Dell D531 nejde WiFi [vyřešeno]
WiFi, drátové sítě atd.
#1 Příspěvek od skrob »
Dobrý den,
pročetl jsem tady co se dalo a otestoval spoustu postupu, naposledy s aktivací wifi u HP nc...tam jsem došel k návodu, který vyvrcholil...po restartu šipka dolu-tab-e a přepsat řádek, nikdy se mi však nepodařilo zastavit ty data a skočil jsem do systemu. Vím, že s těma wifinama jsou problémy, ale není něco na Dell D531? Na D830 to jede v pohodě.
Přidávám výpis lspci -v
skrob@skrob-Latitude-D531 ~ $ lspci -v
00:00.0 Host bridge: Advanced Micro Devices, Inc. [AMD/ATI] RS690 Host Bridge
	Subsystem: Dell Device 0206
	Flags: bus master, 66MHz, medium devsel, latency 64
00:01.0 PCI bridge: Advanced Micro Devices, Inc. [AMD/ATI] RS690 PCI to PCI Bridge (Internal gfx) (prog-if 00 [Normal decode])
	Bus: primary=00, secondary=01, subordinate=01, sec-latency=64
	I/O behind bridge: 0000e000-0000efff
	Memory behind bridge: fe900000-feafffff
	Prefetchable memory behind bridge: 00000000e0000000-00000000efffffff
	Capabilities: <access denied>
00:05.0 PCI bridge: Advanced Micro Devices, Inc. [AMD/ATI] RS690 PCI to PCI Bridge (PCI Express Port 1) (prog-if 00 [Normal decode])
	Flags: bus master, fast devsel, latency 0
	Bus: primary=00, secondary=0b, subordinate=0b, sec-latency=0
	Memory behind bridge: fe800000-fe8fffff
	Kernel driver in use: pcieport
00:06.0 PCI bridge: Advanced Micro Devices, Inc. [AMD/ATI] RS690 PCI to PCI Bridge (PCI Express Port 2) (prog-if 00 [Normal decode])
	Bus: primary=00, secondary=09, subordinate=09, sec-latency=0
	Memory behind bridge: fe700000-fe7fffff
00:12.0 SATA controller: Advanced Micro Devices, Inc. [AMD/ATI] SB600 Non-Raid-5 SATA (prog-if 01 [AHCI 1.0])
	Flags: bus master, 66MHz, medium devsel, latency 64, IRQ 22
	I/O ports at 6eb0 [size=8]
	I/O ports at 6eb8 [size=4]
	I/O ports at 6ec0 [size=8]
	I/O ports at 6ec8 [size=4]
	I/O ports at 6ee0 [size=16]
	Memory at 84000000 (32-bit, non-prefetchable) [size=1K]
	Kernel driver in use: ahci
00:13.0 USB controller: Advanced Micro Devices, Inc. [AMD/ATI] SB600 USB (OHCI0) (prog-if 10 [OHCI])
	Flags: bus master, 66MHz, medium devsel, latency 64, IRQ 16
	Memory at ffb00000 (32-bit, non-prefetchable) [size=4K]
	Kernel driver in use: ohci-pci
00:13.1 USB controller: Advanced Micro Devices, Inc. [AMD/ATI] SB600 USB (OHCI1) (prog-if 10 [OHCI])
	Flags: bus master, 66MHz, medium devsel, latency 64, IRQ 17
	Memory at ffb01000 (32-bit, non-prefetchable) [size=4K]
00:13.2 USB controller: Advanced Micro Devices, Inc. [AMD/ATI] SB600 USB (OHCI2) (prog-if 10 [OHCI])
	Flags: bus master, 66MHz, medium devsel, latency 64, IRQ 18
	Memory at ffb02000 (32-bit, non-prefetchable) [size=4K]
00:13.3 USB controller: Advanced Micro Devices, Inc. [AMD/ATI] SB600 USB (OHCI3) (prog-if 10 [OHCI])
	Memory at ffb03000 (32-bit, non-prefetchable) [size=4K]
00:13.4 USB controller: Advanced Micro Devices, Inc. [AMD/ATI] SB600 USB (OHCI4) (prog-if 10 [OHCI])
	Memory at ffb04000 (32-bit, non-prefetchable) [size=4K]
00:13.5 USB controller: Advanced Micro Devices, Inc. [AMD/ATI] SB600 USB Controller (EHCI) (prog-if 20 [EHCI])
	Flags: bus master, 66MHz, medium devsel, latency 64, IRQ 20
	Memory at ffa80000 (32-bit, non-prefetchable) [size=256]
	Kernel driver in use: ehci-pci
00:14.0 SMBus: Advanced Micro Devices, Inc. [AMD/ATI] SBx00 SMBus Controller (rev 14)
	Flags: 66MHz, medium devsel
	I/O ports at 10c0 [size=16]
	Kernel driver in use: piix4_smbus
00:14.1 IDE interface: Advanced Micro Devices, Inc. [AMD/ATI] SB600 IDE (prog-if 8a [Master SecP PriP])
	I/O ports at 01f0 [size=8]
	I/O ports at 03f4
	I/O ports at 0170 [size=8]
	I/O ports at 0374
	I/O ports at bfa0 [size=16]
	Kernel driver in use: pata_atiixp
00:14.2 Audio device: Advanced Micro Devices, Inc. [AMD/ATI] SBx00 Azalia (Intel HDA)
	Flags: bus master, slow devsel, latency 64, IRQ 16
	Memory at febfc000 (64-bit, non-prefetchable) [size=16K]
	Kernel driver in use: snd_hda_intel
00:14.3 ISA bridge: Advanced Micro Devices, Inc. [AMD/ATI] SB600 PCI to LPC Bridge
	Flags: bus master, 66MHz, medium devsel, latency 0
00:14.4 PCI bridge: Advanced Micro Devices, Inc. [AMD/ATI] SBx00 PCI to PCI Bridge (prog-if 01 [Subtractive decode])
	Bus: primary=00, secondary=03, subordinate=07, sec-latency=64
	I/O behind bridge: 00002000-00002fff
	Memory behind bridge: fe600000-fe6fffff
	Prefetchable memory behind bridge: 80000000-83ffffff
00:18.0 Host bridge: Advanced Micro Devices, Inc. [AMD] K8 [Athlon64/Opteron] HyperTransport Technology Configuration
	Flags: fast devsel
00:18.1 Host bridge: Advanced Micro Devices, Inc. [AMD] K8 [Athlon64/Opteron] Address Map
	Flags: fast devsel
00:18.2 Host bridge: Advanced Micro Devices, Inc. [AMD] K8 [Athlon64/Opteron] DRAM Controller
	Flags: fast devsel
00:18.3 Host bridge: Advanced Micro Devices, Inc. [AMD] K8 [Athlon64/Opteron] Miscellaneous Control
	Flags: fast devsel
	Kernel driver in use: k8temp
01:05.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] RS690M [Radeon Xpress 1200/1250/1270] (prog-if 00 [VGA controller])
	Flags: bus master, fast devsel, latency 64, IRQ 42
	Memory at e0000000 (64-bit, prefetchable) [size=256M]
	Memory at fe9f0000 (64-bit, non-prefetchable) [size=64K]
	I/O ports at ee00 [size=256]
	Memory at fea00000 (32-bit, non-prefetchable) [size=1M]
	Expansion ROM at <unassigned> [disabled]
	Kernel driver in use: radeon
03:01.0 CardBus bridge: O2 Micro, Inc. Cardbus bridge (rev 21)
	Flags: bus master, stepping, slow devsel, latency 168, IRQ 23
	Memory at 88000000 (32-bit, non-prefetchable) [size=4K]
	Bus: primary=03, secondary=04, subordinate=07, sec-latency=176
	Memory window 0: 80000000-83ffffff (prefetchable)
	Memory window 1: 8c000000-8fffffff
	I/O window 0: 00002000-000020ff
	I/O window 1: 00002400-000024ff
	16-bit legacy interface ports at 0001
	Kernel driver in use: yenta_cardbus
03:01.4 FireWire (IEEE 1394): O2 Micro, Inc. Firewire (IEEE 1394) (rev 02) (prog-if 10 [OHCI])
	Subsystem: O2 Micro, Inc. Firewire (IEEE 1394)
	Flags: bus master, medium devsel, latency 64, IRQ 23
	Memory at fe6ff000 (32-bit, non-prefetchable) [size=4K]
	Memory at fe6fe800 (32-bit, non-prefetchable) [size=2K]
	Kernel driver in use: firewire_ohci
09:00.0 Ethernet controller: Broadcom Corporation NetXtreme BCM5755M Gigabit Ethernet PCI Express (rev 02)
	Flags: bus master, fast devsel, latency 0, IRQ 44
	Memory at fe7f0000 (64-bit, non-prefetchable) [size=64K]
	Expansion ROM at <ignored> [disabled]
	Kernel driver in use: tg3
0b:00.0 Network controller: Intel Corporation PRO/Wireless 4965 AG or AGN [Kedron] Network Connection (rev 61)
	Subsystem: Intel Corporation Device 1121
	Flags: bus master, fast devsel, latency 0, IRQ 43
	Memory at fe8fe000 (64-bit, non-prefetchable) [size=8K]
	Kernel driver in use: iwl4965
skrob@skrob-Latitude-D531 ~ $ iwconfig
wlan0     IEEE 802.11abgn  ESSID:off/any
          Mode:Managed  Access Point: Not-Associated   Tx-Power=off
          Retry short limit:7   RTS thr:off   Fragment thr:off
          Power Management:off
lo        no wireless extensions.
eth0      no wireless extensions.
Re: Dell D531 nejde wifi
Asi to bude chtít jiné jádro, vyzkoušej kernel 3.13 až 4.3 , mělo se to čapnout. Aktualizace (v tomto případě) povol všechny 1 až 5 , tzn i firmware. Viz http://www.linux-mint-czech.cz/jak-nain ... nux-mintu/
#3 Příspěvek od skrob »
Jádro je nové 4.3.0
výsledek žádný
#4 Příspěvek od skrob »
Flags: bus master, fast devsel, latency 0, IRQ 28
Flags: bus master, fast devsel, latency 0, IRQ 27
#5 Příspěvek od menom »
Vo vypise iwconfig je jasne vidno, ze ta karta je k dispozicii:
Ovladac tam mas, tak co ti vlastne nefunguje ?
#6 Příspěvek od skrob »
Pokud dám připojení ukáže se mi na liště přepínač on/off, ale nejde přepnout, vždy skočí zpět na off, kabel jde normálně. Wifi sítě nejsou vidět.
#7 Příspěvek od menom »
No a neni na notebooku hardwarove tlacitko na zapnutie wifi.
Pripadne to byva klavesova skratka napriklad fn+f2.
Ale kazdy vyrobca to moze mat inak.
Este mozes skusit zadat do Terminalu prikaz:
sudo rfkill list all
vypise ci neni blokovana karta wifi.
#8 Příspěvek od skrob »
Je to klasika a pořád dokola
Soft blocked: no
Hard blocked: yes
Přepínač na 531 není, v Biosu je to povoleno, wifina je funkční, dával jsem i jinou a taky nic.
Na display vidím bezdrát, ale nejde manualně povolit, přeskakuje zpět, v ovladačích nenabízí nic.
#9 Příspěvek od skrob »
Tak jsem tam dal wifi z 830, našel si ovladač, ale. Pokud ho chci povolit, tak mi při změně skočí zpět na nepoužívat.
http://prntscr.com/97u3ry
#10 Příspěvek od skrob »
Výpis
0b:00.0 Network controller: Broadcom Corporation BCM4321 802.11a/b/g/n (rev 03)
Subsystem: Dell Wireless 1500 Draft 802.11n WLAN Mini-card
Flags: bus master, fast devsel, latency 0, IRQ 17
Memory at fe8fc000 (64-bit, non-prefetchable)
Memory at f0000000 (64-bit, prefetchable)
Kernel driver in use: b43-pci-bridge
