Mouse: DeathAdder Chroma
Úspešně jsem rozchodil neoficialní ovladač pro myš razer "http://bues.ch/cms/hacking/razercfg.html"
Přes GUI vše funguje ale problém je že se nastaveni neuloží tím pádem pri restartovaní počítače musím nastavení DPI a všeho znovu nastavovat.
http://s14.postimg.org/xwg7mt61t/GUI.png
Nevím jak tento problém vyřešit...
Soubor: README
* Razer device configuration tool *
* Copyright (c) 2007-2014 Michael Buesch *
This is a configuration utility for Razer devices on Linux systems.
DEPENDENCIES
* Python 3.x
https://www.python.org/
Debian Linux:
apt-get install python3
* libusb 1.0
http://libusb.org/
Debian Linux:
apt-get install libusb-1.0-0-dev
* PySide (for the graphical qrazercfg tool only)
https://qt-project.org/wiki/PySide
Debian Linux:
apt-get install python3-pyside
* cmake 2.4 or later (for building only)
http://www.cmake.org/
Debian Linux:
apt-get install cmake
Note that almost all distributions ship prebuilt packages of the
above dependencies.
If you installed a dependency after you already ran `cmake .` and/or `make`, it
might happen that the dependency is still not found. Just delete the cmake
status files or unpack a clean razercfg tarball to workaround this issue.
BUILDING
First invoke "cmake" to build the makefiles.
Then invoke "make" to build the binaries:
cmake .
make
(Note the required space and dot after the cmake command)
INSTALLING
First you need to install the tool libraries and binaries. Do this by executing
the following command as root:
make install
If you use systemd:
The `make install` step installed the razerd.service file. Reboot or run the
following command as root to start the razerd daemon:
systemctl start razerd
If you do NOT use systemd:
To automatically start the required system daemon "razerd" at bootup time, you
need to install the init-script. This software package includes a generic
example script, that should work out-of-the-box on many Linux distributions. To
install it, invoke the following commands as root:
cp ./razerd.initscript /etc/init.d/razerd
ln -s /etc/init.d/razerd /etc/rc2.d/S99razerd
ln -s /etc/init.d/razerd /etc/rc5.d/S99razerd
ln -s /etc/init.d/razerd /etc/rc0.d/K01razerd
ln -s /etc/init.d/razerd /etc/rc6.d/K01razerd
If you use udev:
The `make install` step installed the udev script to
$(pkg-config --variable=udevdir udev)/rules.d/80-razer.rules
This should work on most distributions.
If udev notification does not work, try to reboot the system.
RAZERD CONFIGURATION
The user may create a razerd configuration file in /etc/razer.conf which can be
used to specify various razerd options and initial hardware configuration
settings.
An example config file is included as "razer.conf" in this package.
If no configuration file is available, razerd will work with default settings.
X WINDOW SYSTEM (X.ORG) CONFIGURATION
If you don't have an xorg.conf, you don't have to do anything and it should work
out-of-the-box.
X must _not_ be configured to a specific mouse device like /dev/input/mouse0. On
configuration events, razerd may have to temporarily unregister the mouse from
the system. This will confuse X, if it's configured to a specific device.
Configure it to the generic /dev/input/mice device instead. This will enable X
to pick up the mouse again after a configuration event from razerd.
Example xorg.conf snippet:
Section "InputDevice"
Identifier "Mouse"
Driver "mouse"
Option "Device" "/dev/input/mice"
EndSection
Alternatively, do not specify a "Device" at all. X will autodetect the device
then:
Identifier "Mouse"
Driver "mouse"
EndSection
In any case, do _NOT_ use:
Option "Device" "/dev/input/mouseX"
USING THE TOOLS
To use the tools, the razerd daemon needs to be started as root, first. Without
the background daemon, nothing will work. The daemon is responsible for doing
the lowlevel hardware accesses and for tracking the current state of the device.
While the daemon is running, the user interfaces "razercfg" (commandline) and
"qrazercfg" (graphical user interface) can be used.
UNINSTALLING
If you installed razercfg with your distribution packaging system, use that to
uninstall razercfg.
If you compiled razercfg from source and installed it with `make install`, you
can use the "uninstall.sh" script from the razercfg archive to uninstall
razercfg from the system. It must be called with the install prefix as its first
argument. That usually is /usr/local, unless specified otherwise in cmake. A
call to uninstall.sh might look like this:
./uninstall.sh /usr/local
ARCHITECTURE
The architecture layout of the razer tools looks like this:
| hardware driver 0 |--v
------------------- | | lowlevel | -------- ---------
| hardware driver 1 |--x---| librazer |----| razerd |----| pyrazer |
| hardware driver n |--^ | (to be written) librazerd | | | |
| Application 0 |---^ | | | | |
| Application 1 |-----^ | | | |
| Application n |-------^ | | |
| razercfg |----------------------^ | |
| qrazercfg |-----------------------^ |
| Other Python applications |---------^
So in general, your application wants to access the razer devices through
pyrazer or (if it's not a python app) through librazerd.
(Note that librazerd is not written, yet. So currently the only way to access
the devices is through pyrazer).
Applications should never poke with lowlevel librazer directly, because there
will be no instance that keeps track of the device state and permissions and
concurrency.
PS:
Stále nemohu přijít na to co přesne a k čemu slouží tyto příkazy které jsem zadával podle návodu.
