PS: Mám AMD Ryzen 2200G (Raven Ridge / socket AM4).
PPS: Našel jsem pár obdobných dotazů, ale ne jasné řešení. Byly tam mj. výzvy k provedení následujících příkazů ...
~$ inxi -Fxz
System:
Host: ryzen2200g Kernel: 4.19.0-9-amd64 x86_64 bits: 64 compiler: gcc
v: 8.3.0 Desktop: Cinnamon 4.4.8 Distro: LMDE 4 Debbie
base: Debian 10.2 buster
Machine:
Type: Desktop Mobo: ASUSTeK model: ROG STRIX B350-F GAMING v: Rev X.0x
serial: <filter> UEFI [Legacy]: American Megatrends v: 4207
date: 12/07/2018
CPU:
Topology: Quad Core model: AMD Ryzen 3 2200G with Radeon Vega Graphics
bits: 64 type: MCP arch: Zen L2 cache: 2048 KiB
flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
bogomips: 27946
Speed: 1476 MHz min/max: 1600/3500 MHz Core speeds (MHz): 1: 1477 2: 3689
3: 1477 4: 1477
Graphics:
Device-1: AMD Raven Ridge [Radeon Vega Series / Radeon Vega Mobile Series]
vendor: ASUSTeK driver: amdgpu v: kernel bus ID: 09:00.0
Display: x11 server: X.Org 1.20.4 driver: amdgpu,ati
unloaded: fbdev,modesetting,vesa resolution: 1920x1080~60Hz
OpenGL: renderer: AMD RAVEN (DRM 3.27.0 4.19.0-9-amd64 LLVM 7.0.1)
v: 4.5 Mesa 18.3.6 direct render: Yes
Audio:
Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus ID: 09:00.1
Device-2: AMD Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus ID: 09:00.6
Sound Server: ALSA v: k4.19.0-9-amd64
Network:
Device-1: Intel I211 Gigabit Network vendor: ASUSTeK driver: igb
v: 5.4.0-k port: e000 bus ID: 03:00.0
IF: enp3s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Drives:
Local Storage: total: 11.41 TiB used: 3.79 TiB (33.2%)
ID-1: /dev/nvme0n1 vendor: Samsung model: SSD 970 PRO 512GB
ID-2: /dev/sda vendor: Seagate model: ST8000VX004-2M1101 size: 7.28 TiB
ID-3: /dev/sdc vendor: Seagate model: ST4000VX007-2DT166 size: 3.64 TiB
ID-4: /dev/sdd type: USB vendor: Corsair model: Voyager 3.0
Partition:
ID-1: / size: 37.30 GiB used: 13.54 GiB (36.3%) fs: ext4
dev: /dev/nvme0n1p1
ID-2: /home size: 7.22 TiB used: 3.75 TiB (51.9%) fs: ext4 dev: /dev/sda1
ID-3: swap-1 size: 20.00 GiB used: 0 KiB (0.0%) fs: swap
dev: /dev/nvme0n1p3
Sensors:
System Temperatures: cpu: 33.4 C mobo: N/A gpu: amdgpu temp: 33 C
Fan Speeds (RPM): cpu: 0
Info:
Processes: 218 Uptime: 35m Memory: 13.69 GiB used: 3.59 GiB (26.2%)
Init: systemd runlevel: 15 Compilers: gcc: 8.3.0 Shell: bash v: 5.0.3
inxi: 3.0.32Kód: Vybrat vše
~$ lsusb -t
/: Bus 06.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/1p, 10000M
/: Bus 05.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/1p, 480M
/: Bus 04.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/4p, 10000M
/: Bus 03.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/4p, 480M
|__ Port 2: Dev 2, If 0, Class=Human Interface Device, Driver=usbhid, 1.5M
|__ Port 3: Dev 3, If 0, Class=Human Interface Device, Driver=usbhid, 1.5M
/: Bus 02.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/4p, 10000M
|__ Port 3: Dev 2, If 0, Class=Mass Storage, Driver=usb-storage, 5000M
/: Bus 01.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/10p, 480M
|__ Port 7: Dev 2, If 0, Class=Mass Storage, Driver=usb-storage, 480MKód: Vybrat vše
~$ dmesg | grep /input/
[ 1.307917] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0
[ 1.309063] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input1
[ 1.935003] input: DELL Dell USB Entry Keyboard as /devices/pci0000:00/0000:00:08.1/0000:09:00.3/usb3/3-2/3-2:1.0/0003:413C:2107.0001/input/input2
[ 2.258282] input: Microsoft Microsoft® Comfort Mouse 4500 as /devices/pci0000:00/0000:00:08.1/0000:09:00.3/usb3/3-3/3-3:1.0/0003:045E:076C.0002/input/input3
[ 5.429578] input: PC Speaker as /devices/platform/pcspkr/input/input4
[ 5.439350] input: Eee PC WMI hotkeys as /devices/platform/eeepc-wmi/input/input7
[ 6.418676] input: BRLTTY 5.6 Linux Screen Driver Keyboard as /devices/virtual/input/input15
