Minecraft
Pahejl1987
Minecraft
Ahoj, nepokoušel se někdo zprovoznit Minecraft přes wine? Píše mi to, že to chce Javu....Mám v Mintu nainstalovanou, ale zřejmě to chce javu přes wine...Nevím jak nato:-(
Acer v 15 Touch
Re: Minecraft
Minecraft funguje nativně bez Wine. Spustitelný jar soubor je na stránkách výrobce.
https://minecraft.net/store/minecraft
Pahejl1987
Re: Minecraft
Asi jsem trotl, po stažení od tut
píše : The file '/home/tomas/Stažené/Minecraft.jar' is not marked as executable. If this was downloaded or copied from an untrusted source, it may be dangerous to run. For more details, read about the executable bit
Výpis ze stránek:
https://wiki.ubuntu.com/Security/ExecutableBit
Other languages: Español
Software and software installers in Ubuntu need to be marked as "executable" in order to be treated as runnable programs. This indicates to Ubuntu that the file is actually software and is trusted. Normally and preferably software should be installed using the Ubuntu Software Center which is the primary source of software in Ubuntu.
You should only mark a file as executable via the file permissions if you know what you are doing.
Files from outside the supported software repository are not marked as "executable" since they did not get installed via a trusted source. Because of this, attempting to open/run downloaded files that are software will fail. These files are blocked for security reasons to help unsuspecting users avoid malware (i.e. malicious software like trojan horses, worms, and viruses).
Ubuntu Policy requires that software not marked as executable not be runnable. One of the most common ways you will see this is by having a package ship a .desktop file for a MimeType which executes the target file (.EXE, .JAR, etc). This is not allowed unless the target file is already executable (or installed by a trusted software repository).
Ptal jsem se na wine, jelikož mám stažený minecraft z torrentu
https://minecraft.net/downloadpíše : The file '/home/tomas/Stažené/Minecraft.jar' is not marked as executable. If this was downloaded or copied from an untrusted source, it may be dangerous to run. For more details, read about the executable bit
Výpis ze stránek:
Acer v 15 Touch
Pahejl1987
Re: Minecraft
Jsem pitomej:D Už jsem to nastavil jako spustitelný soubor:D:DALe ok, jede mi Demo v Jave,,,,,Teď tedy prosím o radu jak na to ve wine:D
Acer v 15 Touch
Pahejl1987
Re: Minecraft
Tak vyřešeno:-)
Kdyby měl někdo zájem-
Java, free:-) Jedeto:-) Děkuji za pomoc...
Acer v 15 Touch
Re: Minecraft
Java minecraft pro Linux není demo, ale plná verze pro uživatele, kteří mají licenci.
Tvůj odkaz jsem smazal, protože vede na ne zrovna korektní stránky.
Re: Minecraft
ps1 - Kdo si hraje, nezlobí
ps2 - Kernel je jádro, Kelner je ďůlčík
