Nefunguje graficke prostredi [vyřešeno]
jarek163
#1 Příspěvek od jarek163 »
Zdravim
Po restartu mne prestalo fungovat graficke prostredi.
Graficka karta NVIDIA Corporation GT216 [GeForce GT 240M] (rev a2)
v xorg.conf je pouze toto:
Section "Device"
	Identifier	"Default Device"
	Option	"NoLogo"	"True"
EndSection
nevite jak obnovit alespon zakladni nastaveni pro GK nVidia? Dekuji...
HP EliteBook 8570w
ulo
Re: nefunguje graficke prostredi
#2 Příspěvek od ulo »
Takže ti systém najede do černé přihlašovací obrazovky (tzv. konzole)?
Jde grafický režim zapnout ručně? Čili co to udělá nebo vypíše po přihlášení a ručním zadáním:
/etc/init.d/gdm start
nebo
startx
Co máš v logu /var/log/Xorg.0.log ?
jarek163
#3 Příspěvek od jarek163 »
Xorg.0.log:
[   113.009]
X.Org X Server 1.11.3
Release Date: 2011-12-16
[   113.009] X Protocol Version 11, Revision 0
[   113.009] Build Operating System: Linux 2.6.42-37-generic x86_64 Ubuntu
[   113.009] Current Operating System: Linux jarek-Lenovo-IdeaPad-Y550P 3.2.0-23-generic #36-Ubuntu SMP Tue Apr 10 20:39:51 UTC 2012 x86_64
[   113.009] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.2.0-23-generic root=UUID=ed33f0df-1a52-429e-8788-f552eed7a9a3 ro quiet splash vt.handoff=7
[   113.010] Build Date: 27 February 2013  02:07:42AM
[   113.010] xorg-server 2:1.11.4-0ubuntu10.12 (For technical support please see http://www.ubuntu.com/support)
[   113.010] Current version of pixman: 0.24.4
[   113.010] 	Before reporting problems, check http://wiki.x.org
	to make sure that you have the latest version.
[   113.010] Markers: (--) probed, (**) from config file, (==) default setting,
	(++) from command line, (!!) notice, (II) informational,
	(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[   113.010] (==) Log file: "/var/log/Xorg.0.log", Time: Wed Apr 10 09:32:19 2013
[   113.010] (==) Using config file: "/etc/X11/xorg.conf"
[   113.010] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[   113.011] (==) No Layout section.  Using the first Screen section.
[   113.011] (==) No screen section available. Using defaults.
[   113.011] (**) |-->Screen "Default Screen Section" (0)
[   113.011] (**) |   |-->Monitor "<default monitor>"
[   113.011] (==) No device specified for screen "Default Screen Section".
	Using the first device section listed.
[   113.011] (**) |   |-->Device "Default Device"
[   113.011] (==) No monitor specified for screen "Default Screen Section".
	Using a default monitor configuration.
[   113.011] (==) Automatically adding devices
[   113.011] (==) Automatically enabling devices
[   113.011] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[   113.011] 	Entry deleted from font path.
[   113.011] (WW) The directory "/usr/share/fonts/X11/100dpi/" does not exist.
[   113.011] (WW) The directory "/usr/share/fonts/X11/75dpi/" does not exist.
[   113.011] (WW) The directory "/usr/share/fonts/X11/100dpi" does not exist.
[   113.011] (WW) The directory "/usr/share/fonts/X11/75dpi" does not exist.
[   113.011] (WW) The directory "/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType" does not exist.
[   113.011] (==) FontPath set to:
	/usr/share/fonts/X11/misc,
	/usr/share/fonts/X11/Type1,
	built-ins
[   113.011] (==) ModulePath set to "/usr/lib/x86_64-linux-gnu/xorg/extra-modules,/usr/lib/xorg/extra-modules,/usr/lib/xorg/modules"
[   113.011] (II) The server relies on udev to provide the list of input devices.
	If no devices become available, reconfigure udev or disable AutoAddDevices.
[   113.011] (II) Loader magic: 0x7ff1b423fb00
[   113.011] (II) Module ABI versions:
[   113.011] 	X.Org ANSI C Emulation: 0.4
[   113.011] 	X.Org Video Driver: 11.0
[   113.011] 	X.Org XInput driver : 16.0
[   113.011] 	X.Org Server Extension : 6.0
[   113.013] (--) PCI:*(0:1:0:0) 10de:0a34:17aa:38cd rev 162, Mem @ 0xd2000000/16777216, 0xc0000000/268435456, 0xd0000000/33554432, I/O @ 0x00006000/128, BIOS @ 0x????????/524288
[   113.013] (II) Open ACPI successful (/var/run/acpid.socket)
[   113.013] (II) LoadModule: "extmod"
[   113.014] (II) Loading /usr/lib/xorg/modules/extensions/libextmod.so
[   113.014] (II) Module extmod: vendor="X.Org Foundation"
[   113.014] 	compiled for 1.11.3, module version = 1.0.0
[   113.014] 	Module class: X.Org Server Extension
[   113.014] 	ABI class: X.Org Server Extension, version 6.0
[   113.014] (II) Loading extension MIT-SCREEN-SAVER
[   113.014] (II) Loading extension XFree86-VidModeExtension
[   113.014] (II) Loading extension XFree86-DGA
[   113.014] (II) Loading extension DPMS
[   113.014] (II) Loading extension XVideo
[   113.014] (II) Loading extension XVideo-MotionCompensation
[   113.014] (II) Loading extension X-Resource
[   113.014] (II) LoadModule: "dbe"
[   113.015] (II) Loading /usr/lib/xorg/modules/extensions/libdbe.so
[   113.015] (II) Module dbe: vendor="X.Org Foundation"
[   113.015] 	compiled for 1.11.3, module version = 1.0.0
[   113.015] 	Module class: X.Org Server Extension
[   113.015] 	ABI class: X.Org Server Extension, version 6.0
[   113.015] (II) Loading extension DOUBLE-BUFFER
[   113.015] (II) LoadModule: "glx"
[   113.015] (II) Loading /usr/lib/x86_64-linux-gnu/xorg/extra-modules/libglx.so
[   113.036] (II) Module glx: vendor="NVIDIA Corporation"
[   113.036] 	compiled for 4.0.2, module version = 1.0.0
[   113.036] 	Module class: X.Org Server Extension
[   113.036] (II) NVIDIA GLX Module  310.14  Tue Oct  9 12:14:30 PDT 2012
[   113.036] (II) Loading extension GLX
[   113.036] (II) LoadModule: "record"
[   113.037] (II) Loading /usr/lib/xorg/modules/extensions/librecord.so
[   113.037] (II) Module record: vendor="X.Org Foundation"
[   113.037] 	compiled for 1.11.3, module version = 1.13.0
[   113.037] 	Module class: X.Org Server Extension
[   113.037] 	ABI class: X.Org Server Extension, version 6.0
[   113.037] (II) Loading extension RECORD
[   113.037] (II) LoadModule: "dri"
[   113.038] (II) Loading /usr/lib/xorg/modules/extensions/libdri.so
[   113.038] (II) Module dri: vendor="X.Org Foundation"
[   113.038] 	compiled for 1.11.3, module version = 1.0.0
[   113.038] 	ABI class: X.Org Server Extension, version 6.0
[   113.038] (II) Loading extension XFree86-DRI
[   113.038] (II) LoadModule: "dri2"
[   113.039] (II) Loading /usr/lib/xorg/modules/extensions/libdri2.so
[   113.039] (II) Module dri2: vendor="X.Org Foundation"
[   113.039] 	compiled for 1.11.3, module version = 1.2.0
[   113.039] 	ABI class: X.Org Server Extension, version 6.0
[   113.039] (II) Loading extension DRI2
[   113.039] (==) Matched nvidia as autoconfigured driver 0
[   113.039] (==) Matched nouveau as autoconfigured driver 1
[   113.039] (==) Matched nv as autoconfigured driver 2
[   113.039] (==) Matched vesa as autoconfigured driver 3
[   113.039] (==) Matched fbdev as autoconfigured driver 4
[   113.039] (==) Assigned the driver to the xf86ConfigLayout
[   113.039] (II) LoadModule: "nvidia"
[   113.039] (II) Loading /usr/lib/x86_64-linux-gnu/xorg/extra-modules/nvidia_drv.so
[   113.040] (II) Module nvidia: vendor="NVIDIA Corporation"
[   113.040] 	compiled for 4.0.2, module version = 1.0.0
[   113.040] 	Module class: X.Org Video Driver
[   113.042] (II) LoadModule: "nouveau"
[   113.043] (II) Loading /usr/lib/xorg/modules/drivers/nouveau_drv.so
[   113.043] (II) Module nouveau: vendor="X.Org Foundation"
[   113.043] 	compiled for 1.11.3, module version = 0.0.16
[   113.043] 	Module class: X.Org Video Driver
[   113.043] 	ABI class: X.Org Video Driver, version 11.0
[   113.043] (II) LoadModule: "nv"
[   113.044] (WW) Warning, couldn't open module nv
[   113.044] (II) UnloadModule: "nv"
[   113.044] (II) Unloading nv
[   113.044] (EE) Failed to load module "nv" (module does not exist, 0)
[   113.044] (II) LoadModule: "vesa"
[   113.045] (II) Loading /usr/lib/xorg/modules/drivers/vesa_drv.so
[   113.045] (II) Module vesa: vendor="X.Org Foundation"
[   113.045] 	compiled for 1.11.3, module version = 2.3.0
[   113.045] 	Module class: X.Org Video Driver
[   113.045] 	ABI class: X.Org Video Driver, version 11.0
[   113.045] (II) LoadModule: "fbdev"
[   113.045] (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so
[   113.045] (II) Module fbdev: vendor="X.Org Foundation"
[   113.045] 	compiled for 1.11.3, module version = 0.4.2
[   113.046] 	ABI class: X.Org Video Driver, version 11.0
[   113.046] (==) Matched nvidia as autoconfigured driver 0
[   113.046] (==) Matched nouveau as autoconfigured driver 1
[   113.046] (==) Matched nv as autoconfigured driver 2
[   113.046] (==) Matched vesa as autoconfigured driver 3
[   113.046] (==) Matched fbdev as autoconfigured driver 4
[   113.046] (==) Assigned the driver to the xf86ConfigLayout
[   113.046] (II) LoadModule: "nvidia"
[   113.046] (II) Loading /usr/lib/x86_64-linux-gnu/xorg/extra-modules/nvidia_drv.so
[   113.046] (II) Module nvidia: vendor="NVIDIA Corporation"
[   113.046] 	compiled for 4.0.2, module version = 1.0.0
[   113.046] 	Module class: X.Org Video Driver
[   113.046] (II) UnloadModule: "nvidia"
[   113.046] (II) Unloading nvidia
[   113.046] (II) Failed to load module "nvidia" (already loaded, 32753)
[   113.046] (II) LoadModule: "nouveau"
[   113.046] (II) Loading /usr/lib/xorg/modules/drivers/nouveau_drv.so
[   113.046] (II) Module nouveau: vendor="X.Org Foundation"
[   113.046] 	compiled for 1.11.3, module version = 0.0.16
[   113.046] (II) UnloadModule: "nouveau"
[   113.046] (II) Unloading nouveau
[   113.046] (II) Failed to load module "nouveau" (already loaded, 32753)
[   113.046] (II) LoadModule: "nv"
[   113.047] (WW) Warning, couldn't open module nv
[   113.047] (II) UnloadModule: "nv"
[   113.047] (II) Unloading nv
[   113.047] (EE) Failed to load module "nv" (module does not exist, 0)
[   113.047] (II) LoadModule: "vesa"
[   113.048] (II) Loading /usr/lib/xorg/modules/drivers/vesa_drv.so
[   113.048] (II) Module vesa: vendor="X.Org Foundation"
[   113.048] 	compiled for 1.11.3, module version = 2.3.0
[   113.048] 	Module class: X.Org Video Driver
[   113.048] 	ABI class: X.Org Video Driver, version 11.0
[   113.048] (II) UnloadModule: "vesa"
[   113.048] (II) Unloading vesa
[   113.048] (II) Failed to load module "vesa" (already loaded, 0)
[   113.048] (II) LoadModule: "fbdev"
[   113.049] (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so
[   113.049] (II) Module fbdev: vendor="X.Org Foundation"
[   113.049] 	compiled for 1.11.3, module version = 0.4.2
[   113.049] 	ABI class: X.Org Video Driver, version 11.0
[   113.049] (II) UnloadModule: "fbdev"
[   113.049] (II) Unloading fbdev
[   113.049] (II) Failed to load module "fbdev" (already loaded, 0)
[   113.049] (II) NVIDIA dlloader X Driver  310.14  Tue Oct  9 11:54:19 PDT 2012
[   113.049] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[   113.049] (II) NOUVEAU driver Date:   Wed Nov 30 18:56:54 2011 +0100
[   113.049] (II) NOUVEAU driver for NVIDIA chipset families :
[   113.049] 	RIVA TNT        (NV04)
[   113.049] 	RIVA TNT2       (NV05)
[   113.049] 	GeForce 256     (NV10)
[   113.049] 	GeForce 2       (NV11, NV15)
[   113.049] 	GeForce 4MX     (NV17, NV18)
[   113.049] 	GeForce 3       (NV20)
[   113.049] 	GeForce 4Ti     (NV25, NV28)
[   113.049] 	GeForce FX      (NV3x)
[   113.049] 	GeForce 6       (NV4x)
[   113.049] 	GeForce 7       (G7x)
[   113.049] 	GeForce 8       (G8x)
[   113.049] 	GeForce GTX 200 (NVA0)
[   113.049] 	GeForce GTX 400 (NVC0)
[   113.049] (II) VESA: driver for VESA chipsets: vesa
[   113.049] (II) FBDEV: driver for framebuffer: fbdev
[   113.049] (++) using VT number 7
[   113.052] (II) Loading sub module "wfb"
[   113.052] (II) LoadModule: "wfb"
[   113.052] (II) Loading /usr/lib/xorg/modules/libwfb.so
[   113.052] (II) Module wfb: vendor="X.Org Foundation"
[   113.052] 	compiled for 1.11.3, module version = 1.0.0
[   113.052] 	ABI class: X.Org ANSI C Emulation, version 0.4
[   113.052] (II) Loading sub module "ramdac"
[   113.052] (II) LoadModule: "ramdac"
[   113.052] (II) Module "ramdac" already built-in
[   113.053] (II) Loading /usr/lib/x86_64-linux-gnu/xorg/extra-modules/nvidia_drv.so
[   113.053] (II) Loading /usr/lib/xorg/modules/libwfb.so
[   113.053] (WW) Falling back to old probe method for vesa
[   113.053] (WW) Falling back to old probe method for fbdev
[   113.053] (II) Loading sub module "fbdevhw"
[   113.053] (II) LoadModule: "fbdevhw"
[   113.053] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
[   113.053] (II) Module fbdevhw: vendor="X.Org Foundation"
[   113.054] 	compiled for 1.11.3, module version = 0.0.2
[   113.054] 	ABI class: X.Org Video Driver, version 11.0
[   113.054] (II) NVIDIA(0): Creating default Display subsection in Screen section
	"Default Screen Section" for depth/fbbpp 24/32
[   113.054] (==) NVIDIA(0): Depth 24, (==) framebuffer bpp 32
[   113.054] (==) NVIDIA(0): RGB weight 888
[   113.054] (==) NVIDIA(0): Default visual is TrueColor
[   113.054] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[   113.054] (**) NVIDIA(0): Option "NoLogo" "True"
[   113.054] (**) NVIDIA(0): Enabling 2D acceleration
[   113.057] (EE) NVIDIA(0): Failed to initialize the NVIDIA kernel module. Please see the
[   113.057] (EE) NVIDIA(0):     system's kernel log for additional error messages and
[   113.057] (EE) NVIDIA(0):     consult the NVIDIA README for details.
[   113.057] (EE) NVIDIA(0):  *** Aborting ***
[   113.057] (EE) NVIDIA(0): Failing initialization of X screen 0
[   113.057] (II) UnloadModule: "nvidia"
[   113.057] (II) Unloading nvidia
[   113.057] (II) UnloadModule: "wfb"
[   113.057] (II) Unloading wfb
[   113.057] (EE) Screen(s) found, but none have a usable configuration.
[   113.057]
Fatal server error:
[   113.057] no screens found
[   113.057]
Please consult the The X.Org Foundation support
	 at http://wiki.x.org
 for help.
[   113.057] Please also check the log file at "/var/log/Xorg.0.log" for additional information.
[   113.057]
[   113.060]  ddxSigGiveUp: Closing log
[   113.060] Server terminated with error (1). Closing log file.
Při klasickém bootování se mi po uvítací obrazovce Linux Mint zobrazí hlášení:
Spuštění serveru X (vašeho grafického rozhraní) selhalo. Pravděpodobně není správně nastaven.
Kam mám zadat příkaz startx? Do modu recovery - příkazový řádek root?
Zkoušel jsem si nainstalovat ovladač pro nVidii (beta), když se mi vypnul ntbk, vysoká teplota na disku, takže je možné, že to je zdroj mého problému...
Jinak prosím o shovívavost, přestože jsem s Mintem 2. rok, jsem pořád jenom klikač...
HP EliteBook 8570w
#4 Příspěvek od admin »
Jen tak mimochodem, neaktualizoval si kernel?? Startx zadej do příkazáku, jak píšeš. Jinak se ničeho neboj, hlavu ti tu nikdo neutrhne, nejsme tu jako na jiných fórech :)
jarek163
#5 Příspěvek od jarek163 »
takže zde je výpis po zadání příkazu startx:
mktemp: vytvoření souboru dle šablony /tmp/serverauth.XXXXXXXXX" selhalo:system souboru je pouze pro čtení.
xauth:error in locking authority file
xauth:error in locking authority file/root/xauthority
X.cannot stat /tmp/x11-unix (no such file or directory),aborting.
xinit: giving up
xinit: unable to connect to X server:no such file or directory
xinit: server error
xauth: error in locking authority file/root/.xauthority
kernel jsem neaktualizoval...
HP EliteBook 8570w
#6 Příspěvek od admin »
Jestli to blbne po instalaci toho ovladače, tak je příčina jasná... zkusil bych reinstal např. podle článku na http://www.linux-mint-czech.cz/jak-na-o ... ia-310-19/.
ulo
#7 Příspěvek od ulo »
Podle toho logu se nenačte nvidiácký ovladač "nv":
124: [   113.044] (EE) Failed to load module "nv" (module does not exist, 0)
163: [   113.047] (EE) Failed to load module "nv" (module does not exist, 0)
221: [   113.054] (II) NVIDIA(0): Creating default Display subsection in Screen section
222: "Default Screen Section" for depth/fbbpp 24/32
229: [   113.057] (EE) NVIDIA(0): Failed to initialize the NVIDIA kernel module. Please see the
230: [   113.057] (EE) NVIDIA(0):     system's kernel log for additional error messages and
231: [   113.057] (EE) NVIDIA(0):     consult the NVIDIA README for details.
232: [   113.057] (EE) NVIDIA(0):  *** Aborting ***
233: [   113.057] (EE) NVIDIA(0): Failing initialization of X screen 0
238: [   113.057] (EE) Screen(s) found, but none have a usable configuration.
241: [   113.057] no screens found
Zkusil bych ho teda nejdřív přeinstalovat, jak psal Satapouch podle toho návodu. Nejdřív ale asi odinstaluj vše od nvidie, takže z toho příkazového řádku dát:
sudo apt-get purge nvidia-*
A pak bych postupoval v tom návodu rovnou od té spodní části (čili sekce Instalace z PPA zdrojů). Je to nejrychlejší.
jarek163
#8 Příspěvek od jarek163 »
Zkoušel jsem odinstalaci ovladače a následnou instalaci, ale příkazový řádek mne neposlouchal, takže přeinstall...
Děkuji za snahu...
Vyřešeno
HP EliteBook 8570w
ulo
#9 Příspěvek od ulo »
Reinstal je v tomto případě naprosto zbytečný a práce navíc. Kdybys sem dal, co ti příkazový řádek píše, tak si myslím, že bychom ho umravnili.
Na druhou stranu se zase aspoň procvičíš v instalaci systému ;-)
