potřeboval bych poradit s úpravou widgetu v conky.
Chci se zeptat jestli je možné přidat do tohoto widgetu druhé jádro CPU , teplotu CPU a 4 přípojné body na druhém disku nalevo od těch co tam již jsou
# Conky settings #
background no
update_interval 1
cpu_avg_samples 2
net_avg_samples 2
override_utf8_locale yes
double_buffer yes
no_buffers yes
text_buffer_size 2048
#imlib_cache_size 0
temperature_unit fahrenheit
# Window specifications #
own_window yes
own_window_type normal
own_window_transparent yes
own_window_hints undecorate,sticky,skip_taskbar,skip_pager,below
border_inner_margin 0
border_outer_margin 0
minimum_size 200 250
maximum_width 200
alignment tr
gap_x 35
gap_y 55
# Graphics settings #
draw_shades no
draw_outline no
draw_borders no
draw_graph_borders no
# Text settings #
use_xft yes
xftfont Neuropolitical:size=8
xftalpha 0.8
uppercase no
temperature_unit celsius
default_color FFFFFF
# Lua Load #
lua_load ./clock_rings.lua
lua_draw_hook_pre clock_rings
own_window_argb_value 0
own_window_argb_visual yes
own_window_colour 000000
TEXT
${font Neuropolitical:size=42}${time %e}
${goto 100}${font Neuropolitical:size=18}${color 339900}${voffset -75}${time %b}
${font Neuropolitical:size=10}${color 339900}${voffset 15}${time %A}${color 339900}${hr}
${goto 100}${font Neuropolitical:size=15}${color FFFFFF}${voffset -35}${time %Y}
${font Neuropolitical:size=30}${voffset 40}${alignc}${time %H}:${time %M}
${goto 175}${voffset -30}${font Neuropolitical:size=10}${time %S}
${voffset 10}${font Neuropolitical:size=11}${color 339900}${alignr}HOME${font}
${font Neuropolitical:size=13}${color FFFFFF}${alignr}temp: ${weather http://weather.noaa.gov/pub/data/observations/metar/stations/ LQBK temperature temperature 30} °C${font}
${hr}
${image ./logo.png -p 165,10 -s 35x35}
${color FFFFFF}${font Neuropolitical:size=8}Uptime: ${uptime_short}
${color FFFFFF}${font Neuropolitical:size=8}Processes: ${processes}
${color FFFFFF}${font Neuropolitical:size=8}Running: ${running_processes}
${color 339900}${goto 125}${voffset 40}CPU0
${color FFFFFF}${goto 125}${cpu cpu0}%
${color 339900}${goto 125}${voffset 55}RAM
${color FFFFFF}${goto 125}${memperc}%
${color 339900}${goto 125}${voffset 50}Root
${color FFFFFF}${goto 125}${fs_used_perc /}%
${color 339900}${goto 125}${voffset 55}Home
${color FFFFFF}${goto 125}${fs_used_perc /home}%
${color 339900}${goto 130}${voffset 50}Net
${color FFFFFF}${goto 130}${downspeed eth0}
${color FFFFFF}${goto 130}${upspeed eth0}
${color 339900}${font Neuropolitical:size=8}${alignr}${nodename}
${color 339900}${font Neuropolitical:size=8}${alignr}${pre_exec cat /etc/issue.net} $machine
${color 339900}${font Neuropolitical:size=8}${alignr}Kernel: ${kernel}
${hr}
