[Vyřešeno]Star Wars: The Old Republic - grafické anomálie
migrena6
#1 Příspěvek od migrena6 »
Ahojte. Potreboval by som poradiť. Snažím sa hrať Star Wars: The Old Republic, ale vyskytujú sa tam grafické anomálie, ako je vidno na priložených obrázkoch.
Zostava:
System:    Host: 100pc Kernel: 5.4.0-48-generic x86_64 bits: 64 Desktop: Xfce 4.14.2 Distro: Linux Mint 20 Ulyana
Machine:   Type: Laptop System: LENOVO product: 81LL v: IdeaPad L340-17IRH Gaming serial: <superuser/root required>
           Mobo: LENOVO model: LNVNB161216 v: NO DPK serial: <superuser/root required> UEFI: LENOVO v: BGCN29WW
           date: 02/10/2020
Battery:   ID-1: BAT0 charge: 43.7 Wh condition: 43.7/45.0 Wh (97%)
CPU:       Topology: Quad Core model: Intel Core i5-9300HF bits: 64 type: MT MCP L2 cache: 8192 KiB
           Speed: 900 MHz min/max: 800/4100 MHz Core speeds (MHz): 1: 900 2: 900 3: 900 4: 900 5: 900 6: 900 7: 900 8: 900
Graphics:  Device-1: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q] driver: nvidia v: 450.66
           Display: x11 server: X.Org 1.20.8 driver: nvidia unloaded: fbdev,modesetting,nouveau,vesa
           resolution: 1920x1080~60Hz, 1920x1080~60Hz
           OpenGL: renderer: GeForce GTX 1650/PCIe/SSE2 v: 4.6.0 NVIDIA 450.66
Audio:     Device-1: Intel Cannon Lake PCH cAVS driver: snd_hda_intel
           Device-2: NVIDIA driver: snd_hda_intel
           Sound Server: ALSA v: k5.4.0-48-generic
Network:   Device-1: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter driver: ath10k_pci
           IF: wlp7s0 state: up mac:
           Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet driver: r8169
           IF: enp8s0 state: down mac:
           Device-3: Qualcomm Atheros type: USB driver: btusb
Drives:    Local Storage: total: 953.87 GiB used: 210.67 GiB (22.1%)
           ID-1: /dev/nvme0n1 vendor: Micron model: MTFDHBA1T0TCK size: 953.87 GiB
Partition: ID-1: / size: 375.87 GiB used: 210.65 GiB (56.0%) fs: ext4 dev: /dev/nvme0n1p2
           ID-2: swap-1 size: 8.00 GiB used: 6.0 MiB (0.1%) fs: swap dev: /dev/nvme0n1p1
Sensors:   System Temperatures: cpu: 47.0 C mobo: N/A gpu: nvidia temp: 39 C
           Fan Speeds (RPM): N/A
Info:      Processes: 282 Uptime: 3d 5h 25m Memory: 15.56 GiB used: 2.03 GiB (13.1%) Shell: bash inxi: 3.0.38
Na prvom obrázku (sw2) je vidno záber, kde deformácie nie je vidno. Na druhom obrázku (sw3) je vidno čiara v smere pohľadu postavy- vždy smeruje v smere pohľadu postavy (pri otočení postavy sa otočí aj čiara). Na poslednom obrázku (sw5) vidno objekty vo vzduchu, hoci by mali byť na zemi (vidno čiary, ktoré prepojujú objekty vo vzduchu so zemou).
Aktualizácia ovládača grafiky nepomohla (inštalované cez správcu propr. ovl.) a problém sa objavuje aj pri najnižších detailoch, aj pri nastavení na ultra.
Prosím Vás, v čom by mohol byť problém?
Ešte jedna zaujímavosť. Po zadaní prihlasovacích údajov sa objaví chyba s backtrace, ktorý tiež prikladám, ale hra samotná sa spustí.
Naposledy upravil(a) migrena6 dne 08 říj 2020, 15:57, celkem upraveno 1 x.
migrena6
Re: Star Wars: The Old Republic - grafické anomálie
#2 Příspěvek od migrena6 »
V predošlom príspevku sa mi nepodarilo vložiť backtrace, tak ho prikladám dodatočne.
backtrace.txt
(2.71 KiB) Staženo 687 x
#3 Příspěvek od juhele2014 »
Jako první věc bych dal novej kernel. Asi by šlo i snížit rozlišení, na noťasu to nejsou žádný herní orgie, tam se to snese. Možná i celkový abgrejd LM, ale na to opatrně. Nějaký info je i tady : https://appdb.winehq.org/objectManager. ... &iId=13553
migrena6
#4 Příspěvek od migrena6 »
Vďaka za odpoveď.Tak kernel som už upgradoval niekoľkokrát, aj keď je pravda, že iba cez správcu aktualizácií, nie manuálne. Mam skúsiť úplne najnovšie jadro?
Čo sa týka detailov, problém je aj pri najnižších, aj pri najvyšších detailoch (pri najvyšších detailoch sú problémy menšie).
Zarazila ma veta na winehq:
SWTOR_FIX is still required in order to make the swtor.exe to launch
Mne to funguje aj bez toho, akurát sú tam tie deformácie. Pritom donedávna išla tá hra úplne bez problémov.
#5 Příspěvek od menom »
Ked som sem nakukol prvy krat, tak len zbezne a videl som ten notebook co je v podpise.
Az teraz druhy krat vidim, ze mas super vykonny notebook.
No neviem ci sa linuxovy vyvojari pohadali s vyvojarmi nvidia a mozno aj s intelakmi, ale v poslednom case je vsetko akoby v takom
surovom stave, (myslim aj problemy s nvidia aj intel tearing) ze dorob si sam.
Ja som s nvidia zaznamenal nejake problemy v prehliadaci (tearing na dost vykonnej karte) a da sa tomu pomoct
zapnutim FullCompositionPipeline.
Nvidia settings neuklada nastavenia po vypnuti pc.
Treba ist do Menu > Nastavenia > Sedenie a spustanie na karte Autospustenie aplikacie
vlavo dole Pridat
Nazov hocijaky napriklad: Nvidiafix
Popis napriklad: Nvidiafix
Prikaz:
nvidia-settings --assign CurrentMetaMode="nvidia-auto-select +0+0 { ForceFullCompositionPipeline = On }"
Kopirovat cely prikaz a OK a Zatvorit.
Po restarte by malo byt lepsie ....
migrena6
#6 Příspěvek od migrena6 »
Žiaľ, nepomohlo. Inak, inde problém nepozorujem s výnimkou flash hry v Google Chrome, ktorá neskutočne seká a v Opere v tejto flash hre chýbajú ovládacie prvky, ale to neviem či je problém grafiky.
Rozmýšľam, že skúsim ešte nejakú inú hru, či aj tam bude nejaký problém.
//Edit: Star trek Online vyzerá, že funguje bez deformácií, ale problém bude asi väčší, ako som si myslel. Pri spustení wine a prepnutí sa do okna SMplayera na vide mi zmizlo okno prehrávača. Film bežal, okno bolo na lište zobrazené, ale nedalo sa naň vôbec prepnúť, aj kečď som dal vždy navrchu. Párkrát sa mi dokonca stalo, že pravdepodobne padol celý zobrazovací manžér- ostala iba čierna obrazovka, priočom do konzoly 1 sa mi podarilo prihlásiť.
Zabudol som spomeúť, že používam aj externý monitor pripojený cez HDMI. Ale Star Wars som skúšal aj bez zapojeného monitora a bolo to to isté.
Preventívne som vypol aj kompozítor, ale žiadna zmena.
migrena6
#7 Příspěvek od migrena6 »
Tá hra je nainštalovaná cez playonlinux, dokonca je pre ňu v POL vytvorený skript a donedávna bez problémov bežala.
Ale je pravda, že inú verziu wine som neskúšal.
Video pamäť je nastavená na 4096MB. Testované na wine 5.12.
//Edit: Na wine 4.11. staging to ide bez problémov, vyskúšam (zo zvedavosti) ešte wine 5.13 staging. Takže je problém asi wo wine. Ospravedlňujem sa- inú verziu wine (staging) mi nenapadlo vyskúšať.
//Edit2:Takže aj Wine 5.13 staging je v poriadku.
Re: [Vyřešeno]Star Wars: The Old Republic - grafické anomálie
#8 Příspěvek od juhele2014 »
:arrow: migrena6
Pokud chceš zkoušet jiný kernel, je k dispozici utilita ukuu, info např. zde https://www.omgubuntu.co.uk/2017/02/uku ... nel-ubuntu Před nedávnem mě to přes terminál nešlo, jestli neseděli repozitáře, nebo co, nevím. Ale funguje instalace deb balíčku ukuu-v18.9.1-amd64.deb odsud https://github.com/teejee2008/ukuu/releases :idea:
migrena6
#9 Příspěvek od migrena6 »
Ďakujem za tip :)
