WI-FI se po uspání netbooku neprobudí
WiFi, drátové sítě atd.
Re: WI-FI se po uspání netbooku neprobudí
#11 Příspěvek od menom »
Ten subor by som tam este chvilu nechal.
Bolo by zaujimave kuknut na vypisy ked to funguje:
lsusb -t
lspci -v | grep -i hci
lsmod | grep -i hci
A ked nefunguje rovnake vypisy.
Zaujima ma ci sa pouziva naky xhci driver ....
A po prebudeni zo spanku neni problem s usb portami, vsetky funguju ?
caine
#12 Příspěvek od caine »
Před uspáním, když wi-fi funguje:
lsusb -t
/:  Bus 02.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/6p, 5000M
/:  Bus 01.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/7p, 480M
    |__ Port 1: Dev 2, If 1, Class=Video, Driver=uvcvideo, 480M
    |__ Port 1: Dev 2, If 0, Class=Video, Driver=uvcvideo, 480M
    |__ Port 4: Dev 3, If 0, Class=Hub, Driver=hub/4p, 480M
        |__ Port 2: Dev 5, If 0, Class=Vendor Specific Class, Driver=rtsx_usb, 480M
    |__ Port 5: Dev 4, If 0, Class=Wireless, Driver=btusb, 480M
    |__ Port 5: Dev 4, If 1, Class=Wireless, Driver=btusb, 480M
    |__ Port 5: Dev 4, If 2, Class=Vendor Specific Class, Driver=rtl8723bu, 480M
00:13.0 SATA controller: Intel Corporation Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series SATA Controller (rev 35) (prog-if 01 [AHCI 1.0])
	Kernel driver in use: ahci
	Kernel modules: ahci
00:14.0 USB controller: Intel Corporation Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series USB xHCI Controller (rev 35) (prog-if 30 [XHCI])
	Subsystem: Intel Corporation Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series USB xHCI Controller
	Kernel driver in use: xhci_hcd
lsmod | grep -i hci
intel_xhci_usb_role_switch    16384  0
roles                  16384  1 intel_xhci_usb_role_switch
hci_uart              122880  0
btqca                  20480  1 hci_uart
btrtl                  24576  2 hci_uart,btusb
btbcm                  16384  2 hci_uart,btusb
btintel                24576  2 hci_uart,btusb
bluetooth             544768  35 btrtl,btqca,btintel,hci_uart,btbcm,bnep,btusb,rfcomm
ahci                   40960  3
libahci                32768  1 ahci
sdhci_acpi             24576  0
sdhci                  65536  1 sdhci_acpi
Po uspání, když wi-fi nenaběhne:
lsusb -t
lsmod | grep -i hci
hci_uart              122880  0
ahci                   40960  3
sdhci_acpi             24576  0
Obě USB zdířky, jak USB2, tak i USB3 fungují po uspání normálně
#13 Příspěvek od menom »
Skutocne sa Driver=xhci_hcd pouziva a aby som to vysvetlil, mal som s tymto v minulosti problemy s uspanim a
prebudenim zo spanku, vyriesilo to pridat xhci-hcd do suboru unload_module .
Ale ked pises, ze s usb su neni problemy, tak tu cesta nevede.
Jednoznacne sa pouziva ovladac:
Ked to po zobudeni zo spanku nefunguje, by som vyskusal:
Vypnut zariadenie:
sudo ifconfig wlxac5d5c3fdd6e down
Odstranit modul rtl8723bu z jadra:
sudo modprobe -r rtl8723bu
Zasunut modul do jadra:
sudo modprobe rtl8723bu
Zapnut zariadenie:
sudo ifconfig wlxac5d5c3fdd6e up
Nasledne skontrolovat v network manageri ci je mozne sa pripojit.
Ak nepripoji tak co ukaze:
rfkill list all
Naposledy upravil(a) menom dne 12 led 2021, 19:09, celkem upraveno 1 x.
caine
#14 Příspěvek od caine »
Ne, ani potom nebylo možné se připojit.
rfkill list all
1: phy0: Wireless LAN
	Soft blocked: no
	Hard blocked: no
2: hci0: Bluetooth
	Soft blocked: yes
	Hard blocked: no
#15 Příspěvek od menom »
Je to divne.
A je nastavene automaticky pripojit k sieti ?
Pytam sa v tej suvislosti, ze to pise:
Po probuzení nenaběhne, jen se stále po cca půlminutových intervalech objevuje oznámení: "Odpojeno - nyní jste bez připojení".
Mozno to je porteba v nastaveniach zmenit ...
caine
#16 Příspěvek od caine »
Síťová připojení jsem po instalaci nijak neměnil a vypadá to takhle:
Automaticky připojit do této sítě pokud je k dispozici - ano
Priorita spojení pro automatickou aktivaci: 0
Do této sítě se smí připojit všichni uživatelé: -
#17 Příspěvek od menom »
Toto dlhodobo mam vypnute pre vsetky pripojenia v LM, a pripajam sa manualne ked chcem.
Aj pre vsetky Wired connection aj Wifi.
Moznost
Tu mam prave zapnutu.
A nemam stym automatickym odpojovanim a pripojovanim problem.
Ale opakujem pre vsetky spojenia Wired, Wifi v "Sieťové pripojenia"
caine
#18 Příspěvek od caine »
Zkusil jsem tedy obě tyto možnosti v obecném nastavení Wi-fi připojení změnit (drátové připojení tento netbook nemá), ale jedinou změnou je, že teď musím po restartu vybírat z dlouhého seznamu dostupných sousedských wifin ručně tu pravou :-)
Ještě mne napadá... už se jen tak chytám stébla... nemůže v tom hrát nějakou roli i dual boot s Windows? (Wokna byly na interní 64 GB kartě, už když jsem netbook dostal, tak jsem je tam nechal a Mint instaloval na druhý 250 GB M2 disk). A nebo nemůže nějak souviset i to, že kombinace kláves Fn+F8 - která podle vyobrazení ve Windows vypínala wi-fi, tady v linuxu nedělá nic?
Naposledy upravil(a) caine dne 12 led 2021, 21:59, celkem upraveno 1 x.
#19 Příspěvek od menom »
Podla mojich skusenosti windows moze mat vplyv taky, ze ked pomocou kombinace kláves Fn+F8 vypnes
vo windowse, tak uz nemusi wifi vobec fungovat v linuxe.
Ale pises, ze funguje, to je dobre.
K tym klavesam kombinace Fn+F8, viem, ze napriklad u HP sa o funkcnost staral modul hpwmi a
pre asus to je asus_nb_wmi ale veci sa neustale menia.
Mozno by bolo dobre hladat informacie pre tvoj konkretny Umax ako sa veci maju s "hotkeys".
caine
#20 Příspěvek od caine »
Ta nefunkční vypínací klávesa pro wi-fi mě vůbec netrápí. Uváděl jsem to jen z obavy, jestli nemůže mít nějakou souvislost.
Ale pro legraci jsem pak schválně zkusil nahodit ty Wokna a tam klávesovou zkratkou wi-fi vypnul. Když jsem ale chtěl vypnout i ntb a vrátit se zpátky do Mintu, bylo to opravdu legrační - jako bych se vrátil do mládí. Akorát místo modré smrti naběhla taková... zelená :-D Asi Wokýnka poznaly, že už k nim nepatřím, že už jsem dávno emigroval "za kopečky" (s Mátou).
Teď jsem zpátky v Mintu a vše při starém...
