nestreamuje zvuk cez chromecast Vyřešeno
jemi
#1 Příspěvek od jemi »
V prvom rade úctivo zdravím na fóre.
všetko funguje ako má až na to ked dám niečo streamovať cez chromecast do tv... vtedy ide len video a audio sa cez chromecast neprenáša, funguje len youtube ked kliknem na iconu cast pri videu.
System:
  Host: pcc Kernel: 5.15.0-48-generic x86_64 bits: 64 Desktop: MATE 1.26.0
    Distro: Linux Mint 21 Vanessa
Machine:
  Type: Laptop System: ASUSTeK product: X55VDR v: 1.0
    serial: <superuser required>
  Mobo: ASUSTeK model: X55VDR v: 1.0 serial: <superuser required>
    UEFI: American Megatrends v: X55VDR.403 date: 09/04/2012
Battery:
  ID-1: BAT0 charge: 53.8 Wh (94.1%) condition: 57.2/57.2 Wh (100.1%)
CPU:
  Info: dual core model: Intel Core i3-2350M bits: 64 type: MT MCP cache:
    L2: 512 KiB
  Speed (MHz): avg: 798 min/max: 800/2300 cores: 1: 798 2: 798 3: 798
    4: 798
Graphics:
  Device-1: Intel 2nd Generation Core Processor Family Integrated Graphics
    driver: i915 v: kernel
  Device-2: NVIDIA GF119M [GeForce 610M] driver: nvidia v: 390.154
  Device-3: Sunplus Innovation Asus Webcam type: USB driver: uvcvideo
  Display: x11 server: X.Org v: 1.21.1.3 driver: X:
    loaded: modesetting,nvidia unloaded: fbdev,nouveau,vesa gpu: i915
    resolution: 1366x768~60Hz
  OpenGL: renderer: GeForce 610M/PCIe/SSE2 v: 4.6.0 NVIDIA 390.154
Audio:
  Device-1: Intel 7 Series/C216 Family High Definition Audio
    driver: snd_hda_intel
  Sound Server-1: ALSA v: k5.15.0-48-generic running: yes
  Sound Server-2: PulseAudio v: 15.99.1 running: yes
  Sound Server-3: PipeWire v: 0.3.48 running: yes
Network:
  Device-1: Qualcomm Atheros AR9485 Wireless Network Adapter driver: ath9k
  IF: wlp3s0 state: up mac: dc:85:de:29:d1:a9
  Device-2: Qualcomm Atheros AR8161 Gigabit Ethernet driver: alx
  IF: enp4s0 state: down mac: 50:46:5d:dd:af:f0
Bluetooth:
  Device-1: IMC Networks Atheros AR3012 Bluetooth 4.0 Adapter type: USB
    driver: btusb
  Report: hciconfig ID: hci0 state: up address: DC:85:DE:2A:46:D9 bt-v: 2.1
Drives:
  Local Storage: total: 1.18 TiB used: 718.53 GiB (59.4%)
  ID-1: /dev/sda vendor: Crucial model: CT275MX300SSD1 size: 256.17 GiB
  ID-2: /dev/sdb type: USB vendor: A-Data model: SE760 size: 953.87 GiB
Partition:
  ID-1: / size: 47.77 GiB used: 11.91 GiB (24.9%) fs: ext4 dev: /dev/sda3
  ID-2: /boot/efi size: 512 MiB used: 5.2 MiB (1.0%) fs: vfat
    dev: /dev/sda2
Swap:
  ID-1: swap-1 type: file size: 2 GiB used: 256 KiB (0.0%) file: /swapfile
Sensors:
  System Temperatures: cpu: 47.0 C mobo: N/A gpu: nvidia temp: 38 C
  Fan Speeds (RPM): cpu: 2300
Info:
  Processes: 246 Uptime: 2h 4m Memory: 5.68 GiB used: 1.11 GiB (19.5%)
  Shell: Bash inxi: 3.3.13
**** List of PLAYBACK Hardware Devices ****
card 0: PCH [HDA Intel PCH], device 0: VT1802 Analog [VT1802 Analog]
  Subdevices: 1/1
  Subdevice #0: subdevice #0
card 0: PCH [HDA Intel PCH], device 2: VT1802 Alt Analog [VT1802 Alt Analog]
  Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 3: HDMI 0 [HDMI 0]
  Subdevices: 1/1
googlením som našiel nejaký pulse plugin ale ten mi nenainštalovalo a ani mi ho nenašlo v software managery, potom som skúšal aj rôzne audio výstupy vo VLC ale kedže sa to týka aj castenia web browsera (opera) tak predpokladám že chybička bude niekde inde (možno medzi stoličkou a klávesnicou) dakujem za každú radu. ostávam s pozdravom
