nefunkční wifi u HP nx6125
WiFi, drátové sítě atd.
nikkor
#1 Příspěvek od nikkor »
ahoj, prosím o radu s linuxem začínám a po instalaci linuxmint 17.1 nejde wifi. Asi chybí ovladač, ale kam a jak ho instalovat netuším. Budu rád za pomoc...
Terminál po sudo lspci -v
píše:
00:00.0 Host bridge: Advanced Micro Devices, Inc. [AMD/ATI] RS480/RS482/RS485 Host Bridge (rev 01)
Subsystem: Hewlett-Packard Company MX6125
Flags: bus master, 66MHz, medium devsel, latency 64
00:01.0 PCI bridge: Advanced Micro Devices, Inc. [AMD/ATI] RC4xx/RS4xx PCI Bridge [int gfx] (prog-if 00 [Normal decode])
Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
I/O behind bridge: 00003000-00003fff
Memory behind bridge: d0600000-d09fffff
Prefetchable memory behind bridge: 00000000c0000000-00000000cfffffff
Capabilities: [44] HyperTransport: MSI Mapping Enable+ Fixed+
Capabilities: [b0] Subsystem: Hewlett-Packard Company Device 308b
00:04.0 PCI bridge: Advanced Micro Devices, Inc. [AMD/ATI] RC4xx/RS4xx PCI Express Port 1 (prog-if 00 [Normal decode])
Flags: fast devsel
Bus: primary=00, secondary=10, subordinate=10, sec-latency=0
I/O behind bridge: 00001000-00001fff
Memory behind bridge: 54000000-541fffff
Prefetchable memory behind bridge: 54200000-543fffff
Capabilities: [50] Power Management version 3
Capabilities: [58] Express Root Port (Slot+), MSI 00
Capabilities: [80] MSI: Enable- Count=1/1 Maskable- 64bit-
Capabilities: [b8] HyperTransport: MSI Mapping Enable+ Fixed+
Capabilities: [100] Advanced Error Reporting
Kernel driver in use: pcieport
00:05.0 PCI bridge: Advanced Micro Devices, Inc. [AMD/ATI] RC4xx/RS4xx PCI Express Port 2 (prog-if 00 [Normal decode])
Flags: fast devsel
Bus: primary=00, secondary=20, subordinate=20, sec-latency=0
I/O behind bridge: 00005000-00005fff
Memory behind bridge: 54400000-545fffff
Prefetchable memory behind bridge: 54600000-547fffff
00:13.0 USB controller: Advanced Micro Devices, Inc. [AMD/ATI] IXP SB4x0 USB Host Controller (prog-if 10 [OHCI])
Flags: bus master, 66MHz, medium devsel, latency 64, IRQ 19
Memory at d0a00000 (32-bit, non-prefetchable)
Capabilities: [d0] MSI: Enable- Count=1/1 Maskable- 64bit-
Kernel driver in use: ohci-pci
00:13.1 USB controller: Advanced Micro Devices, Inc. [AMD/ATI] IXP SB4x0 USB Host Controller (prog-if 10 [OHCI])
Memory at d0a01000 (32-bit, non-prefetchable)
00:13.2 USB controller: Advanced Micro Devices, Inc. [AMD/ATI] IXP SB4x0 USB2 Host Controller (prog-if 20 [EHCI])
Memory at d0a02000 (32-bit, non-prefetchable)
Capabilities: [dc] Power Management version 2
Kernel driver in use: ehci-pci
00:14.0 SMBus: Advanced Micro Devices, Inc. [AMD/ATI] IXP SB4x0 SMBus Controller (rev 11)
Flags: 66MHz, medium devsel
I/O ports at 8200
Memory at d0a03000 (32-bit, non-prefetchable)
Capabilities: [b0] HyperTransport: MSI Mapping Enable- Fixed+
Kernel driver in use: piix4_smbus
00:14.1 IDE interface: Advanced Micro Devices, Inc. [AMD/ATI] IXP SB4x0 IDE Controller (prog-if 8a [Master SecP PriP])
Flags: bus master, 66MHz, medium devsel, latency 64, IRQ 16
I/O ports at 01f0
I/O ports at 03f4
I/O ports at 0170
I/O ports at 0374
I/O ports at 4010
Capabilities: [70] MSI: Enable- Count=1/1 Maskable- 64bit-
Kernel driver in use: pata_atiixp
00:14.3 ISA bridge: Advanced Micro Devices, Inc. [AMD/ATI] IXP SB4x0 PCI-ISA Bridge
Flags: bus master, 66MHz, medium devsel, latency 0
00:14.4 PCI bridge: Advanced Micro Devices, Inc. [AMD/ATI] IXP SB4x0 PCI-PCI Bridge (prog-if 01 [Subtractive decode])
Flags: bus master, VGA palette snoop, 66MHz, medium devsel, latency 64
Bus: primary=00, secondary=02, subordinate=06, sec-latency=64
I/O behind bridge: 00002000-00002fff
Memory behind bridge: d0000000-d05fffff
Prefetchable memory behind bridge: 50000000-53ffffff
00:14.5 Multimedia audio controller: Advanced Micro Devices, Inc. [AMD/ATI] IXP SB400 AC'97 Audio Controller (rev 02)
Flags: bus master, 66MHz, slow devsel, latency 64, IRQ 17
Memory at d0a04000 (32-bit, non-prefetchable)
Capabilities: [40] MSI: Enable- Count=1/1 Maskable- 64bit-
Kernel driver in use: snd_atiixp
00:14.6 Modem: Advanced Micro Devices, Inc. [AMD/ATI] IXP SB400 AC'97 Modem Controller (rev 02) (prog-if 00 [Generic])
Memory at d0a05000 (32-bit, non-prefetchable)
Kernel driver in use: snd_atiixp_modem
00:18.0 Host bridge: Advanced Micro Devices, Inc. [AMD] K8 [Athlon64/Opteron] HyperTransport Technology Configuration
Flags: fast devsel
Capabilities: [80] HyperTransport: Host or Secondary Interface
00:18.1 Host bridge: Advanced Micro Devices, Inc. [AMD] K8 [Athlon64/Opteron] Address Map
Flags: fast devsel
00:18.2 Host bridge: Advanced Micro Devices, Inc. [AMD] K8 [Athlon64/Opteron] DRAM Controller
Flags: fast devsel
00:18.3 Host bridge: Advanced Micro Devices, Inc. [AMD] K8 [Athlon64/Opteron] Miscellaneous Control
Flags: fast devsel
Kernel driver in use: k8temp
01:05.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] RS480M [Mobility Radeon Xpress 200] (prog-if 00 [VGA controller])
Flags: bus master, fast Back2Back, 66MHz, medium devsel, latency 64, IRQ 17
Memory at c0000000 (32-bit, prefetchable) [size=256M]
I/O ports at 3000 [size=256]
Memory at d0600000 (32-bit, non-prefetchable) [size=64K]
[virtual] Expansion ROM at d0620000 [disabled] [size=128K]
Capabilities: [50] Power Management version 2
Kernel driver in use: radeon
02:01.0 Ethernet controller: Broadcom Corporation NetXtreme BCM5788 Gigabit Ethernet (rev 03)
Flags: bus master, 66MHz, medium devsel, latency 64, IRQ 23
Memory at d0000000 (32-bit, non-prefetchable) [size=64K]
Expansion ROM at <ignored> [disabled]
Capabilities: [48] Power Management version 2
Capabilities: [50] Vital Product Data
Capabilities: [58] MSI: Enable- Count=1/8 Maskable- 64bit+
Kernel driver in use: tg3
02:02.0 Network controller: Broadcom Corporation BCM4318 [AirForce One 54g] 802.11g Wireless LAN Controller (rev 02)
Subsystem: Hewlett-Packard Company Broadcom 802.11b/g WLAN
Flags: bus master, fast devsel, latency 64, IRQ 22
Memory at d0010000 (32-bit, non-prefetchable) [size=8K]
Kernel driver in use: b43-pci-bridge
02:04.0 CardBus bridge: Texas Instruments PCIxx21/x515 Cardbus Controller
Flags: bus master, medium devsel, latency 168, IRQ 20
Memory at d0012000 (32-bit, non-prefetchable) [size=4K]
Bus: primary=02, secondary=03, subordinate=06, sec-latency=176
Memory window 0: 50000000-53ffffff (prefetchable)
Memory window 1: 58000000-5bffffff
I/O window 0: 00002000-000020ff
I/O window 1: 00002400-000024ff
16-bit legacy interface ports at 0001
Capabilities: [a0] Power Management version 2
Kernel driver in use: yenta_cardbus
02:04.2 FireWire (IEEE 1394): Texas Instruments OHCI Compliant IEEE 1394 Host Controller (prog-if 10 [OHCI])
Flags: bus master, medium devsel, latency 64, IRQ 9
Memory at d0013000 (32-bit, non-prefetchable) [size=2K]
Memory at d0014000 (32-bit, non-prefetchable) [size=16K]
Capabilities: [44] Power Management version 2
Kernel driver in use: firewire_ohci
02:04.3 Mass storage controller: Texas Instruments PCIxx21 Integrated FlashMedia Controller
Memory at d0018000 (32-bit, non-prefetchable) [size=8K]
Kernel driver in use: tifm_7xx1
02:04.4 SD Host controller: Texas Instruments PCI6411/6421/6611/6621/7411/7421/7611/7621 Secure Digital Controller
Memory at d001a000 (32-bit, non-prefetchable) [size=256]
Memory at d001b000 (32-bit, non-prefetchable) [size=256]
Memory at d001c000 (32-bit, non-prefetchable) [size=256]
Capabilities: [80] Power Management version 2
Kernel driver in use: sdhci-pci
jirka@jirka-HP-Compaq-nx6125-PZ076UA-ABA ~ $ rfkill list
0: hci0: Bluetooth
Soft blocked: no
Hard blocked: no
Re: nefunkční wifi u HP nx6125
Prva pomoc pripojit sa cez kabel na net a instalovat aktualizacie, restart.
Co vypise po zadani v terminali prikaz:
iwconfig
#3 Příspěvek od juhele2014 »
:arrow: Prva pomoc pripojit sa cez kabel na net a instalovat aktualizacie, restart. Někdy se to čapne, někdy ne. Zrovna tento NTB není nejmladší, takže to bude hodně o zkoušení. Dokonce některé starší jádro je pro ten daný kus HW vhodnější než úplně poslední kernel, např. Mě se osvědčilo jádro 3.19.3, s tím chodí vnitřní wifi okamžitě, s jádrem 4.0.5, to už zase nejede. Chce to hodně trpělivosti ... ;)
nikkor
#4 Příspěvek od nikkor »
Na kabelu jsem a aktualizace jsem již instaloval, ale wifi to nenašlo :? restart proběhl.
jirka@jirka-HP-Compaq-nx6125-PZ076UA-ABA ~ $ iwconfig
lo no wireless extensions.
eth0 no wireless extensions.
segfault
#5 Příspěvek od segfault »
Hypotetické řešení
sudo apt-get purge bcmwl-kernel-source
sudo apt-get install --reinstall b43-fwcutter firmware-b43-installer
http://askubuntu.com/questions/500819/w ... ot-working
nikkor
#6 Příspěvek od nikkor »
jirka@jirka-HP-Compaq-nx6125-PZ076UA-ABA ~ $ sudo apt-get purge bcmwl-kernel-source
[sudo] password for jirka:
Zkuste to znovu, prosím.
Čtu seznamy balíků… Hotovo
Vytváří se strom závislostí
Čtu stavové informace… Hotovo
Package 'bcmwl-kernel-source' is not installed, so not removed
0 aktualizováno, 0 nově instalováno, 0 k odstranění a 58 neaktualizováno.
#7 Příspěvek od menom »
58 neaktualizováno
Aktualizuj to v terminali:
sudo apt-get upgrade
No a mohol by si este instalovat baliky:
linux-firmware
linux-firmware-nonfree
nikkor
#8 Příspěvek od nikkor »
přes terminál aktualizováno, balíčky instalovány a stále nic :|
ještě jsem v hlavní nabídce/ záložka správa/správce ovladačů našel wifinu a aktualizoval dle nabídky, takže se tam již nezobrazuje nicméně to nešlape (restartováno)
#9 Příspěvek od menom »
Riesenim by mohlo byt co pisal segfault, v tomto pripade vsak nemas instalovany:
Mohol by si skusit toto nainstalovat a ten b43-fwcutter by pri spravnom fungovani mal najst spravny ovladac pre tvoju wifi kartu.
sudo apt-get install bcmwl-kernel-source
nikkor
#10 Příspěvek od nikkor »
ten první příkaz hodil
jirka@jirka-HP-Compaq-nx6125-PZ076UA-ABA ~ $ Package 'bcmwl-kernel-source' is not installed, so not removed
Příkaz 'Package' nebyl nalezen. Měli jste na mysli:
Příkaz 'package' z balíku 'mailagent' (universe)
Package: příkaz nebyl nalezen
ten druhý
jirka@jirka-HP-Compaq-nx6125-PZ076UA-ABA ~ $ sudo apt-get install bcmwl-kernel-source
bcmwl-kernel-source je již nejnovější verze.
0 aktualizováno, 0 nově instalováno, 0 k odstranění a 34 neaktualizováno.
ten třetí provedl asi reinstalaci, ale ani po restartu stále nic
Naposledy upravil(a) nikkor dne 11 čer 2015, 21:35, celkem upraveno 1 x.
