Nefunkcna WiFi USB karta ieee802.11N 300Mb v PC [vyřešeno]
Zdravim vsetkych, poradi mi niekdo ako rozbehat usb wifi ieee802.11N 300Mb.Win7 wifinu nasiel bez problemov,ale nakolko sa mi hreje CPU Pentium4,tak som presiel opat na LM17.3.
Vyskusal som vsetky prikazy ,ale LM wifi nevidi.
Dakujem vsetkym za rady.
Re: Nefunkcna wifi usb karta v pc
inxi -F
System: Host: dady-desktop Kernel: 3.13.0-37-generic i686 (32 bit) Desktop: Xfce 4.11.8 Distro: Linux Mint 17.1 Rebecca
Machine: Mobo: N/A model: N/A Bios: Phoenix/Award version: 6.00 PG date: 01/14/2005
CPU: Single core Intel Pentium 4 CPU (-HT-) cache: 1024 KB flags: (nx sse sse2 sse3)
Clock Speeds: 1: 2932.522 MHz 2: 2932.522 MHz
Graphics: Card: NVIDIA GF108 [GeForce GT 630]
X.org: 1.15.1 drivers: (unloaded: fbdev,vesa) FAILED: nouveau tty size: 80x24 Advanced Data: N/A for root
Audio: Card-1: Intel 82801FB/FBM/FR/FW/FRW (ICH6 Family) AC'97 Audio Controller driver: snd_intel8x0
Card-2: NVIDIA GF108 High Definition Audio Controller driver: snd_hda_intel
Card-3: Creative Labs SB0400 Audigy2 Value driver: snd_emu10k1
Sound: Advanced Linux Sound Architecture ver: k3.13.0-37-generic
Network: Card: Realtek RTL8169 PCI Gigabit Ethernet Controller driver: r8169
IF: eth0 state: up speed: 100 Mbps duplex: full mac: 00:01:80:5e:57:58
Drives: HDD Total Size: 820.2GB (2.3% used) 1: id: /dev/sda model: WDC_WD3200AAKS size: 320.1GB
2: id: /dev/sdb model: WDC_WD5000AADS size: 500.1GB
Partition: ID: / size: 96G used: 5.0G (6%) fs: ext4
Sensors: System Temperatures: cpu: 60.0C mobo: N/A
Fan Speeds (in rpm): cpu: N/A
Info: Processes: 148 Uptime: 45 min Memory: 432.9/2015.8MB Client: Shell inxi: 1.8.4Re: Nefunkcna wifi usb karta v pc
Ked je karta v USB tak by si mohol dat vypisy:
Tam ju ma ukazat.
lsusbKód: Vybrat vše
dmesg | tail.
ifconfig
eth0 Link encap:Ethernet HWaddr 00:01:80:5e:57:58
inet addr:192.168.0.100 Bcast:192.168.0.255 Mask:255.255.255.0
inet6 addr: fe80::201:80ff:fe5e:5758/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:455895 errors:0 dropped:0 overruns:0 frame:0
TX packets:191944 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:671346768 (671.3 MB) TX bytes:14148690 (14.1 MB)
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:3315 errors:0 dropped:0 overruns:0 frame:0
TX packets:3315 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:303747 (303.7 KB) TX bytes:303747 (303.7 KB)Kód: Vybrat vše
iwconfig
lo no wireless extensions.
eth0 no wireless extensions.Re: Nefunkcna wifi usb karta v pc
lsusb
Bus 001 Device 002: ID 0bda:818b Realtek Semiconductor Corp.
Bus 004 Device 002: ID 0a5c:2101 Broadcom Corp. BCM2045 Bluetooth
Bus 003 Device 003: ID 0b38:0010 Gear Head 107-Key Keyboard
Bus 003 Device 002: ID 1130:1704 Tenx Technology, Inc.
Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hubKód: Vybrat vše
dmesg | tail
[ 361.639019] init: upstart-udev-bridge main process ended, respawning
[ 361.640188] init: upstart-file-bridge main process (425) terminated with status 1
[ 361.640229] init: upstart-file-bridge main process ended, respawning
[ 361.640661] init: upstart-socket-bridge main process (740) terminated with status 1
[ 361.640696] init: upstart-socket-bridge main process ended, respawning
[ 857.202091] init: smbd main process (641) killed by TERM signal
[ 1292.546918] init: avahi-cups-reload main process (12539) terminated with status 1
[ 1347.006923] init: samba-ad-dc main process (13515) terminated with status 1
[ 2799.115300] perf samples too long (2501 > 2500), lowering kernel.perf_event_max_sample_rate to 50000
[ 5260.711719] perf samples too long (5005 > 5000), lowering kernel.perf_event_max_sample_rate to 25000Re: Nefunkcna wifi usb karta v pc
Ten dmesg | tail nevypise vzdy vsetko, napriek tomu je velka sanca ze vo vypise dmesg bude
daco o blizsie o tej karte.
Mohol by si zadat prikaz dmesg a kopirovat to na http://www.pastebin.com
a sem dat odkaz, leboje to dlhe.
Alebo ako zvykne juhele2014 radit skusit novsie jadro (kernel).
nad tym jadrom som rozmyslal,len neviem,ktore by bolo lepsie.
Tak sa mi zda, ze najlepsie urobis, ked stiahnes .deb balicek a nainstalujes ho cez program Gdebi - instalator balikov.
Na stranke vpravo pod Realtek RTL8192EU chipset (0bda:818b) v riadku
a. Download the following compressed driver package: driver for the RTL8192EU chipset
klik na odkaz.
https://sites.google.com/site/easylinux ... 0bda:818b-
Druha moznost pridat a instalovat cez PPA.
http://askubuntu.com/questions/741559/w ... nect-now-n
Tretia moznost kompilacia ovladaca:
https://ubuntuforums.org/showthread.php?t=2310340
klik na odkaz.
sudo add-apt-repository ppa:hanipouspilot/rtlwifi
sudo apt-get install rtl8192eu-dkmshttps://ubuntuforums.org/showthread.php?t=2310340
isiel som podla druhej a potom podla tretej moznosti, ale stale je to chluche.Ta wifina by mal mat chip 8192.
