nefunkční zvuk po instalaci
bajonos
#1 Příspěvek od bajonos »
jsem linuxovy zacatecnik. Mym vyberem nakonec je MINT, ale zvuk se mi nepodarilo rozbehat. V PulseAudio nemam zadne vystupni zarizeni. Poradite nekdo, prosim?
System:
Host: mint-work Kernel: 6.8.0-48-generic arch: x86_64 bits: 64
Desktop: Cinnamon v: 6.2.9 Distro: Linux Mint 22 Wilma
Machine:
Type: Desktop System: HP product: HP ProDesk 600 G3 MT v: N/A
serial: <superuser required>
Mobo: HP model: 829D v: KBC Version 06.15 serial: <superuser required>
UEFI: HP v: P02 Ver. 02.06 date: 06/09/2017
CPU:
Info: dual core model: Intel Core i3-6100 bits: 64 type: MT MCP cache:
L2: 512 KiB
Speed (MHz): avg: 800 min/max: 800/3700 cores: 1: 800 2: 800 3: 800 4: 800
Graphics:
Device-1: Intel HD Graphics 530 driver: i915 v: kernel
Display: x11 server: X.Org v: 21.1.11 with: Xwayland v: 23.2.6 driver: X:
loaded: modesetting unloaded: fbdev,vesa dri: iris gpu: i915 resolution:
1: 1050x1680~60Hz 2: 1680x1050~60Hz
API: EGL v: 1.5 drivers: iris,swrast platforms: x11,surfaceless,device
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.0.9-0ubuntu0.2
renderer: Mesa Intel HD Graphics 530 (SKL GT2)
Audio:
Message: No device data found.
API: ALSA v: k6.8.0-48-generic status: kernel-api
Server-1: PipeWire v: 1.0.5 status: active
Network:
Message: No PCI device data found.
Device-1: Realtek 8812AU/8821AU 802.11ac WLAN Adapter [USB Wireless
Dual-Band 2.4/5Ghz] driver: rtl8821au type: USB
IF: wlx30169d8723ef state: up mac: 30:16:9d:87:23:ef
Drives:
Local Storage: total: 119.24 GiB used: 25.59 GiB (21.5%)
ID-1: /dev/sda vendor: SanDisk model: SD8SB8U-128G-1006 size: 119.24 GiB
Partition:
ID-1: / size: 116.32 GiB used: 25.58 GiB (22.0%) fs: ext4 dev: /dev/sda3
ID-2: /boot/efi size: 512 MiB used: 6.1 MiB (1.2%) fs: vfat dev: /dev/sda2
Swap:
ID-1: swap-1 type: file size: 3.93 GiB used: 1.13 GiB (28.8%)
file: /swapfile
Sensors:
System Temperatures: cpu: 32.0 C mobo: N/A
Fan Speeds (rpm): N/A
Info:
Memory: total: 4 GiB available: 3.71 GiB used: 2.82 GiB (76.2%)
Processes: 249 Uptime: 2h 51m Shell: Bash inxi: 3.3.34
Diky B.
Re: nefunkční zvuk po instalaci
#2 Příspěvek od Ventero1 »
No ale ty nejedes na PulseAudio - ty mas PipeWire ..
Musis najit nastaveni toho.
#3 Příspěvek od menom »
Vo vypise neukazuje zvukove zariadenie, mozno mrknut na UEFI/BIOS ci je povolene, enable.
Alebo vypnut Secure boot ak neni.
Dalej moze spustit instalacku ako Live system a tam urobit rovnaky vypis inxi -F
A kopirovat sem ak to zvukove zariadenie ukaze.
bajonos
#4 Příspěvek od bajonos »
Ahoj, děkuji za nasměrování. Chyba byla v BIOSu. Člověk se učí každý den :-) Ještě jednou díky !!! B.
#5 Příspěvek od menom »
System:
Machine:
CPU:
L2: 512 KiB
Graphics:
Audio:
Network:
Mas tam intel graficku kartu, ak by blikalo ci traslo s obrazom mozes si pomoct zadanim parametru intel_iommu=igfx_off
do nastavenia GRUBu, ako sa pise tu:
viewtopic.php?p=49264&hilit=intel+grafik#p49264
V mojom pripade to rovnako pomohlo.
bajonos
#6 Příspěvek od bajonos »
Díky za tip. Zatím to vypadá O.K. Kdyby mě to překvapilo, vim kudy vyrazit...
