Pomale spustanie systemu
Re: Pomale spustanie systemu
...tak je na case nainstalovat aj ubuntu klíner...
@redhawk Tak to vyzera ze postup zabral, celkovy rozbeh systemu od zapnutia po uplny nabeh je 2:30 min, co je asi rekord...
Dik...
U mna stacil druhy krok a system ozil...
Snapd som nemal cistit, po prikaze purge odinstalovalo vsetky aplikacie cez neho nainstalovane, takze robota na zajtra dohladavat zas vsetky prikazy a instalovat rucne...
Ten timer som nakoniec nemenil, lebo bol nastaveny na 45 minut, takze uz som ho musel niekedy prestavovat...
Tu je casovy vysledok, od druheho kroku sa v podstate nemenil...
doma@doma-HP-Pro-3400-Series-MT:~$ systemd-analyze blame
12.709s wicd.service
11.770s clamav-milter.service
9.412s NetworkManager-wait-online.service
8.747s dev-sdb1.device
7.794s schroot.service
7.099s gpm.service
7.041s loadcpufreq.service
6.657s accounts-daemon.service
5.788s gpu-manager.service
5.749s avahi-daemon.service
5.723s lm-sensors.service
5.687s clamav-daemon.service
5.676s pppd-dns.service
5.657s atopacct.service
5.655s sysstat.service
5.619s nvidia-persistenced.service
5.539s rsyslog.service
5.479s systemd-logind.service
5.401s snapd.service
5.325s ubuntu-system-adjustments.service
5.162s thermald.service
4.118s udisks2.service
3.997s ModemManager.service
doma@doma-HP-Pro-3400-Series-MT:~$ systemd-analyze critical-chain
The time after the unit is active or started is printed after the "@" character.
The time the unit takes to start is printed after the "+" character.
graphical.target @37.562s
└─multi-user.target @37.562s
└─smbd.service @37.009s +553ms
└─winbind.service @36.521s +487ms
└─nmbd.service @35.328s +1.191s
└─network-online.target @35.326s
└─NetworkManager-wait-online.service @25.914s +9.412s
└─NetworkManager.service @22.226s +3.556s
└─dbus.service @17.505s
└─basic.target @16.627s
└─sockets.target @16.610s
└─snapd.socket @16.210s +364ms
└─sysinit.target @16.050s
└─snapd.apparmor.service @15.962s +68ms
└─apparmor.service @13.858s +2.085s
└─local-fs.target @13.842s
└─run-cgmanager-fs.mount @22.565s
└─swap.target @13.085s
└─dev-disk-by\x2duuid-06fff4f2\x2d05ff\x2d4489
lines 1-23...skipping...
└─dev-disk-by\x2duuid-06fff4f2\x2d05ff\x2d4489\x2da709\x2dd15a324b970d.swap @12.979s +89ms
└─dev-disk-by\x2duuid-06fff4f2\x2d05ff\x2d4489\x2da709\x2dd15a324b970d.device @12.962s
Nižšie ako 5.4.0 nemám.
Wifi mam vypnutu v podstate, zapinam ju iba ked chcem nieco vytlacit na tlaciarni vtedy sa pripojim k wifi, lebo cez ethernetovy kabel aj ked sa jedna o totoznu siet tak to neprechadza, ale to byva tak dva razy do roka, dakedy pred par rokmi som ju pouzival ako extender, ale potom som to zrusil...
Stalo sa, hlavne je ze som si odlozil vystup z teminalu, takze dohladat by to malo ist rychlo, akurat ta instalacia zabere par hodin, po pravde som to neocakaval ani ja, vacsinou ked aj nieco odinstalujem zo snapd tak adresar ostava a aj nasatvenia, ale teraz to zobralo vsetko hopom ani som nestihol mrknut...
Tych par sekund o co to skratilo bude zas naspat po doinstalovani, ale aspon sme mudrejsi...
Fakt ten druhy krok, bol najefektivnejsi, po nom cely system ozil...
Este tak poriesit to stale menenie dev/sdb za dev/sdc, neviem preco to robi, ale po kazdom restarte si iba tento Mintacky disk meni stale cestu k sebe...
Co konkretne mam hladat v synapticu?
Obsah fstab
Obsah fstab
# <file system> <mount point> <type> <options> <dump> <pass>
UUID=fd97e47d-9f39-4c8c-8902-700ecc7b3897 / ext4 errors=remount-ro 0 1
UUID=8d38a690-24ff-4964-9487-1f9582597fbf /home ext4 defaults 0 2
UUID=06fff4f2-05ff-4489-a709-d15a324b970d none swap sw 0 0
UUID=DACEABB4CEAB86FB /media/doma/DATANEW ntfs defaults 0 0
/dev/disk/by-id/usb-Multiple_Card_Reader_058F63666433-0:0 /mnt/usb-Multiple_Card_Reader_058F63666433-0:0 auto nosuid,nodev,nofail,x-gvfs-show,noauto 0 0https://drive.google.com/folderview?id= ... sp=sharing
No tu utilitu gnome-disk
Ja fakt neviem asi som natvrdly, ale co konkretne mam pozriet v tom synapticu? Popripade co mam hladat celkovo?
Tak po terajsom spusteni systemu moj prvy disk uz nieje sda, ale sdb a ostatne sa posunuli o pismeno dalej, je v tom riadny gulas... Este ma napadla otazka dva disku su nastavene na zavadzanie systemu nemoze byt problem vtom ze pri zmene zavadzaca zmeni oznacenie diskov?
Tak teraz som uplne mimo, preto som pridal screenshot zo synapticsu ze je sucastou systemu uz davno a aj to co sa mi nanom nepozdavalo lebo z obrazku vyplyva ze sa tam nieco asi nieje v poriadku ked nieco poskodzuje a s niecim prichadza do konfliktu, ale je zarazajuce ze sam zo sebou...
Dalsia rad co mam skontrolovat? Fakt by som to chcel doriesit nech my conky moze stale sledovat teploty na diskoch...
Ozaj dnes som musel zapnut win, lebo som skusal program na upravu cifernikov na amazfit hodinky a skoro som okoktavel, ten win nabehol do 2 minut co doteraz bolo ako pri linuxe 5-7 minut...
Tak toto som nekontroloval, ale kedze disky neodpajam a nemenim fyzicky musi sa jednat o softwerovy problem...zeleno píše: 23 led 2022, 20:04
Záleží na tom , ktorý disk máš v biose nastavený ako prvý, ten sa nastaví ako sda a ďalší disk vidí z jeho pohľadu ako sdb a opačne. Tiež to tak mám. Aby sa to nemenilo, musel by PC bootovať a mať Grub vždy na tom istom disku.
Opisem to este lepsie, na win mam nastavene zavadzanie systemu kde je 3jity multiboot, jeden win, pod win mam nainstalovane ubunutu 12.xx ktore sa instalovalo priamo pod win ale ma moznost vlastneho bootovania a posledny boot je na testovanie distier ktore tam nahravam...
Dalsi disk kde mam cisto LM som tiez nastavil na zavadzanie systemu, aj ked asi omylom, lebo raz klakol zavadzac na win disku a pri obnove som natstavil zavadzanie na ten LM disk a tam som pomocou grubcustomizera obnovil povodny zavadzac a teraz fakt netusim z ktoreho disku sa spusta zavaadzac ci z win disku, alebo z LM disku a tu moze nastat problem ak to zavadza po kazdom restarte z ineho disku a to by mohlo sposobovat zmeny v poradi diskov, aspon tak moj odhad, len neviem ako to overit...
Tak z tej kopy prikazov som v podstate iba pochopil ze sa jedna o nastavenie bootovacieho menu a ako sa ma spravat system dalej po zvoleni jednotlivych poloziek, ale to je asi tak vsetko co z toho viem vycitat... Napriklad puupy linux som cez grub customizer zadaval rucne ja a chvilu trvalo lez som nasiel ako to spravne zadat....
Takze paradox v grub.cfg je win disk pripojeny ako sda, ale ked som teraz pozrel na program disk tak my vypisuje ze prave win disk je vedeny ako sdb a sda nieje vobec priradeny.... To je ina divocina...
# DO NOT EDIT THIS FILE
# It is automatically generated by grub-mkconfig using templates
# from /etc/grub.d and settings from /etc/default/grub
### BEGIN /etc/grub.d/00_header ###
if [ -s $prefix/grubenv ]; then
set have_grubenv=true
load_env
fi
if [ "${next_entry}" ] ; then
set default="${next_entry}"
set next_entry=
save_env next_entry
set boot_once=true
else
set default="0"
fi
if [ x"${feature_menuentry_id}" = xy ]; then
menuentry_id_option="--id"
else
menuentry_id_option=""
fi
export menuentry_id_option
if [ "${prev_saved_entry}" ]; then
set saved_entry="${prev_saved_entry}"
save_env saved_entry
set prev_saved_entry=
save_env prev_saved_entry
set boot_once=true
fi
function savedefault {
if [ -z "${boot_once}" ]; then
saved_entry="${chosen}"
fi
function recordfail {
set recordfail=1
if [ -n "${have_grubenv}" ]; then if [ -z "${boot_once}" ]; then save_env recordfail; fi; fi
function load_video {
if [ x$feature_all_video_module = xy ]; then
insmod all_video
else
insmod efi_gop
insmod efi_uga
insmod ieee1275_fb
insmod vbe
insmod vga
insmod video_bochs
insmod video_cirrus
fi
insmod part_msdos
insmod ext2
set root='hd2,msdos1'
if [ x$feature_platform_search_hint = xy ]; then
search --no-floppy --fs-uuid --set=root --hint-bios=hd2,msdos1 --hint-efi=hd2,msdos1 --hint-baremetal=ahci2,msdos1 fd97e47d-9f39-4c8c-8902-700ecc7b3897
else
search --no-floppy --fs-uuid --set=root fd97e47d-9f39-4c8c-8902-700ecc7b3897
fi
if loadfont /boot/grub/fonts/UbuntuMono32.pf2 ; then
set gfxmode=auto
load_video
insmod gfxterm
set locale_dir=$prefix/locale
set lang=sk_SK
insmod gettext
fi
terminal_output gfxterm
insmod part_msdos
insmod ext2
else
fi
insmod gfxmenu
insmod png
set theme=($root)/boot/grub/themes/linuxmint-2k/theme.txt
export theme
if [ "${recordfail}" = 1 ] ; then
set timeout=30
else
if [ x$feature_timeout_style = xy ] ; then
set timeout_style=hidden
set timeout=10
# Fallback hidden-timeout code in case the timeout_style feature is
# unavailable.
elif sleep --interruptible 10 ; then
set timeout=0
fi
fi
### END /etc/grub.d/00_header ###
### BEGIN /etc/grub.d/05_debian_theme ###
insmod part_msdos
insmod ext2
set root='hd2,msdos3'
search --no-floppy --fs-uuid --set=root --hint-bios=hd2,msdos3 --hint-efi=hd2,msdos3 --hint-baremetal=ahci2,msdos3 8d38a690-24ff-4964-9487-1f9582597fbf
else
search --no-floppy --fs-uuid --set=root 8d38a690-24ff-4964-9487-1f9582597fbf
fi
insmod jpeg
if background_image /doma/Obrázky/linux.jpg; then
set color_normal=light-gray/black
set color_highlight=light-green/dark-gray
else
set menu_color_normal=white/black
set menu_color_highlight=black/light-gray
fi
### END /etc/grub.d/05_debian_theme ###
### BEGIN /etc/grub.d/06_mint_theme ###
set menu_color_highlight=white/light-gray
### END /etc/grub.d/06_mint_theme ###
### BEGIN /etc/grub.d/10_linux_proxy ###
function gfxmode {
set gfxpayload="${1}"
if [ "${1}" = "keep" ]; then
set vt_handoff=vt.handoff=1
else
set vt_handoff=
fi
if [ "${recordfail}" != 1 ]; then
if [ -e ${prefix}/gfxblacklist.txt ]; then
if hwmatch ${prefix}/gfxblacklist.txt 3; then
if [ ${match} = 0 ]; then
set linux_gfx_mode=keep
else
set linux_gfx_mode=text
fi
else
fi
else
fi
else
fi
export linux_gfx_mode
menuentry "Linux Mint" --class linuxmint --class gnu-linux --class gnu --class os $menuentry_id_option 'Linux Mint 19.3 Cinnamon' {
recordfail
load_video
gfxmode $linux_gfx_mode
insmod gzio
if [ x$grub_platform = xxen ]; then insmod xzio; insmod lzopio; fi
insmod part_msdos
insmod ext2
else
fi
linux /boot/vmlinuz-5.4.0-92-generic root=UUID=fd97e47d-9f39-4c8c-8902-700ecc7b3897 ro ipv6.disable=1 intel_idle.max_cstate=1
initrd /boot/initrd.img-5.4.0-92-generic
submenu "Advanced options for Linux Mint"{
menuentry "Ubuntu, s jadrom Linux 5.4.0-92-generic" --class linuxmint --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-5.4.0-92-generic-advanced-fd97e47d-9f39-4c8c-8902-700ecc7b3897' {
recordfail
load_video
insmod gzio
insmod part_msdos
insmod ext2
else
fi
echo 'Načítava sa Linux 5.4.0-92-generic ...'
echo 'Načítava sa počiatočný ramdisk ...'
menuentry "Ubuntu, with Linux 5.4.0-92-generic (recovery mode)" --class linuxmint --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-5.4.0-92-generic-recovery-fd97e47d-9f39-4c8c-8902-700ecc7b3897' {
recordfail
load_video
insmod gzio
insmod part_msdos
insmod ext2
else
fi
linux /boot/vmlinuz-5.4.0-92-generic root=UUID=fd97e47d-9f39-4c8c-8902-700ecc7b3897 ro recovery nomodeset dis_ucode_ldr
menuentry "Ubuntu, s jadrom Linux 5.4.0-91-generic" --class linuxmint --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-5.4.0-91-generic-advanced-fd97e47d-9f39-4c8c-8902-700ecc7b3897' {
recordfail
load_video
insmod gzio
insmod part_msdos
insmod ext2
else
fi
echo 'Načítava sa Linux 5.4.0-91-generic ...'
linux /boot/vmlinuz-5.4.0-91-generic root=UUID=fd97e47d-9f39-4c8c-8902-700ecc7b3897 ro ipv6.disable=1 intel_idle.max_cstate=1
initrd /boot/initrd.img-5.4.0-91-generic
menuentry "Ubuntu, with Linux 5.4.0-91-generic (recovery mode)" --class linuxmint --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-5.4.0-91-generic-recovery-fd97e47d-9f39-4c8c-8902-700ecc7b3897' {
recordfail
load_video
insmod gzio
insmod part_msdos
insmod ext2
else
fi
linux /boot/vmlinuz-5.4.0-91-generic root=UUID=fd97e47d-9f39-4c8c-8902-700ecc7b3897 ro recovery nomodeset dis_ucode_ldr
### END /etc/grub.d/10_linux_proxy ###
### BEGIN /etc/grub.d/13_lupin ###
### END /etc/grub.d/13_lupin ###
### BEGIN /etc/grub.d/20_ipxe ###
menuentry "Network boot (iPXE)" --users "" --class network {
insmod part_msdos
insmod ext2
else
fi
linux16 /boot/ipxe.lkrn
### END /etc/grub.d/20_ipxe ###
### BEGIN /etc/grub.d/21_linux_xen ###
### END /etc/grub.d/21_linux_xen ###
### BEGIN /etc/grub.d/22_memtest86+ ###
menuentry 'Memory test (memtest86+)' {
insmod part_msdos
insmod ext2
else
fi
knetbsd /boot/memtest86+.elf
menuentry 'Memory test (memtest86+, serial console 115200)' {
insmod part_msdos
insmod ext2
else
fi
linux16 /boot/memtest86+.bin console=ttyS0,115200n8
### END /etc/grub.d/22_memtest86+ ###
### BEGIN /etc/grub.d/30_os-prober_proxy ###
menuentry "Windows 7 (on /dev/sda1)" --class windows --class os $menuentry_id_option 'osprober-chain-FCC2DB9FC2DB5D08' {
insmod part_msdos
insmod ntfs
set root='hd0,msdos1'
search --no-floppy --fs-uuid --set=root --hint-bios=hd0,msdos1 --hint-efi=hd0,msdos1 --hint-baremetal=ahci0,msdos1 FCC2DB9FC2DB5D08
else
search --no-floppy --fs-uuid --set=root FCC2DB9FC2DB5D08
fi
parttool ${root} hidden-
chainloader +1
menuentry "Windows 7 (on /dev/sda2)" --class windows --class os $menuentry_id_option 'osprober-chain-18CCDC90CCDC6A10' {
insmod part_msdos
insmod ntfs
set root='hd0,msdos2'
search --no-floppy --fs-uuid --set=root --hint-bios=hd0,msdos2 --hint-efi=hd0,msdos2 --hint-baremetal=ahci0,msdos2 18CCDC90CCDC6A10
else
search --no-floppy --fs-uuid --set=root 18CCDC90CCDC6A10
fi
chainloader +1
menuentry "Windows Recovery Environment (on /dev/sda3)" --class windows --class os $menuentry_id_option 'osprober-chain-60529DD1529DABF2' {
insmod part_msdos
insmod ntfs
set root='hd0,msdos3'
search --no-floppy --fs-uuid --set=root --hint-bios=hd0,msdos3 --hint-efi=hd0,msdos3 --hint-baremetal=ahci0,msdos3 60529DD1529DABF2
else
search --no-floppy --fs-uuid --set=root 60529DD1529DABF2
fi
drivemap -s (hd0) ${root}
chainloader +1
menuentry "Kali GNU/Linux Rolling (on /dev/sda5)" --class kali --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-simple-b60ca71b-cbe4-46b7-8341-129c690be5d2' {
insmod part_msdos
insmod ext2
set root='hd0,msdos5'
search --no-floppy --fs-uuid --set=root --hint-bios=hd0,msdos5 --hint-efi=hd0,msdos5 --hint-baremetal=ahci0,msdos5 b60ca71b-cbe4-46b7-8341-129c690be5d2
else
search --no-floppy --fs-uuid --set=root b60ca71b-cbe4-46b7-8341-129c690be5d2
fi
linux /boot/vmlinuz-5.10.0-kali9-amd64 root=UUID=b60ca71b-cbe4-46b7-8341-129c690be5d2 ro quiet splash
initrd /boot/initrd.img-5.10.0-kali9-amd64
submenu "Advanced options for Kali GNU/Linux Rolling (on /dev/sda5)"{
menuentry "Kali GNU/Linux (on /dev/sda5)" --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/vmlinuz-5.10.0-kali9-amd64--b60ca71b-cbe4-46b7-8341-129c690be5d2' {
insmod part_msdos
insmod ext2
else
fi
menuentry "Kali GNU/Linux, with Linux 5.10.0-kali9-amd64 (on /dev/sda5)" --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/vmlinuz-5.10.0-kali9-amd64--b60ca71b-cbe4-46b7-8341-129c690be5d2' {
insmod part_msdos
insmod ext2
else
fi
menuentry "Kali GNU/Linux, with Linux 5.10.0-kali9-amd64 (recovery mode) (on /dev/sda5)" --class gnu-linux --class gnu --class os $menuentry_id_option 'osprober-gnulinux-/boot/vmlinuz-5.10.0-kali9-amd64-root=UUID=b60ca71b-cbe4-46b7-8341-129c690be5d2 ro single-b60ca71b-cbe4-46b7-8341-129c690be5d2' {
insmod part_msdos
insmod ext2
else
fi
linux /boot/vmlinuz-5.10.0-kali9-amd64 root=UUID=b60ca71b-cbe4-46b7-8341-129c690be5d2 ro single
set timeout_style=menu
if [ "${timeout}" = 0 ]; then
set timeout=10
fi
### END /etc/grub.d/30_os-prober_proxy ###
### BEGIN /etc/grub.d/31_uefi-firmware ###
### END /etc/grub.d/31_uefi-firmware ###
### BEGIN /etc/grub.d/40_custom_proxy ###
# This file provides an easy way to add custom menu entries. Simply type the
# menu entries you want to add after this comment. Be careful not to change
# the 'exec tail' line above.
menuentry "puppy linux"{
set root='(hd2,1)'
search --no-floppy --fs-uuid --set=root DACEABB4CEAB86FB
linux /slacko/vmlinuz root=UUID=DACEABB4CEAB86FB pmedia=atahd psubdir=slacko
initrd /slacko/initrd.gz
### END /etc/grub.d/40_custom_proxy ###
### BEGIN /etc/grub.d/41_multisystem ###
# Ajout de MultiSystem
### MULTISYSTEM MENU
menuentry "PLoP Boot Manager" {
linux16 /boot/plpbt
menuentry "Smart Boot Manager" {
search --set -f /boot/sbootmgr.dsk
linux16 /boot/memdisk
initrd16 /boot/sbootmgr.dsk
### FIN MULTISYSTEM MENU
### END /etc/grub.d/41_multisystem ###
### BEGIN /etc/grub.d/42_custom ###
if [ -f ${config_directory}/custom.cfg ]; then
source ${config_directory}/custom.cfg
elif [ -z "${config_directory}" -a -f $prefix/custom.cfg ]; then
source $prefix/custom.cfg;
fi
### END /etc/grub.d/42_custom ###https://drive.google.com/folderview?id= ... sp=sharing
