NTB Asus N56VV
Rashidek
NTB Asus N56VV
#1 Příspěvek od Rashidek »
Ahoj, jsem linuxový elév, a chtěl bych se s ním naučit. Nainstaloval jsem si na notebook Linux Mint 17.1 Xfce Rebbeca a mám problémy se správným ovladačem grafické karty Nvidia GeForce 750. V současné době mám nvidia-331.113-0ubuntu0.0.4 ale nefunguje. Ještě mi nejde webcamera, ale to není teď priorita. Mohl by mi někdo poradit?
Grafika:
Graphics: Card: Intel 3rd Gen Core processor Graphics Controller bus-ID: 00:02.0 X.Org: 1.15.1 drivers: intel (unloaded: fbdev,vesa) Resolution: 1920x1080@60.0hz GLX Renderer: Mesa DRI Intel Ivybridge Mobile GLX Version: 3.0 Mesa 10.1.3 Direct Rendering: Yes
Konfigurace NTB:
chose@chose-N56VV ~ $ inxi -Fx
System: Host: chose-N56VV Kernel: 3.13.0-37-generic x86_64 (64 bit, gcc: 4.8.2)
Desktop: Xfce 4.11.8 (Gtk 2.24.23) Distro: Linux Mint 17.1 Rebecca
Machine: System: ASUSTeK (portable) product: N56VV version: 1.0
Mobo: ASUSTeK model: N56VV version: 1.0 Bios: American Megatrends version: N56VV.201 date: 06/05/2013
CPU: Quad core Intel Core i7-3630QM CPU (-HT-MCP-) cache: 6144 KB flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx) bmips: 19155.9
Clock Speeds: 1: 1200.00 MHz 2: 1200.00 MHz 3: 1200.00 MHz 4: 1200.00 MHz 5: 1200.00 MHz 6: 1700.00 MHz 7: 1200.00 MHz 8: 2401.00 MHz
Audio: Card: Intel 7 Series/C210 Series Chipset Family High Definition Audio Controller driver: snd_hda_intel bus-ID: 00:1b.0
Sound: Advanced Linux Sound Architecture ver: k3.13.0-37-generic
Network: Card-1: Qualcomm Atheros AR8161 Gigabit Ethernet driver: alx port: d000 bus-ID: 04:00.0
IF: eth0 state: down mac: 74:d0:2b:20:c5:2f
Card-2: Intel Centrino Wireless-N 2230 driver: iwlwifi ver: in-tree: bus-ID: 03:00.0
IF: wlan0 state: up mac: 68:17:29:64:51:e5
Drives: HDD Total Size: 750.2GB (4.0% used) 1: id: /dev/sda model: Hitachi_HTS72757 size: 750.2GB
Partition: ID: / size: 37G used: 6.1G (18%) fs: ext4 ID: /home size: 649G used: 22G (4%) fs: ext4
ID: swap-1 size: 2.00GB used: 0.00GB (0%) fs: swap
Sensors: System Temperatures: cpu: 48.0C mobo: N/A
Fan Speeds (in rpm): cpu: N/A
Info: Processes: 231 Uptime: 24 min Memory: 1272.5/7870.8MB Runlevel: 2 Gcc sys: 4.8.2 Client: Shell inxi: 1.8.4
Předem děkuji za odpověď.
Re: NTB Asus N56VV
Mas tam 2 graficke karty a zabudovanu technologiu Optimus.
Info mas napriklad tu:
http://www.linux-mint-czech.cz/instalac ... nux-mintu/
http://www.linux-mint-czech.cz/?s=bumblebee
Rashidek
Re: NTB Asus N56VV
#3 Příspěvek od Rashidek »
info je hezke, ale podle navodu mi to nejde...
Re: NTB Asus N56VV
Mohol by si napisat ktory navod si skusil
a dat sem podrobnejsie info o tej nvidii.
Zadat do Terminalu :
lspci -v
A kopirovat sem cely odstavec v ktorom sa pise o nvidia karte.
Predpokladam, ze v BIOSe / UEFI neni zakazana.
Rashidek
Re: NTB Asus N56VV
#5 Příspěvek od Rashidek »
Odinstaloval jsem vše co se týkalo GPU a jel podle návodu. Zkoušel jsem návody oba, jak instalaci přes správce softwaru tak přes příkazový řádek. V Biosu mám nastavené vše dobře. Když si dám po instalaci ověření jaká GPU mi běží tak mi to píše unknown.
chose@chose-N56VV ~ $ sudo prime-select query
[sudo] password for chose:
unknown
lnxi -v:
00:02.0 VGA compatible controller: Intel Corporation 3rd Gen Core processor Graphics Controller (rev 09) (prog-if 00 [VGA controller])
Subsystem: ASUSTeK Computer Inc. Device 1477
Flags: bus master, fast devsel, latency 0, IRQ 43
Memory at f7400000 (64-bit, non-prefetchable)
Memory at d0000000 (64-bit, prefetchable)
I/O ports at f000
Expansion ROM at <unassigned> [disabled]
Capabilities: <access denied>
Kernel driver in use: i915
01:00.0 3D controller: NVIDIA Corporation GK107M [GeForce GT 750M] (rev ff) (prog-if ff)
!!! Unknown header type 7f
Tu Nvidii nemám nastalovanou, přesto že mám naistalovnaný defaultní ovladač + nvidia prime, který se mi po restartu sám nainstaluje.
Asi něco dělám špatně, jinak by to běželo, myslim si.
Dík za ochotu...
Jinak celý výpis pc dávám tu:
chose@chose-N56VV ~ $ lspci -v
00:00.0 Host bridge: Intel Corporation 3rd Gen Core processor DRAM Controller (rev 09)
Subsystem: ASUSTeK Computer Inc. N56VZ
00:01.0 PCI bridge: Intel Corporation Xeon E3-1200 v2/3rd Gen Core processor PCI Express Root Port (rev 09) (prog-if 00 [Normal decode])
Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
I/O behind bridge: 0000e000-0000efff
Memory behind bridge: f6000000-f70fffff
Prefetchable memory behind bridge: 00000000e0000000-00000000f1ffffff
Kernel driver in use: pcieport
I/O ports at f000
00:14.0 USB controller: Intel Corporation 7 Series/C210 Series Chipset Family USB xHCI Host Controller (rev 04) (prog-if 30 [XHCI])
Flags: bus master, medium devsel, latency 0, IRQ 41
Memory at f7a00000 (64-bit, non-prefetchable)
Kernel driver in use: xhci_hcd
00:16.0 Communication controller: Intel Corporation 7 Series/C210 Series Chipset Family MEI Controller #1 (rev 04)
Flags: bus master, fast devsel, latency 0, IRQ 44
Memory at f7a1a000 (64-bit, non-prefetchable)
Kernel driver in use: mei_me
00:1a.0 USB controller: Intel Corporation 7 Series/C210 Series Chipset Family USB Enhanced Host Controller #2 (rev 04) (prog-if 20 [EHCI])
Flags: bus master, medium devsel, latency 0, IRQ 16
Memory at f7a18000 (32-bit, non-prefetchable)
Kernel driver in use: ehci-pci
00:1b.0 Audio device: Intel Corporation 7 Series/C210 Series Chipset Family High Definition Audio Controller (rev 04)
Flags: bus master, fast devsel, latency 0, IRQ 46
Memory at f7a10000 (64-bit, non-prefetchable)
Kernel driver in use: snd_hda_intel
00:1c.0 PCI bridge: Intel Corporation 7 Series/C210 Series Chipset Family PCI Express Root Port 1 (rev c4) (prog-if 00 [Normal decode])
Bus: primary=00, secondary=02, subordinate=02, sec-latency=0
00:1c.1 PCI bridge: Intel Corporation 7 Series/C210 Series Chipset Family PCI Express Root Port 2 (rev c4) (prog-if 00 [Normal decode])
Bus: primary=00, secondary=03, subordinate=03, sec-latency=0
Memory behind bridge: f7900000-f79fffff
00:1c.3 PCI bridge: Intel Corporation 7 Series/C210 Series Chipset Family PCI Express Root Port 4 (rev c4) (prog-if 00 [Normal decode])
Bus: primary=00, secondary=04, subordinate=04, sec-latency=0
I/O behind bridge: 0000d000-0000dfff
Memory behind bridge: f7800000-f78fffff
00:1d.0 USB controller: Intel Corporation 7 Series/C210 Series Chipset Family USB Enhanced Host Controller #1 (rev 04) (prog-if 20 [EHCI])
Flags: bus master, medium devsel, latency 0, IRQ 23
Memory at f7a17000 (32-bit, non-prefetchable) [size=1K]
00:1f.0 ISA bridge: Intel Corporation HM76 Express Chipset LPC Controller (rev 04)
Kernel driver in use: lpc_ich
00:1f.2 SATA controller: Intel Corporation 7 Series Chipset Family 6-port SATA Controller [AHCI mode] (rev 04) (prog-if 01 [AHCI 1.0])
Flags: bus master, 66MHz, medium devsel, latency 0, IRQ 42
I/O ports at f0b0 [size=8]
I/O ports at f0a0 [size=4]
I/O ports at f090 [size=8]
I/O ports at f080 [size=4]
I/O ports at f060 [size=32]
Memory at f7a16000 (32-bit, non-prefetchable) [size=2K]
Kernel driver in use: ahci
00:1f.3 SMBus: Intel Corporation 7 Series/C210 Series Chipset Family SMBus Controller (rev 04)
Flags: medium devsel, IRQ 10
Memory at f7a15000 (64-bit, non-prefetchable) [size=256]
I/O ports at f040 [size=32]
03:00.0 Network controller: Intel Corporation Centrino Wireless-N 2230 (rev c4)
Subsystem: Intel Corporation Centrino Wireless-N 2230 BGN
Flags: bus master, fast devsel, latency 0, IRQ 45
Memory at f7900000 (64-bit, non-prefetchable) [size=8K]
Kernel driver in use: iwlwifi
04:00.0 Ethernet controller: Qualcomm Atheros AR8161 Gigabit Ethernet (rev 10)
Flags: bus master, fast devsel, latency 0, IRQ 47
Memory at f7800000 (64-bit, non-prefetchable) [size=256K]
I/O ports at d000 [size=128]
Kernel driver in use: alx
Re: NTB Asus N56VV
#6 Příspěvek od menom »
Nemyslim ze delas neco spatne, neni zarucene ze Instalace ovladače Nvidia Optimus bude fungovat na kazdej nvidia karte.
Tato hlaska !!! Unknown header type 7f sa objavuje aj v suvislosti s problemami Wifi kariet od roznych vyrobcov.
Mozno by si mal nainstalovat novsie jadro (kernel) - nemusi byt najnovsi ale stabilny.
Bolo by dobre aby operacny system tu kartu spravne rozpoznal a nepisal !!! Unknown header type 7f
Rashidek
Re: NTB Asus N56VV
#7 Příspěvek od Rashidek »
a jakým způsobem nainstaluji nové jádro, tedy nevím ani které je stabilní..
Re: NTB Asus N56VV
#8 Příspěvek od juhele2014 »
Rashidek
Re: NTB Asus N56VV
#9 Příspěvek od Rashidek »
Tak jsem nainstaloval mint 17.2 Rafaela )32bit) a už tu kartu vidím, ale zase ji neumím prostřednictvím nvidia x server settings nakonfiguroval. Při zadání nového uživatele v nvidia x server settings to chce po mně nějaký klíč (key). Takže opět bojuji s nastavením:-d
01:00.0 3D controller: NVIDIA Corporation GK107M [GeForce GT 750M] (rev a1)
Memory at f6000000 (32-bit, non-prefetchable)
Memory at e0000000 (64-bit, prefetchable)
Memory at f0000000 (64-bit, prefetchable)
I/O ports at e000
Expansion ROM at f7000000 [disabled]
Kernel driver in use: nouveau
Re: NTB Asus N56VV
#10 Příspěvek od admin »
Dle výpisu stále používáš svobodný ovladač. Propirietární je třeba instalovat při shozeném graf. rozhraní, jinak se to nepodaří. Článků jak na to je na webu povícero.
