Acer Aspire 3610 WIFI
Nallim
#1 Příspěvek od Nallim »
nainstaloval jsem na tento stařičký notebook Mint 16 a nedaří se mi rozběhnout wifi karta.
Zkoušel jsem ve správci ovladačů vybrat wifi kartu, provedl jsem změny a žádná změna. A když spustím správce ovladačů znovu, tak to už nic nenabídne.
Nějaké řešení? :(
Díky
výpis HW:
00:00.0 Host bridge: Intel Corporation Mobile 915GM/PM/GMS/910GML Express Processor to DRAM Controller (rev 03)
	Subsystem: Acer Incorporated [ALI] Device 006a
	Flags: bus master, fast devsel, latency 0
	Capabilities: <access denied>
	Kernel driver in use: agpgart-intel
00:02.0 VGA compatible controller: Intel Corporation Mobile 915GM/GMS/910GML Express Graphics Controller (rev 03) (prog-if 00 [VGA controller])
	Flags: bus master, fast devsel, latency 0, IRQ 16
	Memory at b0080000 (32-bit, non-prefetchable) [size=512K]
	I/O ports at 1800 [size=8]
	Memory at c0000000 (32-bit, prefetchable) [size=256M]
	Memory at b0000000 (32-bit, non-prefetchable) [size=256K]
	Expansion ROM at <unassigned> [disabled]
	Kernel driver in use: i915
00:02.1 Display controller: Intel Corporation Mobile 915GM/GMS/910GML Express Graphics Controller (rev 03)
	Flags: fast devsel
	Memory at 24000000 (32-bit, non-prefetchable) [disabled] [size=512K]
00:1d.0 USB controller: Intel Corporation 82801FB/FBM/FR/FW/FRW (ICH6 Family) USB UHCI #1 (rev 03) (prog-if 00 [UHCI])
	Flags: bus master, medium devsel, latency 0, IRQ 23
	I/O ports at 1820 [size=32]
	Kernel driver in use: uhci_hcd
00:1d.1 USB controller: Intel Corporation 82801FB/FBM/FR/FW/FRW (ICH6 Family) USB UHCI #2 (rev 03) (prog-if 00 [UHCI])
	Flags: bus master, medium devsel, latency 0, IRQ 17
	I/O ports at 1840 [size=32]
00:1d.2 USB controller: Intel Corporation 82801FB/FBM/FR/FW/FRW (ICH6 Family) USB UHCI #3 (rev 03) (prog-if 00 [UHCI])
	Flags: bus master, medium devsel, latency 0, IRQ 18
	I/O ports at 1860 [size=32]
00:1d.3 USB controller: Intel Corporation 82801FB/FBM/FR/FW/FRW (ICH6 Family) USB UHCI #4 (rev 03) (prog-if 00 [UHCI])
	Flags: bus master, medium devsel, latency 0, IRQ 19
	I/O ports at 1880 [size=32]
00:1d.7 USB controller: Intel Corporation 82801FB/FBM/FR/FW/FRW (ICH6 Family) USB2 EHCI Controller (rev 03) (prog-if 20 [EHCI])
	Memory at b0040000 (32-bit, non-prefetchable) [size=1K]
	Kernel driver in use: ehci-pci
00:1e.0 PCI bridge: Intel Corporation 82801 Mobile PCI Bridge (rev d3) (prog-if 01 [Subtractive decode])
	Bus: primary=00, secondary=06, subordinate=0a, sec-latency=32
	I/O behind bridge: 00003000-00003fff
	Memory behind bridge: b0100000-b01fffff
	Prefetchable memory behind bridge: 0000000020000000-0000000023ffffff
00:1e.2 Multimedia audio controller: Intel Corporation 82801FB/FBM/FR/FW/FRW (ICH6 Family) AC'97 Audio Controller (rev 03)
	Subsystem: Acer Incorporated [ALI] Realtek ALC 655 codec (in Acer TravelMate 2410 serie laptop)
	Flags: bus master, medium devsel, latency 0, IRQ 21
	I/O ports at 1c00 [size=256]
	I/O ports at 18c0 [size=64]
	Memory at b0040800 (32-bit, non-prefetchable) [size=512]
	Memory at b0040400 (32-bit, non-prefetchable) [size=256]
	Kernel driver in use: snd_intel8x0
00:1e.3 Modem: Intel Corporation 82801FB/FBM/FR/FW/FRW (ICH6 Family) AC'97 Modem Controller (rev 03) (prog-if 00 [Generic])
	Subsystem: Acer Incorporated [ALI] Conexant AC'97 CoDec (in Acer TravelMate 2410 serie laptop)
	Flags: medium devsel, IRQ 21
	I/O ports at 2400 [size=256]
	I/O ports at 2000 [size=128]
00:1f.0 ISA bridge: Intel Corporation 82801FBM (ICH6M) LPC Interface Bridge (rev 03)
	Kernel driver in use: lpc_ich
00:1f.1 IDE interface: Intel Corporation 82801FB/FBM/FR/FW/FRW (ICH6 Family) IDE Controller (rev 03) (prog-if 8a [Master SecP PriP])
	Flags: bus master, medium devsel, latency 0, IRQ 16
	I/O ports at 01f0 [size=8]
	I/O ports at 03f4 [size=1]
	I/O ports at 0170 [size=8]
	I/O ports at 0374 [size=1]
	I/O ports at 1810 [size=16]
	Kernel driver in use: ata_piix
00:1f.3 SMBus: Intel Corporation 82801FB/FBM/FR/FW/FRW (ICH6 Family) SMBus Controller (rev 03)
	Flags: medium devsel, IRQ 11
	I/O ports at 20a0 [size=32]
06:05.0 Network controller: Broadcom Corporation BCM4318 [AirForce One 54g] 802.11g Wireless LAN Controller (rev 02)
	Subsystem: AMBIT Microsystem Corp. TravelMate 2410
	Flags: bus master, fast devsel, latency 32, IRQ 21
	Memory at b0100000 (32-bit, non-prefetchable) [size=8K]
	Kernel driver in use: wl
06:07.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL-8139/8139C/8139C+ (rev 10)
	Flags: bus master, medium devsel, latency 32, IRQ 20
	I/O ports at 3000 [size=256]
	Memory at b0102000 (32-bit, non-prefetchable) [size=256]
	Kernel driver in use: 8139too
06:09.0 CardBus bridge: ENE Technology Inc CB1410 Cardbus Controller (rev 01)
	Flags: bus master, medium devsel, latency 168, IRQ 22
	Memory at 28000000 (32-bit, non-prefetchable) [size=4K]
	Bus: primary=06, secondary=07, subordinate=0a, sec-latency=176
	Memory window 0: 20000000-23ffffff (prefetchable)
	Memory window 1: 2c000000-2fffffff
	I/O window 0: 00003400-000034ff
	I/O window 1: 00003800-000038ff
	16-bit legacy interface ports at 0001
	Kernel driver in use: yenta_cardbus
Re: Acer Aspire 3610 WIFI
Cau, podla vypisu tam mas wifi od broadcom:
Ovladac je wl:
Mohol by si v buducnosti s vypisom kopirovat aj prikaz, po zadani ktoreho si ten vypis dostal ako odpoved v Terminali
(pre uplnost informacii).
V tomto pripade by si mohol vyskusat postup, ako sa pise tu:
http://lkubuntu.wordpress.com/2011/09/0 ... dcom-43xx/
Nallim
#3 Příspěvek od Nallim »
Díky.
Hrozně mu to trvá, od času tvého příspěvku jsem s tím nepohl.
Stojí to na: DKMS: install comleted.
A furt to něco dělá.
Zkusím to ještě zítra.
Taka instalacia bezne trva par minut.
Ak sa to zasekne / kousne - tak by si mohol sem okopirovat co terminal pise.
Nallim
#5 Příspěvek od Nallim »
Nakonec nainstalováno přes Synaptics jako B43 a je po problému. :)
#6 Příspěvek od menom »
V poslednom case ma Broadcom bordel v tych ovladacoch.
Je to na kazdom userovi aby hladal, ktory ovladac k jeho hardveru zapasuje.
Ked jeden vyskusas a nefunguje - treba ho odinstalovat a skusit dalsi. :lol:
