The Shrouded Sky update in Arc Raiders brings a wealth of new content, including challenging quests designed to test your skills. Among these new missions is the Stable Housing quest for Tian Wen-a task that demands focus, strategy, and careful execution. Players must complete this quest in a single round, meaning death at any point will force a restart. If you're struggling to secure the rewards, this guide breaks down every step to ARC Raiders Coins successfully complete the Stable Housing quest in Arc Raiders.
Overview of the Stable Housing Quest
The Stable Housing quest takes place on the Stella Montis map. The main objective is to retrieve the Project Heartwood Blueprints from a locked safe in the Security Bridge and then safely return them to Speranza. Completing the quest requires careful navigation, observation, and patience. Here's a step-by-step walkthrough to make sure you succeed.
Important: All objectives must be completed in one round. If you die at any point during the raid, you'll have to start over from the beginning.
Step 1: Reach the Security Bridge
The first task in Stable Housing is to locate and access the Security Bridge, situated in the Lobby area of Stella Montis. From the Lobby, head to the northeast side, where you will find the Security Bridge door.
You have two main options to enter:
Breach the door: If you have tools or abilities that allow you to break doors, this is a straightforward method.
Use the wall jump: For a more daring approach, you can scale the wall on the right side of the door to access the bridge directly.
Once inside, prepare for the next objective: locating the safe on the third floor.
Step 2: Search for the Safe on the Third Floor
Climb the staircase to reach the third floor of the Security Bridge. The safe is located in the room at the back right corner of the floor.
Interact with the safe, but be prepared-initial attempts to open it will fail. This is intentional, as the game requires you to complete additional steps to gain access.
Step 3: Attempt to Print a Key on the Fourth Floor
The next step is to head up one floor to the fourth floor. Directly above the safe room, you will find an Access Card Printer. Interacting with the printer may seem like the solution, but initially, it will not work.
This part of the quest encourages players to explore and think creatively, signaling that the solution requires attention to environmental clues rather than relying solely on obvious interactable ARCR Items.
Step 4: Search for Alternate Ways into the Safe
Return to the safe room on the third floor and inspect the environment closely. Look to the right as you enter the room to find notes pinned to the wall.
Interacting with these notes will reveal important information on how to open the safe, providing the hints needed to bypass the locked mechanisms. This is a critical step-missing these notes can cause confusion and may lead players to think the quest is bugged, when it's simply designed to test observation.
Step 5: Retrieve the Contents of the Safe
Once you have inspected the notes, return to the safe and interact with it again. This time, you will successfully open it and obtain the Project Heartwood Blueprints.
Pro Tip: Store the blueprints in the Safe Pocket. This ensures you won't lose them even if you encounter danger or fail to extract immediately. Protecting your loot is key, as death in this quest forces a full restart.
Step 6: Extraction and Quest Completion
With the Project Heartwood Blueprints in your possession, you must return to Speranza safely to buy ARC Raiders BluePrints complete the quest. Avoid unnecessary risks-RNG encounters with ARCs or other players can make extraction challenging. Staying alert and sticking to safe paths increases your chances of success.
