nefunkcni ovladace grafiky
mart
#1 Příspěvek od mart »
pekny den,
nainstaloval sem mint na velmi stary nb, synovi na pokusy..
pri instalaci uz vznikl problem s necitelnosti displeje nb, podelne cary, jakoby poskladane tri obrazovky pres sebe, vzajemne posunute.. tzn necitelne..
instaloval sem v recovery..
ted nejde nastavit zadne rozliseni obrazovky, spravce nic nenabizi..
nejake rady jak napravit?
m@m-ESPRIMO-Mobile-V6545:~$ inxi -Fxxxrz
System:
  Kernel: 5.4.0-65-generic x86_64 bits: 64 compiler: gcc v: 9.3.0
  Desktop: Cinnamon 4.6.7 wm: muffin 4.6.3 dm: LightDM 1.30.0
  Distro: Linux Mint 20 Ulyana base: Ubuntu 20.04 focal
Machine:
  Type: Laptop System: FUJITSU SIEMENS product: ESPRIMO Mobile V6545 v: 20
  serial: <filter> Chassis: type: 10 v: A2040 serial: <filter>
  Mobo: FUJITSU SIEMENS model: D45 v: 1B serial: <filter> BIOS: Phoenix
  v: 1.18 date: 11/10/2008
Battery:
  ID-1: BAT0 charge: 31.7 Wh condition: 31.7/48.8 Wh (65%) volts: 12.5/11.1
  model: SMP-SDI-22/main e00511402C32C277 type: Unknown serial: <filter>
  status: Full
CPU:
  Topology: Dual Core model: Intel Core2 Duo P8600 bits: 64 type: MCP
  arch: Penryn rev: A L2 cache: 3072 KiB
  flags: lm nx pae sse sse2 sse3 sse4_1 ssse3 vmx bogomips: 9576
  Speed: 798 MHz min/max: 800/2401 MHz boost: enabled Core speeds (MHz):
  1: 799 2: 798
Graphics:
  Device-1: AMD RV620/M82 [Mobility Radeon HD 3450/3470]
  vendor: Fujitsu Solutions driver: N/A bus ID: 01:00.0 chip ID: 1002:95c4
  Display: x11 server: X.Org 1.20.9 driver: ati,fbdev
  unloaded: modesetting,radeon,vesa resolution: 1024x768~76Hz
  OpenGL: renderer: llvmpipe (LLVM 11.0.0 128 bits) v: 4.5 Mesa 20.2.6
  compat-v: 3.1 direct render: Yes
Audio:
  Device-1: Intel 82801I HD Audio vendor: Fujitsu Solutions
  driver: snd_hda_intel v: kernel bus ID: 00:1b.0 chip ID: 8086:293e
  Sound Server: ALSA v: k5.4.0-65-generic
Network:
  Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet
  vendor: Fujitsu Solutions driver: r8169 v: kernel port: 3000
  bus ID: 02:00.0 chip ID: 10ec:8168
  IF: enp2s0 state: down mac: <filter>
  Device-2: Intel WiFi Link 5100 driver: iwlwifi v: kernel port: 3000
  bus ID: 04:00.0 chip ID: 8086:4232
  IF: wlp4s0 state: up mac: <filter>
Drives:
  Local Storage: total: 111.79 GiB used: 16.63 GiB (14.9%)
  ID-1: /dev/sda vendor: Seagate model: ST9120411ASG size: 111.79 GiB
  speed: 3.0 Gb/s rotation: 7200 rpm serial: <filter> rev: DE14 temp: 30 C
  scheme: MBR
Partition:
  ID-1: / size: 108.05 GiB used: 16.63 GiB (15.4%) fs: ext4 dev: /dev/sda5
Sensors:
  System Temperatures: cpu: 44.0 C mobo: 43.0 C
  Fan Speeds (RPM): N/A
Repos:
  No active apt repos in: /etc/apt/sources.list
  Active apt repos in: /etc/apt/sources.list.d/official-package-repositories.list
  1: deb http://mirror.karneval.cz/pub/linux/linuxmint/packages ulyana main upstream import backport
  2: deb http://ftp.sh.cvut.cz/ubuntu focal main restricted universe multiverse
  3: deb http://ftp.sh.cvut.cz/ubuntu focal-updates main restricted universe multiverse
  4: deb http://ftp.sh.cvut.cz/ubuntu focal-backports main restricted universe multiverse
  5: deb http://security.ubuntu.com/ubuntu/ focal-security main restricted universe multiverse
  6: deb http://archive.canonical.com/ubuntu/ focal partner
  Active apt repos in: /etc/apt/sources.list.d/teejee2008-ppa-focal.list
  1: deb http://ppa.launchpad.net/teejee2008/ppa/ubuntu focal main
Info:
  Processes: 185 Uptime: 22h 57m Memory: 3.84 GiB used: 2.14 GiB (55.8%)
  Init: systemd v: 245 runlevel: 5 target: graphical.target Compilers:
  gcc: 9.3.0 alt: 9 Shell: bash v: 5.0.17 running in: gnome-terminal
  inxi: 3.0.38
m@m-ESPRIMO-Mobile-V6545:~$ lsmod
Module                  Size  Used by
ccm                    20480  6
nls_iso8859_1          16384  1
snd_hda_codec_realtek   126976  1
snd_hda_codec_generic    81920  1 snd_hda_codec_realtek
ledtrig_audio          16384  2 snd_hda_codec_generic,snd_hda_codec_realtek
iwldvm                237568  0
snd_hda_intel          53248  3
snd_intel_dspcfg       24576  1 snd_hda_intel
mac80211              843776  1 iwldvm
snd_hda_codec         135168  3 snd_hda_codec_generic,snd_hda_intel,snd_hda_codec_realtek
uvcvideo               98304  0
libarc4                16384  1 mac80211
snd_hda_core           90112  4 snd_hda_codec_generic,snd_hda_intel,snd_hda_codec,snd_hda_codec_realtek
snd_hwdep              20480  1 snd_hda_codec
videobuf2_vmalloc      20480  1 uvcvideo
videobuf2_memops       20480  1 videobuf2_vmalloc
snd_pcm               106496  3 snd_hda_intel,snd_hda_codec,snd_hda_core
videobuf2_v4l2         24576  1 uvcvideo
coretemp               20480  0
snd_seq_midi           20480  0
snd_seq_midi_event     16384  1 snd_seq_midi
iwlwifi               331776  1 iwldvm
videobuf2_common       49152  2 videobuf2_v4l2,uvcvideo
snd_rawmidi            36864  1 snd_seq_midi
videodev              225280  3 videobuf2_v4l2,uvcvideo,videobuf2_common
snd_seq                69632  2 snd_seq_midi,snd_seq_midi_event
mc                     53248  4 videodev,videobuf2_v4l2,uvcvideo,videobuf2_common
kvm_intel             282624  0
snd_seq_device         16384  3 snd_seq,snd_seq_midi,snd_rawmidi
snd_timer              36864  2 snd_seq,snd_pcm
kvm                   663552  1 kvm_intel
cfg80211              704512  3 iwldvm,iwlwifi,mac80211
snd                    90112  16 snd_hda_codec_generic,snd_seq,snd_seq_device,snd_hwdep,snd_hda_intel,snd_hda_codec,snd_hda_codec_realtek,snd_timer,snd_pcm,snd_rawmidi
jmb38x_ms              24576  0
memstick               20480  1 jmb38x_ms
joydev                 24576  0
input_leds             16384  0
sparse_keymap          16384  0
wmi_bmof               16384  0
soundcore              16384  1 snd
serio_raw              20480  0
mac_hid                16384  0
sch_fq_codel           20480  6
parport_pc             40960  0
ppdev                  24576  0
lp                     20480  0
parport                53248  3 parport_pc,lp,ppdev
ip_tables              32768  0
x_tables               40960  1 ip_tables
autofs4                45056  2
btrfs                1257472  0
xor                    24576  1 btrfs
zstd_compress         167936  1 btrfs
raid6_pq              114688  1 btrfs
libcrc32c              16384  1 btrfs
dm_mirror              24576  0
dm_region_hash         20480  1 dm_mirror
dm_log                 20480  2 dm_region_hash,dm_mirror
hid_generic            16384  0
i2c_algo_bit           16384  0
ttm                   106496  0
drm_kms_helper        184320  0
syscopyarea            16384  1 drm_kms_helper
firewire_ohci          40960  0
sysfillrect            16384  1 drm_kms_helper
sysimgblt              16384  1 drm_kms_helper
fb_sys_fops            16384  1 drm_kms_helper
psmouse               155648  0
sdhci_pci              53248  0
usbhid                 57344  0
hid                   131072  2 usbhid,hid_generic
ahci                   40960  2
libahci                32768  1 ahci
i2c_i801               32768  0
lpc_ich                24576  0
cqhci                  28672  1 sdhci_pci
drm                   491520  2 drm_kms_helper,ttm
sdhci                  65536  1 sdhci_pci
firewire_core          65536  1 firewire_ohci
r8169                  90112  0
crc_itu_t              16384  1 firewire_core
realtek                24576  1
wmi                    32768  1 wmi_bmof
video                  49152  0
m@m-ESPRIMO-Mobile-V6545:~$ lspci -vnn | grep VGA -A 12
01:00.0 VGA compatible controller [0300]: Advanced Micro Devices, Inc. [AMD/ATI] RV620/M82 [Mobility Radeon HD 3450/3470] [1002:95c4] (prog-if 00 [VGA controller])
	Subsystem: Fujitsu Technology Solutions RV620/M82 [Mobility Radeon HD 3450/3470] [1734:113f]
	Flags: bus master, fast devsel, latency 0, IRQ 11
	Memory at c0000000 (32-bit, prefetchable) [size=512M]
	I/O ports at 2000 [size=256]
	Memory at f2100000 (32-bit, non-prefetchable) [size=64K]
	Expansion ROM at 000c0000 [virtual] [disabled] [size=128K]
	Capabilities: <access denied>
	Kernel modules: radeon
02:00.0 Ethernet controller [0200]: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller [10ec:8168] (rev 02)
	Subsystem: Fujitsu Technology Solutions RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller [1734:113f]
	Flags: bus master, fast devsel, latency 0, IRQ 16
m@m-ESPRIMO-Mobile-V6545:~$ xrandr
xrandr: Failed to get size of gamma for output default
Screen 0: minimum 1024 x 768, current 1024 x 768, maximum 1024 x 768
default connected primary 1024x768+0+0 0mm x 0mm
   1024x768      76.00*
dekuji za jakoukoli pomoc a snahu
Re: nefunkcni ovladace grafiky
#2 Příspěvek od Ventero1 »
To nema smysl. Tak to zkus znovu a vyber si Mint Xfce.
Pokud to nepomuze, tak zkusit jine vhodnejsi distro pro slabsi PC.
Dobre je si pred instalaci neco pohledat a precist. Pak by jsi zbytecne nezkousel Cinnamon.
Musim vsak pochvalit prikladne pouziti a vkladani vypisu.
mart
#3 Příspěvek od mart »
ok, tvorim instalacku z linuxmint-19.3-xfce-64bit.iso, ale mam pocit ze sem to uz zkousel a bylo to uplne to same.. no, jdu na to
mart
#4 Příspěvek od mart »
ok, ozkousim.. uz jsem na to behem hledani narazil, nejak sem doufal, ze to pujde obejit..
ted sem v haku na datech, rano doma stahnu..
v kazdem pripade moc dekuji za venovany cas a vedomosti
edit: preeinstaloval sem xfce, je to to same..
diky moc
#5 Příspěvek od Ventero1 »
Popr. jestli preferujes Mint, tak verzi 17.3
To vyrazovani podpory jeste pouzitelneho HW me stve. Fakt se linux odlinuxovava ...
#6 Příspěvek od juhele2014 »
Souhlas, mám na noťasu HP právě LM 17.3 xfce, a maká to slušně. Takže fungovat to bude.
Tady to fungovat moc nebude. Jakmile začne syn "pokusničit" a zkusí nějaké "abgrejdy" nebo instalace, může se to šprcnout, a bude konflikt mezi knihovnama, zdrojema, webama, systémama a verzema. Ale žádná tragedie to není - LM se nechá snadno "opravit" (přeflešnout) novou čistou instalací, takže příp. chyba nemá dlouhého trvání. Pokud si udělá dual-boot, může pokusničit bez ztráty kytičky ... ;)
mart
#7 Příspěvek od mart »
dekuji vsem,
nainstaloval sem 17.3, xfce, beha paradne..
pokusy.. jasny dostal rozkaz neaktualizovat jado, vytvoreny zalohy a v nejhorsim mu to preinstaluju, ted uz to bude fofr..
