Jak obnovit smazané kontakty na Sim kartě z telefonu
bino
#1 Příspěvek od bino »
Matka má Aligator A870 podařilo se mě smazat všechny kontakty jak ze Sim karty tak s telefonu.Aligator A870 načetl jen pamětovou kartu musel jsem vše předělat do mého telefonu kde se mě načetla i SIM karta.Zkoušel jsem testdisk ale nevím jak dál:
TestDisk is free data recovery software designed to help recover lost
partitions and/or make non-booting disks bootable again when these symptoms
are caused by faulty software, certain types of viruses or human error.
It can also be used to repair some filesystem errors.
Information gathered during TestDisk use can be recorded for later
review. If you choose to create the text file, testdisk.log , it
will contain TestDisk options, technical information and various
outputs; including any folder/file names TestDisk was used to find and
list onscreen.
Use arrow keys to select, then press Enter key:
>[ Create ] Create a new log file
[ Append ] Append information to log file
[ No Log ] Don't record anything
TestDisk is free software, and
comes with ABSOLUTELY NO WARRANTY.
Select a media (use Arrow keys, then press Enter):
>Disk /dev/sda - 500 GB / 465 GiB - WDC WD5000AAKS-00V1A0
Disk /dev/sdb - 203 GB / 189 GiB - Maxtor 6B200M0
Disk /dev/sdc - 1000 GB / 931 GiB - ST1000DM003-9YN162
Disk /dev/sdd - 1000 GB / 931 GiB - ADATA HV620
Disk /dev/sde - 15 GB / 14 GiB - JetFlash Transcend 16GB
Disk /dev/sdf - 15 GB / 14 GiB - Kingston DataTraveler 2.0
Disk /dev/sdi - 107 MB / 102 MiB - SAMSUNG GT-S5610
Disk /dev/sdj - 3960 MB / 3777 MiB - SAMSUNG GT-S5610 CARD
>[Proceed ] [ Quit ]
Note: Disk capacity must be correctly detected for a successful recovery.
If a disk listed above has incorrect size, check HD jumper settings, BIOS
detection, and install the latest OS patches and disk drivers.
Please select the partition table type, press Enter when done.
>[Intel ] Intel/PC partition
[EFI GPT] EFI GPT partition map (Mac i386, some x86_64...)
[Humax ] Humax partition table
[Mac ] Apple partition map
[None ] Non partitioned media
[Sun ] Sun Solaris partition
[XBox ] XBox partition
[Return ] Return to disk selection
Hint: None partition table type has been detected.
Note: Do NOT select 'None' for media with only a single partition. It's very
rare for a drive to be 'Non-partitioned'.
CHS 1011 4 52 - sector size=512
>[ Analyse ] Analyse current partition structure and search for lost partitions
[ Advanced ] Filesystem Utils
[ Geometry ] Change disk geometry
[ Options ] Modify options
[ MBR Code ] Write TestDisk MBR code to first sector
[ Delete ] Delete all data in the partition table
[ Quit ] Return to disk selection
Note: Correct disk geometry is required for a successful recovery. 'Analyse'
process may give some warnings if it thinks the logical geometry is mismatched.
Disk /dev/sdi - 107 MB / 102 MiB - CHS 1011 4 52
Current partition structure:
Partition Start End Size in sectors
No partition is bootable
*=Primary bootable P=Primary L=Logical E=Extended D=Deleted
>[Quick Search]
Try to locate partition
Keys A: add partition, L: load backup, Enter: to continue
No partition 0 0 1 1010 3 52 210288
>[Cylinder] [ Head ] [ Sector ] [Cylinder] [ Head ] [ Sector ]
[ Type ] [ Done ]
Change starting cylinder
>List of partition type
01 FAT12 50 OnTrack DM RO a9 NetBSD
02 XENIX root 51 OnTrack DM RW-NOVEL ab Darwin boot
03 XENIX /usr 52 CP/M-Microport V/386 af HFS
04 FAT16 <32M 53 OnTrack DM WO ??? b7 BSDI
06 FAT16 >32M 54 OnTrack DM DDO b8 BSDI swap
07 HPFS - NTFS 55 EZ-Drive bc Acronis
09 AIX data 56 GoldenBow VFeature be Solaris boot
0a OS/2 Boot Manager 61 SpeedStor bf Solaris
0b FAT32 63 Unixware, HURD, SCO c1 secured FAT12
0c FAT32 LBA 64 NetWare 286 c4 secured FAT16
0e FAT16 LBA 65 NetWare 3.11+ c6 sec. Huge-bad FAT16
Next
>[Proceed ]
Go set the partition type
Dál už nevím jak na to.
Re: Jak obnovit smazané kontakty na Sim kartě z telefonu
#2 Příspěvek od admin »
A jak toto vlákno souvisí s Linux Mintem? Ještě jeden podobný pokus a bude z toho banán!
bino
#3 Příspěvek od bino »
Tak to se omlouvám myslel jsem že když mám Linux Mint a chtěl jsem jen poradit jak v Linux Mintu používat program testdik.
Díval jsem se tento návod
http://wiki.ubuntu.cz/syst%C3%A9m/datov ... redirect=1
ale nešlo mě to chtěl jsem vědět kde jsem udělal chybu.
bino
#4 Příspěvek od bino »
Psal jsem to rychle protože jsem si už nevěděl rady tady píši na to co jsem zapoměl napsat mám
Linux jirka-To-be-filled-by-O-E-M 3.13.0-24-generic #47-Ubuntu SMP Fri May 2 23:30:00 UTC 2014 x86_64 x86_64 x86_64 GNU/Linux
LSB Version: core-2.0-amd64:core-2.0-noarch:core-3.0-amd64:core-3.0-noarch:core-3.1-amd64:core-3.1-noarch:core-3.2-amd64:core-3.2-noarch:core-4.0-amd64:core-4.0-noarch:core-4.1-amd64:core-4.1-noarch:security-4.0-amd64:security-4.0-noarch:security-4.1-amd64:security-4.1-noarch
Distributor ID: LinuxMint
Description: Linux Mint 17 Qiana
Release: 17
Codename: qiana
#5 Příspěvek od admin »
Takže celé vlákno přesunuji tam, kam patří, do fóra Software. Jinak to je přesně příklad toho, proč zde tolik zdůrazňujeme, aby dotazy byly pokládány srozumitelně a s uvedením verze mintu, jádra, prac. prostředí apod.
