Nesvítí klávesnice
Person
Nesvítí klávesnice
#1 Příspěvek od Person »
Ahoj, bohužel mi v Mintu nesvítí klávesnice. Abych byl přesný tak většinou, zhruba 1 z 10 spuštění svítí. Nemáte radu, jak Mint přesvědčit. aby svítila vždy? Díky.
System: Host: user-SATELLITE-U50t-A Kernel: 4.10.0-42-generic x86_64 (64 bit gcc: 5.4.0)
Desktop: KDE Plasma 5.8.8 (Qt 5.6.1) dm: sddm,sddm Distro: Linux Mint 18.3 Sylvia
Machine: System: TOSHIBA product: SATELLITE U50t-A v: PSUBAE-00L01QCZ Chassis: type: 10
Mobo: TOSHIBA model: ZEMAA v: 1.00 Bios: TOSHIBA v: 1.50 date: 12/02/2013
CPU: Dual core Intel Core i5-4200U (-HT-MCP-) cache: 3072 KB
flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx) bmips: 9178
clock speeds: min/max: 800/2600 MHz 1: 2296 MHz 2: 2299 MHz 3: 2300 MHz 4: 2543 MHz
Graphics: Card: Intel Haswell-ULT Integrated Graphics Controller bus-ID: 00:02.0 chip-ID: 8086:0a16
Display Server: X.Org 1.18.4 drivers: intel (unloaded: fbdev,vesa) Resolution: 1366x768@60.00hz
GLX Renderer: Mesa DRI Intel Haswell Mobile GLX Version: 3.0 Mesa 17.2.4 Direct Rendering: Yes
Audio: Card-1 Intel 8 Series HD Audio Controller driver: snd_hda_intel bus-ID: 00:1b.0 chip-ID: 8086:9c20
Card-2 Intel Haswell-ULT HD Audio Controller driver: snd_hda_intel bus-ID: 00:03.0 chip-ID: 8086:0a0c
Sound: Advanced Linux Sound Architecture v: k4.10.0-42-generic
Network: Card-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
driver: r8169 v: 2.3LK-NAPI port: e000 bus-ID: 02:00.0 chip-ID: 10ec:8168
Card-2: Intel Wireless 7260 driver: iwlwifi bus-ID: 03:00.0 chip-ID: 8086:08b1
Drives: HDD Total Size: 782.2GB (2.1% used)
ID-1: /dev/sda model: TOSHIBA_MQ01ABD0 size: 750.2GB serial: 63D6FXC9S
ID-2: /dev/sdb model: TOSHIBA_THNSNX03 size: 32.0GB serial: 83QB31SDK5AX
Partition: ID-1: / size: 26G used: 12G (48%) fs: ext4 dev: /dev/sdb1
ID-2: swap-1 size: 4.20GB used: 0.00GB (0%) fs: swap dev: /dev/sdb5
RAID: System: supported: N/A
Unused Devices: none
Sensors: System Temperatures: cpu: 73.0C mobo: N/A
Fan Speeds (in rpm): cpu: N/A
Info: Processes: 192 Uptime: 20 min Memory: 1527.7/3863.2MB
Init: systemd v: 229 runlevel: 5 default: 2 Gcc sys: 5.4.0
Client: Shell (bash 4.3.481 running in konsole) inxi: 2.2.35
a ještě:
wmi 16384 1 toshiba_acpi
snd_rawmidi 32768 1 snd_seq_midi
snd_seq_device 16384 3 snd_seq,snd_rawmidi,snd_seq_midi
snd 77824 23 snd_compress,snd_hda_intel,snd_hwdep,snd_seq,snd_hda_codec,snd_timer,snd_rawmidi,snd_hda_codec_hdmi,snd_hda_codec_generic,snd_seq_device,snd_hda_codec_realtek,snd_soc_core,snd_pcm
fikejz
Re: Nesvítí klávesnice
#2 Příspěvek od fikejz »
To podsvícení se spouští samo podle okolního osvětlení/ svítí stále/ nebo zapínáš-vypínáš klávesou? Zkus mrknout na ovladače a jak to podsvícení detekuje systém. Jestli jako USB tak použij
lsusb
a podle výsledku pohledej na netu a když tak to postni sem.
Person
#3 Příspěvek od Person »
je to zapínatelné na klávesu, svítit by to mělo pořád...
Bus 001 Device 004: ID 04f2:b3fb Chicony Electronics Co., Ltd
Bus 001 Device 003: ID 04f3:0165 Elan Microelectronics Corp.
Bus 001 Device 002: ID 8087:8000 Intel Corp.
Bus 003 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Person píše:Ahoj, bohužel mi v Mintu nesvítí klávesnice. Abych byl přesný tak většinou, zhruba 1 z 10 spuštění svítí. Nemáte radu, jak Mint přesvědčit. aby svítila vždy?
Mohol by si dat vypis vo chvili, ked sviti - funguje.
lsmod
Potom aj v druhom pripade ked nesviti, aby to bolo mozno porovnat, mal by tam byt videt rozdiel.
fikejz
#5 Příspěvek od fikejz »
Jen trošičku jsem koukal po netu. Nemůže za to, že klávesnice jednou svítí a jednou ne režim napájení? Respektive vyloučil si možnost, že do toho "kecá" řízení spotřeby? Stejný problém (na + - stejném notebooku) někdo řešil na zive.cz s Widlema. Kde píše, že si aktivoval nějaký eko režim a pak za boha nemohl zprovoznit podsvětlení.
Naposledy upravil(a) fikejz dne 10 led 2018, 06:34, celkem upraveno 1 x.
#6 Příspěvek od Ventero1 »
Je zcela vyloucena zavada klavesnice? V jinem OS treba sviti pokazde?
I kdyz podle me by na to OS vubec nemel mit vliv. Podsvetleni klavesnice by melo byt zcela v rezii klavesnice a svitit by mela hned jak je pod napetim a podsviceni zapnuto. Takze treba uz v biosu.
Jestli to ma klavesnice vazane na nejaky ovadac v OS, tak je to totalni mimoza konstrukteru a prvotridni hovadina a takovou bych nechtel ...
