Grafická karta GeForce 9800 GT [vyřešeno]
Zdravím mám problém s GeForce 9800 GT při scrollování ve Firefoxu a sledováním HD filmů mi to přes Firefox ci otevřený program dělá čáry, nevíte co s tím?
Re: Geforce 9800 GT
Aky system pouzivas, a co vypise Terminal po zadani prikazu:
Pripadne zmenit ovladac pre graficku kartu ....
lspci -k | grep VGA -A3.
Re: Geforce 9800 GT
Re: Geforce 9800 GT
WARNING: you should run this program as super-user.
kovi-system-product-name
description: Computer
width: 64 bits
capabilities: vsyscall32
*-core
description: Motherboard
physical id: 0
*-memory
description: System memory
physical id: 0
*-cpu
product: AMD Athlon(tm) 64 X2 Dual Core Processor 4200+
vendor: Advanced Micro Devices [AMD]
physical id: 1
bus info: cpu@0
capacity: 2200MHz
width: 64 bits
capabilities: fpu fpu_exception wp vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush mmx fxsr sse sse2 ht syscall nx mmxext fxsr_opt rdtscp x86-64 3dnowext 3dnow rep_good nopl extd_apicid pni cx16 lahf_lm cmp_legacy svm extapic cr8_legacy 3dnowprefetch vmmcall cpufreq
*-pci:0
description: Host bridge
product: RD580 Host Bridge
vendor: Advanced Micro Devices, Inc. [AMD/ATI]
physical id: 100
bus info: pci@0000:00:00.0
version: 00
width: 32 bits
clock: 66MHz
*-pci:0
description: PCI bridge
product: RS4xx PCI Express Port [ext gfx]
physical id: 2
bus info: pci@0000:00:02.0
version: 00
width: 32 bits
clock: 33MHz
capabilities: pci normal_decode bus_master cap_list
configuration: driver=pcieport
resources: irq:24 ioport:c000(size=4096) memory:f8000000-fbdfffff ioport:d0000000(size=268435456)
*-display
product: G92 [GeForce 9800 GT]
vendor: NVIDIA Corporation
physical id: 0
bus info: pci@0000:01:00.0
version: a2
width: 64 bits
clock: 33MHz
capabilities: vga_controller bus_master cap_list rom
configuration: driver=nvidia latency=0
resources: irq:27 memory:fa000000-faffffff memory:d0000000-dfffffff memory:f8000000-f9ffffff ioport:cc00(size=128) memory:fbde0000-fbdfffff
*-pci:1
product: RC4xx/RS4xx PCI Express Port 2
physical id: 5
bus info: pci@0000:00:05.0
version: 00
width: 32 bits
clock: 33MHz
resources: irq:25 ioport:d000(size=4096) memory:fbe00000-fbefffff
*-storage
description: SATA controller
product: JMB360 AHCI Controller
vendor: JMicron Technology Corp.
physical id: 0
bus info: pci@0000:02:00.0
version: 02
width: 32 bits
clock: 33MHz
capabilities: storage ahci_1.0 bus_master cap_list
configuration: driver=ahci latency=0
resources: irq:17 ioport:dc00(size=8) ioport:d880(size=4) ioport:d800(size=8) ioport:d480(size=4) ioport:d400(size=16) memory:fbefe000-fbefffff
*-storage
product: SB600 Non-Raid-5 SATA
physical id: 12
bus info: pci@0000:00:12.0
version: 00
width: 32 bits
clock: 66MHz
configuration: driver=ahci latency=64
resources: irq:21 ioport:b000(size=8) ioport:a000(size=4) ioport:9000(size=8) ioport:8000(size=4) ioport:7000(size=16) memory:f7fffc00-f7ffffff
*-usb:0
description: USB controller
product: SB600 USB (OHCI0)
physical id: 13
bus info: pci@0000:00:13.0
version: 00
width: 32 bits
clock: 66MHz
capabilities: ohci bus_master cap_list
configuration: driver=ohci-pci latency=64
resources: irq:16 memory:f7ffe000-f7ffefff
*-usb:1
product: SB600 USB (OHCI1)
physical id: 13.1
bus info: pci@0000:00:13.1
version: 00
width: 32 bits
clock: 66MHz
resources: irq:17 memory:f7ffd000-f7ffdfff
*-usb:2
product: SB600 USB (OHCI2)
physical id: 13.2
bus info: pci@0000:00:13.2
version: 00
width: 32 bits
clock: 66MHz
resources: irq:18 memory:f7ffc000-f7ffcfff
*-usb:3
product: SB600 USB (OHCI3)
physical id: 13.3
bus info: pci@0000:00:13.3
version: 00
width: 32 bits
clock: 66MHz
resources: irq:17 memory:f7ffb000-f7ffbfff
*-usb:4
product: SB600 USB (OHCI4)
physical id: 13.4
bus info: pci@0000:00:13.4
version: 00
width: 32 bits
clock: 66MHz
resources: irq:18 memory:f7ffa000-f7ffafff
*-usb:5
product: SB600 USB Controller (EHCI)
physical id: 13.5
bus info: pci@0000:00:13.5
version: 00
width: 32 bits
clock: 66MHz
capabilities: ehci bus_master cap_list
configuration: driver=ehci-pci latency=64
resources: irq:19 memory:f7fff800-f7fff8ff
*-serial
description: SMBus
product: SBx00 SMBus Controller
physical id: 14
bus info: pci@0000:00:14.0
version: 13
width: 32 bits
clock: 66MHz
capabilities: cap_list
configuration: driver=piix4_smbus latency=0
resources: irq:0 ioport:b00(size=16) memory:fed00000-fed003ff
*-ide
description: IDE interface
product: SB600 IDE
physical id: 14.1
bus info: pci@0000:00:14.1
version: 00
width: 32 bits
clock: 66MHz
capabilities: ide bus_master cap_list
configuration: driver=pata_atiixp latency=64
resources: irq:16 ioport:1f0(size=8) ioport:3f6 ioport:170(size=8) ioport:376 ioport:ff00(size=16)
*-multimedia
description: Audio device
product: SBx00 Azalia (Intel HDA)
physical id: 14.2
bus info: pci@0000:00:14.2
version: 00
width: 64 bits
clock: 33MHz
capabilities: bus_master cap_list
configuration: driver=snd_hda_intel latency=64
resources: irq:26 memory:f7ff4000-f7ff7fff
*-isa
description: ISA bridge
product: SB600 PCI to LPC Bridge
physical id: 14.3
bus info: pci@0000:00:14.3
version: 00
width: 32 bits
clock: 66MHz
capabilities: isa bus_master
configuration: latency=0
*-pci:2
product: SBx00 PCI to PCI Bridge
physical id: 14.4
bus info: pci@0000:00:14.4
version: 00
width: 32 bits
clock: 66MHz
capabilities: pci subtractive_decode bus_master
resources: ioport:e000(size=4096) memory:fbf00000-fbffffff
*-multimedia
description: Multimedia audio controller
product: CA0106 Soundblaster
vendor: Creative Labs
physical id: 1
bus info: pci@0000:03:01.0
version: 00
width: 32 bits
clock: 33MHz
configuration: driver=snd_ca0106 latency=64 maxlatency=20 mingnt=2
resources: irq:21 ioport:ec00(size=32)
*-network:0
product: RTL-8100/8101L/8139 PCI Fast Ethernet Adapter
physical id: 2
bus info: pci@0000:03:02.0
logical name: enp3s2
version: 10
serial: 00:e0:4c:03:d7:a8
capacity: 100Mbit/s
width: 32 bits
clock: 33MHz
capabilities: bus_master cap_list rom ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=8139too driverversion=0.9.28 duplex=full ip=192.168.2.42 latency=64 link=yes maxlatency=64 mingnt=32 multicast=yes port=MII speed=100Mbit/s
resources: irq:22 ioport:e800(size=256) memory:fbfffc00-fbfffcff memory:fbfe0000-fbfeffff
*-firewire
description: FireWire (IEEE 1394)
product: VT6306/7/8 [Fire II(M)] IEEE 1394 OHCI Controller
vendor: VIA Technologies, Inc.
physical id: 3
bus info: pci@0000:03:03.0
version: c0
width: 32 bits
clock: 33MHz
configuration: driver=firewire_ohci latency=64 maxlatency=32
resources: irq:22 memory:fbfff000-fbfff7ff ioport:e480(size=128)
*-network:1
product: 88E8001 Gigabit Ethernet Controller
vendor: Marvell Technology Group Ltd.
physical id: 4
bus info: pci@0000:03:04.0
logical name: enp3s4
version: 13
serial: 00:18:f3:62:9c:25
capacity: 1Gbit/s
width: 32 bits
clock: 66MHz
capabilities: bus_master cap_list rom ethernet physical tp 10bt 10bt-fd 100bt 100bt-fd 1000bt 1000bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=skge driverversion=1.14 latency=64 link=no maxlatency=31 mingnt=23 multicast=yes port=twisted pair
resources: irq:23 memory:fbff8000-fbffbfff ioport:e000(size=256) memory:fbfc0000-fbfdffff
*-pci:1
product: K8 [Athlon64/Opteron] HyperTransport Technology Configuration
vendor: Advanced Micro Devices, Inc. [AMD]
physical id: 101
bus info: pci@0000:00:18.0
version: 00
width: 32 bits
clock: 33MHz
*-pci:2
product: K8 [Athlon64/Opteron] Address Map
physical id: 102
bus info: pci@0000:00:18.1
version: 00
width: 32 bits
clock: 33MHz
*-pci:3
product: K8 [Athlon64/Opteron] DRAM Controller
physical id: 103
bus info: pci@0000:00:18.2
version: 00
width: 32 bits
clock: 33MHz
*-pci:4
product: K8 [Athlon64/Opteron] Miscellaneous Control
physical id: 104
bus info: pci@0000:00:18.3
version: 00
width: 32 bits
clock: 33MHz
configuration: driver=k8temp
resources: irq:0
*-scsi
physical id: 2
logical name: scsi5
capabilities: emulated
*-cdrom
description: DVD-RAM writer
product: DVDRAM GSA-H10N
vendor: HL-DT-ST
physical id: 0.0.0
bus info: scsi@5:0.0.0
logical name: /dev/cdrom
logical name: /dev/cdrw
logical name: /dev/dvd
logical name: /dev/dvdrw
logical name: /dev/sr0
version: JL12
capabilities: removable audio cd-r cd-rw dvd dvd-r dvd-ram
*-scsi:0
physical id: 1
bus info: scsi@7
logical name: scsi7
capabilities: scsi-host
configuration: driver=usb-storage
*-scsi:1
physical id: 2
bus info: scsi@8
logical name: scsi8
WARNING: output may be incomplete or inaccurate, you should run this program as super-user.
kovi@kovi-System-Product-Name ~ $
kovi@kovi-System-Product-Name ~ $ lspci -k | grep VGA -A3
01:00.0 VGA compatible controller: NVIDIA Corporation G92 [GeForce 9800 GT] (rev a2)
Subsystem: CardExpert Technology G92 [GeForce 9800 GT]
Kernel driver in use: nvidia
Kernel modules: nvidiafb, nouveau, nvidia_340
kovi@kovi-System-Product-Name ~ $ inxi -xxxF
System: Host: kovi-System-Product-Name Kernel: 4.4.0-36-generic x86_64 (64 bit gcc: 5.4.0)
Desktop: KDE Plasma 5.6.5 (Qt 5.5.1) dm: sddm,sddm Distro: Linux Mint 18 Sarah
Machine: Mobo: ASUSTeK model: M2R32-MVP v: Rev 1.xx Bios: American Megatrends v: 1109 date: 09/22/2009
CPU: Dual core AMD Athlon 64 X2 4200+ (-MCP-) cache: 1024 KB flags: (lm nx sse sse2 sse3 svm) bmips: 4009
clock speeds: min/max: 1000/2200 MHz 1: 1000 MHz 2: 1000 MHz
Graphics: Card: NVIDIA G92 [GeForce 9800 GT] bus-ID: 01:00.0 chip-ID: 10de:0614
Display Server: X.Org 1.18.3 drivers: nvidia (unloaded: fbdev,vesa,nouveau)
Resolution: 1920x1080@60.00hz
GLX Renderer: GeForce 9800 GT/PCIe/SSE2 GLX Version: 3.3.0 NVIDIA 340.96 Direct Rendering: Yes
Audio: Card-1 Creative Labs CA0106 Soundblaster
driver: snd_ca0106 port: ec00 bus-ID: 03:01.0 chip-ID: 1102:0007
Card-2 Advanced Micro Devices [AMD/ATI] SBx00 Azalia (Intel HDA)
driver: snd_hda_intel bus-ID: 00:14.2 chip-ID: 1002:4383
Sound: Advanced Linux Sound Architecture v: k4.4.0-36-generic
Network: Card-1: Realtek RTL-8100/8101L/8139 PCI Fast Ethernet Adapter
driver: 8139too v: 0.9.28 port: e800 bus-ID: 03:02.0 chip-ID: 10ec:8139
IF: enp3s2 state: unknown speed: 100 Mbps duplex: full mac: 00:e0:4c:03:d7:a8
Card-2: Marvell 88E8001 Gigabit Ethernet Controller
driver: skge v: 1.14 port: e000 bus-ID: 03:04.0 chip-ID: 11ab:4320
IF: enp3s4 state: down mac: 00:18:f3:62:9c:25
Drives: HDD Total Size: 1240.2GB (58.9% used)
ID-1: /dev/sda model: KINGSTON_SV300S3 size: 240.1GB serial: 50026B7757087102
ID-2: USB /dev/sdb model: My_Passport_0740 size: 1000.2GB serial: 575831314139325032393739-0:0
Partition: ID-1: / size: 216G used: 16G (8%) fs: ext4 dev: /dev/sda1
ID-2: swap-1 size: 4.29GB used: 0.00GB (0%) fs: swap dev: /dev/sda5
RAID: System: supported: N/A
Unused Devices: none
Sensors: System Temperatures: cpu: 36.0C mobo: 36.0C gpu: 0.0:42C
Fan Speeds (in rpm): cpu: 1194 psu: 0 sys-1: 1534 sys-2: 0
Info: Processes: 199 Uptime: 10:44 Memory: 1496.9/3951.7MB
Init: systemd v: 229 runlevel: 5 default: 2 Gcc sys: 5.4.0
Client: Shell (bash 4.3.421 running in konsole) inxi: 2.2.35
Zmenu ovladačů jsem jsem provedl je to zhruba nastejno akorát xserver ovladače jsou nejhorší.
width: 64 bits
*-core
physical id: 0
*-memory
physical id: 0
*-cpu
physical id: 1
bus info: cpu@0
capacity: 2200MHz
width: 64 bits
*-pci:0
physical id: 100
version: 00
width: 32 bits
clock: 66MHz
*-pci:0
physical id: 2
version: 00
width: 32 bits
clock: 33MHz
*-display
physical id: 0
version: a2
width: 64 bits
clock: 33MHz
*-pci:1
physical id: 5
version: 00
width: 32 bits
clock: 33MHz
*-storage
physical id: 0
version: 02
width: 32 bits
clock: 33MHz
*-storage
physical id: 12
version: 00
width: 32 bits
clock: 66MHz
*-usb:0
physical id: 13
version: 00
width: 32 bits
clock: 66MHz
*-usb:1
physical id: 13.1
version: 00
width: 32 bits
clock: 66MHz
*-usb:2
physical id: 13.2
version: 00
width: 32 bits
clock: 66MHz
*-usb:3
physical id: 13.3
version: 00
width: 32 bits
clock: 66MHz
*-usb:4
physical id: 13.4
version: 00
width: 32 bits
clock: 66MHz
*-usb:5
physical id: 13.5
version: 00
width: 32 bits
clock: 66MHz
*-serial
description: SMBus
physical id: 14
version: 13
width: 32 bits
clock: 66MHz
*-ide
product: SB600 IDE
physical id: 14.1
version: 00
width: 32 bits
clock: 66MHz
*-multimedia
physical id: 14.2
version: 00
width: 64 bits
clock: 33MHz
*-isa
physical id: 14.3
version: 00
width: 32 bits
clock: 66MHz
*-pci:2
physical id: 14.4
version: 00
width: 32 bits
clock: 66MHz
*-multimedia
physical id: 1
version: 00
width: 32 bits
clock: 33MHz
*-network:0
physical id: 2
version: 10
capacity: 100Mbit/s
width: 32 bits
clock: 33MHz
*-firewire
physical id: 3
version: c0
width: 32 bits
clock: 33MHz
*-network:1
physical id: 4
version: 13
capacity: 1Gbit/s
width: 32 bits
clock: 66MHz
*-pci:1
physical id: 101
version: 00
width: 32 bits
clock: 33MHz
*-pci:2
physical id: 102
version: 00
width: 32 bits
clock: 33MHz
*-pci:3
physical id: 103
version: 00
width: 32 bits
clock: 33MHz
*-pci:4
physical id: 104
version: 00
width: 32 bits
clock: 33MHz
resources: irq:0
*-scsi
physical id: 2
logical name: scsi5
*-cdrom
vendor: HL-DT-ST
physical id: 0.0.0
version: JL12
*-scsi:0
physical id: 1
bus info: scsi@7
logical name: scsi7
*-scsi:1
physical id: 2
bus info: scsi@8
logical name: scsi8
Re: Geforce 9800 GT
Mohol by si vyskusat ukoncit programy, kde to blbne a do Terminalu kopirovat, zadat prikaz, (vlozit Ctrl+Shift+V):
Potom vyskusat ci doslo k zmene.
nvidia-settings --assign CurrentMetaMode="nvidia-auto-select +0+0 { ForceFullCompositionPipeline = On }"
Re: Geforce 9800 GT
Děkuji tento příkaz mi pomohl nedělá to už ani po restartu počítače, k linuxu jsem se vrátil po cca 6-ti letech tak se zase učím.
Re: Geforce 9800 GT
To je dobra sprava, ak to este zblbne, tak napis
Inak temu si mohol oznacit tou zelenou fajfkou.
