:
Graphics:
v: 470.103.01
v: 4.6 Mesa 21.3.5.
Nema prepnuto - na to je taky nejaka aplikace tusim nebo se to da udelat i prikazem, jestli se nepletu. Tuhle problematiku neznam - nemam osobni zkusenost, bo jsem zatim neinstaloval Linux na dvougrafikovy ntb.
...som to riesil pri mate 18.04...notbuk lenovo,dve grafické karty,obidva AMD...ale to je už minulost...
ja som mal nedávno takýto problém a aj sme to vyriešili.je to velký problém.pri inštalácii na NTB lenovo G70-80 mi vždy pri hociakom distre nainštaluje slabšiu grafiku INTEL a mám problém.a veľký.PC mi mrzne.kým to nevyriešim a nenainštalujem ovládač graf.karty NVIDIA-nie vždy sa mi poradí nainštalovať správny-záleží aj od distra-asi je aj vo mne chyba ale už to neriešim dovtedy PC nejde dobre.proste kým nenainštalujem správny ovládač graf.karty NVIDIA PC mi mrzne.nejde dobre.s troma distrami som zatial na mojom PC nemal problém.Mint,Ubuntu a Debian.tieto mi idú.ale asi záleží aj od PC.lebo na druhom mi ide všetko.hociaké distro.a ten PC má asi aj 15 rokov.už presne ani neviem.aj nové rolling distrá idú na ňom.nemá probléma...
