nvidia gefoorce GT 635M problem s prehrievanim
balli
#1 Příspěvek od balli »
zdravim,
mam problem s prehrievanim aj pri beznej cinnosti, ked zapnem grafiku od nvidie a nie vstavanu, bezne sa mi vypne cely notebook, kvoli vysokej teplote. ovladac na grafiku mam nainstalovany nvidia-375, ktory je odporucany.
_____________________
Asus K55VJ, Intel Core i5-3210M, NVIDIA GF108M [GeForce GT 635M],
Linux Mint 18.1 Serena, 4.4.0-62-generic x86_64 (64 bit), Cinnamon 3.2.7
balli
Re: nvidia gefoorce GT 635M problem s prehrievanim
#2 Příspěvek od balli »
nemoze byt problem v tom, ze prechodom na Linux Mint 18 a 18.1 som presiel na 64 bitovu verziu? dovtedy som pouzival 32bitove verzie Mintu.
Asus K55VJ, 4xIntel(R) Core(TM) i5-3210M CPU@2.50GHz, 8GB RAM, NVIDIA GF108M [GeForce GT 635M],
balli
#3 Příspěvek od balli »
System: Host: Kernel: 4.4.0-62-generic x86_64 (64 bit)
Desktop: Cinnamon 3.2.7 Distro: Linux Mint 18.1 Serena
Machine: System: ASUSTeK (portable) product: K55VJ v: 1.0
Mobo: ASUSTeK model: K55VJ v: 1.0
Bios: American Megatrends v: K55VJ.201 date: 09/11/2012
CPU: Dual core Intel Core i5-3210M (-HT-MCP-) cache: 3072 KB
clock speeds: max: 3100 MHz 1: 1210 MHz 2: 1308 MHz 3: 1256 MHz
4: 1386 MHz
Graphics: Card-1: Intel 3rd Gen Core processor Graphics Controller
Card-2: NVIDIA GF108M [GeForce GT 635M]
Display Server: X.Org 1.18.4 driver: nvidia
Resolution: 1366x768@59.99hz, 1920x1080@60.00hz
GLX Renderer: GeForce GT 635M/PCIe/SSE2
GLX Version: 4.5.0 NVIDIA 375.39
Audio: Card Intel 7 Series/C210 Series Family High Definition Audio Controller
driver: snd_hda_intel
Sound: Advanced Linux Sound Architecture v: k4.4.0-62-generic
Network: Card-1: Intel Centrino Wireless-N 2230 driver: iwlwifi
IF: wlp3s0 state: up
Card-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
driver: r8169
IF: enp4s0f2 state: down
Drives: HDD Total Size: 1004.2GB (62.6% used)
ID-1: /dev/sda model: WDC_WD10JPVT size: 1000.2GB
ID-2: USB /dev/sdb model: Cruzer_Switch size: 4.0GB
Partition: ID-1: / size: 909G used: 578G (67%) fs: ext4 dev: /dev/sda2
ID-2: swap-1 size: 8.47GB used: 0.00GB (0%) fs: swap dev: /dev/sda3
Sensors: System Temperatures: cpu: 67.0C mobo: N/A gpu: 66C
Fan Speeds (in rpm): cpu: 3200
Info: Processes: 233 Uptime: 55 min Memory: 4200.7/7869.3MB
Client: Shell (zsh) inxi: 2.2.35
Ked chces stabilny system, ktory budes pouzivat k spokojnosti, tak vyskusaj LM 17.3
Inak by mohlo pomoct doinstalovat TLP.
Kukni tu:
https://www.linux-mint-czech.cz/tlp-pok ... nux-mintu/
balli
#5 Příspěvek od balli »
cistil som ho cca pred 3mesiacmi, ale neprepastoval som ho, mozno to pomoze, ta teplota relativne nizska, to som mal pusteny len terminal, vacsinou uz pri browsovani mam 75C a viac..preto to riesim..:/ pri starne mi to vybehne pri nvidii cez 60C pri intregrovanej grafike som pod 50C..
#6 Příspěvek od menom »
Tak ako nevyhnutne podmienky ratam mat poslednu dostupnu veziu pre UEFI/BIOS.
Vymena pasty tak cca po 3 rokoch pod procesorom, ale na notebooku len s intel grafikou. som pod GPU nechal tu zuvacku,
a ide to stale vyborne.
Potom zohravaju svoju ulohu vsetky dalsie veci, OS co uz sme pisali, ze LM 18 ma mnoho problemov,
Ovladac grafickej karty - tu tiez treba vyskusat viacej moznosti ....
A o tom je Linux - ked hladas riesenie - tak vacsinou aj najdes - aby to fungovalo k spokojnosti.
Neda sa spoliehat na automatiku - treba hladat vlastnu cestu.
Linux neni Windows zadarmo - toto ked clovek pochopi, tak najde co hlada.
balli
#7 Příspěvek od balli »
redhawk píše:
balli píše:cistil som ho cca pred 3mesiacmi, ale neprepastoval som ho, mozno to pomoze, ta teplota relativne nizska, to som mal pusteny len terminal, vacsinou uz pri browsovani mam 75C a viac..preto to riesim..:/ pri starne mi to vybehne pri nvidii cez 60C pri intregrovanej grafike som pod 50C..
uf no a co mint 17.3 mate 64bit.
na ASUS x 200CA (intel 1007U ) mam 50 stupnov, prizatazi max 65-67 vypnuty ventilator be zataze, ltp a mx-4 pasta.
inak ma napadlo, nainstalovane su vsetky drivery z ovladacieho panela?
no pokial viem, tak by malo byt vsetky ovladace nainstalovane, na mint 17.3 som nemal ani ja take problemy, zjavne sa k nej budem musiet vratit, lebo cim dalej tym viac sa prehrieva..uz par tyzdnov fungujem na intelackej grafike kvoli tomu, dnes som to zacal riesit znova lebo som mal cas, ale katastrofa 2x samovypnutie a raz som ho musel vypnut ked vyskol nad 90C a zostal zapnuty..
balli
#8 Příspěvek od balli »
redhawk píše:
balli píše:
no ano asi to bude najlepsie.
ono dost tych zmien v 18 robi problemy.
pokial nebude mint na ubuntu 16.04.2 tak by som to nechal na fungujucom, ja mam vsade okrem testovacej masiny 17.3 prave z dovodov pravidenych problemov.
no zjavne hej, vssetko co som skusal postavene na ubuntu 16.04 tak to nebolo nic moc..
#9 Příspěvek od menom »
Tak mozes vyskusat linuxovy operacny system MX-16_64
V odkaze sa da najst vyhovujuca verzia:
https://mxlinux.org/download-links#Mirrors
