17.1 mate, WiFi Aspire 3050
WiFi, drátové sítě atd.
HonzaD
#1 Příspěvek od HonzaD »
17.1 mate, WiFi acer Aspire 3050 nebo 3053WXmi (to první je na displeji to druhé na těle).
Nejde WiFina. zkoušel jsme i OpenSuse a tam také nejela. Není tam vůbec vidět.Ve windows XP funguje.
Jak to jde rozchodit a proč nejede hned? :)
Má cenu zkusit poslední kernel?
milhouse
Re: 17.1 mate, WiFi Aspire 3050
#2 Příspěvek od milhouse »
Ovladače jsou v kernelu, takže má. A výpis sem:
sudo lspci
sudo lshw -short
sudo dmesg | tail
HonzaD
#3 Příspěvek od HonzaD »
cech@CechuvNTB ~ $ sudo lspci
[sudo] password for cech:
00:00.0 Host bridge: Advanced Micro Devices, Inc. [AMD/ATI] RS480/RS482/RS485 Host Bridge (rev 10)
00:01.0 PCI bridge: Advanced Micro Devices, Inc. [AMD/ATI] RC4xx/RS4xx PCI Bridge [int gfx]
00:04.0 PCI bridge: Advanced Micro Devices, Inc. [AMD/ATI] RC4xx/RS4xx PCI Express Port 1
00:05.0 PCI bridge: Advanced Micro Devices, Inc. [AMD/ATI] RC4xx/RS4xx PCI Express Port 2
00:06.0 PCI bridge: Advanced Micro Devices, Inc. [AMD/ATI] RC4xx/RS4xx PCI Express Port 3
00:07.0 PCI bridge: Advanced Micro Devices, Inc. [AMD/ATI] RC4xx/RS4xx PCI Express Port 4
00:12.0 IDE interface: Advanced Micro Devices, Inc. [AMD/ATI] IXP SB4x0 Serial ATA Controller (rev 80)
00:13.0 USB controller: Advanced Micro Devices, Inc. [AMD/ATI] IXP SB4x0 USB Host Controller (rev 80)
00:13.1 USB controller: Advanced Micro Devices, Inc. [AMD/ATI] IXP SB4x0 USB Host Controller (rev 80)
00:13.2 USB controller: Advanced Micro Devices, Inc. [AMD/ATI] IXP SB4x0 USB2 Host Controller (rev 80)
00:14.0 SMBus: Advanced Micro Devices, Inc. [AMD/ATI] IXP SB4x0 SMBus Controller (rev 83)
00:14.1 IDE interface: Advanced Micro Devices, Inc. [AMD/ATI] IXP SB4x0 IDE Controller (rev 80)
00:14.2 Audio device: Advanced Micro Devices, Inc. [AMD/ATI] IXP SB4x0 High Definition Audio Controller (rev 01)
00:14.3 ISA bridge: Advanced Micro Devices, Inc. [AMD/ATI] IXP SB4x0 PCI-ISA Bridge (rev 80)
00:14.4 PCI bridge: Advanced Micro Devices, Inc. [AMD/ATI] IXP SB4x0 PCI-PCI Bridge (rev 80)
00:18.0 Host bridge: Advanced Micro Devices, Inc. [AMD] K8 [Athlon64/Opteron] HyperTransport Technology Configuration
00:18.1 Host bridge: Advanced Micro Devices, Inc. [AMD] K8 [Athlon64/Opteron] Address Map
00:18.2 Host bridge: Advanced Micro Devices, Inc. [AMD] K8 [Athlon64/Opteron] DRAM Controller
00:18.3 Host bridge: Advanced Micro Devices, Inc. [AMD] K8 [Athlon64/Opteron] Miscellaneous Control
01:05.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] RS482M [Mobility Radeon Xpress 200]
08:01.0 CardBus bridge: ENE Technology Inc CB-712/4 Cardbus Controller (rev 10)
08:01.1 FLASH memory: ENE Technology Inc ENE PCI Memory Stick Card Reader Controller (rev 01)
08:01.2 SD Host controller: ENE Technology Inc ENE PCI Secure Digital Card Reader Controller (rev 01)
08:01.3 FLASH memory: ENE Technology Inc FLASH memory: ENE Technology Inc: (rev 01)
08:01.4 FLASH memory: ENE Technology Inc SD/MMC Card Reader Controller (rev 01)
08:02.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL-8100/8101L/8139 PCI Fast Ethernet Adapter (rev 10)
08:04.0 Network controller: Broadcom Corporation BCM4318 [AirForce One 54g] 802.11g Wireless LAN Controller (rev 02)
cech@CechuvNTB ~ $ sudo lshw -short
H/W path         Device      Class       Description
                             system      Aspire 3050 ()
/0                           bus         Prespa M
/0/0                         memory      107KiB BIOS
/0/4                         processor   Mobile AMD Sempron(tm) Processor 3400+
/0/4/5                       memory      256KiB L2 cache
/0/4/0                       memory      128KiB L1 cache
/0/4/1                       memory      256KiB L2 cache
/0/1b                        memory      2560MiB System Memory
/0/1b/0                      memory      512MiB DIMM DDR2 Synchronous
/0/1b/1                      memory      2GiB DIMM DDR2 Synchronous
/0/100                       bridge      RS480/RS482/RS485 Host Bridge
/0/100/1                     bridge      RC4xx/RS4xx PCI Bridge [int gfx]
/0/100/1/5                   display     RS482M [Mobility Radeon Xpress 200]
/0/100/4                     bridge      RC4xx/RS4xx PCI Express Port 1
/0/100/5                     bridge      RC4xx/RS4xx PCI Express Port 2
/0/100/6                     bridge      RC4xx/RS4xx PCI Express Port 3
/0/100/7                     bridge      RC4xx/RS4xx PCI Express Port 4
/0/100/12                    storage     IXP SB4x0 Serial ATA Controller
/0/100/13                    bus         IXP SB4x0 USB Host Controller
/0/100/13.1                  bus         IXP SB4x0 USB Host Controller
/0/100/13.2                  bus         IXP SB4x0 USB2 Host Controller
/0/100/14                    bus         IXP SB4x0 SMBus Controller
/0/100/14.1                  storage     IXP SB4x0 IDE Controller
/0/100/14.2                  multimedia  IXP SB4x0 High Definition Audio Control
/0/100/14.3                  bridge      IXP SB4x0 PCI-ISA Bridge
/0/100/14.4                  bridge      IXP SB4x0 PCI-PCI Bridge
/0/100/14.4/1                bridge      CB-712/4 Cardbus Controller
/0/100/14.4/1.1              memory      FLASH memory
/0/100/14.4/1.2              generic     ENE PCI Secure Digital Card Reader Cont
/0/100/14.4/1.3              memory      FLASH memory
/0/100/14.4/1.4              memory      FLASH memory
/0/100/14.4/2    eth0        network     RTL-8100/8101L/8139 PCI Fast Ethernet A
/0/100/14.4/4                network     BCM4318 [AirForce One 54g] 802.11g Wire
/0/101                       bridge      K8 [Athlon64/Opteron] HyperTransport Te
/0/102                       bridge      K8 [Athlon64/Opteron] Address Map
/0/103                       bridge      K8 [Athlon64/Opteron] DRAM Controller
/0/104                       bridge      K8 [Athlon64/Opteron] Miscellaneous Con
/0/1             scsi2       storage
/0/1/0.0.0       /dev/sda    disk        60GB Hitachi HTS54166
/0/1/0.0.0/1     /dev/sda1   volume      3992MiB Windows FAT volume
/0/1/0.0.0/2     /dev/sda2   volume      25GiB Windows FAT volume
/0/1/0.0.0/3     /dev/sda3   volume      26GiB Extended partition
/0/1/0.0.0/3/5   /dev/sda5   volume      2860MiB Linux swap / Solaris partition
/0/1/0.0.0/3/6   /dev/sda6   volume      23GiB Linux filesystem partition
/0/1/0.1.0       /dev/cdrom  disk        DVD-RAM UJ-850S
cech@CechuvNTB ~ $
cech@CechuvNTB ~ $ sudo dmesg | tail
[   30.302205]  excluding 0x60000000-0x60ffffff
[   30.302223] pcmcia_socket pcmcia_socket0: cs: IO port probe 0xa00-0xaff:
[   30.303150]  clean.
[   34.537646] init: samba-ad-dc main process (738) terminated with status 1
[   34.579249] 8139too 0000:08:02.0 eth0: link down
[   34.579393] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[   34.580226] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[   37.624163] tsc: Marking TSC unstable due to cpufreq changes
[   37.624235] Switched to clocksource acpi_pm
[   38.315159] init: plymouth-upstart-bridge main process ended, respawning
cech@CechuvNTB ~ $
#4 Příspěvek od juhele2014 »
:arrow: S wifi bývá problém, ale řešení se vždy najde. Mě na LM 17 Mate fungovalo toto - instaloval sem program wicd-gtk utilitou Správce softwaru. Po spuštění notasu se wifina aktivuje, najde sítě a ty se připojíš. Jestli to nepůjde, zkus tedy nové jádro, viz http://www.linux-mint-czech.cz/category ... e_systemu/ (poslední je 3.19.1), a jestli to furt nepůjde, tak se podívej na tuhle stránku http://wiki.ubuntu.cz/bcm4318 , jestli ten postup pomůže. Ve výpisu sem viděl kartu BCM4318.
HonzaD
#5 Příspěvek od HonzaD »
wicd-gtk nepomohl jdu zkusit jádro
nové jádro nepomohlo
na wiku ubuntu je kompliace neakeho SW do jadra a to jeste neni ani samotny ovladac :/
milhouse
#6 Příspěvek od milhouse »
HonzaD
#7 Příspěvek od HonzaD »
Neumím moc EN. Chápu to dobře, že stačí tohle?:
sudo apt-get purge bcmwl-kernel-source
sudo apt-get install linux-firmware-nonfree
milhouse
#8 Příspěvek od milhouse »
#9 Příspěvek od juhele2014 »
:arrow: HonzaD
Chápeš to správně. Pomohlo to?
tomkom18
#10 Příspěvek od tomkom18 »
No mám obdobný problém. Po neúspešnom update kernelu 3.19.0 na LM 17.1 som sa vrátil k pôvodnému 3.13.... Po reštarte ma nepustí na internet ani update nefunguje, proste nikde sa nedostanem. Pripojil som sa už aj priamo cez kábel na modem, ale stále nič. Problém je ten, že mi ukazuje, že som pripojený LAN/wifi, ale na internet sa nedá ísť. Odinštaloval som wifi driver, ale vlastne teraz mi nejde nainštalovať znovu lebo mi nejde ani LAN. Ešte som sa s takým niečím nestretol. Neviete mi poradiť?
P.S.: píšem zo stroja kde kernel 3.19.0 fičí skvele :-)
-->HP Pav DV5-C2D 2GHz+4G RAM+LM17.1 Cin -->Bratislava -->Nokia 206 dual SIM+Samsung GT i9001
