Stav SSD disku [vyřešeno] Vyřešeno
hank
#1 Příspěvek od hank »
Přátelé, můžete prosím někdo vyhodnotit tento log? Děkuji předem za ochotu.
sudo smartctl -a /dev/sda
smartctl 6.2 2013-07-26 r3841 [x86_64-linux-3.19.3-031903-generic] (local build)
Copyright (C) 2002-13, Bruce Allen, Christian Franke, http://www.smartmontools.org
=== START OF INFORMATION SECTION ===
Device Model:     Samsung SSD 850 EVO 250GB
Serial Number:    S21PNXAG962890A
LU WWN Device Id: 5 002538 d4051c026
Firmware Version: EMT01B6Q
User Capacity:    250 059 350 016 bytes [250 GB]
Sector Size:      512 bytes logical/physical
Rotation Rate:    Solid State Device
Device is:        Not in smartctl database [for details use: -P showall]
ATA Version is:   ACS-2, ATA8-ACS T13/1699-D revision 4c
SATA Version is:  SATA 3.1, 6.0 Gb/s (current: 3.0 Gb/s)
Local Time is:    Fri Nov 25 12:15:18 2016 CET
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status:  (0x00)	Offline data collection activity
					was never started.
					Auto Offline Data Collection: Disabled.
Self-test execution status:      (   0)	The previous self-test routine completed
					without error or no self-test has ever
					been run.
Total time to complete Offline
data collection: 		(    0) seconds.
capabilities: 			 (0x53) SMART execute Offline immediate.
					Auto Offline data collection on/off support.
					Suspend Offline collection upon new
					command.
					No Offline surface scan supported.
					Self-test supported.
					No Conveyance Self-test supported.
					Selective Self-test supported.
SMART capabilities:            (0x0003)	Saves SMART data before entering
					power-saving mode.
					Supports SMART auto save timer.
Error logging capability:        (0x01)	Error logging supported.
					General Purpose Logging supported.
Short self-test routine
recommended polling time: 	 (   2) minutes.
Extended self-test routine
recommended polling time: 	 ( 133) minutes.
SCT capabilities: 	       (0x003d)	SCT Status supported.
					SCT Error Recovery Control supported.
					SCT Feature Control supported.
					SCT Data Table supported.
SMART Attributes Data Structure revision number: 1
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME          FLAG     VALUE WORST THRESH TYPE      UPDATED  WHEN_FAILED RAW_VALUE
  5 Reallocated_Sector_Ct   0x0033   100   100   010    Pre-fail  Always       -       0
  9 Power_On_Hours          0x0032   098   098   000    Old_age   Always       -       5542
 12 Power_Cycle_Count       0x0032   099   099   000    Old_age   Always       -       802
177 Wear_Leveling_Count     0x0013   099   099   000    Pre-fail  Always       -       14
179 Used_Rsvd_Blk_Cnt_Tot   0x0013   100   100   010    Pre-fail  Always       -       0
181 Program_Fail_Cnt_Total  0x0032   100   100   010    Old_age   Always       -       0
182 Erase_Fail_Count_Total  0x0032   100   100   010    Old_age   Always       -       0
183 Runtime_Bad_Block       0x0013   100   100   010    Pre-fail  Always       -       0
187 Reported_Uncorrect      0x0032   100   100   000    Old_age   Always       -       0
190 Airflow_Temperature_Cel 0x0032   068   056   000    Old_age   Always       -       32
195 Hardware_ECC_Recovered  0x001a   200   200   000    Old_age   Always       -       0
199 UDMA_CRC_Error_Count    0x003e   100   100   000    Old_age   Always       -       0
235 Unknown_Attribute       0x0012   099   099   000    Old_age   Always       -       45
241 Total_LBAs_Written      0x0032   099   099   000    Old_age   Always       -       7084496759
SMART Error Log Version: 1
No Errors Logged
SMART Self-test log structure revision number 1
No self-tests have been logged.  [To run self-tests, use: smartctl -t]
Warning! SMART Selective Self-Test Log Structure error: invalid SMART checksum.
SMART Selective self-test log data structure revision number 1
 SPAN  MIN_LBA  MAX_LBA  CURRENT_TEST_STATUS
    1        0        0  Not_testing
    2        0        0  Not_testing
    3        0        0  Not_testing
    4        0        0  Not_testing
    5        0        0  Not_testing
  255        0    65535  Read_scanning was never started
Selective self-test flags (0x0):
  After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
Re: Stav SSD disku
SMART tvrdi ze disk je OK
Disk nema sektory, ktore bolo nutne presunut do nahradnej oblasti.
Lebo sa ich nepodarilo zapisat.
without error or no self-test has ever been run.
Nebol spusteny zadny test, tak ho spusti.
hank
Re: Stav SSD disku
#3 Příspěvek od hank »
menom: No, to jsem zkusil.
Nejdřív jsem dal tohle:
sudo smartctl -t short /dev/sda
=== START OF OFFLINE IMMEDIATE AND SELF-TEST SECTION ===
Sending command: "Execute SMART Short self-test routine immediately in off-line mode".
Drive command "Execute SMART Short self-test routine immediately in off-line mode" successful.
Testing has begun.
Please wait 2 minutes for test to complete.
Test will complete after Fri Nov 25 12:24:23 2016
Když to ani po hodině nevyhodilo žádný výsledek, test jsem zastavil a zkusil jsem se podívat do logu:
sudo smartctl -l selftest /dev/sda
Warning! SMART Self-Test Log Structure error: invalid SMART checksum.
Num  Test_Description    Status                  Remaining  LifeTime(hours)  LBA_of_first_error
# 1  Short offline       Completed without error       00%      5543         -
Obávám se, že tomu dost dobře nerozumím. V grafickém uživatelském rozhraní se zobrazilo "Poslední autokontrola úspěšně dokončena", "Prahová hodnota není překročena" a "Disk je v pořádku". Nicméně u 4 hodnot je poznámka "Předzvěst selhání" (ty jsou vidět i ve výpisu ze smart logu v terminálu). Zatím jsem měl za to, že to znamená kritický stav disku. (Neměl by být, je starý rok a měsíc.)
Re: Stav SSD disku
Testing has begun.
Ono to tak funguje u short testu mas cakat 2 min a potom znova kuknut na:
Pre-fail
U teba je to prelozene ako "Předzvěst selhání" a u mna ako "Zlyhavajuci".
Takze by si tam mohol mat aj "Selhavajici" (mysleno v case), keby to tak niekto prelozil.
Tym je myslene ze Hodnoty u tych Jednotlivych Atributov postupne narastaju
tak ako napriklad clovek postupne ako starne tak ma horsie Zdravie.
Ale to sa deje priebezne - prubezne stale postupom casu, aj ked u kazdeho inou rychlostou.
SMART nedokaze urcit kedy disk zlyha (selze)
len sleduje narast hodnot u jednotlivych atributov a na zaklade toho moze upozornit ze sa blizi zlyhanie - selhani.
hank
Re: Stav SSD disku
#5 Příspěvek od hank »
menom: Netreba prekladať do češtiny, ja som z generácie, ktorá ešte vie po slovensky 8-) Okrem toho som vyrástol na Moravskom Slovácku :lol:
Proceduru jsem zopakoval podle tvého doporučení, ukazuje to pořád totéž. Mám tomu tedy rozumět tak, že bezprostřední nebezpečí havárie disku nehrozí?
Re: Stav SSD disku
#6 Příspěvek od menom »
hank píše:menom: Netreba prekladať do češtiny, ja som z generácie, ktorá ešte vie po slovensky 8-) Okrem toho som vyrástol na Moravskom Slovácku :lol:
Snazim sa pisat tak aby tomu porozumeli aj mladsie rocniky.
Neni su tam ziadne realokovane sektory, preto myslim ze disk je v poradku.
hank
Re: Stav SSD disku
#7 Příspěvek od hank »
Zatím děkuji.
Re: Stav SSD disku
#8 Příspěvek od skrob »
Taky jsem s tím nějakou dobu laboroval a došel jsem k závěru, že těm SMART hodnotám rozumějí možná ti co je vymysleli, a to si nejsem úplně jistý. V každém případě každý SSD co jsem testoval byl před selháním, nebo dle laického pohledu už po smrti:-)))
Výsledek: Pokud se mu věnuješ trimováním a neházíš tím o zem, v plné síle přežije HW, o tom jsem přesvědčen a kdyby ne, tak propočet s pětiletou zárukou dělá 1,- na den - má cenu to řešit, pokud zálohujete data?
