Java
jardahaje10ch
Java
Ahoj pratele.
Potreboval bych pomoci s Javou u DVR.
Kdyz nainstaluji starsi Javu, tak funguje DVR (recorder na vzdalenem miste, ktery nelze preinstalovat).
V tom pripade nefunguje bankovnictvi.
Dam prepinac na starou a novou, tak nejde nic.
Da se to nejak vyresit?
Re: Java
jardahaje10ch
Re: Java
Proste to nejede.
DVR pouziva starou verzi a nove na to nejdou.
Musel bych Ti dat link a heslo. Sem ale nemohu.
Pak by jsi videl, jak to vlastne myslim.
Zajimave je, ze s Mintem 13,14 a 16. KDE mi to slo.
U 17-17.3 mi nejde ani nektery HW. Treba bluetoot.
Zase mi, ale zacala bezet WiFi v 5GHz.
Jsem z toho tak trochu zoufaly. Ted hledam novy ThinkPad a bojim se, ze se nedostanu do alarmu a kamer.
Na novy chci dat uz jen Mint.
Trochu jsem toho napsal vic, nez jsem puvodne chtel, ale alespon si rad poslechnu rady a budu se tim ridit.
Tak Te prosim o radu. A dekuji
Re: Java
jardahaje10ch
Re: Java
Ahoj.
Ja to nepochopil. Asi jsi chtel toto.
System: Host: eleinst-ThinkPad-R52 Kernel: 3.19.0-32-generic i686 (32 bit)
Desktop: N/A Distro: Linux Mint 17.3 Rosa
Machine: System: IBM product: 18464CG v: ThinkPad R52 serial: L3V6290
Mobo: IBM model: 18464CG serial: 1ZAHE56G1G9
Bios: IBM v: 76ET28WW (1.08 ) date: 06/07/2005
CPU: Single core Intel Pentium M (-UP-) cache: 2048 KB
speed: 1866 MHz (max)
Graphics: Card: Advanced Micro Devices [AMD/ATI] RV370/M22 [Mobility Radeon X300]
Display Server: X.org 1.17.1 drivers: ati,radeon (unloaded: fbdev,vesa)
tty size: 80x38 Advanced Data: N/A for root
Audio: Card Intel 82801FB/FBM/FR/FW/FRW (ICH6 Family) AC'97 Audio Controller
driver: snd_intel8x0
Network: Card-1: Broadcom NetXtreme BCM5751M Gigabit Ethernet PCI Express
driver: tg3
IF: eth0 state: down mac: 00:0a:e4:c0:9c:12
Card-2: Intel PRO/Wireless 2915ABG [Calexico2] Network Connection
driver: ipw2200
IF: eth1 state: up mac: 00:12:f0:b2:1d:ac
Drives: HDD Total Size: 60.0GB (11.4% used)
ID-1: /dev/sda model: HTS541060G9AT00 size: 60.0GB
Partition: ID-1: / size: 54G used: 5.4G (11%) fs: ext4 dev: /dev/dm-0
ID-2: /boot size: 236M used: 48M (22%) fs: ext2 dev: /dev/sda1
ID-3: swap-1 size: 1.07GB used: 0.04GB (4%) fs: swap dev: /dev/dm-1
Sensors: System Temperatures: cpu: 55.0C mobo: 44.0C
Fan Speeds (in rpm): cpu: 3255
Info: Processes: 166 Uptime: 19 min Memory: 486.8/1000.2MB
driver: tg3
driver: ipw2200
Re: Java
atom@drevokocur ~ $ inxi -F
System: Host: drevokocur Kernel: 4.4.1-040401-generic i686 (32 bit) Desktop: Xfce 4.12.2
Machine: System: ASUSTeK product: 1000H v: x.x
Mobo: ASUSTeK model: 1000H v: x.xx Bios: American Megatrends v: 2102 date: 07/21/2009
CPU: Single core Intel Atom N270 (-HT-) cache: 512 KB
clock speeds: max: 1600 MHz 1: 1600 MHz 2: 1600 MHz
Graphics: Card: Intel Mobile 945GSE Express Integrated Graphics Controller
Display Server: X.Org 1.15.1 drivers: intel (unloaded: fbdev,vesa)
Resolution: 1024x600@60.0hz
GLX Renderer: Mesa DRI Intel 945GME x86/MMX/SSE2 GLX Version: 1.4 Mesa 10.1.3
Audio: Card Intel NM10/ICH7 Family High Definition Audio Controller driver: snd_hda_intel
Sound: Advanced Linux Sound Architecture v: k4.4.1-040401-generic
Network: Card-1: Ralink RT2790 Wireless 802.11n 1T/2R PCIe driver: rt2800pci
IF: wlan0 state: down mac: 00:15:af:d9:35:33
Card-2: Qualcomm Atheros AR8121/AR8113/AR8114 Gigabit or Fast Ethernet driver: ATL1E
IF: eth0 state: down mac: 00:24:8c:47:7c:84
Card-3: Ralink RT2870/RT3070 Wireless Adapter driver: rt2800usb
IF: wlan1 state: N/A mac: N/A
Drives: HDD Total Size: 168.0GB (5.4% used) ID-1: /dev/sda model: ST9160310AS size: 160.0GB
ID-2: USB /dev/sdb model: Flash_Reader size: 7.9GB
Partition: ID-1: / size: 66G used: 7.6G (13%) fs: ext4 dev: /dev/sda5
ID-2: swap-1 size: 1.06GB used: 0.01GB (1%) fs: swap dev: /dev/sda6
Sensors: System Temperatures: cpu: 64.0C mobo: N/A
Fan Speeds (in rpm): cpu: 1430
Info: Processes: 172 Uptime: 1:31 Memory: 423.6/991.9MB Client: Shell (bash) inxi: 2.2.28
atom@drevokocur ~ $
i vhodný sw. Svůj k svému, jestli mě rozumíš. Co se týká javy a prohlížeče, zkus něco jiného (chrom. superbird, operu, etc) https://www.starryhope.com/10-alternati ... ntu-linux/ třeba se něco čapne, kdo ví ...
