LM 18 Cinnamon, instalace HP710C
CZDavy
#1 Příspěvek od CZDavy »
Ahoj, zkoušel sem na netu najít různé návody na instalaci. Bohužel bez úspěchu. Tato tiskárna není podporována v rámci HPLIPu. Připojení je na paralelním portu. Děkuji za pomoc.
CZDavy
Re: LM 18 Cinnamon, instalace HP710C
#2 Příspěvek od CZDavy »
System:    Host: Davyho Kernel: 4.4.0-47-generic x86_64 (64 bit)
           Desktop: Cinnamon 3.0.7  Distro: Linux Mint 18 Sarah
Machine:   Mobo: Gigabyte model: M52S-S3P v: x.x
           Bios: Award v: F3 date: 10/05/2007
CPU:       Single core AMD Athlon LE-1600 (-UP-) cache: 1024 KB
           speed/max: 1000/2200 MHz
Graphics:  Card: NVIDIA Device 128b
           Display Server: X.Org 1.18.3 drivers: nvidia (unloaded: fbdev,vesa,nouveau)
           Resolution: 1360x768@60.02hz
           GLX Renderer: GeForce GT 710/PCIe/SSE2
           GLX Version: 4.5.0 NVIDIA 367.57
Audio:     Card-1 NVIDIA MCP61 High Definition Audio driver: snd_hda_intel
           Card-2 NVIDIA GK208 HDMI/DP Audio Controller driver: snd_hda_intel
           Sound: Advanced Linux Sound Architecture v: k4.4.0-47-generic
Network:   Card-1: NVIDIA MCP61 Ethernet driver: forcedeth
           IF: enp0s7 state: up speed: 100 Mbps duplex: full
           mac: 00:1a:4d:9e:0e:b8
           Card-2: Realtek RTL-8100/8101L/8139 PCI Fast Ethernet Adapter
           driver: 8139too
           IF: enp1s7 state: down mac: 00:21:27:c7:8d:80
Drives:    HDD Total Size: 247.9GB (9.9% used)
           ID-1: /dev/sda model: ST3120827AS size: 119.9GB
           ID-2: /dev/sdb model: Patriot_Spark size: 128.0GB
Partition: ID-1: / size: 22G used: 7.4G (37%) fs: ext4 dev: /dev/sdb1
           ID-2: /home size: 96G used: 2.2G (3%) fs: ext4 dev: /dev/sdb5
           ID-3: swap-1 size: 15.03GB used: 0.00GB (0%) fs: swap dev: /dev/sda1
Sensors:   System Temperatures: cpu: 19.0C mobo: N/A gpu: 24C
           Fan Speeds (in rpm): cpu: N/A
Info:      Processes: 183 Uptime: 3 min Memory: 899.3/3952.1MB
 description: Computer
    width: 64 bits
    capabilities: vsyscall32
  *-core
       description: Motherboard
       physical id: 0
     *-memory:0
          description: System memory
          physical id: 3
     *-cpu
          product: AMD Athlon(tm) Processor LE-1600
          vendor: Advanced Micro Devices [AMD]
          physical id: a
          bus info: cpu@0
          capacity: 2200MHz
          width: 64 bits
          capabilities: fpu fpu_exception wp vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush mmx fxsr sse sse2 syscall nx mmxext fxsr_opt rdtscp x86-64 3dnowext 3dnow rep_good nopl extd_apicid pni cx16 lahf_lm svm extapic cr8_legacy 3dnowprefetch vmmcall cpufreq
     *-memory:1 UNCLAIMED
          description: RAM memory
          product: MCP61 Memory Controller
          vendor: NVIDIA Corporation
          physical id: 0
          bus info: pci@0000:00:00.0
          version: a1
          width: 32 bits
          clock: 66MHz (15.2ns)
          capabilities: bus_master cap_list
          configuration: latency=0
     *-isa
          description: ISA bridge
          product: MCP61 LPC Bridge
          physical id: 1
          bus info: pci@0000:00:01.0
          version: a2
          width: 32 bits
          clock: 66MHz
          capabilities: isa bus_master
     *-serial
          description: SMBus
          product: MCP61 SMBus
          physical id: 1.1
          bus info: pci@0000:00:01.1
          version: a2
          width: 32 bits
          clock: 66MHz
          capabilities: cap_list
          configuration: driver=nForce2_smbus latency=0
          resources: irq:11 ioport:b400(size=64) ioport:1c00(size=64) ioport:1c40(size=64)
     *-memory:2 UNCLAIMED
          physical id: 1.2
          bus info: pci@0000:00:01.2
          version: a2
          width: 32 bits
     *-usb:0
          description: USB controller
          product: MCP61 USB 1.1 Controller
          physical id: 2
          bus info: pci@0000:00:02.0
          version: a3
          width: 32 bits
          clock: 66MHz
          capabilities: ohci bus_master cap_list
          configuration: driver=ohci-pci latency=0 maxlatency=1 mingnt=3
          resources: irq:23 memory:fd007000-fd007fff
     *-usb:1
          product: MCP61 USB 2.0 Controller
          physical id: 2.1
          bus info: pci@0000:00:02.1
          version: a3
          width: 32 bits
          clock: 66MHz
          capabilities: ehci bus_master cap_list
          configuration: driver=ehci-pci latency=0 maxlatency=1 mingnt=3
          resources: irq:22 memory:fd008000-fd0080ff
     *-pci:0
          description: PCI bridge
          product: MCP61 PCI bridge
          physical id: 4
          bus info: pci@0000:00:04.0
          version: a1
          width: 32 bits
          clock: 66MHz
          capabilities: pci subtractive_decode bus_master cap_list
          resources: ioport:9000(size=4096) memory:fb000000-fcffffff memory:fd100000-fd1fffff
        *-network
             product: RTL-8100/8101L/8139 PCI Fast Ethernet Adapter
             physical id: 7
             bus info: pci@0000:01:07.0
             logical name: enp1s7
             version: 10
             serial: 00:21:27:c7:8d:80
             capacity: 100Mbit/s
             width: 32 bits
             clock: 33MHz
             capabilities: bus_master cap_list rom ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd autonegotiation
             configuration: autonegotiation=on broadcast=yes driver=8139too driverversion=0.9.28 duplex=half latency=64 link=no maxlatency=64 mingnt=32 multicast=yes port=MII speed=10Mbit/s
             resources: irq:17 ioport:9000(size=256) memory:fc010000-fc0100ff memory:fd100000-fd11ffff
        *-communication UNCLAIMED
             description: Communication controller
             product: HSF 56k HSFi Modem
             vendor: Conexant Systems, Inc.
             physical id: 8
             bus info: pci@0000:01:08.0
             version: 01
             width: 32 bits
             clock: 33MHz
             configuration: latency=32
             resources: memory:fc000000-fc00ffff ioport:9400(size=8)
     *-multimedia
          description: Audio device
          product: MCP61 High Definition Audio
          physical id: 5
          bus info: pci@0000:00:05.0
          version: a2
          width: 32 bits
          clock: 66MHz
          configuration: driver=snd_hda_intel latency=0 maxlatency=5 mingnt=2
          resources: irq:22 memory:fd000000-fd003fff
     *-ide:0
          description: IDE interface
          product: MCP61 IDE
          physical id: 6
          bus info: pci@0000:00:06.0
          version: a2
          width: 32 bits
          clock: 66MHz
          capabilities: ide bus_master cap_list
          configuration: driver=pata_amd latency=0 maxlatency=1 mingnt=3
          resources: irq:0 ioport:1f0(size=8) ioport:3f6 ioport:170(size=8) ioport:376 ioport:f000(size=16)
     *-bridge
          product: MCP61 Ethernet
          physical id: 7
          bus info: pci@0000:00:07.0
          logical name: enp0s7
          version: a2
          serial: 00:1a:4d:9e:0e:b8
          capacity: 1000000000
          width: 32 bits
          clock: 66MHz
          capabilities: bridge bus_master cap_list ethernet physical mii 10bt 10bt-fd 100bt 100bt-fd 1000bt-fd autonegotiation
          configuration: autonegotiation=on broadcast=yes driver=forcedeth driverversion=0.64 duplex=full ip=192.168.1.100 latency=0 link=yes maxlatency=20 mingnt=1 multicast=yes port=MII speed=100Mbit/s
          resources: irq:25 memory:fd004000-fd004fff ioport:b800(size=8)
     *-ide:1
          product: MCP61 SATA Controller
          physical id: 8
          bus info: pci@0000:00:08.0
          version: a2
          width: 32 bits
          clock: 66MHz
          configuration: driver=sata_nv latency=0 maxlatency=1 mingnt=3
          resources: irq:20 ioport:9f0(size=8) ioport:bf0(size=4) ioport:970(size=8) ioport:b70(size=4) ioport:cc00(size=16) memory:fd005000-fd005fff
     *-ide:2
          physical id: 8.1
          bus info: pci@0000:00:08.1
          version: a2
          width: 32 bits
          clock: 66MHz
          resources: irq:23 ioport:9e0(size=8) ioport:be0(size=4) ioport:960(size=8) ioport:b60(size=4) ioport:e000(size=16) memory:fd006000-fd006fff
     *-pci:1
          product: MCP61 PCI Express bridge
          physical id: 9
          bus info: pci@0000:00:09.0
          version: a2
          width: 32 bits
          clock: 33MHz
          capabilities: pci normal_decode bus_master cap_list
          configuration: driver=pcieport
          resources: irq:24 ioport:a000(size=4096) memory:f8000000-faffffff ioport:e8000000(size=268435456)
        *-display
             product: NVIDIA Corporation
             physical id: 0
             bus info: pci@0000:02:00.0
             version: a1
             width: 64 bits
             clock: 33MHz
             capabilities: vga_controller bus_master cap_list rom
             configuration: driver=nvidia latency=0
             resources: irq:26 memory:f8000000-f8ffffff memory:e8000000-efffffff memory:f0000000-f1ffffff ioport:a000(size=128) memory:f9000000-f907ffff
        *-multimedia
             product: GK208 HDMI/DP Audio Controller
             physical id: 0.1
             bus info: pci@0000:02:00.1
             version: a1
             width: 32 bits
             clock: 33MHz
             resources: irq:16 memory:fa000000-fa003fff
     *-pci:2
          description: Host bridge
          product: K8 [Athlon64/Opteron] HyperTransport Technology Configuration
          vendor: Advanced Micro Devices, Inc. [AMD]
          physical id: 100
          bus info: pci@0000:00:18.0
          version: 00
          width: 32 bits
          clock: 33MHz
     *-pci:3
          product: K8 [Athlon64/Opteron] Address Map
          physical id: 101
          bus info: pci@0000:00:18.1
          version: 00
          width: 32 bits
          clock: 33MHz
     *-pci:4
          product: K8 [Athlon64/Opteron] DRAM Controller
          physical id: 102
          bus info: pci@0000:00:18.2
          version: 00
          width: 32 bits
          clock: 33MHz
     *-pci:5
          product: K8 [Athlon64/Opteron] Miscellaneous Control
          physical id: 103
          bus info: pci@0000:00:18.3
          version: 00
          width: 32 bits
          clock: 33MHz
          configuration: driver=k8temp
          resources: irq:0
     *-scsi
          physical id: b
          logical name: scsi0
          capabilities: emulated
        *-cdrom
             description: DVD-RAM writer
             product: DVD-RAM GSA-H20L
             vendor: HL-DT-ST
             physical id: 0.0.0
             bus info: scsi@0:0.0.0
             logical name: /dev/cdrom
             logical name: /dev/cdrw
             logical name: /dev/dvd
             logical name: /dev/dvdrw
             logical name: /dev/sr0
             version: 1.00
             serial: [
             capabilities: removable audio cd-r cd-rw dvd dvd-r dvd-ram
CZDavy
#3 Příspěvek od CZDavy »
Děkuji, i když sem prolézal a nastavoval BIOS.. tak sem měl dojem, že je port nastaven dobře. Nebyl. Po přenastavení tiskárna funkční. Takže problém mezi podlahou a klávesnicí..
Jinak BIOS je v6.00PG, když jsme u těch teplot??..
Děkuji
CZDavy píše:Jinak BIOS je v6.00PG, když jsme u těch teplot??..
Děkuji
Teploty su OK, mobo bude podobne ako cpu ..
