LM 17.2 - Cinnamon zblbnul [vyřešeno] Vyřešeno
Ahoj, mám linux mint 17.2 x64, a behem přehazování ikonek v menu najednou všechny zmizely a je tu jen tohle, viz obrázek. Zkoušel jsem restartovat Cinnamon, dát menu do puvodniho nastaveni i panel odebrat, ale vsechno neupsesne, muzete mi prosim nekdo poradit co s tim?
http://postimg.org/image/d82sj9uyd/full/
Re: Cinnamon zblbnul
Problém vyřešen, cinnamonu se nelíbilo, že jsem odebral wine ikonku, pomohl návod na https://github.com/linuxmint/Cinnamon/issues/3440:
I've deleted the folder "/home/USER/.cinnamon/configs/menu@cinnamon.org"
I've deleted the file cinnamon-applications.menu in ~/.config/menus
I've deleted the folder application-merged ind ~/.config/menus
I've deleted all .desktop-files with wine in its name @ /usr/share/applications and ~./local/share/applications
That solved my problem, the Menu Applet works smooth now. Thanks for the help.
