Bootinfo
este jedna otazka, dobre mi instalacia zarovnala oddiely na SSD? Dakujem za kazdu raduPaste2
Create Paste
Followup Paste
QR
Boot Info Script cfd9efe + Boot-Repair extra info [Boot-Info 26Apr2016]
============================= Boot Info Summary: ===============================
=> libparted MBR boot code is installed in the MBR of /dev/sdb.
=> Grub2 (v2.00) is installed in the MBR of /dev/sdc and looks at sector 1 of
the same hard drive for core.img. core.img is at this location and looks
for (,msdos1)/boot/grub. It also embeds following components:
modules
fshelp ext2 part_msdos biosdisk
sdb1: __________________________________________________________________________
File system: ext4
Boot sector type: -
Boot sector info:
Operating System:
Boot files:
sdb2: __________________________________________________________________________
File system: swap
Boot sector type: -
Boot sector info:
sdb3: __________________________________________________________________________
File system: ext4
Boot sector type: -
Boot sector info:
Operating System:
Boot files:
sdc1: __________________________________________________________________________
File system: ext4
Boot sector type: -
Boot sector info:
Operating System: Linux Mint 18
Boot files: /boot/grub/grub.cfg /etc/fstab
/boot/grub/i386-pc/core.img
============================ Drive/Partition Info: =============================
Drive: sdb _____________________________________________________________________
Disk /dev/sdb: 465.8 GiB, 500107862016 bytes, 976773168 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Disklabel type: dos
Partition Boot Start Sector End Sector # of Sectors Id System
/dev/sdb1 2,048 7,813,119 7,811,072 83 Linux
/dev/sdb2 7,813,120 11,718,655 3,905,536 82 Linux swap / Solaris
/dev/sdb3 11,718,656 976,771,071 965,052,416 83 Linux
Drive: sdc _____________________________________________________________________
Disk /dev/sdc: 55.9 GiB, 60022480896 bytes, 117231408 sectors
Disklabel type: dos
/dev/sdc1 * 2,048 107,464,703 107,462,656 83 Linux
"blkid" output: ________________________________________________________________
Device UUID TYPE LABEL
/dev/sdb1 9d08c17b-f9e2-4054-a466-27d58c66642f ext4
/dev/sdb2 20e03f84-2c16-40be-b024-0c2b7ebda6f0 swap
/dev/sdb3 3a8fa9af-6ceb-45f5-8617-ccf359b99545 ext4
/dev/sdc1 7766a712-7ff6-4120-ad31-a78a6b666103 ext4
========================= "ls -l /dev/disk/by-id" output: ======================
total 0
lrwxrwxrwx 1 root root 9 Sep 3 00:13 ata-Hitachi_HTS547550A9E384_J2170052H10LGC -> ../../sdb
lrwxrwxrwx 1 root root 10 Sep 3 00:13 ata-Hitachi_HTS547550A9E384_J2170052H10LGC-part1 -> ../../sdb1
lrwxrwxrwx 1 root root 10 Sep 3 00:13 ata-Hitachi_HTS547550A9E384_J2170052H10LGC-part2 -> ../../sdb2
lrwxrwxrwx 1 root root 10 Sep 3 00:13 ata-Hitachi_HTS547550A9E384_J2170052H10LGC-part3 -> ../../sdb3
lrwxrwxrwx 1 root root 9 Sep 3 00:13 ata-KINGSTON_SV300S37A60G_50026B723B060BF3 -> ../../sdc
lrwxrwxrwx 1 root root 10 Sep 3 00:13 ata-KINGSTON_SV300S37A60G_50026B723B060BF3-part1 -> ../../sdc1
lrwxrwxrwx 1 root root 9 Sep 3 00:13 wwn-0x5000cca642ce8e1c -> ../../sdb
lrwxrwxrwx 1 root root 10 Sep 3 00:13 wwn-0x5000cca642ce8e1c-part1 -> ../../sdb1
lrwxrwxrwx 1 root root 10 Sep 3 00:13 wwn-0x5000cca642ce8e1c-part2 -> ../../sdb2
lrwxrwxrwx 1 root root 10 Sep 3 00:13 wwn-0x5000cca642ce8e1c-part3 -> ../../sdb3
lrwxrwxrwx 1 root root 9 Sep 3 00:13 wwn-0x50026b723b060bf3 -> ../../sdc
lrwxrwxrwx 1 root root 10 Sep 3 00:13 wwn-0x50026b723b060bf3-part1 -> ../../sdc1
================================ Mount points: =================================
Device Mount_Point Type Options
/dev/sdb1 /tmp ext4 (rw,relatime,data=ordered)
/dev/sdb3 /home ext4 (rw,relatime,data=ordered)
/dev/sdc1 / ext4 (rw,noatime,errors=remount-ro,data=ordered)
=========================== sdc1/boot/grub/grub.cfg: ===========================
# DO NOT EDIT THIS FILE
# It is automatically generated by grub-mkconfig using templates
# from /etc/grub.d and settings from /etc/default/grub
### BEGIN /etc/grub.d/00_header ###
if [ -s $prefix/grubenv ]; then
set have_grubenv=true
load_env
fi
if [ "${next_entry}" ] ; then
set default="${next_entry}"
set next_entry=
save_env next_entry
set boot_once=true
else
set default="0"
fi
if [ x"${feature_menuentry_id}" = xy ]; then
menuentry_id_option="--id"
else
menuentry_id_option=""
fi
export menuentry_id_option
if [ "${prev_saved_entry}" ]; then
set saved_entry="${prev_saved_entry}"
save_env saved_entry
set prev_saved_entry=
save_env prev_saved_entry
set boot_once=true
fi
function savedefault {
if [ -z "${boot_once}" ]; then
saved_entry="${chosen}"
fi
function recordfail {
set recordfail=1
if [ -n "${have_grubenv}" ]; then if [ -z "${boot_once}" ]; then save_env recordfail; fi; fi
function load_video {
if [ x$feature_all_video_module = xy ]; then
insmod all_video
else
insmod efi_gop
insmod efi_uga
insmod ieee1275_fb
insmod vbe
insmod vga
insmod video_bochs
insmod video_cirrus
fi
if [ x$feature_default_font_path = xy ] ; then
font=unicode
else
insmod part_msdos
insmod ext2
set root='hd1,msdos1'
if [ x$feature_platform_search_hint = xy ]; then
search --no-floppy --fs-uuid --set=root --hint-bios=hd1,msdos1 --hint-efi=hd1,msdos1 --hint-baremetal=ahci1,msdos1 7766a712-7ff6-4120-ad31-a78a6b666103
else
search --no-floppy --fs-uuid --set=root 7766a712-7ff6-4120-ad31-a78a6b666103
fi
font="/usr/share/grub/unicode.pf2"
fi
if loadfont $font ; then
set gfxmode=auto
load_video
insmod gfxterm
set locale_dir=$prefix/locale
set lang=sk_SK
insmod gettext
fi
terminal_output gfxterm
if [ "${recordfail}" = 1 ] ; then
set timeout=30
else
if [ x$feature_timeout_style = xy ] ; then
set timeout_style=hidden
set timeout=0
# Fallback hidden-timeout code in case the timeout_style feature is
# unavailable.
elif sleep --interruptible 0 ; then
set timeout=0
fi
fi
### END /etc/grub.d/00_header ###
### BEGIN /etc/grub.d/05_debian_theme ###
set menu_color_normal=white/black
set menu_color_highlight=black/light-gray
### END /etc/grub.d/05_debian_theme ###
### BEGIN /etc/grub.d/06_mint_theme ###
set menu_color_highlight=white/light-gray
### END /etc/grub.d/06_mint_theme ###
### BEGIN /etc/grub.d/10_linux ###
function gfxmode {
set gfxpayload="${1}"
if [ "${1}" = "keep" ]; then
set vt_handoff=vt.handoff=7
else
set vt_handoff=
fi
if [ "${recordfail}" != 1 ]; then
if [ -e ${prefix}/gfxblacklist.txt ]; then
if hwmatch ${prefix}/gfxblacklist.txt 3; then
if [ ${match} = 0 ]; then
set linux_gfx_mode=keep
else
set linux_gfx_mode=text
fi
else
fi
else
fi
else
fi
export linux_gfx_mode
menuentry 'Linux Mint 18 Cinnamon 32-bit' --class ubuntu --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-simple-7766a712-7ff6-4120-ad31-a78a6b666103' {
recordfail
load_video
gfxmode $linux_gfx_mode
insmod gzio
if [ x$grub_platform = xxen ]; then insmod xzio; insmod lzopio; fi
insmod part_msdos
insmod ext2
else
fi
linux /boot/vmlinuz-4.6.2-040602-generic root=UUID=7766a712-7ff6-4120-ad31-a78a6b666103 ro reboot=efi elevator=deadline quiet splash $vt_handoff
initrd /boot/initrd.img-4.6.2-040602-generic
submenu 'Advanced options for Linux Mint 18 Cinnamon 32-bit' $menuentry_id_option 'gnulinux-advanced-7766a712-7ff6-4120-ad31-a78a6b666103' {
menuentry 'Linux Mint 18 Cinnamon 32-bit, with Linux 4.6.2-040602-generic' --class ubuntu --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-4.6.2-040602-generic-advanced-7766a712-7ff6-4120-ad31-a78a6b666103' {
recordfail
load_video
insmod gzio
insmod part_msdos
insmod ext2
else
fi
echo 'Loading Linux 4.6.2-040602-generic ...'
echo 'Loading initial ramdisk ...'
menuentry 'Linux Mint 18 Cinnamon 32-bit, with Linux 4.6.2-040602-generic (upstart)' --class ubuntu --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-4.6.2-040602-generic-init-upstart-7766a712-7ff6-4120-ad31-a78a6b666103' {
recordfail
load_video
insmod gzio
insmod part_msdos
insmod ext2
else
fi
linux /boot/vmlinuz-4.6.2-040602-generic root=UUID=7766a712-7ff6-4120-ad31-a78a6b666103 ro reboot=efi elevator=deadline quiet splash $vt_handoff init=/sbin/upstart
menuentry 'Linux Mint 18 Cinnamon 32-bit, with Linux 4.6.2-040602-generic (recovery mode)' --class ubuntu --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-4.6.2-040602-generic-recovery-7766a712-7ff6-4120-ad31-a78a6b666103' {
recordfail
load_video
insmod gzio
insmod part_msdos
insmod ext2
else
fi
linux /boot/vmlinuz-4.6.2-040602-generic root=UUID=7766a712-7ff6-4120-ad31-a78a6b666103 ro recovery nomodeset reboot=efi
menuentry 'Linux Mint 18 Cinnamon 32-bit, with Linux 4.4.0-36-generic' --class ubuntu --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-4.4.0-36-generic-advanced-7766a712-7ff6-4120-ad31-a78a6b666103' {
recordfail
load_video
insmod gzio
insmod part_msdos
insmod ext2
else
fi
echo 'Loading Linux 4.4.0-36-generic ...'
linux /boot/vmlinuz-4.4.0-36-generic root=UUID=7766a712-7ff6-4120-ad31-a78a6b666103 ro reboot=efi elevator=deadline quiet splash $vt_handoff
initrd /boot/initrd.img-4.4.0-36-generic
menuentry 'Linux Mint 18 Cinnamon 32-bit, with Linux 4.4.0-36-generic (upstart)' --class ubuntu --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-4.4.0-36-generic-init-upstart-7766a712-7ff6-4120-ad31-a78a6b666103' {
recordfail
load_video
insmod gzio
insmod part_msdos
insmod ext2
else
fi
linux /boot/vmlinuz-4.4.0-36-generic root=UUID=7766a712-7ff6-4120-ad31-a78a6b666103 ro reboot=efi elevator=deadline quiet splash $vt_handoff init=/sbin/upstart
menuentry 'Linux Mint 18 Cinnamon 32-bit, with Linux 4.4.0-36-generic (recovery mode)' --class ubuntu --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-4.4.0-36-generic-recovery-7766a712-7ff6-4120-ad31-a78a6b666103' {
recordfail
load_video
insmod gzio
insmod part_msdos
insmod ext2
else
fi
linux /boot/vmlinuz-4.4.0-36-generic root=UUID=7766a712-7ff6-4120-ad31-a78a6b666103 ro recovery nomodeset reboot=efi
menuentry 'Linux Mint 18 Cinnamon 32-bit, with Linux 4.4.0-21-generic' --class ubuntu --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-4.4.0-21-generic-advanced-7766a712-7ff6-4120-ad31-a78a6b666103' {
recordfail
load_video
insmod gzio
insmod part_msdos
insmod ext2
else
fi
echo 'Loading Linux 4.4.0-21-generic ...'
linux /boot/vmlinuz-4.4.0-21-generic root=UUID=7766a712-7ff6-4120-ad31-a78a6b666103 ro reboot=efi elevator=deadline quiet splash $vt_handoff
initrd /boot/initrd.img-4.4.0-21-generic
menuentry 'Linux Mint 18 Cinnamon 32-bit, with Linux 4.4.0-21-generic (upstart)' --class ubuntu --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-4.4.0-21-generic-init-upstart-7766a712-7ff6-4120-ad31-a78a6b666103' {
recordfail
load_video
insmod gzio
insmod part_msdos
insmod ext2
else
fi
linux /boot/vmlinuz-4.4.0-21-generic root=UUID=7766a712-7ff6-4120-ad31-a78a6b666103 ro reboot=efi elevator=deadline quiet splash $vt_handoff init=/sbin/upstart
menuentry 'Linux Mint 18 Cinnamon 32-bit, with Linux 4.4.0-21-generic (recovery mode)' --class ubuntu --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-4.4.0-21-generic-recovery-7766a712-7ff6-4120-ad31-a78a6b666103' {
recordfail
load_video
insmod gzio
insmod part_msdos
insmod ext2
else
fi
linux /boot/vmlinuz-4.4.0-21-generic root=UUID=7766a712-7ff6-4120-ad31-a78a6b666103 ro recovery nomodeset reboot=efi
### END /etc/grub.d/10_linux ###
### BEGIN /etc/grub.d/10_lupin ###
### END /etc/grub.d/10_lupin ###
### BEGIN /etc/grub.d/20_linux_xen ###
### END /etc/grub.d/20_linux_xen ###
### BEGIN /etc/grub.d/20_memtest86+ ###
menuentry 'Memory test (memtest86+)' {
insmod part_msdos
insmod ext2
else
fi
knetbsd /boot/memtest86+.elf
menuentry 'Memory test (memtest86+, serial console 115200)' {
insmod part_msdos
insmod ext2
else
fi
linux16 /boot/memtest86+.bin console=ttyS0,115200n8
### END /etc/grub.d/20_memtest86+ ###
### BEGIN /etc/grub.d/30_os-prober ###
### END /etc/grub.d/30_os-prober ###
### BEGIN /etc/grub.d/30_uefi-firmware ###
### END /etc/grub.d/30_uefi-firmware ###
### BEGIN /etc/grub.d/40_custom ###
# This file provides an easy way to add custom menu entries. Simply type the
# menu entries you want to add after this comment. Be careful not to change
# the 'exec tail' line above.
### END /etc/grub.d/40_custom ###
### BEGIN /etc/grub.d/41_custom ###
if [ -f ${config_directory}/custom.cfg ]; then
source ${config_directory}/custom.cfg
elif [ -z "${config_directory}" -a -f $prefix/custom.cfg ]; then
source $prefix/custom.cfg;
fi
### END /etc/grub.d/41_custom ###
=============================== sdc1/etc/fstab: ================================
# Use 'blkid' to print the universally unique identifier for a
# device; this may be used with UUID= as a more robust way to name devices
# that works even if disks are added and removed. See fstab(5).
# <file system> <mount point> <type> <options> <dump> <pass>
# / was on /dev/sdc1 during installation
UUID=7766a712-7ff6-4120-ad31-a78a6b666103 / ext4 noatime,errors=remount-ro 0 1
# /home was on /dev/sda3 during installation
UUID=3a8fa9af-6ceb-45f5-8617-ccf359b99545 /home ext4 defaults 0 2
# /tmp was on /dev/sda1 during installation
UUID=9d08c17b-f9e2-4054-a466-27d58c66642f /tmp ext4 defaults 0 2
# swap was on /dev/sda2 during installation
UUID=20e03f84-2c16-40be-b024-0c2b7ebda6f0 none swap sw 0 0
=================== sdc1: Location of files loaded by Grub: ====================
GiB - GB File Fragment(s)
48.333053589 = 51.897221120 boot/grub/grub.cfg 1
48.342491150 = 51.907354624 boot/grub/i386-pc/core.img 1
38.139232635 = 40.951689216 boot/vmlinuz-4.4.0-21-generic 1
4.711063385 = 5.058465792 boot/vmlinuz-4.4.0-36-generic 1
0.575839996 = 0.618303488 boot/vmlinuz-4.6.2-040602-generic 1
0.575839996 = 0.618303488 vmlinuz 1
3.539451599 = 3.800457216 boot/initrd.img-4.4.0-21-generic 4
48.259963989 = 51.818741760 boot/initrd.img-4.4.0-36-generic 5
2.680652618 = 2.878328832 boot/initrd.img-4.6.2-040602-generic 3
2.680652618 = 2.878328832 initrd.img 3
=============================== StdErr Messages: ===============================
File descriptor 9 (/proc/6124/mounts) leaked on lvs invocation. Parent PID 13943: bash
File descriptor 63 (pipe:[52717]) leaked on lvs invocation. Parent PID 13943: bash
ADDITIONAL INFORMATION :
=================== log of boot-info 2016-09-03__00h13 ===================
boot-info version : 4ppa38
boot-sav version : 4ppa38
glade2script version : 3.2.3~ppa1
boot-sav-extra version :
File descriptor 9 (/proc/6124/mounts) leaked on lvs invocation. Parent PID 7770: /bin/sh
boot-info is executed in installed-session (Linux Mint 18 Sarah, sarah, LinuxMint, i686)
CPU op-mode(s): 32-bit, 64-bit
BOOT_IMAGE=/boot/vmlinuz-4.6.2-040602-generic root=UUID=7766a712-7ff6-4120-ad31-a78a6b666103 ro reboot=efi elevator=deadline quiet splash vt.handoff=7
=================== os-prober:
/dev/sdc1:Používaný OS - Linux Mint 18 Sarah CurrentSession:linux
=================== blkid:
/dev/sdb1: UUID="9d08c17b-f9e2-4054-a466-27d58c66642f" TYPE="ext4" PARTUUID="2d402834-01"
/dev/sdb2: UUID="20e03f84-2c16-40be-b024-0c2b7ebda6f0" TYPE="swap" PARTUUID="2d402834-02"
/dev/sdb3: UUID="3a8fa9af-6ceb-45f5-8617-ccf359b99545" TYPE="ext4" PARTUUID="2d402834-03"
/dev/sdc1: UUID="7766a712-7ff6-4120-ad31-a78a6b666103" TYPE="ext4" PARTUUID="7aca49f6-01"
1 disks with OS, 1 OS : 1 Linux, 0 MacOS, 0 Windows, 0 unknown type OS.
=================== /etc/grub.d/ :
drwxr-xr-x 2 root root 4096 sep 2 23:50 grub.d
total 92
-rw-r--r-- 1 root root 483 apr 16 00:02 README
-rwxr-xr-x 1 root root 9791 apr 16 00:02 00_header
-rwxr-xr-x 1 root root 6258 mar 15 19:08 05_debian_theme
-rwxr-xr-x 1 root root 1180 okt 25 2014 06_mint_theme
-rwxr-xr-x 1 root root 12271 sep 2 23:50 10_linux
-rwxr-xr-x 1 root root 10634 okt 1 2012 10_lupin
-rwxr-xr-x 1 root root 11082 apr 16 00:02 20_linux_xen
-rwxr-xr-x 1 root root 1992 jan 28 2016 20_memtest86+
-rwxr-xr-x 1 root root 11692 apr 16 00:02 30_os-prober
-rwxr-xr-x 1 root root 1418 apr 16 00:02 30_uefi-firmware
-rwxr-xr-x 1 root root 214 apr 16 00:02 40_custom
-rwxr-xr-x 1 root root 216 apr 16 00:02 41_custom
=================== /etc/default/grub :
# If you change this file, run 'update-grub' afterwards to update
# /boot/grub/grub.cfg.
# For full documentation of the options in this file, see:
# info -f grub -n 'Simple configuration'
GRUB_DEFAULT=0
GRUB_HIDDEN_TIMEOUT=0
GRUB_HIDDEN_TIMEOUT_QUIET=true
GRUB_TIMEOUT=10
GRUB_DISTRIBUTOR=`lsb_release -i -s 2> /dev/null || echo Debian`
GRUB_CMDLINE_LINUX_DEFAULT="elevator=deadline quiet splash"
GRUB_CMDLINE_LINUX="reboot=efi"
# Uncomment to enable BadRAM filtering, modify to suit your needs
# This works with Linux (no patch required) and with any kernel that obtains
# the memory map information from GRUB (GNU Mach, kernel of FreeBSD ...)
#GRUB_BADRAM="0x01234567,0xfefefefe,0x89abcdef,0xefefefef"
# Uncomment to disable graphical terminal (grub-pc only)
#GRUB_TERMINAL=console
# The resolution used on graphical terminal
# note that you can use only modes which your graphic card supports via VBE
# you can see them in real GRUB with the command `vbeinfo'
#GRUB_GFXMODE=640x480
# Uncomment if you don't want GRUB to pass "root=UUID=xxx" parameter to Linux
#GRUB_DISABLE_LINUX_UUID=true
# Uncomment to disable generation of recovery mode menu entries
#GRUB_DISABLE_RECOVERY="true"
# Uncomment to get a beep at grub start
#GRUB_INIT_TUNE="480 440 1"
=================== UEFI/Legacy mode:
This installed-session is not EFI-compatible.
SecureBoot disabled.
=================== PARTITIONS & DISKS:
sdc1 : sdc, not-sepboot, grubenv-ok grub2, grub-pc , update-grub, 32, with-boot, is-os, not--efi--part, fstab-without-boot, fstab-without-efi, no-nt, no-winload, no-recov-nor-hid, no-bmgr, notwinboot, apt-get, grub-install, with--usr, fstab-without-usr, not-sep-usr, standard, not-far, .
sdb1 : sdb, maybesepboot, no-grubenv nogrub, no-docgrub, no-update-grub, 32, no-boot, no-os, not--efi--part, part-has-no-fstab, part-has-no-fstab, no-nt, no-winload, no-recov-nor-hid, no-bmgr, notwinboot, nopakmgr, nogrubinstall, no---usr, part-has-no-fstab, not-sep-usr, standard, not-far, /tmp.
sdb3 : sdb, maybesepboot, no-grubenv nogrub, no-docgrub, no-update-grub, 32, no-boot, no-os, not--efi--part, part-has-no-fstab, part-has-no-fstab, no-nt, no-winload, no-recov-nor-hid, no-bmgr, notwinboot, nopakmgr, nogrubinstall, no---usr, part-has-no-fstab, not-sep-usr, standard, farbios, /home.
sdc : not-GPT, BIOSboot-not-needed, has-no-EFIpart, not-usb, has-os, 2048 sectors * 512 bytes
sdb : not-GPT, BIOSboot-not-needed, has-no-EFIpart, not-usb, no-os, 2048 sectors * 512 bytes
=================== parted -l:
Model: ATA Hitachi HTS54755 (scsi)
Disk /dev/sdb: 500GB
Sector size (logical/physical): 512B/4096B
Partition Table: msdos
Disk Flags:
Number Start End Size Type File system Flags
1 1049kB 4000MB 3999MB primary ext4
2 4000MB 6000MB 2000MB primary linux-swap(v1)
3 6000MB 500GB 494GB primary ext4
Model: ATA KINGSTON SV300S3 (scsi)
Disk /dev/sdc: 60.0GB
Disk Flags:
1 1049kB 55.0GB 55.0GB primary ext4 boot
=================== parted -lm:
BYT;
/dev/sdb:500GB:scsi:512:4096:msdos:ATA Hitachi HTS54755:;
1:1049kB:4000MB:3999MB:ext4::;
2:4000MB:6000MB:2000MB:linux-swap(v1)::;
3:6000MB:500GB:494GB:ext4::;
BYT;
/dev/sdc:60.0GB:scsi:512:512:msdos:ATA KINGSTON SV300S3:;
1:1049kB:55.0GB:55.0GB:ext4::boot;
=================== lsblk:
KNAME TYPE FSTYPE SIZE LABEL
sdb disk 465,8G
sdb1 part ext4 3,7G
sdb2 part swap 1,9G
sdb3 part ext4 460,2G
sdc disk 55,9G
sdc1 part ext4 51,2G
KNAME ROTA RO RM STATE MOUNTPOINT
sdb 1 0 0 running
sdb1 1 0 0 /tmp
sdb2 1 0 0 [SWAP]
sdb3 1 0 0 /home
sdc 0 0 0 running
sdc1 0 0 0 /
=================== mount:
sysfs on /sys type sysfs (rw,nosuid,nodev,noexec,relatime)
proc on /proc type proc (rw,nosuid,nodev,noexec,relatime)
udev on /dev type devtmpfs (rw,nosuid,relatime,size=1527640k,nr_inodes=208090,mode=755)
devpts on /dev/pts type devpts (rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000)
tmpfs on /run type tmpfs (rw,nosuid,noexec,relatime,size=309360k,mode=755)
/dev/sdc1 on / type ext4 (rw,noatime,errors=remount-ro,data=ordered)
securityfs on /sys/kernel/security type securityfs (rw,nosuid,nodev,noexec,relatime)
tmpfs on /dev/shm type tmpfs (rw,nosuid,nodev)
tmpfs on /run/lock type tmpfs (rw,nosuid,nodev,noexec,relatime,size=5120k)
tmpfs on /sys/fs/cgroup type tmpfs (rw,mode=755)
cgroup on /sys/fs/cgroup/systemd type cgroup (rw,nosuid,nodev,noexec,relatime,xattr,release_agent=/lib/systemd/systemd-cgroups-agent,name=systemd)
pstore on /sys/fs/pstore type pstore (rw,nosuid,nodev,noexec,relatime)
cgroup on /sys/fs/cgroup/net_cls,net_prio type cgroup (rw,nosuid,nodev,noexec,relatime,net_cls,net_prio)
cgroup on /sys/fs/cgroup/cpuset type cgroup (rw,nosuid,nodev,noexec,relatime,cpuset,clone_children)
cgroup on /sys/fs/cgroup/perf_event type cgroup (rw,nosuid,nodev,noexec,relatime,perf_event,release_agent=/run/cgmanager/agents/cgm-release-agent.perf_event)
cgroup on /sys/fs/cgroup/cpu,cpuacct type cgroup (rw,nosuid,nodev,noexec,relatime,cpu,cpuacct)
cgroup on /sys/fs/cgroup/devices type cgroup (rw,nosuid,nodev,noexec,relatime,devices)
cgroup on /sys/fs/cgroup/pids type cgroup (rw,nosuid,nodev,noexec,relatime,pids,release_agent=/run/cgmanager/agents/cgm-release-agent.pids)
cgroup on /sys/fs/cgroup/freezer type cgroup (rw,nosuid,nodev,noexec,relatime,freezer)
cgroup on /sys/fs/cgroup/blkio type cgroup (rw,nosuid,nodev,noexec,relatime,blkio)
cgroup on /sys/fs/cgroup/hugetlb type cgroup (rw,nosuid,nodev,noexec,relatime,hugetlb,release_agent=/run/cgmanager/agents/cgm-release-agent.hugetlb)
cgroup on /sys/fs/cgroup/memory type cgroup (rw,nosuid,nodev,noexec,relatime,memory)
systemd-1 on /proc/sys/fs/binfmt_misc type autofs (rw,relatime,fd=27,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=12986)
mqueue on /dev/mqueue type mqueue (rw,relatime)
debugfs on /sys/kernel/debug type debugfs (rw,relatime)
hugetlbfs on /dev/hugepages type hugetlbfs (rw,relatime)
tracefs on /sys/kernel/debug/tracing type tracefs (rw,relatime)
/dev/sdb1 on /tmp type ext4 (rw,relatime,data=ordered)
/dev/sdb3 on /home type ext4 (rw,relatime,data=ordered)
binfmt_misc on /proc/sys/fs/binfmt_misc type binfmt_misc (rw,relatime)
cgmfs on /run/cgmanager/fs type tmpfs (rw,relatime,size=100k,mode=755)
tmpfs on /run/user/1000 type tmpfs (rw,nosuid,nodev,relatime,size=309360k,mode=700,uid=1000,gid=1000)
gvfsd-fuse on /run/user/1000/gvfs type fuse.gvfsd-fuse (rw,nosuid,nodev,relatime,user_id=1000,group_id=1000)
fusectl on /sys/fs/fuse/connections type fusectl (rw,relatime)
=================== ls:
/sys/block/sdb (filtered): alignment_offset badblocks bdi capability dev device discard_alignment events events_async events_poll_msecs ext_range holders inflight integrity power queue range removable ro sdb1 sdb2 sdb3 size slaves stat subsystem trace uevent
/sys/block/sdc (filtered): alignment_offset badblocks bdi capability dev device discard_alignment events events_async events_poll_msecs ext_range holders inflight integrity power queue range removable ro sdc1 size slaves stat subsystem trace uevent
/dev (filtered): autofs block bsg btrfs-control bus console core cpu cpu_dma_latency cuse disk dri fb0 fd full fuse fw0 hpet hugepages hwrng char initctl input kmsg kvm lightnvm log mapper mcelog media0 mem memory_bandwidth mqueue net network_latency network_throughput null port ppp psaux ptmx pts random rfkill rtc rtc0 sdb sdb1 sdb2 sdb3 sdc sdc1 sg1 sg2 shm snapshot snd stderr stdin stdout uhid uinput urandom userio vfio vga_arbiter vhci vhost-net video0 v4l zero
ls /dev/mapper: control
ls: cannot access '': No such file or directory
=================== df -Th:
Filesystem Type Size Used Avail Use% Mounted on
udev devtmpfs 1.5G 0 1.5G 0% /dev
tmpfs tmpfs 303M 5.1M 298M 2% /run
/dev/sdc1 ext4 51G 5.9G 42G 13% /
tmpfs tmpfs 1.5G 11M 1.5G 1% /dev/shm
tmpfs tmpfs 5.0M 4.0K 5.0M 1% /run/lock
tmpfs tmpfs 1.5G 0 1.5G 0% /sys/fs/cgroup
/dev/sdb1 ext4 3.7G 7.6M 3.4G 1% /tmp
/dev/sdb3 ext4 453G 494M 430G 1% /home
cgmfs tmpfs 100K 0 100K 0% /run/cgmanager/fs
tmpfs tmpfs 303M 20K 303M 1% /run/user/1000
=================== fdisk -l:
Disklabel type: dos
Disk identifier: 0x2d402834
Device Boot Start End Sectors Size Id Type
/dev/sdb1 2048 7813119 7811072 3.7G 83 Linux
/dev/sdb2 7813120 11718655 3905536 1.9G 82 Linux swap / Solaris
/dev/sdb3 11718656 976771071 965052416 460.2G 83 Linux
Disklabel type: dos
Disk identifier: 0x7aca49f6
/dev/sdc1 * 2048 107464703 107462656 51.2G 83 Linux
=================== Suggested repair
The default repair of the Boot-Repair utility would reinstall the grub2 of sdc1 into the MBRs of all disks (except USB without OS).
The boot flag would be placed on sdb3.
Additional repair would be performed: unhide-bootmenu-10s
