Po instalacii LMDE2 nevidi sietove karty
mikip22
#1 Příspěvek od mikip22 »
Po instalacii LMDE2 nemam ziadne sietove karty, co je pre mna az moc divne.
Nieje tede mozne ani nic doinstalovat.
Ze nejde WiFi beriem, da sa doinstalovat ovladac, ale ze po instalacii nemam k dispozicii net po kabli, je pre mna novinka.
Skusal som image z viacerych zdrojov nepomohlo.
V LIVE ide bez problemov, ale po instalacii ju nevidno.
Snad niekoho napadne v com by mohol byt problem.
miki@mint ~ $ lspci
00:00.0 Host bridge: Intel Corporation Mobile 945GM/PM/GMS, 943/940GML and 945GT Express Memory Controller Hub (rev 03)
00:02.0 VGA compatible controller: Intel Corporation Mobile 945GM/GMS, 943/940GML Express Integrated Graphics Controller (rev 03)
00:02.1 Display controller: Intel Corporation Mobile 945GM/GMS/GME, 943/940GML Express Integrated Graphics Controller (rev 03)
00:1b.0 Audio device: Intel Corporation NM10/ICH7 Family High Definition Audio Controller (rev 01)
00:1c.0 PCI bridge: Intel Corporation NM10/ICH7 Family PCI Express Port 1 (rev 01)
00:1c.1 PCI bridge: Intel Corporation NM10/ICH7 Family PCI Express Port 2 (rev 01)
00:1c.3 PCI bridge: Intel Corporation NM10/ICH7 Family PCI Express Port 4 (rev 01)
00:1d.0 USB controller: Intel Corporation NM10/ICH7 Family USB UHCI Controller #1 (rev 01)
00:1d.1 USB controller: Intel Corporation NM10/ICH7 Family USB UHCI Controller #2 (rev 01)
00:1d.2 USB controller: Intel Corporation NM10/ICH7 Family USB UHCI Controller #3 (rev 01)
00:1d.3 USB controller: Intel Corporation NM10/ICH7 Family USB UHCI Controller #4 (rev 01)
00:1d.7 USB controller: Intel Corporation NM10/ICH7 Family USB2 EHCI Controller (rev 01)
00:1e.0 PCI bridge: Intel Corporation 82801 Mobile PCI Bridge (rev e1)
00:1f.0 ISA bridge: Intel Corporation 82801GBM (ICH7-M) LPC Interface Bridge (rev 01)
00:1f.2 IDE interface: Intel Corporation 82801GBM/GHM (ICH7-M Family) SATA Controller [IDE mode] (rev 01)
02:06.0 CardBus bridge: Texas Instruments PCIxx12 Cardbus Controller
02:06.1 FireWire (IEEE 1394): Texas Instruments PCIxx12 OHCI Compliant IEEE 1394 Host Controller
02:0e.0 Ethernet controller: Broadcom Corporation BCM4401-B0 100Base-TX (rev 02)
10:00.0 Network controller: Broadcom Corporation BCM4311 802.11b/g WLAN (rev 01
boot.log (LMDE2-po instalacii)
fsck from util-linux 2.25.2
/dev/sda2: recovering journal
/dev/sda2: Clearing orphaned inode 263673 (uid=1000, gid=1000, mode=0100600, size=65536)
/dev/sda2: clean, 178145/981120 files, 1292804/3919860 blocks
INIT: version 2.88 booting
[[36minfo[39;49m] Using makefile-style concurrent boot in runlevel S.
[....] Starting the hotplug events dispatcher: udevd[?25l[?1c7[1G[[32m ok [39;49m8[?25h[?0c.
[....] Synthesizing the initial hotplug events...[?25l[?1c7[1G[[32m ok [39;49m8[?25h[?0cdone.
[....] Waiting for /dev to be fully populated...[?25l[?1c7[1G[[32m ok [39;49m8[?25h[?0cdone.
[....] Starting Braille terminal driver: brltty[?25l[?1c7[1G[[32m ok [39;49m8[?25h[?0c.
[....] Setting preliminary keymap...[?25l[?1c7[1G[[32m ok [39;49m8[?25h[?0cdone.
[....] Setting parameters of disc: (none)[?25l[?1c7[1G[[32m ok [39;49m8[?25h[?0c.
[....] Activating swap...[?25l[?1c7[1G[[32m ok [39;49m8[?25h[?0cdone.
[....] Checking root file system...fsck from util-linux 2.25.2
[....] Cleaning up temporary files... /tmp[?25l[?1c7[1G[[32m ok [39;49m8[?25h[?0c.
[....] Starting early crypto disks...[?25l[?1c7[1G[[32m ok [39;49m8[?25h[?0cdone.
[....] Setting up LVM Volume Groups...  No volume groups found
[[36minfo[39;49m] Loading kernel module lp.
[[36minfo[39;49m] Loading kernel module ppdev.
[[36minfo[39;49m] Loading kernel module parport_pc.
[[36minfo[39;49m] Loading kernel module ecryptfs.
[[36minfo[39;49m] Loading kernel module fuse.
[....] Starting remaining crypto disks...[?25l[?1c7[1G[[32m ok [39;49m8[?25h[?0cdone.
[....] Activating lvm and md swap...[?25l[?1c7[1G[[32m ok [39;49m8[?25h[?0cdone.
[....] Checking file systems...fsck from util-linux 2.25.2
[....] Mounting local filesystems...[?25l[?1c7[1G[[32m ok [39;49m8[?25h[?0cdone.
[....] Activating swapfile swap...[?25l[?1c7[1G[[32m ok [39;49m8[?25h[?0cdone.
[....] Cleaning up temporary files...[?25l[?1c7[1G[[32m ok [39;49m8[?25h[?0c.
Running 0dns-down to make sure resolv.conf is ok...done.
[....] Skip starting firewall: ufw (not enabled)...[?25l[?1c7[1G[[32m ok [39;49m8[?25h[?0cdone.
[....] Setting kernel variables ...[?25l[?1c7[1G[[32m ok [39;49m8[?25h[?0cdone.
[....] Setting up resolvconf.../etc/resolvconf/update.d/libc: Warning: /etc/resolv.conf is not a symbolic link to /etc/resolvconf/run/resolv.conf
[....] Configuring network interfaces...[?25l[?1c7[1G[[32m ok [39;49m8[?25h[?0cdone.
[....] Setting up ALSA...[?25l[?1c7[1G[[32m ok [39;49m8[?25h[?0cdone.
[[36minfo[39;49m] Setting console screen modes.
[9;30][14;30][....] Setting up console font and keymap...[?25l[?1c7[1G[[32m ok [39;49m8[?25h[?0cdone.
[....] VirtualBox Additions disabled, not in a Virtual Machine ...[?25l[?1c7[1G[[33mwarn[39;49m8[?25h[?0c [33m(warning).[39;49m
[....] Setting up X socket directories... /tmp/.X11-unix /tmp/.ICE-unix[?25l[?1c7[1G[[32m ok [39;49m8[?25h[?0c.
[....] Setting sensors limits[?25l[?1c7[1G[[32m ok [39;49m8[?25h[?0c.
INIT: Entering runlevel: 2
[[36minfo[39;49m] Using makefile-style concurrent boot in runlevel 2.
[....] Starting uuid generator: uuidd[?25l[?1c7[1G[[32m ok [39;49m8[?25h[?0c.
[....] Starting enhanced syslogd: rsyslogd[?25l[?1c7[1G[[32m ok [39;49m8[?25h[?0c.
[....] Enabling additional executable binary formats: binfmt-support[?25l[?1c7[1G[[32m ok [39;49m8[?25h[?0c.
[....] Enabling power management...[?25l[?1c7[1G[[32m ok [39;49m8[?25h[?0cdone.
[....] Starting anac(h)ronistic cron: anacron[?25l[?1c7[1G[[32m ok [39;49m8[?25h[?0c.
[....] Starting ACPI services...[?25l[?1c7[1G[[32m ok [39;49m8[?25h[?0c.
[....] Starting NetBIOS name server: nmbd[?25l[?1c7[1G[[32m ok [39;49m8[?25h[?0c.
[....] Starting periodic command scheduler: cron[?25l[?1c7[1G[[32m ok [39;49m8[?25h[?0c.
[....] Starting CUPS Bonjour daemon: cups-browsed[?25l[?1c7[1G[[32m ok [39;49m8[?25h[?0c.
[....] Starting Common Unix Printing System: cupsd[?25l[?1c7[1G[[32m ok [39;49m8[?25h[?0c.
[....] Starting system message bus: dbus[?25l[?1c7[1G[[32m ok [39;49m8[?25h[?0c.
[....] Starting SMP IRQ Balancer: irqbalance[?25l[?1c7[1G[[32m ok [39;49m8[?25h[?0c.
[....] Starting bluetooth: bluetoothd[?25l[?1c7[1G[[32m ok [39;49m8[?25h[?0c.
[....] Starting Avahi mDNS/DNS-SD Daemon: avahi-daemon[?25l[?1c7[1G[[32m ok [39;49m8[?25h[?0c.
[....] Loading cpufreq kernel modules...[?25l[?1c7[1G[[32m ok [39;49m8[?25h[?0cdone (acpi-cpufreq).
[....] Starting cgroup management daemon: cgmanager[....] Starting cgroup management proxy daemon: cgproxy[?25l[?1c7[1G[[32m ok [39;49m8[?25h[?0c.
[....] CPUFreq Utilities: Setting ondemand CPUFreq governor...CPU0...CPU1...[?25l[?1c7[1G[[32m ok [39;49m8[?25h[?0cdone.
[[36minfo[39;49m] speech-dispatcher disabled; edit /etc/default/speech-dispatcher.
[....] Starting network connection manager: NetworkManager[?25l[?1c7[1G[[32m ok [39;49m8[?25h[?0c.
[....] saned disabled; edit /etc/default/saned[?25l[?1c7[1G[[32m ok [39;49m8[?25h[?0c.
Re: Po instalacii LMDE2 nevidi sietove karty
Ked mas spusteny ten Live system, tak zistit ovladace, ktore sa pouzivaju a tie potom dostat do instalovaneho systemu.
Napriklad vypis
inxi -F
lspci -k | grep net -A3
