vůbec sice netuším co to je za výpis, ale tady je
(snad se v tom nějak vyznáš, je toho docela dost
[ 5.438638] ath10k_pci 0000:03:00.0: pci irq msi-x interrupts 8 irq_mode 0 reset_mode 0
[ 5.704125] ath10k_pci 0000:03:00.0: Direct firmware load for ath10k/cal-pci-0000:03:00.0.bin failed with error -2
[ 5.704952] ath10k_pci 0000:03:00.0: Direct firmware load for ath10k/QCA6174/hw3.0/firmware-5.bin failed with error -2
[ 5.704958] ath10k_pci 0000:03:00.0: could not fetch firmware file 'ath10k/QCA6174/hw3.0/firmware-5.bin': -2
[ 5.783309] ath10k_pci 0000:03:00.0: Direct firmware load for ath10k/QCA6174/hw3.0/board-2.bin failed with error -2
[ 7.918898] ath10k_pci 0000:03:00.0: qca6174 hw3.2 (0x05030000, 0x00340aff sub 105b:e09d) fw WLAN.RM.2.0-00180-QCARMSWPZ-1 fwapi 4 bdapi 1 htt-ver 3.26 wmi-op 4 htt-op 3 cal otp max-sta 32 raw 0 hwcrypto 1 features wowlan,ignore-otp,no-4addr-pad
[ 7.918902] ath10k_pci 0000:03:00.0: debug 0 debugfs 1 tracing 1 dfs 0 testmode 0
[ 10.917750] ath10k_pci 0000:03:00.0: could not suspend target (-11)
[ 10.993069] ath10k_pci 0000:03:00.0 wlp3s0: renamed from wlan0
[ 16.258063] ath10k_pci 0000:03:00.0: failed to enable dynamic BW: -11
[ 22.258263] ath10k_pci 0000:03:00.0: could not suspend target (-11)
[ 27.586445] ath10k_pci 0000:03:00.0: failed to enable dynamic BW: -11
[ 33.586642] ath10k_pci 0000:03:00.0: could not suspend target (-11)
[ 38.938808] ath10k_pci 0000:03:00.0: failed to enable dynamic BW: -11
[ 44.939012] ath10k_pci 0000:03:00.0: could not suspend target (-11)
[ 50.251184] ath10k_pci 0000:03:00.0: failed to enable dynamic BW: -11
[ 56.251395] ath10k_pci 0000:03:00.0: could not suspend target (-11)
[ 72.253221] ath10k_pci 0000:03:00.0: failed to enable dynamic BW: -11
[ 78.253705] ath10k_pci 0000:03:00.0: could not suspend target (-11)
[ 83.566399] ath10k_pci 0000:03:00.0: failed to enable dynamic BW: -11
[ 89.567004] ath10k_pci 0000:03:00.0: could not suspend target (-11)
[ 94.879656] ath10k_pci 0000:03:00.0: failed to enable dynamic BW: -11
[ 100.879973] ath10k_pci 0000:03:00.0: could not suspend target (-11)
[ 106.200575] ath10k_pci 0000:03:00.0: failed to set rx-chainmask: -11, req 0x3
[ 109.200886] ath10k_pci 0000:03:00.0: failed to set arp ac override parameter: -11
[ 115.201079] ath10k_pci 0000:03:00.0: could not suspend target (-11)
[ 120.513630] ath10k_pci 0000:03:00.0: failed to enable dynamic BW: -11
[ 126.513896] ath10k_pci 0000:03:00.0: could not suspend target (-11)
[ 140.255328] ath10k_pci 0000:03:00.0: failed to enable dynamic BW: -11
[ 146.255802] ath10k_pci 0000:03:00.0: could not suspend target (-11)
[ 151.568126] ath10k_pci 0000:03:00.0: failed to enable dynamic BW: -11
[ 157.568579] ath10k_pci 0000:03:00.0: could not suspend target (-11)
[ 173.265697] ath10k_pci 0000:03:00.0: failed to set tx-chainmask: -11, req 0x3
[ 176.265863] ath10k_pci 0000:03:00.0: failed to set arp ac override parameter: -11
[ 182.266176] ath10k_pci 0000:03:00.0: could not suspend target (-11)
[ 187.578446] ath10k_pci 0000:03:00.0: failed to enable dynamic BW: -11
[ 193.578718] ath10k_pci 0000:03:00.0: could not suspend target (-11)
[ 208.263136] ath10k_pci 0000:03:00.0: failed to enable dynamic BW: -11
[ 214.263493] ath10k_pci 0000:03:00.0: could not suspend target (-11)
[ 219.579551] ath10k_pci 0000:03:00.0: failed to enable dynamic BW: -11
[ 225.579722] ath10k_pci 0000:03:00.0: could not suspend target (-11)
[ 299.014423] ath10k_pci 0000:03:00.0: failed to set tx-chainmask: -11, req 0x3
[ 302.014549] ath10k_pci 0000:03:00.0: failed to set arp ac override parameter: -11
[ 308.014733] ath10k_pci 0000:03:00.0: could not suspend target (-11)
[ 313.510812] ath10k_pci 0000:03:00.0: failed to enable dynamic BW: -11
[ 319.511027] ath10k_pci 0000:03:00.0: could not suspend target (-11)
[ 324.827088] ath10k_pci 0000:03:00.0: failed to enable dynamic BW: -11
[ 330.827381] ath10k_pci 0000:03:00.0: could not suspend target (-11)
[ 346.270326] ath10k_pci 0000:03:00.0: failed to enable dynamic BW: -11
[ 352.270078] ath10k_pci 0000:03:00.0: could not suspend target (-11)
[ 357.582149] ath10k_pci 0000:03:00.0: failed to enable dynamic BW: -11
[ 363.582446] ath10k_pci 0000:03:00.0: could not suspend target (-11)
[ 379.262841] ath10k_pci 0000:03:00.0: failed to enable dynamic BW: -11
[ 385.263136] ath10k_pci 0000:03:00.0: could not suspend target (-11)
[ 390.579099] ath10k_pci 0000:03:00.0: failed to enable dynamic BW: -11
[ 396.579432] ath10k_pci 0000:03:00.0: could not suspend target (-11)
[ 401.923453] ath10k_pci 0000:03:00.0: failed to enable dynamic BW: -11
[ 407.923850] ath10k_pci 0000:03:00.0: could not suspend target (-11)
[ 462.353659] ath10k_pci 0000:03:00.0: failed to enable dynamic BW: -11
[ 468.353721] ath10k_pci 0000:03:00.0: could not suspend target (-11)
[ 473.665871] ath10k_pci 0000:03:00.0: failed to enable dynamic BW: -11
[ 479.666252] ath10k_pci 0000:03:00.0: could not suspend target (-11)
[ 512.391401] ath10k_pci 0000:03:00.0: failed to enable dynamic BW: -11
[ 518.391597] ath10k_pci 0000:03:00.0: could not suspend target (-11)
[ 525.431830] ath10k_pci 0000:03:00.0: failed to enable dynamic BW: -11
[ 531.432065] ath10k_pci 0000:03:00.0: could not suspend target (-11)
[ 1064.455657] ath10k_pci 0000:03:00.0: failed to enable dynamic BW: -11
[ 1070.455855] ath10k_pci 0000:03:00.0: could not suspend target (-11)
[ 1075.836031] ath10k_pci 0000:03:00.0: failed to enable dynamic BW: -11
[ 1081.836269] ath10k_pci 0000:03:00.0: could not suspend target (-11)
[ 1087.164431] ath10k_pci 0000:03:00.0: failed to enable dynamic BW: -11
[ 1093.164635] ath10k_pci 0000:03:00.0: could not suspend target (-11)
[ 1098.660592] ath10k_pci 0000:03:00.0: failed to enable dynamic BW: -11
[ 1104.661014] ath10k_pci 0000:03:00.0: could not suspend target (-11)
