HP laserJet p1005
leondealer
Re: HP laserJet p1005
#11 Příspěvek od leondealer » 17 dub 2019, 14:47
tak aktualizace hotova, ohledne hplip tam nic nebylo, ale po resetu a pripojeni tiskarny se me obevila ikona HP a byla zde moznost diagnostiky, kterou jsem vyuzil, a tohle je report z toho
[quote]
HP Linux Imaging and Printing System (ver. 3.19.3)
Self Diagnse Utility and Healing Utility ver. 1.0
Copyright (c) 2001-18 HP Development Company, LP
This software comes with ABSOLUTELY NO WARRANTY.
This is free software, and you are welcome to distribute it
under certain conditions. See COPYING file for more details.
Checking for Deprecated items....
No Deprecated items are found
Checking for HPLIP updates....
HPLIP upgrade latest version ver. 1.0
Latest version of HPLIP is already installed.
Checking for Dependencies....
| SYSTEM INFO |
 Kernel: 4.15.0-47-generic #50-Ubuntu SMP Wed Mar 13 10:44:52 UTC 2019 GNU/Linux
 Host: leon-NTB
 Proc: 4.15.0-47-generic #50-Ubuntu SMP Wed Mar 13 10:44:52 UTC 2019 GNU/Linux
 Distribution: 22 19
 Bitness: 64 bit
| HPLIP CONFIGURATION |
HPLIP-Version: HPLIP 3.19.3
HPLIP-Home: /usr/share/hplip
HPLIP-Installation: Auto installation is supported for linuxmint distro  19 version
Current contents of '/etc/hp/hplip.conf' file:
# hplip.conf.  Generated from hplip.conf.in by configure.
[hplip]
version=3.19.3
[dirs]
home=/usr/share/hplip
run=/var/run
ppd=/usr/share/ppd/HP
ppdbase=/usr/share/ppd
doc=/usr/share/doc/hplip-3.19.3
html=/usr/share/doc/hplip-3.19.3
icon=/usr/share/applications
cupsbackend=/usr/lib/cups/backend
cupsfilter=/usr/lib/cups/filter
drv=/usr/share/cups/drv/hp
bin=/usr/bin
apparmor=/etc/apparmor.d
# Following values are determined at configure time and cannot be changed.
[configure]
network-build=yes
libusb01-build=no
pp-build=no
gui-build=yes
scanner-build=yes
fax-build=yes
dbus-build=yes
cups11-build=no
doc-build=yes
shadow-build=no
hpijs-install=no
foomatic-drv-install=no
foomatic-ppd-install=no
foomatic-rip-hplip-install=no
hpcups-install=yes
cups-drv-install=yes
cups-ppd-install=no
internal-tag=3.19.3
restricted-build=no
ui-toolkit=qt4
qt3=no
qt4=yes
qt5=no
policy-kit=no
lite-build=no
udev_sysfs_rules=no
hpcups-only-build=no
hpijs-only-build=no
apparmor_build=yes
class-driver=no
Current contents of '/var/lib/hp/hplip.state' file:
Plugins are not installed. Could not access file: Adresář nebo soubor neexistuje
Current contents of '~/.hplip/hplip.conf' file:
[upgrade]
notify_upgrade = true
last_upgraded_time = 1555355122
pending_upgrade_time = 0
latest_available_version = 3.17.10
[settings]
systray_visible = 0
systray_messages = 0
[last_used]
device_uri = hp:/usb/hp_LaserJet_1000?serial=0
printer_name = LaserJet-1000
working_dir = /home/leon/Sta\x17e\x65n\xe9/hplip-3.19.3.run
[commands]
scan = /usr/bin/xsane -V %SANE_URI%
[refresh]
rate = 30
enable = true
type = 1
[polling]
enable = false
interval = 5
device_list =
[fax]
voice_phone =
email_address =
[installation]
date_time = 17.4.2019 14:39:33
version = 3.19.3
 <Package-name>        <Package-Desc>      <Required/Optional> <Min-Version> <Installed-Version> <Status>   <Comment>
| COMPILEDEP |
 gcc                  gcc - GNU Project C and C++ Compiler                         REQUIRED        -               7.3.0           OK         -
 make                 make - GNU make utility to maintain groups of programs       REQUIRED        3.0             4.1             OK         -
 libtool              libtool - Library building support services                  REQUIRED        -               2.4.6           OK         -
| General Dependencies |
 libcrypto            libcrypto - OpenSSL cryptographic library                    REQUIRED        -               1.1.0           OK         -
 python-xml           Python XML libraries                                         REQUIRED        -               2.2.5           OK         -
 libnetsnmp-devel     libnetsnmp-devel - SNMP networking library development files REQUIRED        5.0.9           5.7.3           OK         -
 sane-devel           SANE - Scanning library development files                    REQUIRED        -               -               OK         -
 pil                  PIL - Python Imaging Library (required for commandline scanning with hp-scan) OPTIONAL        -               1.1.7           OK         -
 pyqt4-dbus           PyQt 4 DBus - DBus Support for PyQt4                         REQUIRED        4.0             4.12.1          OK         -
 libpthread           libpthread - POSIX threads library                           REQUIRED        -               2.27            OK         -
 python-devel         Python devel - Python development files                      REQUIRED        2.2             2.7.15          OK         -
 cups-devel           CUPS devel- Common Unix Printing System development files    REQUIRED        -               2.2.7           OK         -
 python-dbus          Python DBus - Python bindings for DBus                       REQUIRED        0.80.0          1.2.6           OK         -
 cups-ddk             CUPS DDK - CUPS driver development kit                       OPTIONAL        -               -               OK         -
 reportlab            Reportlab - PDF library for Python                           OPTIONAL        2.0             3.4.0           OK         -
 pyqt4                PyQt 4- Qt interface for Python (for Qt version 4.x)         REQUIRED        4.0             4.12.1          OK         -
 libusb               libusb - USB library                                         REQUIRED        -               1.0             OK         -
 cups-image           CUPS image - CUPS image development files                    REQUIRED        -               2.2.7           OK         -
 python2X             Python 2.2 or greater - Python programming language          REQUIRED        2.2             2.7.15          OK         -
 python-notify        Python libnotify - Python bindings for the libnotify Desktop notifications OPTIONAL        -               -               OK         -
 libjpeg              libjpeg - JPEG library                                       REQUIRED        -               -               OK         -
 sane                 SANE - Scanning library                                      REQUIRED        -               -               OK         -
| Scan Configuration |
 scanext              Scan-SANE-Extension                                          REQUIRED        -               3.19.3          OK         -
 hpaio                HPLIP-SANE-Backend                                           REQUIRED        -               3.19.3          OK         'hpaio found in /etc/sane.d/dll.conf'
| External Dependencies |
 gs                   GhostScript - PostScript and PDF language interpreter and previewer REQUIRED        7.05            9.26            OK         -
 scanimage            scanimage - Shell scanning program                           OPTIONAL        1.0             1.0.27          OK         -
 cups                 CUPS - Common Unix Printing System                           REQUIRED        1.1             2.2.7           OK         'CUPS Scheduler is running'
 network              network -wget                                                OPTIONAL        -               1.19.4          OK         -
 policykit            PolicyKit - Administrative policy framework                  OPTIONAL        -               0.105           OK         -
 xsane                xsane - Graphical scanner frontend for SANE                  OPTIONAL        0.9             0.999           OK         -
 dbus                 DBus - Message bus system                                    REQUIRED        -               1.12.2          OK         -
 avahi-utils          avahi-utils                                                  OPTIONAL        -               0.7             OK         -
| Python Extentions |
 hpmudext             IO-Extension                                                 REQUIRED        -               3.19.3          OK         -
 cupsext              CUPS-Extension                                               REQUIRED        -               3.19.3          OK         -
| DISCOVERED SCANNER DEVICES |
No Scanner found.
| DISCOVERED USB DEVICES |
  Device URI                        Model
  hp:/usb/hp_LaserJet_1000?serial=  HP LaserJet 1000
  0
| INSTALLED CUPS PRINTER QUEUES |
LaserJet-1000
Type: Printer
Device URI: hp:/usb/hp_LaserJet_1000?serial=0
PPD: /etc/cups/ppd/LaserJet-1000.ppd
warning: Failed to read /etc/cups/ppd/LaserJet-1000.ppd ppd file
PPD Description:
Printer status: printer LaserJet-1000 is idle.  enabled since St 17. dubna 2019, 14:39:1ready to print
error: Required plug-in status: Not installed
Communication status: Good
LaserJet-2550
Type: Unknown
Device URI: usb://HP/color%20LaserJet%202550%20series?serial=00CNHHB09055
PPD: /etc/cups/ppd/LaserJet-2550.ppd
warning: Failed to read /etc/cups/ppd/LaserJet-2550.ppd ppd file
PPD Description:
Printer status: printer LaserJet-2550 is idle.  enabled since Út 26. března 2019, 19:27:45 CET
warning: Printer is not HPLIP installed. Printers must use the hp: or hpfax: CUPS backend for HP-Devices.
| PERMISSION |
USB             LaserJet-1000                  Required        -        -        OK       Node:'/dev/bus/usb/001/007' Perm:'  root  lp rw- rw- rw- rw- r--'
Checking Permissions....
Checking for Configured Queues....
warning: Fail to read ppd=/etc/cups/ppd/LaserJet-1000.ppd file
warning: Insufficient permission to access file /etc/cups/ppd/LaserJet-1000.ppd
warning: Could not complete Queue(s) configuration check
Checking for HP Properitery Plugin's....
Plugin's are missing. Press 'y' to install the plugin(y=yes*, n=no):y
Plugin Download and Install Utility ver. 2.1
(Note: Defaults for each question are maked with a '*'. Press <enter> to accept the default.)
| PLUG-IN INSTALLATION FOR HPLIP 3.19.3 |
  Option      Description
  d           Download plug-in from HP (recommended)
  p           Specify a path to the plug-in (advanced)
  q           Quit hp-plugin (skip installation)
Enter option (d=download*, p=specify path, q=quit) ? d
| DOWNLOAD PLUGIN |
Checking for network connection...
Downloading plug-in from:
Downloading plug-in: [\                                   ] 0% Receiving digital keys: /usr/bin/gpg --homedir /home/leon/.hplip/.gnupg --no-permission-warning --keyserver pgp.mit.edu --recv-keys 0x4ABA2F66DBD5A95894910E0673D770CDA59047B9
| INSTALLING PLUG-IN |
Creating directory plugin_tmp
Verifying archive integrity... All good.
Uncompressing HPLIP 3.19.3 Plugin Self Extracting Archive..............................................................
Plugin Installer ver. 3.0
Plug-in version: 3.19.3
Installed HPLIP version: 3.19.3
Number of files to install: 64
You must agree to the license terms before installing the plug-in:
LICENSE TERMS FOR HP Linux Imaging and Printing (HPLIP) Driver Plug-in
These License Terms govern your Use of the HPLIP Driver Plug-in Software (the
"Software"). USE OF THE SOFTWARE INCLUDING, WITHOUT LIMITATION, ANY
DOCUMENTATION, IS SUBJECT TO THESE LICENSE TERMS AND THE APPLICABLE AS-IS
WARRANTY STATEMENT. BY DOWNLOADING AND INSTALLING THE SOFTWARE, YOU ARE AGREEING
TO BE BOUND BY THESE TERMS. IF YOU DO NOT AGREE TO ALL OF THESE TERMS, DO NOT
DOWNLOAD AND INSTALL THE SOFTWARE ON YOUR SYSTEM.
1. License Grant. HP grants you a license to Use one copy of the Software with
HP printing products only. "Use" includes using, storing, loading, installing,
executing, and displaying the Software. You may not modify the Software or
disable any licensing or control features of the Software.
2. Ownership. The Software is owned and copyrighted by HP or its third party
suppliers. Your license confers no title to, or ownership in, the Software and
is not a sale of any rights in the Software. HP's third party suppliers may
protect their rights in the Software in the event of any violation of these
license terms.
3. Copies and Adaptations. You may only make copies or adaptations of the
Software for archival purposes or when copying or adaptation is an essential
step in the authorized Use of the Software. You must reproduce all copyright
notices in the original Software on all copies or adaptations. You may not copy
the Software onto any public network.
4. No Disassembly. You may not Disassemble the Software unless HP's prior
written consent is obtained. "Disassemble" includes disassembling, decompiling,
decrypting, and reverse engineering. In some jurisdictions, HP's consent may not
be required for limited Disassembly. Upon request, you will provide HP with
reasonably detailed information regarding any Disassembly.
5. No Transfer. You may not assign, sublicense or otherwise transfer all or any
part of these License Terms or the Software.
6. Termination. HP may terminate your license, upon notice, for failure to
comply with any of these License Terms. Upon termination, you must immediately
destroy the Software, together with all copies, adaptations and merged portions
in any form.
7. Export Requirements. You may not export or re-export the Software or any copy
or adaptation in violation of any applicable laws or regulations.
8. U.S. Government Restricted Rights. The Software has been developed entirely
at private expense. It is delivered and licensed, as defined in any applicable
DFARS, FARS, or other equivalent federal agency regulation or contract clause,
as either "commercial computer software" or "restricted computer software",
whichever is applicable. You have only those rights provided for such Software
by the applicable clause or regulation or by these License Terms.
9. DISCLAIMER OF WARRANTIES. TO THE MAXIMUM EXTENT PERMITTED BY APPLICABLE LAW,
HP AND ITS SUPPLIERS PROVIDE THE SOFTWARE "AS IS" AND WITH ALL FAULTS, AND
HEREBY DISCLAIM ALL OTHER WARRANTIES AND CONDITIONS, EITHER EXPRESS, IMPLIED, OR
STATUTORY, INCLUDING, BUT NOT LIMITED TO, WARRANTIES OF TITLE AND
NON-INFRINGEMENT, ANY IMPLIED WARRANTIES, DUTIES OR CONDITIONS OF
MERCHANTABILITY, OF FITNESS FOR A PARTICULAR PURPOSE, AND OF LACK OF VIRUSES ALL
WITH REGARD TO THE SOFTWARE. Some states/jurisdictions do not allow exclusion of
implied warranties or limitations on the duration of implied warranties, so the
above disclaimer may not apply to you in its entirety.
10. LIMITATION OF LIABILITY. Notwithstanding any damages that you might incur,
the entire liability of HP and any of its suppliers under any provision of this
agreement and your exclusive remedy for all of the foregoing shall be limited to
the greater of the amount actually paid by you separately for the Software or
U.S. $5.00. TO THE MAXIMUM EXTENT PERMITTED BY APPLICABLE LAW, IN NO EVENT SHALL
HP OR ITS SUPPLIERS BE LIABLE FOR ANY SPECIAL, INCIDENTAL,
INDIRECT, OR CONSEQUENTIAL DAMAGES WHATSOEVER (INCLUDING, BUT NOT LIMITED TO,
DAMAGES FOR LOSS OF PROFITS OR CONFIDENTIAL OR OTHER INFORMATION, FOR BUSINESS
INTERRUPTION, FOR PERSONAL INJURY, FOR LOSS OF PRIVACY ARISING OUT OF OR IN ANY
WAY RELATED TO THE USE OF OR INABILITY TO USE THE SOFTWARE, OR OTHERWISE IN
CONNECTION WITH ANY PROVISION OF THIS AGREEMENT, EVEN IF HP OR ANY SUPPLIER HAS
BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES AND EVEN IF THE REMEDY FAILS OF
ITS ESSENTIAL PURPOSE. Some states/jurisdictions do not allow the exclusion or
limitation of incidental or consequential damages, so the above limitation or
exclusion may not apply to you.
Do you accept the license terms for the plug-in (y=yes*, n=no, q=quit) ? y
Please enter the sudoer (leon)'s password:
error: Password incorrect. 2 attempt(s) left.
Plugin installation failed
error: Plugin installation failed
Done.
| DOWNLOADING FIRMWARE |
Downloading firmware to device hp:/usb/hp_LaserJet_1000?serial=0...
Firmware download successful.
Done.
Diagnose completed...
More information on Troubleshooting,How-To's and Support is available on http://hplipopensource.com/hplip-web/index.html
Please close this terminal manually.
[/quote]
Naposledy upravil(a) leondealer dne 17 dub 2019, 22:19, celkem upraveno 1 x.
leondealer
#12 Příspěvek od leondealer » 17 dub 2019, 14:49
chci se zeptat, nepomohlo by třeba odinstalovat vše od té tiskárny a zkusit no znovanainstalovat, třeba došlo při stahování k nějaké chybě a teď mě to jen provází.
EDIT: pokud ano, poprosím o postup :)
Guru Mintu
#13 Příspěvek od juhele2014 » 17 dub 2019, 19:03
To se čte jak detektivka, je to napínavý jak kšandy ... :roll: Ale - vidim, že je problém se čtením ppd souborů v adresáři /etc/cups/ppd/ Trochu jsem hledal a našel tady https://askubuntu.com/questions/778970/ ... d-ppd-file tohle I have an HP printer PhotoSmart and had the same problem... I went into /etc/cups/ppd/ and modified the permission of my ppd file (root permission needed): It was Owner Root Read and write - Group lp Read only - Other No right I changed that last permission into Read only And it did the trick so far! Good luck! Takže v adresáři ppd změnit práva, a obecně, jestli v tom adresáři něco vůbec je ... :idea:
leondealer
#14 Příspěvek od leondealer » 17 dub 2019, 21:57
Tak jsem to zkusil celé od začátku, reinstaloval jsem celý mint (zkušenosti z Windows :) ) a ejhle
[quote]zdenek@zdenek-NTB:~$ hp-setup
HP Linux Imaging and Printing System (ver. 3.17.10)
Printer/Fax Setup Utility ver. 9.0
Copyright (c) 2001-15 HP Development Company, LP
warning: GUI Modules PyQt4 and PyQt5 are not installed
error: hp-setup requires GUI support (try running with --qt3). Also, try using interactive (-i) mode.
zdenek@zdenek-NTB:~$ hp-setup -i
| SELECT CONNECTION (I/O) TYPE |
  Num       Connection  Description
            Type
  0*        usb         Universal Serial Bus (USB)
  1         net         Network/Ethernet/Wireless (direct connection or JetDirect)
  2         par         Parallel Port (LPT:)
Enter number 0...2 for connection type (q=quit, enter=usb*) ?
Using connection type: usb
Setting up device: hp:/usb/hp_LaserJet_1000?serial=0
| PLUG-IN INSTALLATION |
| PLUG-IN INSTALLATION FOR HPLIP 3.17.10 |
  Option      Description
| DOWNLOAD PLUGIN |
Downloading plug-in: [\                                   ] 0% Receiving digital keys: /usr/bin/gpg --homedir /home/zdenek/.hplip/.gnupg --no-permission-warning --keyserver pgp.mit.edu --recv-keys 0x4ABA2F66DBD5A95894910E0673D770CDA59047B9
Uncompressing HPLIP 3.17.10 Plugin Self Extracting Archive................................................
Plug-in version: 3.17.10
Installed HPLIP version: 3.17.10
Number of files to install: 42
license terms.
in any form.
Please enter the sudoer (zdenek)'s password:
Done.
Done.
| PRINT QUEUE SETUP |
Please enter a name for this print queue (m=use model name:'hp_LaserJet_1000'*, q=quit) ?m
Using queue name: hp_LaserJet_1000
Locating PPD file... Please wait.
Found PPD file: drv:///hpcups.drv/hp-laserjet_1000.ppd
Description:
Note: The model number may vary slightly from the actual model number on the device.
Does this PPD file appear to be the correct one (y=yes*, n=no, q=quit) ? y
Enter a location description for this printer (q=quit) ?q
OK, done.
[/quote]
tiskárnu jsem ještě nezkoušel, na to už dneska asi neseberu odvahu :D
i když možná...
EDIT: hotovo, tisknu
Guru Mintu
#15 Příspěvek od juhele2014 » 17 dub 2019, 23:02
No vidíš, že to jde ... ;) Je to jiná verze ovladačů, ale co je to za mint? Cinnamon?
leondealer
#16 Příspěvek od leondealer » 18 dub 2019, 03:42
Ano instaloval jsem Mint 19 cinnamon
