Problem s bootovanim z rezimu spanku
janhakl
#1 Příspěvek od janhakl »
Ahoj, zkousel jsem upgrade na Mint 18 pomoci prikazu
sudo apt-get upgrade
sudo apt-get distro-upgrade
a od te doby mne nefunguje probuzeni ntb z rezimu spanku. Zustanu viset na chybe
[48725.031769] snd_hda_intel 0000:00:03.0:azx_get_response timeout, switching to single_cmd mode:last cmd=0x007f2e08
a pomuze mne jen hard reset. Nejaka rada jak z toho ven?
Pouzivam Linux Mint 17.3 64bit, jadro 3.19.0-32-generic
Diky :)
janhakl
Re: Problem s bootovanim z rezimu spanku
#2 Příspěvek od janhakl »
honza@honza-Lenovo-Z50-70 ~ $  inxi -xxxF
System:    Host: honza-Lenovo-Z50-70 Kernel: 3.19.0-32-generic x86_64 (64 bit gcc: 4.8.2)
           Desktop: Cinnamon 2.8.8 (Gtk 2.24.23) dm: mdm Distro: Linux Mint 17.3 Rosa
Machine:   System: LENOVO product: 20354 v: Lenovo Z50-70 Chassis: type: 10 v: Lenovo Z50-70
           Mobo: LENOVO model: Lancer 5A5 v: NANANANANO DPK Bios: LENOVO v: 9BCN29WW date: 10/20/2014
CPU:       Dual core Intel Core i5-4210U (-HT-MCP-) cache: 3072 KB
           flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx) bmips: 9578
           clock speeds: min/max: 800/2700 MHz 1: 2092 MHz 2: 1700 MHz 3: 1422 MHz 4: 1700 MHz
Graphics:  Card-1: Intel Haswell-ULT Integrated Graphics Controller bus-ID: 00:02.0 chip-ID: 8086:0a16
           Card-2: NVIDIA GM108M [GeForce 840M] bus-ID: 03:00.0 chip-ID: 10de:1341
           Display Server: X.Org 1.15.1 drivers: nvidia,intel Resolution: 1920x1080@60.1hz
           GLX Renderer: GeForce 840M/PCIe/SSE2 GLX Version: 4.5.0 NVIDIA 352.63 Direct Rendering: Yes
Audio:     Card-1 Intel 8 Series HD Audio Controller driver: snd_hda_intel bus-ID: 00:1b.0 chip-ID: 8086:9c20
           Card-2 Intel Haswell-ULT HD Audio Controller driver: snd_hda_intel bus-ID: 00:03.0 chip-ID: 8086:0a0c
Network:   Card-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
           driver: r8169 v: 2.3LK-NAPI port: 4000 bus-ID: 01:00.0 chip-ID: 10ec:8168
           IF: eth0 state: down mac: 68:f7:28:25:ea:62
           Card-2: Intel Wireless 3160 driver: iwlwifi v: in-tree: bus-ID: 02:00.0 chip-ID: 8086:08b4
           IF: wlan0 state: up mac: d0:7e:35:3b:22:0c
Drives:    HDD Total Size: 1120.2GB (82.8% used)
           ID-1: /dev/sda model: Crucial_CT120M50 size: 120.0GB serial: 14190C1F7413
           ID-2: /dev/sdb model: ST1000LM014 size: 1000.2GB serial: W770LA6A
Partition: ID-1: / size: 94G used: 46G (52%) fs: ext4 dev: /dev/sda1
           ID-2: /home size: 917G used: 810G (93%) fs: ext4 dev: /dev/sdb1
           ID-3: swap-1 size: 10.24GB used: 0.00GB (0%) fs: swap dev: /dev/sda2
RAID:      System: supported: N/A
           Unused Devices: none
Sensors:   System Temperatures: cpu: 53.0C mobo: N/A gpu: 0.0:49C
           Fan Speeds (in rpm): cpu: N/A
Info:      Processes: 232 Uptime: 2:47 Memory: 3533.2/11912.7MB
           Init: Upstart v: 1.12.1 runlevel: 2 default: 2 Gcc sys: 4.8.4
           Client: Shell (bash 4.3.111 running in termin) inxi: 2.2.28
janhakl
#3 Příspěvek od janhakl »
Kde to v tom GSmart Control najdu? Ten update biosu, je to nutny? :D v zivote jsem to nedelal a co vim, tak je to hodne rizikovy
janhakl
#4 Příspěvek od janhakl »
jestli se divam dobre, tak error log je prazdny...
janhakl
#5 Příspěvek od janhakl »
taky dokonceno bez chyb
janhakl
#6 Příspěvek od janhakl »
Zadny dalsi napady krome toho update biosu? :(
janhakl
#7 Příspěvek od janhakl »
Tak podle vseho byl problem s proprietarnim ovladacem pro GPU. Nakonec jsem OS preinstaloval a pri zmene ovladacu jsem mel opet problem s bootovanim z rezimu spanku jako predtim. Nejaky rady jak to vyresit? potrebuji vubec proprietarni ovladac kdyz zadnej hrac nejsem?
#8 Příspěvek od menom »
Vyskusaj dalsi ovladac ...
#9 Příspěvek od kamowski »
janhakl píše:potrebuji vubec proprietarni ovladac kdyz zadnej hrac nejsem?
no to teda nepotrebuješ
stále používam to, čo si to samo nainštaluje a vôbec nejaké ovládače GK neriešim
prenoska
#10 Příspěvek od prenoska »
Ahoj, mám linux mint 18 KDE, a měl jsem problémy s probuzením z režimu spánku, počítač zamrzl a musel jsem to natvrdo resetnout, měl jsem nainstalováno jádro 4.7.3 a pomohlo mi vrácení se k jádru 4.6.4, na něm je probuzení v pohodě, jen doufám, že bude fungovat všechno ostatní, tak, jak to fungovalo na novějším jádru. Docela by mě zajímalo jaká komponenta to zamrzání způsobovala, protože bych časem chtěl jádro aktualizovat na novější, ale třeba až na něj přijde řada, tak už to bude vyladěné.
Tak jsem to přechválil, ono to s tím uspáním a probuzením jde jenom někdy, jindy, místo aby se notebook uspal, tak se při zavření víka restartuje, takže budu zkoušet ještě starší jádro, docela mě to mrzí, protože, jinak systém běhal na novějších jádrech slušně.
Naposledy upravil(a) prenoska dne 23 zář 2016, 18:01, celkem upraveno 1 x.
