PS: zabudol som spomenut ze tu nejde o konkretnu hru, ale celkovo o flash obsah. Skusal som aj novsi kernel 4.2.5, tiez aj ine distribucie zalozene na Ubuntu {32 aj 64bit} ale vsade rovnaky problem. Pod Win XP aj Vista mi flash funguje bez tohto problemu
Prikladam nieco o systeme {dal by som do spoileru ale nezistil som ako}:
System: Host: kaperko Kernel: 4.2.5-040205-generic i686 (32 bit)
Desktop: LXDE (Openbox 3.5.2) Distro: Ubuntu 15.04 vivid
CPU: Dual core Intel Pentium Dual E2180 (-MCP-) cache: 1024 KB
clock speeds: max: 2000 MHz 1: 2000 MHz 2: 2000 MHz
Memory: Array-1 capacity: 8 GB devices: 4 EC: None
Device-1: DIMM_1 size: 2 GB speed: 667 MHz type: DDR2
Device-2: DIMM_3 size: No Module Installed type: DDR2
Device-3: DIMM_2 size: 2 GB speed: 667 MHz type: DDR2
Device-4: DIMM_4 size: No Module Installed type: DDR2
Graphics: Card: Intel 82Q35 Express Integrated Graphics Controller
Display Server: X.org 1.17.1 drivers: intel (unloaded: fbdev,vesa)
tty size: 80x24 Advanced Data: N/A for root
Sensors: System Temperatures: cpu: 71.0C mobo: N/A
Fan Speeds (in rpm): cpu: N/A
Info: Processes: 176 Uptime: 6:48 Memory: 999.0/3897.1MB
Client: Shell (sudo) inxi: 2.2.16 T
