Tak po poslednom fiasku z jadrom 3.19.0 a po jeho odinstalovani sa my zmenilo rozlisenie v terminali, nie v emulatore to znamena ked dam ctr+alt+F1-F7 tak sa prepnem do terminalu ktory vzdy maval rovnake rozlisenie. Teraz su tam take male pismenka ze na to poriadne nevidim a neviem ako to prepnut viete niekto poradit ako na to? Dik za rady...
Este pre upresnenie pouzivam Linux Mint 17 cinnamon 64-bit 2.2.16 z jadrom 3.18.5.
Zmena rozlisenia terminlau
Nižšie ako 5.4.0 nemám.
HP-Pro-3400-Series-MT
Re: Zmena rozlisenia terminlau
Ahoj, asi ti to zapsalo něco do grubu, hoď sem výpis z terminálu příkazu:
cat /etc/default/grub
# If you change this file, run 'update-grub' afterwards to update
# /boot/grub/grub.cfg.
# For full documentation of the options in this file, see:
# info -f grub -n 'Simple configuration'
GRUB_DEFAULT="0"
#GRUB_HIDDEN_TIMEOUT="0"
GRUB_HIDDEN_TIMEOUT_QUIET="true"
GRUB_TIMEOUT="10"
GRUB_DISTRIBUTOR="`lsb_release -i -s 2> /dev/null || echo Debian`"
GRUB_CMDLINE_LINUX=""
# Uncomment to enable BadRAM filtering, modify to suit your needs
# This works with Linux (no patch required) and with any kernel that obtains
# the memory map information from GRUB (GNU Mach, kernel of FreeBSD ...)
#GRUB_BADRAM="0x01234567,0xfefefefe,0x89abcdef,0xefefefef"
# Uncomment to disable graphical terminal (grub-pc only)
#GRUB_TERMINAL="console"
# The resolution used on graphical terminal
# note that you can use only modes which your graphic card supports via VBE
# you can see them in real GRUB with the command `vbeinfo'
#GRUB_GFXMODE="640x480"
# Uncomment if you don't want GRUB to pass "root=UUID=xxx" parameter to Linux
#GRUB_DISABLE_LINUX_UUID="true"
# Uncomment to disable generation of recovery mode menu entries
#GRUB_DISABLE_RECOVERY="true"
# Uncomment to get a beep at grub start
#GRUB_INIT_TUNE="480 440 1"
GRUB_FONT="/boot/grub/unicode.pf2
GRUB_DEFAULT="0"
GRUB_TIMEOUT="10"
Allconius dik, az teraz ma to napadlo, moj system sa casto sprava nepochopytelne a toto je jedna z tych situacii, aj ked ma nastavene 640x480 tak grub a vsteko v skutocnosti islo na 1920x1080. Po tvojej poznamke a po vypise my to nedalo a pouzil som grub customizer ktory som nemal zapnuty ani nepamatam a zacal som prestavovat hodnoti a nastavyl som mu najskor 640x480 a po restarte uz islo vsetko na 640x480, ale samozerejme ze to boli kone tak som vyskusal 800x600 ale grub bol cely rozbyty, tak este vyskusam 1280X720 snad uz bude grub v poriadku. Oznacim vlakno za vyriesene ale aj tak ma zaujima co je vo veci preco isiel grub aj terminalove rozhranie na 1920x1080 aj ked mal nastavenych 640x480? Este ma zaraza jedna vec pri spustani sa my zobrazuje logo LM a to sa my doteraz zobrazovalo iba pri nouvea ovladacoch tak teraz fakt neviem. To posledne odinstalovanie jadra asi rozhodilo neako system...
Tak po vlastnych slovach som dostal typicky windowsacky napad preinstalovat ovladace grafiky dal som mu prikaz sudo apt-get install nvidia-current a div sa svete stiahol si ovladace nv304 a konecne zmizlo logo LM a miesto neho sa objavyl stary znamy nazov Linix Mint 17 zo styrmi bielimy bodkamy pod napisom, tak a potom som dal preinstalovat ovladace naspat na nv 346 a vsetko bezi ako ma okrem jednej veci, zas v terminale nezobrazuje znaky z diakritikou a miesto nich dava rozne graficke znaky v emulatore a v cinnamone ide vsetko v pohode mate niekto neaku radu co je zas s tym?...
Tak nakoniec som nasiel navod na ubuntu fore ohladom zmeny znakovej sady. http://wiki.ubuntu.cz/syst%C3%A9m/p%C5% ... redirect=1 Aj ked prva cast tohto navodu my nesla tak druha hej a ukazalo sa ako uz pred tym ze ked som zmenil znakovu sadu v konzole a vratil spat povodnu tak sa konecne rozbehla konzola tak ako mala...
