Xerox B215 tiskne jen jednu kopii
Radyn
#1 Příspěvek od Radyn »
Zkouším rozchodit tiskárnu a stále tiskne jen jednu kopii. V ubuntu mi to dělalo také, ale v Majaro linux jede v pohodě. Nevíte někdo řešení?
System:    Kernel: 5.4.0-91-generic x86_64 bits: 64 compiler: gcc v: 9.3.0 Desktop: Cinnamon 5.0.7
           wm: muffin dm: LightDM Distro: Linux Mint 20.2 Uma base: Ubuntu 20.04 focal
Machine:   Type: Desktop System: LENOVO product: 3285A1G v: ThinkCentre M58p serial: <filter>
           Chassis: type: 3 serial: <filter>
           Mobo: LENOVO model: LENOVO serial: <filter> BIOS: LENOVO v: 5CKT77AUS date: 05/07/2012
Battery:   Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard PID:0055 serial: N/A
           charge: 70% (should be ignored) status: Discharging
           Device-2: hidpp_battery_1 model: Logitech Wireless Mouse PID:003f serial: N/A
           charge: 55% (should be ignored) status: Discharging
CPU:       Topology: Dual Core model: Intel Core2 Duo E8400 bits: 64 type: MCP arch: Penryn rev: A
           L2 cache: 6144 KiB
           flags: lm nx pae sse sse2 sse3 sse4_1 ssse3 vmx bogomips: 11969
           Speed: 1995 MHz min/max: 2000/3000 MHz Core speeds (MHz): 1: 1995 2: 1995
Graphics:  Device-1: Intel 4 Series Integrated Graphics vendor: Lenovo driver: i915 v: kernel
           bus ID: 00:02.0 chip ID: 8086:2e12
           Display: x11 server: X.Org 1.20.13 driver: modesetting unloaded: fbdev,vesa
           resolution: 1440x900~60Hz
           OpenGL: renderer: Mesa DRI Intel Q45/Q43 (ELK) v: 2.1 Mesa 21.0.3 direct render: Yes
Audio:     Device-1: Intel 82801JD/DO HD Audio vendor: Lenovo driver: snd_hda_intel v: kernel
           bus ID: 00:1b.0 chip ID: 8086:3a6e
           Sound Server: ALSA v: k5.4.0-91-generic
Network:   Device-1: Intel 82567LM-3 Gigabit Network vendor: Lenovo driver: e1000e v: 3.2.6-k
           port: 1820 bus ID: 00:19.0 chip ID: 8086:10de
           IF: enp0s25 state: up speed: 1000 Mbps duplex: full mac: <filter>
Drives:    Local Storage: total: 698.65 GiB used: 13.12 GiB (1.9%)
           ID-1: /dev/sda vendor: Western Digital model: WD2500AAJS-08L7A0 size: 232.89 GiB
           speed: 3.0 Gb/s serial: <filter>
           ID-2: /dev/sdb vendor: Seagate model: ST3500418AS size: 465.76 GiB speed: 1.5 Gb/s
           serial: <filter>
Partition: ID-1: / size: 456.95 GiB used: 13.12 GiB (2.9%) fs: ext4 dev: /dev/sdb5
Sensors:   System Temperatures: cpu: 43.0 C mobo: N/A
           Fan Speeds (RPM): N/A
Repos:     No active apt repos in: /etc/apt/sources.list
           Active apt repos in: /etc/apt/sources.list.d/official-package-repositories.list
           1: deb http: //packages.linuxmint.com uma main upstream import backport #id:linuxmint_main
           2: deb http: //archive.ubuntu.com/ubuntu focal main restricted universe multiverse
           3: deb http: //archive.ubuntu.com/ubuntu focal-updates main restricted universe multiverse
           4: deb http: //archive.ubuntu.com/ubuntu focal-backports main restricted universe multiverse
           5: deb http: //security.ubuntu.com/ubuntu/ focal-security main restricted universe multiverse
           6: deb http: //archive.canonical.com/ubuntu/ focal partner
Info:      Processes: 212 Uptime: 6h 13m Memory: 3.32 GiB used: 2.57 GiB (77.3%) Init: systemd
           v: 245 runlevel: 5 Compilers: gcc: 9.3.0 alt: 9 Client: Unknown python3.8 client
           inxi: 3.0.38
