Mint na visionbook 14Wi - bez wifi a zvuku
Patrik
#1 Příspěvek od Patrik »
Zdravim vsetkych. Kupil som NTB umax visionbook 14Wi s WIn10. Jeho kvalitativnu uroven nechcem riesit. Chcem vyhodit Win10 a instalovat Mint. Po pociatocnych problemoch s nabootovanim mintu z USB som ho zatial skusil ako Live a zistil som ze nefunguje wifi ani zvuk. Co je vsak horsie, Mint asi ani nevie najst hardware. Pozri vypisy nizsie. Vo Win10 vsetko funguje.
Ma niekto sajn ako to vyriesit ?
Dik za tipy.
mint@mint ~ $ lsusb
Bus 001 Device 004: ID 090c:037c Silicon Motion, Inc. - Taiwan (formerly Feiya Technology Corp.) 300k Pixel Camera
Bus 001 Device 003: ID 6080:8060
Bus 001 Device 002: ID 0930:6545 Toshiba Corp. Kingston DataTraveler 102/2.0 / HEMA Flash Drive 2 GB / PNY Attache 4GB Stick
mint@mint ~ $
mint@mint ~ $ inxi -Fxz
System: Host: mint Kernel: 4.4.0-53-generic x86_64 (64 bit gcc: 5.4.0)
Desktop: Cinnamon 3.2.6 (Gtk 3.18.9-1ubuntu3.1) Distro: Linux Mint 18.1 Serena
Machine: System: Umax Czech a.s. product: VisionBook 14Wi
Mobo: AMI model: Cherry Trail CR Bios: N/A v: LC-BI-14-Y116CR200-316-B date: 09/24/2016
CPU: Quad core Intel Atom x5-Z8300 (-MCP-) cache: 1024 KB
flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx) bmips: 11519
clock speeds: max: 1840 MHz 1: 1040 MHz 2: 1028 MHz 3: 479 MHz 4: 1130 MHz
Graphics: Card: Intel Device 22b0 bus-ID: 00:02.0
Display Server: X.Org 1.18.4 drivers: intel (unloaded: fbdev,vesa) Resolution: 1366x768@60.06hz
GLX Renderer: Mesa DRI Intel HD Graphics (Cherryview)
GLX Version: 3.0 Mesa 11.2.0 Direct Rendering: Yes
Audio: Card Failed to Detect Sound Card! Sound: ALSA v: k4.4.0-53-generic
Network: Card: Failed to Detect Network Card!
Drives: HDD Total Size: 7.8GB (Used Error!) ID-1: /dev/mmcblk0 model: N/A size: 30.9GB
ID-2: /dev/mmcblk1 model: N/A size: 4.0GB
ID-3: USB /dev/sda model: USB_Flash_Memory size: 7.8GB temp: 0C
Partition: ID-1: / size: 963M used: 35M (4%) fs: overlay dev: N/A
Sensors: System Temperatures: cpu: 49.0C mobo: N/A
Fan Speeds (in rpm): cpu: N/A
Info: Processes: 177 Uptime: 26 min Memory: 552.6/1924.8MB Init: systemd runlevel: 5 Gcc sys: 5.4.0
Client: Shell (bash 4.3.461) inxi: 2.2.35
mint@mint ~ $
mint@mint ~ $ rfkill list all
mint@mint ~ $
mint@mint ~ $ inxi -Nn
mint@mint ~ $
mint@mint ~ $ iwconfig
lo no wireless extensions.
mint@mint ~ $
Patrik
Re: Mint na visionbook 14Wi - bez wifi a zvuku
#2 Příspěvek od Patrik »
Dik za tipy. Nahodim teda poslednu verziu mintu. Este k tomu "postupu na podobny stroj". Nevedel som o tom, ale je teda potrebne pri instalacii ponechat povodnu / vytvorit novu solo particiu pre uefi subory a teda nepouzit cely ssd len pre mint ? Predmetny notebook nema bios, len uefi bez moznosti prepnutia na legacy resp. CSM.
#3 Příspěvek od menom »
Patrik píše: 03 dub 2018, 21:49 Dik za tipy. Nahodim teda poslednu verziu mintu. Este k tomu "postupu na podobny stroj". Nevedel som o tom, ale je teda potrebne pri instalacii ponechat povodnu / vytvorit novu solo particiu pre uefi subory a teda nepouzit cely ssd len pre mint ? Predmetny notebook nema bios, len uefi bez moznosti prepnutia na legacy resp. CSM.
Takze tam das LM s prostredim Mate ? Na cinnamon je 2GB RAM malo, ak to chces komfortne pouzivat.
Ked to bude instalacia v UEFI mode, tak je dobre aby na tom harddisku bola tabulka rozdelenia GPT.
Ked das instalovat na cely harddisk, tak netreba spekulovat s particiami, budu vytvorene automaticky pocas instalacie.
A mozno by bolo najlepsie instalovat do dualbootu vedla Win ,
kym vlastne zistis co ti na tomto stroji vyhovuje.
#4 Příspěvek od Ventero1 »
Jedine xfce. Kdyz nepujde posledni Mint, tak zkus ten Gallium - dava nejvic sanci. Kdyz nepujde, tak hledat dal..
Patrik
#5 Příspěvek od Patrik »
Dik za dalsie info. Nemusi to byt vyslovene cinamon.
Viaceri tu odprucaju galium, avsak na dom. stranke sa hovori ako o podmienke podpory lagacy a ja mam len uefi. Rovnako cherry trail nie uvedeny v podpore.
https://wiki.galliumos.org/Hardware_Compatibility
Napriek tomu mozem skusit liveusb.
#6 Příspěvek od Ventero1 »
Cherry trail je tusim prebrandovany bay trail. Je mi divne, ze by Gallium nemel EFI podporu, ale nejspis mas pravdu - jsou trapny. Galium OS jsem na Umax 2v1 najel live v EFI (jinak to nejde, cca 2 roky zpet) a fungoval tam nejlepe, jde jen o spravnou pripravu flashky. Bohuzel s temihle zarizenimi byl vzdy problem - jak nainstalovat to nevim. Mozna by to technicky vyresit slo - predstavu mam, ale byla by to pekna piplacka ...
Patrik
#7 Příspěvek od Patrik »
Nazdar, nechcem sa vzdat toho mintu a kedze vzhladom na dostupnte moznosti nemozem pripojit ten ntb na internet inak ako cez wifi, chcem doinstalovat ovladace na zvuk a wifi z hdd resp. usb. Pripominam ze Mint spustam z liveusb.
Konkretne tam chcem dat bcm43.. kvoli wifi a pyta si to aj gstreamer plugin na zvuk. Ako ich teda instalovat ? Dik
Pokusy z gallium zatial nefunguju - pri bootovani - alloc magic broken.., ale to je asi skor otazka pripravy liveusb. Skusim este posledne ubuntu lts.
doplnam, ubuntu sa tvari ze bootuje ale nakoniec si pozrite foto. nic z toho zatial.
na pripravu liveusb pouzivam rufus, je tam vsak viacero moznosti ako na to a neviem ci to robim spravne.
#8 Příspěvek od Ventero1 »
Mint miva drivery na Broadcom wifi - problem je vsak zejmena v pouzitem rohrani pro komunikaci s kartou. A MX17.1 jsi zkousel?
Patrik
#9 Příspěvek od Patrik »
liveusb mint 18.3. stale bez wifi a zvuku. aspon som pripojeny na net cez smartfone - usb tethering.
System: Host: mint Kernel: 4.10.0-38-generic x86_64 (64 bit)
Desktop: Cinnamon 3.6.6 Distro: Linux Mint 18.3 Sylvia
clock speeds: max: 1840 MHz 1: 760 MHz 2: 490 MHz 3: 479 MHz
4: 608 MHz
GLX Renderer: Mesa DRI Intel HD Graphics (Cherrytrail)
GLX Version: 3.0 Mesa 17.0.7
Audio: Sound: Advanced Linux Sound Architecture v: k4.10.0-38-generic
Drives: HDD Total Size: 16.0GB (Used Error!)
ID-2: /dev/mmcblk2 model: N/A size: 7.9GB
ID-3: USB /dev/sda model: Flash_Disk size: 16.0GB
Sensors: System Temperatures: cpu: 56.0C mobo: N/A
Info: Processes: 198 Uptime: 1:06 Memory: 1029.0/1922.9MB
mint@mint ~ $
ziadna stopa ani na nete.
Patrik
#10 Příspěvek od Patrik »
Asi som si to od zaciatku skomplikoval. Podla spravcu zariadeni vo win10 su tam tieto veci:
Realtek RTL8723BS Wireless LAN 802.11n SDIO Network Adapter
Intel SST Audio Device (WDM)
Zatial neviem co s tym. Vyskusam, napisem.
Btw, od Gallium.org som dostal nezavaznu odpoved, ze iso pre bay trail by mohlo fungovat. Ale.. Vysledok v skorsom poste.
