Jedneho krasneho dna proste prestane fungovat zvuk Vyřešeno
Cyrus666
#1 Příspěvek od Cyrus666 »
Zdravim vsetkych co mi budu chciet pomoct a trapit sa so mnou.
Mint 18.3 Cinnamon x64
Uz som robil cistu instalaciu kvoli tomuto problemu, ktory sa vzdy casom vrati. Vcera prestal z nicoho nic fungovat zvuk. Predvcerom bol comp normalne vypaty, neboli ani ziadne aktualizacie, ked aj su, instalujem len 1, 2 a 3. Az potom som tam skusil hodit aj novy kernel, no bez zmeny.
Mam dualboot s 10.
Taktiez som skusal reinstalovat komplet pulse audio, no ma ma to na salame, pouzivam este Plantronics BT 600 zvukovku obcas k sluchatkam,
no momentalne neni pripojena.
Poradte prosim
Pridavam screeny a vypis:
https://drive.google.com/open?id=1b4EI-OwgDTcMNjcP4mvf3Lb2-txx76UW
https://drive.google.com/open?id=19JwNV79c1EN65NBFmJ8wdSOViwQz_A-t
https://drive.google.com/open?id=1RoS8Zy5KKOuf9kVk76w1PSMP0sy5eGc4
https://drive.google.com/open?id=1ssupRmSe8OMVzg1qVmtV-ERklImwPl9f
00:00.0 Host bridge: Intel Corporation Sky Lake Host Bridge/DRAM Registers (rev 07)
00:01.0 PCI bridge: Intel Corporation Sky Lake PCIe Controller (x16) (rev 07)
00:08.0 System peripheral: Intel Corporation Sky Lake Gaussian Mixture Model
00:14.0 USB controller: Intel Corporation Sunrise Point-H USB 3.0 xHCI Controller (rev 31)
00:14.2 Signal processing controller: Intel Corporation Sunrise Point-H Thermal subsystem (rev 31)
00:16.0 Communication controller: Intel Corporation Sunrise Point-H CSME HECI #1 (rev 31)
00:17.0 SATA controller: Intel Corporation Sunrise Point-H SATA controller [AHCI mode] (rev 31)
00:1c.0 PCI bridge: Intel Corporation Sunrise Point-H PCI Express Root Port #1 (rev f1)
00:1c.2 PCI bridge: Intel Corporation Sunrise Point-H PCI Express Root Port #3 (rev f1)
00:1d.0 PCI bridge: Intel Corporation Sunrise Point-H PCI Express Root Port #9 (rev f1)
00:1d.2 PCI bridge: Intel Corporation Sunrise Point-H PCI Express Root Port #11 (rev f1)
00:1d.3 PCI bridge: Intel Corporation Sunrise Point-H PCI Express Root Port #12 (rev f1)
00:1f.0 ISA bridge: Intel Corporation Sunrise Point-H LPC Controller (rev 31)
00:1f.2 Memory controller: Intel Corporation Sunrise Point-H PMC (rev 31)
00:1f.3 Audio device: Intel Corporation Sunrise Point-H HD Audio (rev 31)
00:1f.4 SMBus: Intel Corporation Sunrise Point-H SMBus (rev 31)
01:00.0 VGA compatible controller: NVIDIA Corporation GM200 [GeForce GTX 980 Ti] (rev a1)
01:00.1 Audio device: NVIDIA Corporation Device 0fb0 (rev a1)
03:00.0 USB controller: ASMedia Technology Inc. ASM1142 USB 3.1 Host Controller
05:00.0 PCI bridge: ASMedia Technology Inc. ASM1083/1085 PCIe to PCI Bridge (rev 03)
07:00.0 Ethernet controller: Qualcomm Atheros Killer E2400 Gigabit Ethernet Controller (rev 10)
Re: Jedneho krasneho dna proste prestane fungovat zvuk
Cyrus666 píše:Taktiez som skusal reinstalovat komplet pulse audio, no ma ma to na salame, pouzivam este Plantronics BT 600 zvukovku obcas k sluchatkam,
Nebude to mat suvis, ze ked pouzivas zvukovku co momentalne neni pripojena, tak sa zmenia
nastavenia a ked uz neni pripojena tak ju nenajde ?
Mohlo by pomoct doinstalovat pavucontrol a tam nastavit.
Mozno sa treba s nastavenim viac pohrat...
Cyrus666
#3 Příspěvek od Cyrus666 »
pavucontrol mam nainstalovany, 4 screen, ani mi ho nespusti
Cyrus666 píše: 08 dub 2018, 14:42 pavucontrol mam nainstalovany, 4 screen, ani mi ho nespusti
Mozno to treba skusit tak aby v tom momente neboli spustene ziadne ine programy v ktorych sa da nastavovat audio.
Mozno treba vyskusat najprv zadat ten prikaz v Terminali:
start-pulseaudio-x11
Alebo so sudo:
sudo start-pulseaudio-x11
A potom spomenuty pavucontrol spustit a nastavit.
Cyrus666
#5 Příspěvek od Cyrus666 »
to som tiez skusal vypise:
Zlyhanie pripojenia: Spojenie odmietnuté
Operácia pa_context_connect() zlyhala: Spojenie odmietnuté
Cyrus666
#6 Příspěvek od Cyrus666 »
pulseaudio --start
E: [pulseaudio] main.c: Daemon startup failed.
ked dam:
pulseaudio -k
E: [pulseaudio] main.c: Failed to kill daemon: No such process
Cyrus666
#7 Příspěvek od Cyrus666 »
ok mensi update:
vymazal som .config/pulse, restart, uz vidim ikonu zvuku, aj ukazuje HW, ale stale je to ticho
#8 Příspěvek od menom »
Cyrus666 píše: 08 dub 2018, 18:13 ok mensi update:
Skusil si zmenit nastavenie ako pisala Lombardo ?
Preinstalovat aj s odstranenim konfiguracnych suborov ?
To je dolezite.
Cyrus666
#9 Příspěvek od Cyrus666 »
ano spravil som presne vsetko ako bolo napisane, uz to ide, po tom vymazani pulse v configu a po restarte trebalo sa este pohrat v pulse volume control a uz vsetko slape, diky vsetkym
#10 Příspěvek od menom »
Ked je to vyriesene, tak pre istotu zacitujem spravne riesenie, aby sa zachovalo pre buducnost:
lombardo1981 píše: 08 dub 2018, 17:53
Cyrus666 píše:Operácia pa_context_connect() zlyhala: Spojenie odmietnuté
Toto by malo indikovať problém s autospawn.
Potrebný konfiguračný súbor by sa mal nachádzať (nepoužívam LM) v /etc/pulse/client.conf. Nachádza sa tam autospawn= . Napríklad:
autospawn=yes
Skús to zmeniť na:
autospawn=no
Alebo riadok zakomentovať.
Možno bude potrebné predtým úplne preinštalovať pulseaudio:
sudo apt-get --purge --reinstall install pulseaudio
Potom už len reštartovať. Alebo by pomohlo aj manuálne reštartovanie pulseaudio:
pulseaudio --start
