Disconnected-You are offline now
WiFi, drátové sítě atd.
david10
#1 Příspěvek od david10 »
Poradi mi niekto viem ze ste to tu rozoberali ale neviem sa pohnut.. naistaloval som si linux..a wifi siet mi vyhlada..ale nejde mi pripojit tak aby sla.. mam toshibu a300
Re: Disconnected-You are offline now
Dal si malo informacii,
skus sem kopirovat co odpovie Terminal po zadani prikazov:
inxi -F
sudo lshw | grep Wire -A12
lspci -k | grep Wire -A3
david10
#3 Příspěvek od david10 »
dakujem za ochotu. to stredne mi nede pyta heslo a nejde zadat
Host: David-Satellite-A300 Kernel: 3.13.0-37-generic i686 (32 bit) Desktop: Gnome Distro: Linux Mint 17.1 Rebecca
Machine: System: TOSHIBA (portable) product: Satellite A300 version: PSAGCE-0KC008CZ
Mobo: TOSHIBA model: Portable PC Bios: INSYDE version: 1.90 date: 03/20/2009
CPU: Dual core Pentium CPU T4200 (-MCP-) cache: 1024 KB flags: (lm nx sse sse2 sse3 ssse3)
Clock Speeds: 1: 1200.00 MHz 2: 1200.00 MHz
Graphics: Card: Advanced Micro Devices [AMD/ATI] RV620/M82 [Mobility Radeon HD 3450/3470]
X.Org: 1.15.1 drivers: ati,radeon (unloaded: fbdev,vesa) Resolution: 1280x800@60.0hz
GLX Renderer: Gallium 0.4 on AMD RV620 GLX Version: 3.0 Mesa 10.1.3
Audio: Card: Intel 82801I (ICH9 Family) HD Audio Controller driver: snd_hda_intel Sound: ALSA ver: k3.13.0-37-generic
Network: Card-1: Realtek RTL8101E/RTL8102E PCI Express Fast Ethernet controller driver: r8169
IF: eth0 state: down mac: 00:1e:33:de:df:68
Card-2: Qualcomm Atheros AR242x / AR542x Wireless Network Adapter (PCI-Express) driver: ath5k
IF: wlan0 state: down mac: 00:24:d2:ea:e2:95
Drives: HDD Total Size: 324.0GB (1.7% used) 1: id: /dev/sda model: WDC_WD3200BEVS size: 320.1GB
2: USB id: /dev/sdb model: DT_101_G2 size: 3.9GB
Partition: ID: / size: 290G used: 3.8G (2%) fs: ext4 ID: swap-1 size: 4.29GB used: 0.00GB (0%) fs: swap
Sensors: System Temperatures: cpu: 59.0C mobo: N/A
Fan Speeds (in rpm): cpu: N/A
Info: Processes: 155 Uptime: 8 min Memory: 307.4/4032.1MB Client: Shell inxi: 1.8.4
03:00.0 Ethernet controller: Qualcomm Atheros AR242x / AR542x Wireless Network Adapter (PCI-Express) (rev 01)
Subsystem: Askey Computer Corp. WLL3141 (Toshiba PA3613U-1MPC) 802.11bg Wireless Mini PCIe Card
Kernel driver in use: ath5k
04:06.0 FireWire (IEEE 1394): Ricoh Co Ltd R5C832 IEEE 1394 Controller (rev 05)
Subsystem: Toshiba America Info Systems Device ff1e
Kernel driver in use: firewire_ohci
04:06.1 SD Host controller: Ricoh Co Ltd R5C822 SD/SDIO/MMC/MS/MSPro Host Adapter (rev 22)
To heslo sa da zadat, len neukazuje hviezdicky ako vo windowse.
Treba ho napisat a stlacit Enter.
Tato karta je v linuxe vela rokov dobre podporovana, ovladac je spravny ath5k.
Predpokladam ze heslo si zadal spravne (aj male a velke pismena)
Neni to tak, ze sa to pripoji a odpoji a potom znova dokola ?
Ak hej tak v Sietovych nastaveniach pre tu konkretnu siet si to najdi oznac a daj Upravit.
Pohladaj nieco ako Automaticky pripojit a zrus to aby to nebolo zaskrtnute, daj ulozit.
Potom sa rucne pripojis.
Ja to vypinam pre vsetky dostupne pripojenia aj po kabli (wired).
david10
#5 Příspěvek od david10 »
skusil som nic..akurat ked si pyta heslo pre overenie totoznosti tak mi nejde kliknut na pripojit.. ide iba pri urcitom pocte znakov.. ale to neni rovnake ako dlzka mojho hesla k wifi.. tiez signal ukazuje vcelku dost slaby 30% nato ze je to pri routeri..
product: AR242x / AR542x Wireless Network Adapter (PCI-Express)
vendor: Qualcomm Atheros
physical id: 0
bus info: pci@0000:03:00.0
logical name: wlan0
version: 01
serial: 00:24:d2:ea:e2:95
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress msix bus_master cap_list ethernet physical wireless
configuration: broadcast=yes driver=ath5k driverversion=3.13.0-37-generic firmware=N/A latency=0 link=no multicast=yes wireless=IEEE 802.11bg
resources: irq:17 memory:d4200000-d420ffff
*-pci:3
description: FireWire (IEEE 1394)
product: R5C832 IEEE 1394 Controller
vendor: Ricoh Co Ltd
physical id: 6
bus info: pci@0000:04:06.0
version: 05
width: 32 bits
clock: 33MHz
capabilities: pm ohci bus_master cap_list
configuration: driver=firewire_ohci latency=64 maxlatency=4 mingnt=2
resources: irq:17 memory:d3100000-d31007ff
*-generic:0
#6 Příspěvek od menom »
V tom vypise je vsetko OK.
Ake pouzivas sifrovanie.
Dufam ze nie WEP.
A ake mas v nastaveni pre tuto konkretnu siet ?
david10
#7 Příspěvek od david10 »
asi WEP..ale ja som v tychto temach amater.. neviem kde co nastavit.. v nastaveniach je WEP osobny.. ake mam dat ? alebo to mam odfotit ?
#8 Příspěvek od menom »
Nuz dolezite je aby to bolo rovnake ako v routri.
Obrazok vela napovie.
Ak si to v routri nikdy nenastavoval, tak to nechaj niekomu skusenejsiemu.
A dalsie riadky ignoruj.
Ak sa nebojis, ze to pokazis, tak (Daj si WPA2 v routri.
V linuxe pre tuto siet v nastaveniach by to malo byt Osobne WPA a WPA2.)
Potom aj vo vsetkych ostatnych zariadeniach treba nastavit to iste.(mobil,tablet)
Pozor na velkost pismen, specialne znaky a aj medzera sa pocita ako znak.
david10
#9 Příspěvek od david10 »
mne vsade inde ide internet okrem linuxu.. a na routri je wep/wpa .. cervena bodka pri tom svieti.. takze podrobny navod je kdesi?.. nemozeem zas inde odpalit nastavenia?
#10 Příspěvek od menom »
No to je zahada
Vypada to ako vec spravnych nastaveni v linuxovom operacnom systeme.
Navod ako spravne nastavit router bol urcite v krabici spolu s routrom.
Alebo pohladaj na nete.
